[新功能] NX 10.0.1mp2及mp1 修复的问题列表,大家可以参考下
2015-5-5 20:36:32 6539 0
发表于 2015-5-5 20:36:32 | 显示全部楼层 |阅读模式
NX 10.0.1mp2 修复的问题列表,大家可以参考下
6 i, _" N& @8 _2 c3 G" N2 a" l# m如果你有遇到这种问题,可以尝试升级你的NX版本!
, s5 v  A( M. a& ^8 ~/ E
) I4 |' J. y* b  r8 a9 [! r  Q0 i  U2 u
3 G5 l0 _7 ?* O- k9 s
MP1
% I# D1 Z1 W5 ^5 \2 ]9 s* @% `1965779- c  d/ {' E. m% y. }. P0 U
NX crashes when the user swiTChes between Family Template and an assembly.2 ^5 r$ v5 Y3 f) P5 K' i
MP1
0 a: S4 `- K( t" K: D6975351. j: _5 V/ l' a, J
Need 4GD Capability to Limit Realization by Item Type
: D# [. W7 S+ C9 F5 i0 y6 LMP1- i* f) s( v  D/ _/ g/ n. h
7132153
9 Z- S% @& Q4 G& \6 b% b0 KFixed contour operation cut region tool collision avoidance gives internal error
) H: k3 k: |- i/ A: V: z' lMP1* z) `/ G% m* j  z6 i  _! }: h( O
7172245, E5 [! Q% w$ o) f1 L
Routing SAC, length attribute missing from part in 4GD workset
; H5 `! e  C; R/ e2 U& ]' s% K& rMP1. N( ]" H" i3 q' J; @
7254028$ P# z5 @9 H5 G; S
NX Cannot save after delete trim angle curve& j% a6 s' r, M. s
MP16 C$ Y; p9 L7 d( f. `9 m
7254771" ?4 |1 S- ^" w7 ?, x
NX Part Family Assemblies fail in TcVis; p  @2 S. O; U3 X8 |( m
MP1) \6 h/ b# \$ q+ J+ U
7270769
. m% g) |/ h9 p, u5 ]; qDeformed part reverts to un-deformed condition after Part family Part Update.
6 S" }' l: r' DMP1
9 `/ @' }2 g3 v2 I. y! |7277787
' g) p4 Q8 j+ j9 f- m. R. _$ nUnable to specify Boundary in Planar Mill operations.
* G1 l$ w% s( P+ sMP10 z( G+ {4 H; K9 h$ r
7281263
4 i! l4 E8 E/ e9 A" x1 v7 b6 |3 tWeld Advisor issue with the Fault result on Point Face6 ~: C( g) Y7 {2 b! s2 }) \; t
MP1+ x; m2 L) e( G/ L- T
7281599
# E+ W* }, A1 hUnnecessary splines are created while changing options in "3D Curve Blend."
: p1 Y% n. F% `( IMP1: q- V9 |* H6 U5 l" K! P
7283968/ C9 Z1 d* D% ?( ~  l7 E
Delete User defined Motion, all other axes are gone in Machine Tool Builder0 H6 `9 M( V6 M, A
MP19 H" J) @* O) N3 W
72866096 D( z3 W3 |0 R- c' l4 T( g0 D( Q3 v
Can't perform a unbend operation on a sheet metal part, when has define pre-bend.7 n1 X5 j1 ^6 z% l; {8 E3 x. L8 ~- r
MP1
( y4 _/ [+ l  ?8 H4 C6 D- x) g  Q9 N, J# F7293558
3 ?" T, O5 Y! I) [+ A* BUsing PartCollection.Iterator doesn't work in NX 10
( x9 h* m$ y& P( TMP1
0 J# G5 O- S# o9 c# H0 T& f72936440 Y* w' y6 e* H- U
Manufacturing-Turning-Groove tool definitions incorrect when tracking is changed
0 S. w) _( U! d6 Y: h$ D1 a2 R! z4 {MP1
8 c! P, c! X" r7294550
! `6 q2 ]# m" o$ mAutomated Pipe Welding Error6 n" m3 u7 g8 B) m7 {# K
MP1
! r1 ^% a. S8 |, D" p72962095 w7 w6 @5 \8 u; q/ f, m1 h
Boundaries created with Boundary Manager unelectable in Planar Mill op
( N2 m, W" {) q; G% Y7 DMP1
9 j& {* B% \' ]7299059
9 T2 S! a/ C2 z+ A  n' XThe Highlighting remains ON in the Motion Simulation
0 u& a8 e9 K( W0 d" [( TMP1
: P) G, |9 ~2 _, c# i7299945
' N+ l" E4 E$ {7 |Turning - groove tool graphical display is wrong.
  j( s; O: f4 j2 O( U% X' uMP11 l0 d6 `6 I9 z4 `8 G6 \
7300284' Q0 ]2 x9 R& P7 J
Automated Pipe Welding Doesn't Support Welding Pipe to Pipe
& H, N: K3 [$ l/ O4 XMP1
/ F: ]! A( ^- W/ Y6 h73002910 m% P3 y' a# m# D
Automated Pipe Welding Doesn't Support Welding Fitting to Fitting
$ _; z# k: e) zMP1
, |3 ?: U- ^3 k, h! D4 F) Z7300296
' s; L  R# s( e" r# y4 QAutomated Pipe Welding Permanently Changes Preference7 S* H6 E  y7 m, F2 N# |! ]
MP1
  \2 F- o  P' _7 k( n) h9 @% L+ j( i73056322 I8 F/ u, B. T* x& B2 l2 h
PartCollection iterator fails in NX10& Q. W5 C4 j. \
MP1) Y+ T  q( p( A8 K7 F# c
7312970
4 P3 b8 O( ]4 M( E' A4 o- f; nUnable to pick faces to define a fixed contour boundary drive operation
( X% r. [8 \3 ?- \' V! qMP1( b# f5 ~1 R& z
7315737
0 Y) ^; B2 C4 o8 BTool tracking point displayed wrongly for grooving tool.$ y+ f" c6 e* Y& _( N
MP1
- D- v% T' B  p* R8 O/ |2 q  @7317682. X6 z: q% m1 c! `: `! q
IPW error when trying to verify tool path in 3D Dynamic  S8 l* ]) B( {9 ]* O" f
MP1/ C3 [( _* Q% {$ h; x" n
8252492# K0 u' v7 a: \* h. ~4 M8 U
Part save failed after delete unused Elements and old geometry elements available
* g! ]% A; ^0 H6 Q+ NMP1
0 G" S: g0 j* R3 y  ~; Z* ^82621486 z, Q$ w: w) w* T' g
CAM: Tool display fails -> Internal error: memory access violation2 X) E) n5 P: V1 ^: G; e# K
& B! ]1 M6 B5 t& `1 [* J
) L7 p# K% V* o4 s1 N% X( ^" }9 m
2 z2 L7 l) x% F2 L& H* e0 `* w) LRelease
$ [+ d8 J6 H  c! [9 B4 RPR Number8 h$ Q/ |1 B; F: }( m! g
Problem Description
9 Z$ b. Q3 u. E5 }$ k" {# WMP2
4 }; f% W# ~$ E! ]- ?7191032  O. B* P9 r7 [* j0 D
NX-View Updates in Drafting
9 h5 h- |" q7 |2 B, h" A4 A+ TMP2
, J, O5 [" N7 P; i7259032% v2 O3 r$ w; K
Internal error when trying to open a drawing" l3 Y( Q$ F$ m2 x
MP2
& a% F, N: ?3 C& C& h2 L7259542
2 w0 \+ A  ^7 L0 L! U: QNX returns an Internal Error when opening a drawing if the UGmaster is open7 l7 I. a4 a, _! A: I
MP2
% c2 o% W6 ^5 S1 Y' d! e7260603
. z  e% A* `3 C3 W2 Fcannot open the drawing if the part is already open- G$ n8 |6 U! r* }! ?  I1 ~* J
MP2
9 Q# r: @2 ]! w. Z7260856
1 J' F3 t. l( w/ HDrawing fails to open, if model opened first and modified
5 F. e+ S+ ^7 p4 W3 ~6 HMP28 g" ~5 d6 E% f3 J9 w: v. `
7270903
& C: z4 B2 e2 {Unable to open SolidWorks 2015 part or assembly files
$ N8 x7 r! S; Y8 lMP2
1 k8 ]0 g) e, R1 ~. B7276052% R- w7 X' S4 p! O1 e4 R, ~
JT file for override does not contain correct refset information
: H: z6 J! D  j0 F! Y5 x, l9 jMP2
) g/ [% ~: s& P. p7278612
+ e1 K5 k: ^( I& g, O/ TUnable to open SolidWorks 2015 part or assembly files
8 ?. ^' n. d/ m& A3 ]' M) @9 iMP2
3 T3 c: \; J7 i% U( U7286985
* ~* K* x" O6 r' Y2 O. t- X( PCannot open the drawing if the part is already open" p: ?" D5 L' s5 G
MP2% ~; T; F: N$ V: Y  H( {0 q6 {
72872046 a! ]+ z: f' A7 W5 P
PMI not displaying properly in JT files generated by ugtopv.exe utility NX9
! _! ~9 q6 Y1 I6 c/ R) t8 AMP2
! p, M5 ?" t  V7293181
' ?: K$ {. |5 I+ ?# H$ gUsing Find Feature disturb any VIEW dependent manipulation (FIT ; PAN ; ZOOM)9 Y9 O& b' [" c; N+ [7 d! M
MP2
, y$ ^5 {& [) J0 T) B1 e4 i5 F9 X' X7296169
: _, E; x3 I8 x' f+ K( ^% v- D/ b% eCannot open a 2015 Solidworks file in NX9 the PLM XML document failed to load/ X1 F0 G* M* M% A% s
MP2! Z) v7 _) e( T4 e
7301423" w# f& i6 n9 f2 B1 D8 f/ p: ]
Exported jt assembly doesn’t display correctly when turning on Model Views
% r& `+ b$ H2 s+ J3 Z* KMP2( R, G0 _  p5 S
7307405: T+ I, ?7 W% t
Thread hole milling doesn’t update Tap Drill Size.# n, y+ Y3 P/ P9 R: R
MP2$ V7 z- I/ d: _
7314018
3 T6 s0 Y3 B! y4 Eugtopv jt -single_part creation changes load_options and loads all parts4 ]4 @0 T6 x1 E* v" B
MP2
8 Z( u4 k/ g' Q) \7318795
1 q; L& E3 ~: v2 ]$ W2 sSignificant meshing speed decrease of CHEXA elements in NX10.0.1.4+ \" S) ~& Q6 B5 L
MP2! w/ K0 a5 m) H# `! q
7321100
7 P! s# a- n# C- ~Graphic window freezes when a Find Feature is run to Parasolid model.
% N( A2 d  ?" C% AMP2
  B  e* u6 [7 R& E: f$ a/ ]7321742
9 {0 j$ d% c+ V( ~$ H( `5 c5 p! f( L) PGraphics window freezes after parametric feature recognition of SE part( _& [- w) c7 O' M+ g2 R
MP20 j6 m1 p- j" I" l* {, y
7323594  D: V+ D* z  y$ Y$ n' Q+ h9 j: J
NX CAM graphics lock when Hole or Boss geom group -Solid Edge generated part.# Z8 W: Q. B/ F5 h! b+ ^
MP2, q. l) ]7 e' f4 y
7332095
- @3 o  u% n- A! @  O2 o5 LNX 10.0.1 Very slow with certain operations
' |4 J2 ^8 D( W5 E  W& r& BMP2
, s  f! E! S: i82518278 w) p3 m' h' t0 j4 t
V5 to NX translator does not translate mirrored components correctly! W0 v/ r: m8 H8 ^8 v7 N
MP2
4 j2 Z% y& A5 w7 o8 q* B4 ]; f8259516
) x2 z; h8 D6 R0 r3 c& `) UFailure to open MIRROR prt in NX 9.0.3.4$ S, Q+ R6 Y# G
MP2- j  Z8 [! O( Q8 a, Q
82595172 p" j$ F4 u- e/ w+ m
Failure to open drawing prt in NX 9.0.3.43 m& X# ?. M, ?, ~
MP23 j/ A. i6 i4 B6 q! H* K
8259822  H( ~+ T, s  C
Cause for the message: A material with this name already exists
: l; Q( a: u3 A! WMP2
3 P" ^, g3 e; x. G82630423 @' S2 K" w: _+ |- @
Thread hole milling doesn’t update Tap Drill Size in NX10.0.1.- n: a% U8 d( f, a$ E: m
MP2) u7 p3 X1 ?: }3 z0 }7 x1 P
82632636 N  {) u: F" E% u- \1 x+ }% R
Update status not correct
( _' e2 Z4 i0 T, ~- SMP2( D' ~' d- x) D* ~* J9 g/ h
8264418. w: t/ a' J( k+ w9 D9 o( [; d
Planes and axes of linked CSYS appear to be disassociated from the CSYS tripod
! k- Q: M, v( ^/ t* p% KMP2
, T1 N5 J0 D. A& o' s8264863; @/ U: G, C2 t3 ^' Z3 f9 F
NX freezes ca. 3 min or more when expand Polygon Geometry with 156 objects4 c' q7 N9 `9 d$ g5 T# I. K* y
' N: E/ k. M( b  b4 Z1 R
* f$ ~& j5 w& {, b  \  ]) u1 I
, `; Z% O: _/ v
$ b( ^7 e3 I) b1 V; n. J& q" d9 ~4 Y- ?3 K& E' Y( U
$ i; R4 y8 k! J* @( Z& L2 B! `! m
# n. `  X+ @/ c+ l" q2 X+ O
  L  I( }4 j! r- x
  h' ]' W3 F3 L! g4 e2 d! o
; X" w5 W+ B% T  @: O
