[二次开发源码] NX二次开发源码分享:删除树控件中选中的Node节点行
2018-3-25 16:59:27 2222 0
发表于 2018-3-25 16:59:27 | 显示全部楼层 |阅读模式
7 w8 I$ N3 J# t0 A! T# i! ], l
, c+ W5 I! R7 L* n3 Q) p6 ZNX二次开发源码分享:删除树控件中选中的Node节点行
' G  W; E/ n2 g+ q8 ?% J& @( X
7 J9 V& c2 k) a5 ?7 O非常有用,分享出来,直接可以用哦!!!; Q2 j- x+ k6 ?2 @+ X4 e2 [4 m; Z( [
6 D4 B/ F5 X+ n4 t回复可见!!
1 j# ?7 T4 _: Y" m0 k0 N9 `' N) X% w& H: |
[mw_shl_code=cpp,true]void  createSectionGridTool::deleteValueToTreeList(Tree *tree)
" q! g  _4 b; l4 ?{
; u: W% v7 G& ^3 e4 o5 K% S        std::vector<BlockStyler::Node *>selectedNodes=tree->GetSelectedNodes();
/ o7 T1 r! `7 B2 Q, b        if(selectedNodes.size()>0)0 A# @7 x, v0 s  z# ?8 h) I
  e% q! u, X4 a                while(selectedNodes.size()>0)# B  g$ u" u7 u6 O1 w! r! N
                {# F" `' Q7 I5 U! _% _% F6 `
                        tree->DeleteNode(selectedNodes[0]);
2 |. E6 M  G9 Q                        selectedNodes=tree->GetSelectedNodes();
5 Q4 a, @+ m$ ~. }1 l                }- t  w& ?0 p$ Z+ v! k8 D
        }" z4 \' A# J# i$ E$ y( u, C
        else
2 h0 R+ D/ E3 L5 N        {1 H# U* P- H8 d  W% N% P6 o
                theUI->NXMessageBox()->Show("Delete Node", NXOpen::NXMessageBox:ialogTypeInformation, "No Nodes are selected");) f6 k  e2 z" A. h& B
        } % g) j. P4 R  m( n
& [3 T2 [7 a; x[/mw_shl_code]/ V3 e: ?% p5 x6 d7 v* w  H
