查看: 8355|回复: 0
[二次开发源码] NX二次开发源码分享:NXOpen C++获取当前加工模版和所有设置
发表于 2014-12-18 16:45:22 | 显示全部楼层 |阅读模式
NX二次开发源码分享:NXOpen C++获取当前模版和所有设置/ v" G8 d" y/ H) d* G4 |+ f
( H$ ~+ W. Y" L4 p) z
% X& d: s, S1 G4 T
void createCAMTool::do_it()
. M7 q9 _9 B# b! m( s{1 A; z/ ^9 S( N; \, s" a
% X. l( g9 u5 c0 v: h% C* k
! s7 D. c9 m. u' r5 E
        // TODO: add your code here4 E  c; J! ^1 w2 ?5 `) _! X
        std::vector<NXString> types = theSession->CAMSession()->GetTemplateTypes();2 h) O9 o& V, b1 p
        for(int i = 0 ; i < types.size();i++)! }! }: ^7 ^" B+ Y
        {4 x& S7 h1 D1 Y) v
                print("Types:"+ types+"\n");& B1 E7 L, r/ A, o$ {) h4 f
                std::vector<NXString> ObjectSubtypeGeometrysubtypes = theSession->CAMSession()->GetTemplateSubtypes(types,NXOpen::CAM::CAMSession::ObjectSubtypeGeometry);
4 U* y" P, R0 Y3 r* H                print("\t----ObjectSubtypeGeometry-------");7 G- V% k/ m7 T7 f  v3 {4 L
                for(int ii = 0 ; ii < ObjectSubtypeGeometrysubtypes.size();ii++)  `9 ^0 K( ^9 T+ w3 P
                {2 @5 P& [! v  x& r3 E
                        print(ObjectSubtypeGeometrysubtypes[ii]);
" j" @% |/ e, G1 {9 e, C, `+ X: R                }
& S5 s$ m* B& _+ c0 L! ~                std::vector<NXString> ObjectSubtypeMethodsubtypes = theSession->CAMSession()->GetTemplateSubtypes(types,NXOpen::CAM::CAMSession::ObjectSubtypeMethod);* e% ?) U2 ]5 H0 l' C" n
                print("\t----ObjectSubtypeMethod-------");
5 F4 |& U% y% }' T" C                for(int ii = 0 ; ii < ObjectSubtypeMethodsubtypes.size();ii++)
3 ?! r( b6 y  E$ ^( p                {$ T( Z2 W$ O: s" N: N
                        print(ObjectSubtypeMethodsubtypes[ii]);4 l0 q/ J* K$ g$ d, M% P, `
6 z- e% S% T1 L, u1 ?$ V                std::vector<NXString> ObjectSubtypeOperationsubtypes = theSession->CAMSession()->GetTemplateSubtypes(types,NXOpen::CAM::CAMSession::ObjectSubtypeOperation);
& e7 t) e, u, y: d; Z  C                print("\t----ObjectSubtypeOperation-------");
& ]! z: u8 h3 M8 q) j% n# F. n( T                for(int ii = 0 ; ii < ObjectSubtypeOperationsubtypes.size();ii++). j& k/ y# z  `$ V5 K2 s$ c
                {8 n1 u0 f! R5 c2 R; v. {$ c- Q
                        print(ObjectSubtypeOperationsubtypes[ii]);
& h% H' A% m+ A9 c9 l+ M/ z                }
) c6 R1 O- ]- }: L' o                std::vector<NXString> ObjectSubtypeProgramsubtypes = theSession->CAMSession()->GetTemplateSubtypes(types,NXOpen::CAM::CAMSession::ObjectSubtypeProgram);
8 f* U2 I2 @1 |, |- b; A                print("\t----ObjectSubtypeProgram-------");7 [8 j6 w) l7 D$ T4 {8 |( D
                for(int ii = 0 ; ii < ObjectSubtypeProgramsubtypes.size();ii++)
+ |# d0 f1 K% B% f                {
- ~/ Q4 g3 P2 i  f5 d+ b! r: Q, h! d                        print(ObjectSubtypeProgramsubtypes[ii]);" K+ p& q; f- [  v1 _8 ]7 F8 m7 C
( L5 d$ O! R" F6 L+ A8 a$ z                std::vector<NXString> ObjectSubtypeSetupsubtypes = theSession->CAMSession()->GetTemplateSubtypes(types,NXOpen::CAM::CAMSession::ObjectSubtypeSetup);
, z0 g/ v6 G1 N, ^7 z                print("\t----ObjectSubtypeSetup-------");
& p& Z% X) z/ X5 Q                for(int ii = 0 ; ii < ObjectSubtypeSetupsubtypes.size();ii++), w. s; P: ^+ s$ u! T! M
                {% q" B# t1 d3 j  j1 r5 x
                        print(ObjectSubtypeSetupsubtypes[ii]);
4 W0 m% r+ [7 @+ R! S0 V                }3 W( \, F1 f" {: }. b; P9 J
                std::vector<NXString> ObjectSubtypeToolsubtypes = theSession->CAMSession()->GetTemplateSubtypes(types,NXOpen::CAM::CAMSession::ObjectSubtypeTool);
2 |, K  u, j8 K( B                print("\t----ObjectSubtypeTool-------");3 f; ]4 n" U+ O" Q( W! {, C0 h
                for(int ii = 0 ; ii < ObjectSubtypeToolsubtypes.size();ii++)  Y/ s0 H$ {0 S& d
                {: ?- S. v1 V" Z; r0 w) D
                        print(ObjectSubtypeToolsubtypes[ii]);* o) Z: I0 {9 G' Z: ]+ C
! [0 H6 B! O& c6 t3 G  M* @% Z}( M: r0 N! r- q# b
. ^2 F% F: V# U) S8 o- v6 }8 C
1 R7 B" ^; H8 d
3 x6 C- {! \7 t结果如下:4 p' L! P: g6 F; Z* n
' o+ k* ]7 a! g9 _% g! I% X
* }/ g% s) T- }) j+ l; @' K
Types:mill_planar0 G9 K" j- P  L3 |: e8 q" Y# _7 G
# ]# N. ~! ]& n+ d# U: T3 R, {MCS* E' I3 Q( X3 e' e
WORKPIECE
1 z4 k. L, r  k* ?5 o  ^% H+ FMILL_AREA1 [% v- ~! B6 i7 w7 |
MILL_BND+ u3 H8 F; }1 b" T
MILL_TEXT
0 m2 Y* X! ]# J2 v+ Y' T' xHOLE_BOSS_GEOM+ a1 ]4 P9 M- G* m2 a
MILL_GEOM
! |6 E; I$ h  C' X; ?        ----ObjectSubtypeMethod-------
5 p$ g. u. G, W' t+ E' b+ GMILL_METHOD
* i) \: `; a* Q- r* ~, v        ----ObjectSubtypeOperation-------% j! [3 \+ c1 {% d  }* \. ?
FLOOR_WALL4 e1 E7 M% A) Z7 k0 P+ Q* R) }
FLOOR_WALL_IPW+ [6 J# i: c% ^8 o
FACE_MILLING
; y9 C& G( [9 ]3 `' eFACE_MILLING_MANUAL% j+ C: G7 }3 U# n. U
PLANAR_MILL
3 F( c+ E3 n9 [' p7 R5 L5 m! ~1 U3 DPLANAR_PROFILE
6 K0 I4 l5 w$ W2 s' \' V; B. @' bCLEANUP_CORNERS: o- @& N! Q$ u4 c7 ^
FINISH_WALLS
$ z; v8 l! L6 r0 u% G+ Z5 DFINISH_FLOOR8 W, W' r# Y9 F, G2 }
GROOVE_MILLING- [0 b! U( T" F
HOLE_MILLING
* m/ ^( \, M+ H2 Z2 _. J# n+ S# `THREAD_MILLING" t; D, A! H; d- c, J
PLANAR_TEXT
) a$ _) q* t5 d3 uMILL_CONTROL* B4 ^) N; W- Y: a$ k
MILL_USER
, a( |6 Z; `" j. P& F        ----ObjectSubtypeProgram-------
8 n  Y0 w7 x) W4 B4 b* ?PROGRAM
4 g# A" o9 o- l0 k# e; n2 ~8 [* M        ----ObjectSubtypeSetup-------
5 X+ l+ N% N8 J4 R        ----ObjectSubtypeTool-------  v+ @8 t3 x2 v! X) d/ u% ]0 ]: q
MILL1 O# k$ U/ y* N9 q4 g4 u
CHAMFER_MILL2 p' b6 J/ W1 M
BALL_MILL
- |- J8 s% d+ X+ \: v! t' f$ C2 }- `' \SPHERICAL_MILL. E' `3 \2 T  p7 o
T_CUTTER2 O* }  ?+ K, [( H
BARREL
3 K) |; E" H, O( C  ATHREAD_MILL0 Z3 u5 [9 N; }7 W
MILL_USER_DEFINED
; v$ o; H; _& F* y* ICARRIER
! `+ u8 v0 ?, r5 p) e, \/ @MCT_POCKET: i8 U" x2 |, Y! ]: d5 `% N. U! P/ n/ U
HEAD( M9 ^9 H6 g- T: f0 G' v: R
Types:mill_contour
  {5 R' E/ i0 Q& [2 ]        ----ObjectSubtypeGeometry-------9 E: u; C4 u. @7 \+ w
MCS. b8 t5 w3 r3 o6 q, R+ W; u- q
WORKPIECE
& B! P1 x. {$ O; F8 r& @MILL_AREA9 U6 F# q! `+ M/ c4 i0 X
MILL_BND' d0 z- M. p) w9 i
MILL_TEXT% B+ x" V8 ]# F: \; Y8 f7 Y# c/ }
MILL_GEOM
4 G3 x+ M4 G+ g' {( u        ----ObjectSubtypeMethod-------+ A2 T( F/ _0 H
MILL_METHOD3 |1 j  ?) u+ l
MOLD_ROUGH_HSM
. f# Q/ ~- L1 O0 t" l' AMOLD_SEMI_FINISH_HSM: p  X# ?$ f4 u" q( _) {6 c& U
MOLD_FINISH_HSM# Y& X# c  m, e2 t
! B7 @$ }& P0 Y+ H; s8 xCAVITY_MILL
6 `$ q7 H, v+ Z4 F" w3 NPLUNGE_MILLING& [4 c/ h4 R) t# G
CORNER_ROUGH2 k" J1 d. v* x
REST_MILLING$ P# J; n! s: @: K. a) t
ZLEVEL_PROFILE6 h% R2 H! U9 p* f  e" e( a
ZLEVEL_CORNER( G, q- \1 l8 \# Q; t1 \8 Z, w, n$ S
FIXED_CONTOUR
& L  u! F! V8 t" h" Z6 p3 ICONTOUR_AREA" F% V0 r! b. d: o4 q8 w4 m/ d
CONTOUR_SURFACE_AREA: D2 J1 h6 p0 O
STREAMLINE
0 i$ G# w, o/ w1 f4 `) g7 OCONTOUR_AREA_NON_STEEP- |/ N- _3 }: {' ^/ F3 M5 e8 j# x
CONTOUR_AREA_DIR_STEEP
2 p3 T% Q8 L6 C& O  c$ I1 ^  PFLOWCUT_SINGLE5 e" j& N9 T8 [4 ?
FLOWCUT_MULTIPLE
" g8 L2 [7 s% s2 rFLOWCUT_REF_TOOL6 G0 w7 q* V- e) o. }( Z1 R; y
SOLID_PROFILE_3D7 s1 D4 f, _' `. }  V
PROFILE_3D
$ i" `) W3 u2 V6 _) p7 R! M/ HCONTOUR_TEXT
! A8 B1 z! f. \+ h' CMILL_USER
4 U& |  F9 ^9 ^) pMILL_CONTROL5 V; Y4 I& S. @6 T- o# i# j! y7 G7 q
        ----ObjectSubtypeProgram-------6 H, w; y" g, y1 q, b
PROGRAM! g8 j2 R) ]: B) E3 x/ W5 R3 t8 ]
        ----ObjectSubtypeSetup-------* x  z" s; h8 h+ f/ ?7 Y* x
        ----ObjectSubtypeTool-------5 f6 g1 d. R. p- I
MILL, s3 H/ j6 B2 y5 B7 [# z( |
CHAMFER_MILL
$ h$ I3 M$ g. g0 TBALL_MILL# a% q# |! K5 X' I/ }8 a3 ?
SPHERICAL_MILL
% l% W8 s! o  u% pBARREL
3 c7 f+ k& L" t- }, sT_CUTTER) L" h  _) a$ w2 N
CARRIER
! p6 V" b% m5 p* P* c2 W8 oMCT_POCKET
; Z9 U: _' l- I* QHEAD9 I( v2 P9 F: r" G5 s
Types:mill_multi-axis8 h( o6 d' b/ W* v$ q% ^
        ----ObjectSubtypeGeometry-------* X6 N# C- x. Z% i9 W0 q
MCS8 ]! N; L, L4 }: x% m
WORKPIECE
. `' s" g  P' g. Z0 \" [- ~2 EMILL_AREA( l/ s& ~5 Q( t, U1 ?
MILL_BND5 [# K. E+ C" M6 ^1 J+ r+ L
MILL_GEOM
& P1 P% x; U, a* q+ `        ----ObjectSubtypeMethod-------
, R! W' [1 h' {. fMILL_METHOD8 I/ [9 k/ A- ^. H0 P4 o9 \( Y# c
5 C7 q8 I, F/ k  F+ H7 X# V: ^VARIABLE_CONTOUR
+ e8 k' w& \7 C7 U/ EVARIABLE_STREAMLINE
4 R7 I' p. M& D& m3 eCONTOUR_PROFILE( y- i  q( v( f1 H+ [
FIXED_CONTOUR* w8 r2 A+ w  W& E
ZLEVEL_5AXIS
! w; u: c; t% `0 j. f* w- p$ |SEQUENTIAL_MILL
) U# t% N2 @3 g+ q8 N6 PGENERIC_MOTION6 h' w; T, B# f9 M0 S) [
MILL_USER
3 o. Y8 }7 f& u' s6 c- ~1 l$ BMILL_CONTROL
9 v1 m4 u' R* j, o        ----ObjectSubtypeProgram-------* ~3 m. Z4 H5 k% z; j
PROGRAM
+ L) r, {7 N3 J# R# E' Q9 B* r        ----ObjectSubtypeSetup-------
9 J0 _! F% ~: |) O* T% ]        ----ObjectSubtypeTool-------2 J1 b" }, c! A$ q6 c0 u
MILL
0 W1 Z2 B+ j; a/ E  N& MCHAMFER_MILL
3 P- M: r( z0 nBALL_MILL
7 h/ ^. \8 T3 D' `/ K9 NSPHERICAL_MILL
" I, @6 k' |: z: W4 m' OMILL_7_PARAMETER, ~+ c: ^( O% `7 ?
MILL_10_PARAMETER
) ]5 }- ?. C" l5 {' ]1 @; \BARREL
$ z; f* a4 U$ f& ^T_CUTTER. J3 O2 S; |% M* \; T
CARRIER4 N& ]6 }  M) Y  F4 q# n; B/ F
MCT_POCKET
! O9 h8 _$ U+ o# |+ x" dHEAD' l( u5 b2 t$ d1 B8 d" Y2 i
Types:mill_multi_blade/ i. f' ]. `; M" v; u2 ]
        ----ObjectSubtypeGeometry-------3 T1 B: D, h' A, f1 f# ?8 ?
MCS
$ z; I$ K0 f$ E) AWORKPIECE
" c% }/ R3 B% y( BMULTI_BLADE_GEOM+ |: u1 m' v: S
        ----ObjectSubtypeMethod-------4 {1 @3 u6 a8 U$ `
MULTI_BLADE_FINISH0 t. R, a! |& U' P
MILL_METHOD
3 E) h4 M2 U* X        ----ObjectSubtypeOperation-------) J2 j) \. }2 ^% j  a, s1 u6 }
MULTI_BLADE_ROUGH
, A( [# S/ _8 \3 A8 r( Q: xHUB_FINISH
1 X  ]  i. _* FBLADE_FINISH
( u& F8 b0 ]: B  oBLEND_FINISH
. W2 ~5 X+ M+ M5 K4 OGENERIC_MOTION
3 P4 d6 K+ o% p" i7 U% I5 w/ uMILL_USER/ @/ F2 f7 ^( b# e) j" B( x" W
MILL_CONTROL6 l! ]+ b7 E3 q. a4 C; ]
        ----ObjectSubtypeProgram-------  G7 _# S6 |& Y- G* h7 N" \7 I
PROGRAM+ u" @% z' k- G
/ E: g# R; R$ S4 T) d        ----ObjectSubtypeTool-------4 J/ y6 X. n9 ^! i# Y$ W1 o
MILL- O9 A* E( |9 T+ |( |7 z2 l. h: B
CHAMFER_MILL6 @3 k3 a) M, q* {
BALL_MILL; g( {1 Q# ~/ H. y' R
SPHERICAL_MILL
- R+ M; K- k2 v) L5 a4 _/ w3 FMILL_7_PARAMETER3 ~+ w* \) Q1 @# C6 u
MILL_10_PARAMETER
. j# n- W) ]6 `3 s9 OBARREL
: ~4 [( r7 A! {. p+ a7 PT_CUTTER8 m% b: r- _( Z3 U
CARRIER8 U: a5 P' t' k3 o% i
MCT_POCKET
) {) k- H5 g, ^  L( G+ P0 B& d# X, THEAD
  W/ O% \8 a6 u7 h8 x$ b8 X! ZTypes:mill_rotary  z, F( M. `/ E5 C! n5 e2 p
        ----ObjectSubtypeGeometry-------% n1 G0 o5 c+ D7 e, d( n: N" Z
MCS
& G  p* l7 V* Q9 u# S1 A, S2 xWORKPIECE5 F; Z1 J6 K3 p( H% B  o
ROTARY_GEOM( C* O) s. M% J4 ^3 o- R) F
  d  p0 [- z. C4 s8 X6 m6 \' W6 lMILL_METHOD
) v* ?3 d# i$ d, _. Y        ----ObjectSubtypeOperation-------
" R; ~  M, h; d3 uROTARY_FLOOR# G# p* V9 C5 Z0 @4 L! c) C
GENERIC_MOTION
) i  L' W5 X9 U& [' gMILL_USER
; V" ]% ^( v' h5 t9 Z8 |MILL_CONTROL7 S, p) z8 m0 Z/ n- z
% Z# W- a5 y2 W+ m7 FPROGRAM
# n$ v& w3 c. a        ----ObjectSubtypeSetup-------
: n" Z% H4 S$ d- ?7 _        ----ObjectSubtypeTool-------; w6 E: ]: j; d- U& M5 f# j% A0 x
BALL_MILL3 j4 D& c+ O- d$ p4 r# r
SPHERICAL_MILL+ ]: M! d  w9 z
CARRIER
; y5 Z) N) _. JMCT_POCKET( A8 O2 ^5 ]# h( R9 W
Types:hole_making8 n! u6 t. O8 R* w
        ----ObjectSubtypeGeometry-------- u9 w6 T  [" e; T' _; y
MCS
; `$ J8 v/ {& Z; cWORKPIECE
" X+ O% D  r  U# N( s/ EMILL_AREA
- m7 b" N* `3 C! ^% x* {0 |FBM_GEOM) e% Z7 O3 D0 k0 a9 ]/ G5 q  q
SIMPLE_HOLE
, y8 \) |/ K& ^+ Y' c$ [CB_HOLE4 d% P# ^1 c" p9 @
CS_HOLE
, S+ n. s/ z# Y8 ITHD_SIMPLE_HOLE9 Y( B0 Q) c& A/ U8 B
THD_CB_HOLE4 Y! [" v( O% V# `6 y; K  `
THD_CS_HOLE
( _! j- X( g4 [8 O; T/ h- rSYMBOLIC_THREAD5 m0 g" u- A' v
CAP_SCREW_CB
$ \) T* Q* S" [" [" K  |8 zCAP_SCREW_CS
! d6 W/ q6 c& w: R* DFIT_HOLE: j6 B/ @1 {4 I1 x
STANDARD_THREAD
1 r. Q; i7 Y. O$ z/ `& m% L$ L2 ?. DALL_FEATURES
. d9 t: P) j0 {2 w  u# MHOLE_BOSS_GEOM
* ?. z( V  Q, V+ D. K        ----ObjectSubtypeMethod-------) D: V( B6 [% r- Z% U- h
DRILL_METHOD% b! ~8 ?% P: i! ^
HOLE_MILL_METHOD% s) V7 c* e- b$ v* \" A0 V
) Y, t7 j% r% t4 y7 Q6 ~# n2 o$ qSPOT_DRILLING5 F* G/ K7 S  h7 C( M! O. K
DRILLING, A: H* V) M. o9 n$ B; q2 }
COUNTERSINKING
3 R0 r6 d4 M" x, u* jTAPPING: x+ r3 S) @. j9 F8 z1 M# N
HOLE_MILLING
2 M% U/ l# S' t; v6 l; A" ]HOLE_CHAMFER_MILLING
/ _* W- G) T: A4 @BOSS_MILLING1 U4 u4 w8 q6 }8 \/ b! }- N
THREAD_MILLING1 l& k: `1 @# E. Q
BOSS_THREAD_MILLING( Z1 h; ^  v5 i) f) D
MILL_CONTROL* M) S1 H5 I9 W, {) j; a
HOLE_MAKING) X) ?3 ?1 W; l6 t
HOLE_MILL; [& @6 s& a+ z& X& L/ L( [4 C2 Q
0 P9 z* L( [0 u8 F/ V( [( EPROGRAM
: I2 D4 H8 [* s; v7 }# b  nOPTIMIZED_NC
# {. b* t, k% g( b+ A; l        ----ObjectSubtypeSetup-------
, _+ t) k8 v) G! G* o* R9 c        ----ObjectSubtypeTool-------
/ H' J# I7 {* M* {+ N+ T6 s/ kSTD_DRILL
( R1 C/ C3 I: q/ jCENTERDRILL
9 a4 w- y! M- u: R1 N* fCOUNTER_SINK& z! Y# q* i# C
SPOT_DRILL4 S$ L* S; a# y# `4 x/ c  o
BORE8 ?* X" M0 v$ Y& K
REAMER
  g" |, p7 h+ i( b; K4 ]- MSTEP_DRILL
$ `: l/ ?( M5 {/ }; rCORE_DRILL
, S4 Y, `- C+ d4 S% mCOUNTER_BORE& C& g7 |' m6 ~6 E7 I
TAP8 ]/ x0 e. a2 O) Y7 C1 d" D9 p
THREAD_MILL' ?! a  i- L; c
SPOT_FACING
1 `! j% S3 l! u' S8 i6 b, OCHAMFER_MILL
5 z6 g. S3 U' U/ L9 k- P/ a' uMILL' K  C7 d: I. L, s: S
CARRIER( B: b, H. F; k+ n' w$ i( }
MCT_POCKET
5 A. C$ O: E" t. l8 wHEAD% u4 b* b7 V. G8 g1 W! a
Types:drill
( K3 t9 |8 |" g5 K) D- Q* y        ----ObjectSubtypeGeometry-------. ]/ h; i* x: `' K
MCS
0 c; D4 h' \' o, L$ BWORKPIECE$ K5 u- ]* G$ b
DRILL_GEOM% ?4 Q+ S6 z& G
HOLE_BOSS_GEOM, K0 Q; N! J& u) ?: _
3 W2 b' _- C: o& GDRILL_METHOD- }9 D7 g6 Y% X: s
        ----ObjectSubtypeOperation-------# m& M) O! x, Q! _& c+ X
SPOT_FACING
- x# \* }/ I& S3 iSPOT_DRILLING3 t+ D7 W! W( X  H2 u- S
DRILLING& _8 Q* w& H; L, C& J4 [% O
PECK_DRILLING( T9 k$ V: q+ q  r4 x1 U
BREAKCHIP_DRILLING" h4 M) ^7 \. W/ p( X" n
BORING( o3 V7 \( P% c& d
REAMING
, O* x% _9 I8 j2 Y4 `COUNTERBORING
$ F% v  m3 ^; g+ JCOUNTERSINKING4 f1 s) j. B3 i. {4 x
TAPPING
7 l" R% i$ J3 H7 X9 E2 p8 I+ c; pHOLE_MILLING% @% i8 j: q& N
THREAD_MILLING
" J( s$ ?4 _( H* `: p: q2 GMILL_CONTROL
$ e& _. y/ @# ~- H" IMILL_USER
0 e  \0 _  }4 e( H  E6 {: H. m9 o# n        ----ObjectSubtypeProgram-------7 M( ]' v6 c% B1 ], D
PROGRAM& G7 \" q6 d) }( ^& r3 m6 f; k
8 B* d8 P! F  I; W; z        ----ObjectSubtypeTool-------
4 g( D0 O( B- |6 p- X7 S# ySPOTFACING_TOOL
) }/ d6 c4 X0 w+ n7 y; a7 j) r8 wSPOTDRILLING_TOOL7 y3 x, L' A% A- D9 A
DRILLING_TOOL
- V2 N* Q' |+ b$ j: xBORING_BAR6 K! U7 ]: R3 S/ e
REAMER
8 z2 q' \8 }' }! L  Y% N( ^  g+ _COUNTERBORING_TOOL
9 h+ |! K4 O+ O- q& V# hCOUNTERSINKING_TOOL1 ]  N6 u' }; K
TAP5 ?" ~+ H. C, X: d
THREAD_MILL
1 m( N) h3 T& r' mCARRIER9 V: Y) V- D# z! {! K& g
MCT_POCKET
; I8 [& b8 {# ?4 ]' aHEAD; Q8 B6 v) r% ^0 {- r$ b$ R
Types:turning
, h: Z+ n/ `0 P8 C- z2 k" @: B% z  l        ----ObjectSubtypeGeometry-------
! A; `" x" G$ k9 I: F8 k( h+ X- E8 ?+ HMCS_SPINDLE
$ ^) h0 X& C) T& g& v# K8 SWORKPIECE  @: F0 W" u1 T' L, Q
TURNING_WORKPIECE4 V" t0 G: q/ K
TURNING_PART/ m: h; L' ^! g" _3 }0 B
CONTAINMENT
# e$ G* M' y8 r" `7 G1 p5 @AVOIDANCE2 A: [6 `* ]& M5 R
        ----ObjectSubtypeMethod-------5 w) C! q# i# G. U2 t
LATHE_METHOD7 t( N  J" h2 y* ?! [0 g8 a
' X. c, D6 F* H) H9 ~" bCENTERLINE_SPOTDRILL& {' |! E9 E* a' `
CENTERLINE_DRILLING
* ~& u4 O! k! O' lCENTERLINE_PECKDRILL
+ X! G" r5 w. `2 V' F) S$ G; r( `CENTERLINE_BREAKCHIP$ [; i& g3 ^  i
CENTERLINE_REAMING
) `+ M$ G) y% d* A- L4 ECENTERLINE_TAPPING8 Z  M/ g: C: W" ~% o' a
FACING
: ]7 j7 l" E! A  PROUGH_TURN_OD
' I6 R) x# x# m& ZROUGH_BACK_TURN
5 o  p) J- }/ X! C, SROUGH_BORE_ID
% ?$ v6 ^  |& {4 p9 |5 LROUGH_BACK_BORE% V+ `9 b3 ]) e, }& Q! C. a
FINISH_TURN_OD
+ Z" [, E& n% Z6 tFINISH_BORE_ID) n' r2 y4 [6 {- I+ w
FINISH_BACK_BORE
/ }0 J, h+ l+ _- bTEACH_MODE, B( ^7 v8 U) P7 A" }7 [
GROOVE_OD
& {# n7 `: ]1 W. l* L0 aGROOVE_ID
" I3 C  K) c' m# `" o+ G6 F1 zGROOVE_FACE
- V, x( d; A) p0 N- W# a5 `THREAD_OD
$ _' F7 R4 O& j; M3 t- p- Q% k: OTHREAD_ID9 j, }$ w! B! _" h# w
PARTOFF4 v( J* e+ ~5 _* D- b; I+ ?7 l7 U
LATHE_CONTROL
# R( o' i( _$ k6 A; `1 e2 V$ K( X% gLATHE_USER5 @! Q  U7 }" r9 t: s- w
. ^7 Z1 [! w4 {, y) {# IPROGRAM
9 t0 r* Y8 C( O- W' x        ----ObjectSubtypeSetup-------
7 F$ B( e! b& U$ |9 d% O4 z2 C        ----ObjectSubtypeTool-------! c; ^, p3 V: W9 d8 \2 a7 z+ }
SPOTDRILLING_TOOL& k; J0 Q( z7 i1 |, m
DRILLING_TOOL
. B+ T' X; X- mOD_80_L& M5 [, b1 B9 W
OD_80_R
" n* ^6 w, A* \9 {' B# z: ^OD_55_L/ v1 D2 d/ C, A' M! B
OD_55_R7 j+ w# f/ B& s5 ~$ {0 S% x4 G- c0 i
ID_80_L$ U1 M" f3 `/ j* x, a7 w2 h
ID_55_L
* j. I4 X! x  G( v# GBACKBORE_55_L
$ W! u# _$ W, H1 {0 C+ c& x& NOD_GROOVE_L. U! v- Y# Y; N; W
FACE_GROOVE_L9 e+ N/ m3 |9 q) g
ID_GROOVE_L# o! R6 E; n: l( v) q
OD_THREAD_L
4 Q, x1 i/ n+ l; D; D; x8 T- ]0 yID_THREAD_L
. _' G* k5 x5 s! p$ \9 Y; r, DFORM_TOOL
& o& i  A9 r* y3 }2 f8 C: ~CARRIER
6 {% ?, M9 g# ~$ E9 {' g0 HMCT_POCKET9 W+ \6 L% m, |" h- F# g) ~
Types:wire_edm
4 c3 x( N" x/ K1 S7 {( N! Q        ----ObjectSubtypeGeometry-------
. Y; I2 |" B+ Q; Q7 K; r0 AMCS_WEDM0 O$ u* h" Y" t0 k0 I! W
WORKPIECE
& X1 a0 \* }. `; b( I- ZSEQUENCE_INTERNAL_TRIM  f7 j3 S2 u) A: f/ \
SEQUENCE_EXTERNAL_TRIM5 s" f$ O+ a4 T, W9 Z  }" d4 h
WEDM_GEOM3 P1 ~% M) P* m2 |7 E" _/ V
        ----ObjectSubtypeMethod-------6 J: [5 c" y" M- o- R. l4 ]
WEDM_METHOD
/ t. u% I" l% e# m* t: ?) O        ----ObjectSubtypeOperation-------' q: C0 x4 b) n5 }
NOCORE; i; R3 w6 M) U- u
EXTERNAL_TRIM' ^. x( D# i4 F( ]' N/ p
INTERNAL_TRIM
& f( b8 h  z; F3 @9 p6 _5 P( mOPEN_PROFILE/ W: I& v& |1 M9 K! g8 M0 q) A
WEDM_CONTROL3 ~/ a" ?) Y- a  c( z
WEDM_USER, m2 {7 t3 J, S' P5 b
6 J  F2 t8 Z# e/ K2 u; E$ wPROGRAM
- X) }: ~) d7 U: _8 Y! k        ----ObjectSubtypeSetup-------5 n( e0 n" T# V, R
        ----ObjectSubtypeTool-------" V7 k7 A- `/ }) y( B
WIRE( X/ `6 t4 s, m4 p! l$ ~6 K, C
Types:probing
- f' h0 @- [" a* g8 B2 c2 M4 y        ----ObjectSubtypeGeometry-------' d1 v- e8 H7 w& p9 g2 v
MCS_MILL
6 }0 B/ f, k0 wWORKPIECE
: y+ a; S; l% Z$ t6 V2 m3 _        ----ObjectSubtypeMethod-------6 ?* s) [8 y2 V  _
MILL_METHOD, m0 Y! }3 N* p/ D6 R
LATHE_METHOD
: M: D3 K- \: x- Z        ----ObjectSubtypeOperation-------
6 g/ d! d0 S8 v" }MILL_PART_PROBING
0 Y9 f- T3 t; w; m9 HTURN_PART_PROBING9 Q4 `4 ]" u7 ]+ W; h: t% n
MILL_TOOL_PROBING: B: A% t! ]. O) f
TURN_TOOL_PROBING
) T# B  `5 A: ]/ \GENERIC_MOTION
: n& q- Y& j! @# V( t% {$ ~        ----ObjectSubtypeProgram-------
1 j* h: D6 a% g3 \! @$ ?5 J1 rPROGRAM
. e) _5 C" V7 L1 F        ----ObjectSubtypeSetup-------
+ }: J% [9 T6 Y# g8 O5 e8 [        ----ObjectSubtypeTool-------
6 }, U% F4 ?0 Q* C. h) @PROBE7 {+ f3 ~8 t  [* u% v
GENERIC
$ S7 ]7 s# K7 T; G% LTypes:solid_tool
% V9 b% g& W4 Y+ ]# y, p4 r        ----ObjectSubtypeGeometry-------
7 y# k' }. J3 v0 _        ----ObjectSubtypeMethod-------
/ G. u  m& G1 }3 a9 m4 P; u        ----ObjectSubtypeOperation-------: S4 N% j& b( U0 F# a
+ k9 e- \1 {+ x7 X) v# u2 e+ x        ----ObjectSubtypeSetup-------- ~4 s& [% x2 [1 n. F
1 a% B, l* K. g  G  uGENERIC
; S0 ~- p. Y( l/ i4 X- X8 QPROBE3 A& i$ J( O/ c
Types:machining_knowledge4 }5 Z$ T# {0 [# z4 p- ]. g
        ----ObjectSubtypeGeometry-------8 F* d1 V4 E' Q+ Q0 ?, Z. n( H2 E
MCS
4 d$ L5 E4 Q# }4 O! ~: aWORKPIECE
  b# Z, G5 c7 i! c8 pMILL_AREA
; H  f  z$ v$ ?2 @/ A' ^; U4 dPROCESS_FEATURES; P1 I& h3 b& _$ q$ U" H- \4 m2 V% j
3 L2 _/ O' V% s) W# s4 {. g. RPRE_DRILL_METHOD) r7 z7 W+ N' D' {2 P
DEBURRING_METHOD" w( b6 X- [  [0 j3 }: h
CSINK_THD_METHOD
, Q7 q6 g$ j+ {+ Y, f8 H2 m: ]TAP_METHOD+ Z. f  _, D7 U8 K1 b8 H
STEP_DRILL_METHOD3 @" w5 u2 Q  ^; S! g' |5 U
THREAD_MILL_METHOD' V& q3 Q' ~9 _. c
MILL_CB_METHOD
& U5 Y- l2 g/ _# A& z. bBREAKCHIP_DRILL_METHOD
9 \/ Z- B; q. x& jBORE_METHOD' n2 @# e; l# m
CENTER_DRILL_METHOD
2 ]7 u2 a2 F0 ~+ Z; e5 C8 K- QCORE_DRILL_METHOD2 u* W5 y0 U# i* H- ^( w
CBORE_METHOD' c7 x6 e% h% ~) c5 p
CSINK_METHOD
& ?8 D* T0 f7 n& r# k5 jDRILL_METHOD- u1 h* \% R6 ]) w8 n+ c
PECK_DRILL_METHOD, s8 w& c& R& ^2 d
REAMING_METHOD
/ M( I' y  r- ?1 |SPOT_DRILL_METHOD
& V# s, `3 Z4 Z; _. P; E/ ]TAPPING_METHOD
) u& O( J; Y# J: [5 h7 ~HOLE_MILL_METHOD
$ }5 j3 [) }7 k6 t0 Z# R7 zMILL_METHOD_ROUGH
& }# d, B: ?9 r! s  n        ----ObjectSubtypeOperation-------- L8 ^% f6 U! V$ [
HOLE_MAKING
$ P  J2 r# a$ }) M' yHOLE_MAKING_DRILL_TEXT
* q- [3 [* r5 w/ THOLE_MAKING_DRILL_DEEP6 C2 q5 A% e$ j$ R
HOLE_MAKING_DRILL_BORE_DRAG
- \+ W! t; V. ^7 l/ l) e; e* tHOLE_MAKING_DRILL_BORE_NODRAG
& R* L/ C) |! }! X8 G' |$ [& IHOLE_MAKING_DRILL_BORE_BACK- c1 L2 m6 ^+ b. ]8 k, r
HOLE_MAKING_DRILL_BORE_MANUAL
% T. g7 Q' @8 ^3 z  {0 V6 S* tSPOT_DRILLING
6 |/ y5 b3 F/ O/ o' f6 ^6 IDRILLING  v9 |  C0 {' J" X5 @$ n3 W' u
PECK_DRILLING
; u& g  k8 L# _BREAKCHIP_DRILLING4 L2 b+ ^$ A, ^' _
COUNTERBORING
: _4 j" \4 j% P/ y2 ]6 VCOUNTERSINKING7 p. `! e/ E$ x' o$ H) H
REAMING/ ~/ }2 K5 f5 k6 q( Y, p2 H, R2 t
BORING& `* G/ M6 k2 A+ n' J2 q6 {
HOLE_MILL
; }* H; d$ E5 \1 W, NFLOOR_WALL
" E* J/ |, I) U1 bFACE_MILLING
4 ]6 w0 c! P+ a$ C- k' hCAVITY_MILL0 e! S6 h0 A# {) x) |& r
TAPPING
( g# k3 m0 c0 M) q7 C& r        ----ObjectSubtypeProgram-------
; M0 e" g! p: `# g# g( ]! T. yPROGRAM
$ r; R+ e9 i( Z( q4 w/ F  Q; e        ----ObjectSubtypeSetup-------5 x; i" k3 s1 r" e8 N% _$ E# n$ i
        ----ObjectSubtypeTool-------" R/ K1 q! ?6 T  J. I
CARRIER
' G# }7 w8 O: l; KMCT_POCKET! e8 m) O; I' b' d' z9 P
HEAD2 |3 b1 }# ~2 y% G& F/ i$ J
6 r: y, m7 R/ Y# D6 o3 }& Q: E$ n; T$ z! f" v5 D3 k6 J
4 j" R  p( {; n$ V
