[资料] Teancenter和catia 集成使用Active workspace 的功能
2018-2-11 20:16:57 3228 0
发表于 2018-2-11 20:16:57 | 显示全部楼层 |阅读模式
' U) {2 N# C1 ]( {
* d# e4 ^5 e; c7 L$ @9 @& O9 Z" W& J( a
The Integration combines the capabilities of Active Workspace and CATIA V5 products to enable users to place CATIA components (products and parts) under Embedded Active Workspace control. Use the Integration to:
6 X- b* g) ?- R9 g0 w! f! e) e• Load an assembly selected in the Active Workspace in CATIA V5( m! F$ T( D/ Y  _% n& R2 a+ S8 J
• Load a document selected in CATIA into Active Workspace0 m5 f3 C/ ]# K7 n8 E, {1 b
• Highlight an instance selected in CATIA in Active Workspace7 K8 Q$ K$ W* ^1 Q+ w. B
• Copy an instance in Active Workspace and paste it into an assembly in CATIA: _: b  M, X6 n+ i0 ^  w- {% t9 n
• Copy an instance in CATIA and paste it into an assembly in Active Workspace
9 m2 }8 g- V% S3 M' m• Check In/Check out an item revision. K) \) i8 F6 E' H9 E
• Create CATPart/CATProduct datasets
8 M8 N1 }, r2 ]# M+ ?$ Y% H• Cross Refresh.7 L0 w4 {* c. F5 C* N
Under Standalone Active Workspace, use the Integration to:
/ {+ i) ?! a0 U" J• Load an assembly selected in the Active Workspace in CATIA V5. H  m- R+ x- M4 W* {$ o* }
• Load a document selected in CATIA into Active Workspace.
2 }4 w1 N" B1 K  w2 j
" S& i9 \. a! _# p5 Y3 o/ T. i. U$ H
