细节太多,有些人安装后 run time prompt 是灰色的,编译报错等等,高版本需要依赖低版本,真的很坑爹哦!
2 I6 F+ g7 i' C/ t6 G- S/ H
g* z# G2 f% {" b5 m
+ N: ?4 n' |1 U: `9 }# O' I a$ ~You not only need both VS2008 (VC++ 2009) and VS2012 (VC++ 2011) you need both RADE R24 and R26.
# e+ O, i, q: a$ c1 U0 L, @ G1 x
9 T+ F O6 D# `1 ZThe reason for two compilers is because some things (Any custom automation interfaces) require the VC++ 2009 compiler. In use you only use VS2012. It will call the other compiler automatically for things when it needs to. & P7 H- N) ~" d- q9 a9 w; N
1 \# V& K3 d2 c; f1 U% _( V
Below are my install notes for installing CAA for R25. Hopefully just substitue R26 for R25 and you should be good.
* r1 p8 s8 w* B+ V5 Q+ M6 A) g4 r; n0 r) |% U6 a$ y
- O9 c6 s9 [# q/ V
) B1 b" q6 \3 \- A" ]$ r+ ]1. Install VS 2008
; b' S! b- g7 }2 Z( }' }- g2 e- I" t6 p2 c- @" G# y0 X
--> Make sure to select the 64 bit compiler tools which are not selected by default3 w9 e& t* b: U
# Y5 v( D. _4 @! r1 W+ l
--> No need for Crystal Reports crapware.
& F' G. b% U8 I
0 h0 ?6 L5 M* m" r& h2 R. i2. Install VS2008 SP1' x/ c6 e/ K- C9 R
. U. Q; q: l) _- V9 X3. Install R25 CAA* v7 J4 c; J) x( Q
1 W* s* ~9 B6 n% N+ j4. Install R25 CAA SP4 # q( z' O o- K. D4 x
: ^- t3 M/ j$ e5 ~9 N, k
5. Install R24 RADE% C! L: z- v3 g9 r
, |: J1 I3 I1 ~
--> Use a path without any spaces; for example C:\ProgramFiles\DS\B24RADE7 f6 O* q6 c# H. j# x; w$ g! J6 \$ h
( H# v" [; {! b. S6 `7 s" G# |0 z6. navigate to the folder C:\ProgramFiles\DS\B24RADE\intel_a\code\bin and run the program CATVBTSetup.exe
# Y: C7 ?% z& x0 U$ F6 D
7 n2 E& e* G+ ?; f--> Select Visual Studio 2008 as the target application
2 f) x. R; F, ^% T9 T Y& u6 n3 B. i- E0 E
--> Check all the boxes2 U0 z* P9 p7 J+ k: m4 @8 t$ o$ _
7 ~' f+ V# C/ ?5 a: s
--> Click Install
+ \8 v, d' \! b4 ?. Y4 m* `3 c& ~; O, j6 M2 L) J1 }; Q
--> Click Close7 q7 |3 `6 @ p- U2 m9 ]
" e( R; R# S9 {; ~0 Y0 B
7. Install VS 2012
4 b2 M$ _& Z7 S9 m a \- Z v; F, Z* S% a. u& y, x" p4 V& t
8. Install VS 2012 SP4
6 h% d9 L. M: W7 s" n: ]. y, a T5 a! o4 p! }% Z5 |
9. Install R25 RADE
* q! {9 [! B' R$ J$ J* P/ x
- Z6 s4 g4 [/ M7 j--> Use a path without any spaces; for example C:\ProgramFiles\DS\B25RADE ! K' j8 j. T+ _3 A) Q
$ g, C% q! r3 ~, K9 N--> For the environment, the sUGgested default path is OK but creat the directory first. It does not seem to be built automatically. ' X, q' u* E$ x0 [
2 u: B7 J8 s1 @# f5 X
10. Run the program C:\ProgramFiles\DS\B25RADE\intel_a\code\bin\3DSOpenNativeAppExt2012.vsix
5 h6 Y0 V3 ]7 K% C' e5 Z+ G5 _! ?4 |- N& M* u/ q
--> Install the application
' j/ }* j( n5 `1 Q0 a" o8 r2 d4 Z* C" V0 i5 z7 l
11. Run the program C:\ProgramFiles\DS\B25RADE\intel_a\code\bin\CATVBTSetup.exe
: `; k! c9 F; O; `
) O7 Y7 u" `8 C- B. s" ]$ _--> Click the check box for IBM/Rational tools
4 h0 z4 ~: q3 c0 q% B) z8 x1 b% ^8 c0 h* Q' X3 [# j, P- X
--> Select all the options# W7 w3 w. X- E7 a) ^
0 c( B7 [ I$ w$ o) ^--> Go* e( ]. q$ g+ r3 F3 ?5 b7 x
" P+ x4 `$ [6 l* b' S12. Start Visual Studio 2012' t9 N9 T5 U8 ]# K( p+ }- C: z6 g
! \( Y t; [) X0 B$ E4 H
--> The options panel should be displayed- f; H6 R. _6 H' G3 X, d. b; s
5 q) d7 C0 w! [7 ~* |--> Enter the path to TCk_init.bat which should be C:\ProgramFiles\DS\B25RADE\intel_a\code\command\tck_init.bat
; {. I& Q! d& P- ~3 J# T" f' e7 S) m) T8 Z \/ G: e
13. Restart Visual Studio 2012, Z% A2 w8 Z0 J% c- l, x
' e9 B' l: r0 |4 q--> The tools should now be available. ' L9 v& ]4 f$ l( ?8 `# Y/ @8 x$ h
