[新功能] NX10.0.3新版本修复的问题列表
2016-4-24 21:28:31 16095 1
发表于 2015-11-29 13:32:58 | 显示全部楼层 |阅读模式
Fixed Problem ReportsNX 10.0.3& e. |3 X; Z# f& b  f: h$ J
PR
% N0 P; D7 P5 L* t  eDescription
" W) }- t' t; I; F. @5 r* H62732445 Y  G+ ~  e! d; R, O  W
A part which has Linked Composite Curve created before   NX 7.5.1, and  has source parts completely unloaded, may show curves in wrong position  after Part Import
, D# k+ W4 w0 }! n. v1 |# }- Z6987529
4 S( B8 x) {- B$ ~' N' vThis issue was when two concentric circle or arcs  were used as input to create the 2D centerline, we created an approximate  arc in between, and hence the dimension values were slightly off
5 W. s5 r7 w0 Z! E( m; r& P( S: `7276407
! K! o0 t! c7 Z# d" G4 Q  q4 z' y$ P1. 74045096 P8 J  I4 Y2 I. @! V  U
Selection issue for link type filter - There is logic  in bui_layer.c  selection_cb()  that always adds a new cog marker to the selection list if the selection  list contains a link object. To avoid this, check that the cog marker  is not already in the selection list before adding it.
7 ?6 d/ B, c8 `" S5 V2.  72764072 R4 I0 v3 A8 }7 Z) ?) ?% J
Hide Pattern Feature does not work if datum csys  is patterned - There is a call to FREC_is_global_selectable()  in IsRmFeatureSupported()  for pattern features that caused this regression. Removed the call to   FREC_is_global_selectable().
8 e5 R3 h- j4 R1 ^. ^7340173$ ~5 C. y5 a7 ~, G+ g
Leader location of the labels having no text changes  on view update
# j- @! {+ r  c1 P7392623, q3 O3 H2 I& g" L6 \
% V* s) r8 r9 G* _7 z7397240
3 X# c' m! e5 A* S0 _& tThe problem where the datasetname  for PDF export  can be changed if it contains a colon or slash is fixed
$ J8 B4 P* b: j5 K: z  @, [7403885
6 P2 b; q, p  r" b* N+ Y) FA number of autotests  are failing due to the OM  check world failure of PART_placeholder  object created for stubs resolution
7 s( ~$ C) I0 Z9 B7404509# J' }$ M2 H$ u- g1 A
1. 74045099 q1 X& X3 x0 s
Selection issue for link type filter - There is logic  in bui_layer.c  selection_cb()  that always adds a new cog marker to the selection list if the selection  list contains a link object. To avoid this, check that the cog marker  is not already in the selection list before adding it.; C, G0 e; |# t: K# ]! F
2. 7276407
3 M9 Z4 J0 r# N% qHide Pattern Feature does not work if datum csys  is patterned - There is a call to FREC_is_global_selectable()  in IsRmFeatureSupported()  for pattern features that caused this regression. Removed the call to   FREC_is_global_selectable().) }/ p  N% t" O5 v5 J+ S
7419493/ X- {& O7 @) l" Z6 M+ \' _9 n
A part which has Linked Composite Curve created before   NX 751, and  has source parts completely unloaded, may show curves in wrong position  after Part Import5 _' u7 z+ }9 |
7424602
3 }# B+ i0 Q7 l' f% B1. 7498710 [priority 2] "EB2015"
. ]' f5 [( `2 E+ ]Custom  symbol leader arrow heads change orientation in TCVis  for VDG9 L, _3 K9 M1 G2 G8 E
2. 7498696 [priority 2] "EB2015"
0 P1 O" X7 M( r+ ]8 L+ j' I+ ~8 MIn View dependent geometry holecall  out dimn values  are missing in TcVis  3. Avoid processing pending instances. It generates an exception.6 j8 j6 y; P! Y6 S% O; p
7451718
; p$ e7 a* V: t, E+ TView stored on the SO objects referenced by Associatively  classes are out of date. Editing the Associatively is only changing the  view stored on Associatively class, but not on the referenced SO class.
! e# @6 {3 v# @+ F0 n; X7452021
* V# ]. Y, Y: m% I: G+ }" ^Annotations with extensions are hidden when view break  is applied& H2 ^! E  [7 c
7453295( @4 Z% [2 M8 T3 o2 d5 Y
$ N  K! t. \  u" q6 C# l$ a2 |, X7461929: s, {5 d# @" a
This CP  will fix the following PRs  7461929, 8277290, 7432871, 7495264, PR7508401, PR7513312, PR7509156, PR7516040,  PR7514922, PR7515960, PR7518217, 8280972* O. f; M8 Y. U! w% b0 a* Q
7467273
% [6 @* ?% Q7 p$ v0 O" AThe display of assembly parts for grooving tools with  an tool tip junction at a different corner then the first was wrong
; I, o) I/ }3 N4 u+ U6 \8 ^0 K7 N7476679; X  [# o. ]3 \8 ]& e" W
A number of autotests  are failing due to the OM  check world failure of PART_placeholder  object created for stubs resolution- X9 U) P; @# Z8 f; i9 }0 v
7478090
4 v, }/ |5 P# o) h5 c- BLeader location of the labels having no text changes  on view update
$ D" M6 ~' J# p3 P74793583 Z' ]6 D# J. a0 r
Copy/Paste does not handle UI error in UI codes) t1 H: _6 Y+ U( d, p7 \
7479663" W* E' j& o6 p/ b& c7 z8 M; A$ Y
A number of autotests  are failing due to the OM  check world failure of PART_placeholder  object created for stubs resolution- N& u& w3 i5 `  b7 w; Y" ]
7484052' y1 h4 j4 u0 N' G
A number of autotests  are failing due to the OM  check world failure of PART_placeholder  object created for stubs resolution2 J6 ^( u% F+ G8 X( |
7486047
' n9 J& |  y1 U" rThe Origin Symbol arrowhead is displaying as filled  in JT when  viewed in TCVis# R, R6 F  V- p3 }% b; H% D1 l
74892495 a9 t5 D9 k$ H; y4 \% o3 |' ?
Deleting a newly created Ude  will cause an internal error when closing the part  F9 R6 b" Q9 |. ?5 I. z3 Z" R
7492187# s5 `, G4 s$ n  g5 G
These issues are EB  related issues and solves the LWSV  cases.6 @, k3 l, K5 ~
7495264
5 k$ N0 B0 Y' `4 a# b( g" MThis CP  will fix the following PRs  7461929, 8277290, 7432871, 7495264, PR7508401, PR7513312, PR7509156, PR7516040,  PR7514922, PR7515960, PR7518217, 8280972
7 q# [2 @% D% k8 F% P$ X! `7498696/ ^0 g4 U0 m( e$ E
1. 7498710 [priority 2] "EB2015") y9 J. w2 a& ~1 Y: e
Custom symbol leader arrow heads change orientation  in TcVis for   VDG
  Y* W6 C% y( u7 _: j# N2. 7498696 [priority 2] "EB2015"% |. L( q8 m9 C% Z
In View dependent geometry holecall  out dim values are missing in TcVis
  s; S4 }" F' N5 g( h! @- ~3. Avoid processing pending instances. It generates  an exception
5 k4 a2 u# x- e. P$ Q" b) x3 J74987101 }) Q9 a" ~0 W0 }
1. 7498710 [priority 2] "EB2015", {- d4 x8 c/ U
  X5 d1 T( n& s( b: K" s8 o2. 7498696 [priority 2] "EB2015"
6 m# n' b% K+ U2 `, a; R: `! h2 EIn View dependent geometry holecall  out dim values are missing in TcVis
% j( R# i6 r3 _* P( k1 h) K3. Avoid processing pending instances. It generates  an exception- a3 C' B& J# c+ I  h4 y1 c
74988450 l( F9 ?: V1 A$ k1 s
The problem where the datasetname  for PDF export  can be changed if it contains a colon or slash is fixed/ c5 m- e8 {; h" L9 ?
74999499 x: J) n6 n( B2 X; G" c
; ~4 M' C( `8 @# W) @7508401- B3 U/ q) k* B
This CP  will fix the following PRs  7461929, 8277290, 7432871, 7495264, PR7508401, PR7513312, PR7509156, PR7516040,  PR7514922, PR7515960, PR7518217, 8280972: N. p  G" z  q( |
7509156) s  C) R5 i* `. j: M
2 I  }7 b7 I" w# ~; Y) W" V. p$ _7510245
5 E& o, O7 C4 S1 I. e9 l4 aAn internal error results from toggling a UI setting  for group nesting after hiding the default grou.
9 }& N% Y5 g3 I7511122
. C" }, X- D: l) a5 EIf user resend sends a Assembly with a variant configuration  from Structure Manager to NX,   NX present  a dialog to Add or Replace Variants, this is unsupported ., and user does  Add or Replace it causes a crash. The change is to block this functionality,  and allow only when OLD_VARIANTS  is used8 ]6 J1 ~  Y* {0 ~
7513312
9 R2 a4 e) C9 K3 N; QThis CP  will fix the following PRs  7461929, 8277290, 7432871, 7495264, PR7508401, PR7513312, PR7509156, PR7516040,  PR7514922, PR7515960, PR7518217, 8280972
$ O4 F+ U+ F/ h6 H7514048
( U! A1 w0 T  |The problem where the datasetname  for PDF export  can be changed if it contains a colon or slash is fixed
% k) F% w- T- _9 n( F7514831. s& L- i% @+ ?6 ?: s
Resolve PRs  related to Daimler Enhancement Request for Convert Legacy Weld Points
- o+ M. j% A9 a- z) ~$ p0 w$ E7515446
2 H2 V0 ~8 V7 ~7 Q9 n& @* QThe problem where the datasetname  for PDF export  can be changed if it contains a colon or slash is fixed
( H$ E0 d0 P  d( b7516187
$ N/ I' A0 H$ D  SThe OM  check error occurs when edit the encrypted processor
. p! z! b# o8 K' ~+ A$ Y! F75167516 R. q+ Z9 R$ `) d+ A
This is to fix Daimler relinker  cached expression issue
3 V( q1 Y4 w  Q8 A75171302 V' S- ~# }3 }8 R& j  ]; z
An internal error results from toggling a UI setting  for group nesting after hiding the default group
% a" _5 r/ d# O) {! A% D) o1 ]7519740+ T! W$ M: l, u+ _0 k1 S- a6 y
Values on dialog are incorrect when editing MAD. R' Y4 K' ]% h
75216810 C* n* a( \0 X6 ~$ G- T3 g
/ P* k6 u2 U* P$ x# n* m6 X7526846/ G* V/ Y) v* U: B
* }0 }; E& p% v5 L# v% V- N6 C7527170
7 L! q- i; l$ U& a+ ~' _2 uSee PR Text! V7 z8 w4 E2 E6 q5 X" H
75273328 a! E1 }6 Y+ a& h, ]
See PR Text
; ?( C6 R& i- A! l: Z7527417' {; J; k4 u$ P( `0 R
See PR Text
3 S; y  O1 c) U$ ?' d7 e75284702 o8 i; d3 _, p# ]. ^# T& \1 T
The issue reported in PR7522519 that Spark Gap settings  not kept if position values are changed is fixed
6 h; C, w/ E* {7530542
3 n0 W" [- }4 r2 S: l% M' rThe display of assembly parts for grooving tools with  an tool tip junction at a different corner then the first was wrong
: k0 S/ F& q7 n, L0 P  g7533256
7 t7 J) ]1 F) u! H! [+ t/ A3 N* EThe auto and manual Tool Change settings are missing4 h; ?2 U. a1 Z/ O1 [+ ~
82511798 x( _0 {% |* z
In the old part family template if we add any new  member at last row, the last row was getting replaced with existing member  at first row
% j  j( _, K/ l( P8 Y5 I8270898% P, [6 g3 W$ C# w0 ]1 s
Feature Playback failed due to change in Law Extension  feature, [) @4 r  @6 h6 N% o- s
8275328
$ c+ \0 g2 }6 NLeader location of the labels having no text changes  on view update: u2 B9 v, E6 |  n
82765967 C3 }, z: n9 F; f# X9 l; C6 [6 L  i
Problem was originally fixed in NX  10.0.3 but the change had to be backported  to NX 10.0.2MP.  There was a new version token added for the MP  fix. That token needs to be reused in NX  10.0.3 so that parts created in NX  10.0.2MP don't regress in NX  10.0.3.
# c$ ?) Z- \2 h' A. c! W  Z8277626
+ q5 T7 t& L) X/ I0 i# `$ U1) when creating reuse features in a different feature  group, the reused weld points are left in the original feature group
/ o) a! p1 y7 L: n7 _6 f) u) b2) a change was made to the signature of 2 NXopen  functions in NX  10 that may affect the stability of existing customer NXOpen  functions! U1 p9 {5 M1 l9 k/ g/ e
8277662* i/ a8 b2 w$ X: c, y1 e. ^- K
This is to fix customer relinker  failure in managed mode and one IE  with view feature failure in case of part being closed
1 y- C: }7 G& Z8 c$ n8510681: |; G' B1 j; L' s1 [3 A5 Z! Q
! P( d- w3 l$ o5 _6 i2 `9 H11276136 @( [& M( N/ W& X1 {2 g, h4 M
Misbehavior Wave Geometry-Linker& k4 N& c2 @, T% e/ L
1127821
$ G' F$ z- m; J0 gWrong tool path computation in PLANAR PROFILE8 ?2 y8 {# }0 W* u/ w$ B
11278243 M' ^7 j3 Y, ^1 E# u5 F
Law Extension Miter Method2 W- [6 g. h7 H; x3 z; {# Q7 e
1127845
* S& L6 o( ]; P) }Sketch coincident constraint snaps to opposite end  point of edge than selected+ J! L8 x0 v1 H
1127902
$ y8 s/ K$ @! n$ ^Routing Reuse search does not filter on previous selection
# W: Z5 y0 o' {8 x; ^3 i1127927; t- X$ B+ c* |6 H& z7 M5 [, T  _; Z
Curve Length BUG in NX  9.0.3
& ^* Q+ M6 j. T% O1127954
- z$ n5 n3 i/ A/ {Error - Invalid view sequence number found, creating  Stock Offset Spline  Point
' l5 Y* `2 Z( g9 V, [( O11279748 H1 t: k1 R1 o" w2 z
Not able to open Partfile  (last stored in NX  9.0.1) in NX  9.0.2.5 D3, 04Aug14
% ]; f  I, |6 \6 Y# I9 ]4 n1127978  j+ q3 c( C: O: R
Wrong Z  direction of weld point created by existing points- I1 l' y: @/ \5 V  x2 T: G9 b
11280018 j1 ~2 t. c3 h. @' w
Unknown IPW  Collision Checking
& p5 i; A: G  c/ k! \: t1128175- R, x1 }' S: L1 }6 E& S
NXOpen  can't get Dimension Hole AND Shaft tol  values from FitSymbolsAndLimits
* O3 {6 x! ^9 S: |/ n1 ^5 Q0 T, L5 q11282778 u" Q1 @) Q& u6 r- D3 V5 B7 s( Y; D7 A9 J
Editing of spline  path created Pre NX  9.0 takes a long time
/ a$ _% e$ y$ N1128535
: f6 e$ n1 D/ ?Constraints not displayed on screen when creating  path with Lock Length _ Angle& Z$ _" V: O: Y$ I7 E7 P  m5 J% G7 A
1128541
: Y5 e6 a2 o& {0 LRouting assembly constraints show the incorrect value  in the display
) q2 g, O4 |. s: k: j/ a1128678
( o( R, Z6 B- o7 H" A  c7 aCannot add drawing for undercut blank due to missing   EW_COMPONENT_TYPE8 `% d' _; A0 I& J, L  ~
1128688
; i+ |" |4 G7 h2 [# OShow exact fails on JT  file1 B. |. _2 u0 o' F" q4 T7 I5 q
1128705
3 p0 }4 F3 x8 O8 V" ?: [6 NElectrode Design Blank increases undercut REF_Z  value on each Position Update
/ ~- d. h( s" M% M# m1 S11287571 I5 c. _8 X, \" X
Multiple bodies in global shaping results in scattered  sheet bodies/ w( Z! x% g$ l# f& _' Y- b
11287617 f& [: H. ^- p, P
Studio spline  in expand view6 w) {" G7 Z" z0 i$ g3 l% v4 ~
1128937! e6 s+ D. U/ u
PMI  Reference Plane_Datum  Plane not translated from NX  9.0.3.4 to JT2 H3 w# I# a1 f" D9 ?. E( @
1129052
9 N" Z! g/ N/ t4 n- |Reference Text Attribute does not update after revise8 f8 k  V  f' p" I
11291674 y- q; V8 V  w! J/ D. y
Strange behavior during edit reusable components
* `; u0 M* m4 G# K; g1129175( k( m$ F5 n% m3 [" @4 M
COM  Error 80010100 while creating parts from complex part family
' w5 ]$ S0 K3 a: m8 V1129227& ^; C4 {+ ~& G; D
Colors on faces are not preserved during Feature Playback
/ n- x( ^2 u; q8 d- U0 S& y; p& S0 c11292341 y( k* i" K: \# g
Law extension surface doesn't meet quality- \3 k" e$ p- z: \  J* V  w& N
1129704
$ v+ h0 V- I' p4 S- {( g4 FWrong dimension value in view break) v( H; r5 \  a2 S( }+ }: n
11298034 \. n, h5 H( t3 C1 L) l7 y- ?" E
Cannot create desired development with One Step -  Entire Uniform
' H" l9 v' g6 o2 p/ g2 k3 K1760113. Q* N5 k4 n& y4 S! G1 F
Mirrored faceted bodies get dimmed colours3 g, i* s  }( N$ p. x: H
1791299' L' O' v9 L5 t
Streamline gouges in the part1 z) G" i/ |/ c6 E  E
1793082
: E1 v9 V$ S5 v8 d  p. HCAM: PR - Turning - Toolpath  with Custom Stock Value is not created correctly
- a  i3 I2 F  e+ ^' n1814361
; f7 r+ G) o  |Problem with center marks
/ e9 v5 Y; x7 _/ H3 |1820370
2 K1 a+ r" N0 D2 ~3 W. SChange in custom boundary stock values is not handled  correctly0 t% L( D2 h% z" G
1822765
/ j: r+ D' h* P6 Z8 B. C1 ISame Cylindrical centerline selection does not give  the same dimension
' o3 R# T7 q( g! ]+ L: e1835918" K* a4 J* d/ g* C3 v1 m8 [
Retain Annotation font set to invisible does not work  for 3D centerlines
: T, ~# ]5 H8 G4 I+ f( N1842352
1 U6 C: I' p" c+ Y2D Centerlines not updated in Revolved Section View3 L  h* p0 P5 L5 u' Z
1844476# o; a, }: r4 Y$ \) V
8251179- In the old part family template if we add  any new member at last row, the last row was getting replaced with existing  member at first row1 t! m( W: P' G' T& V7 C
1845934: r7 ]! f) L) k& D5 m* @8 D+ z' ]
/ L" }" W; G% L- W2 I1848798
. C6 Z) x( s7 s* w$ ZNX  hangs when creating Formboard6 z! A) Y* b2 v6 J8 @
1850987
9 ~5 [; |9 s& Q% UPlace part does not work in native environment7 C, p% s6 G5 V7 L, ]
1866971
5 m; z9 E1 J4 g  v0 yFamily Object Name is invalid with specified attribute  and space character3 L! _. v$ ~0 y" |( @
1870054
4 a* s' l- g& F, p9 tOrient branch fails following flip component
' G) U. J4 i3 |1874908
; F5 p; i$ u9 p/ [% \Create interpart  link default at off is still creating Wavelinked  body& U! h& d9 K. N/ ?' C
1875433
$ v4 X* ?3 ]8 T1 ^7 f8 Y9 ZOpen whole assembly in NX  7.5 - opens only one level at time
$ |# f: p! n/ F' F1878931
: p6 ]( p7 @! N+ oKeep switch settings in session memory in selection  tool bar5 j. p2 D- @& D
1884620
, n2 O5 h- s) h* K+ {% o5 M: k  ~1D mesh direction change
% T+ x. |: D/ [. Y* v4 m# \+ p1891032* x. E* Y% X' _
Stock Values for Custom Member Boundary work wrong  when Curves have wrong direct/ N' N5 o4 u, z" [$ I
19038413 X6 j( `" p; H! K) J5 h' s
Points not added correctly when editing spline  path0 B3 B. G& u7 |' U6 z
19088204 Q2 W! {( A4 L" \. [6 u) W$ [
Shell element stress results wrong if plotted vs material  coordinate system; R2 _1 p2 t+ S! z4 c, G
1914851
  v5 T4 S' [( f6 @, n* m8 zError in Sketch constraints after plotting un-displayed  drawing sheet" K' ^' g- Y# O
1916880: `" ^7 l0 `  u
Dimension changes in NX  8 without reason5 F# m2 c) c9 q' d7 X" R+ \. V* u
1918104
" S4 s4 j& I9 UThread with "Move Object" Feature not possible  to move, too! g: I+ ]) V% W' ^- u$ Y
1922140
! G3 J/ [6 i# ]6 X# jRouting Port does not move with path when using deformable  part TODO:VIS3 z5 D9 F9 O7 b# ]9 j4 g7 z
1922502
4 s5 t9 c" d3 Q- P, b: qLightweight representation icon shown when no geometry  in JT file   ref set6 E/ i" X8 o7 V3 o0 @: Y
1931502
( z" V: k5 y7 S9 L7 ^4 f( _Surface Finish Symbols do not migrate correctly from  Ideas to NX  via CMM& P6 C% ?5 n" b- U
1933385
7 e2 S0 }8 j' c; C, H) UAdded support to translate the smart lightweight views  using 2D Exchange translator
- M7 v& Y# s3 o- i/ u19364535 L  f0 [' ]& r" k. k
CMM  Ideas: Surface Finish Symbols do not migrate correctly
5 }5 g+ |) @4 w19368451 W; @( M8 O4 Q7 M4 i
Surface Finish Symbols are not migrated correctly  via CMM 8.5.1& ^) p: G" Q+ X. X/ t' @
19370247 I% |/ T) P& ^5 p; H5 R
Surface finish symbols do not migrate correctly  c. k  ^' ?; }: }% d1 N0 q
19392509 \# [+ u; O2 K% }* ]
Sheet-Metal-Expression "Sheet_Metal_Neutral_Factor"  locked when change material& ]0 m) M8 `: L( e9 s6 ]
1939354, z; o& Q* |0 @, t/ S. E" g
Section function fails at sectioning of Sheet Body  with bad data quality
" J4 L2 U3 U  k1940563
3 {9 z2 V; m# XCAM NX.8.5 - FloorWall  Mill - Use Exact Inconsistencies) n6 }) k8 a2 i. s
19410649 l7 a' i( w# {3 ?1 a
Assign Corner - Mitre_Cope  is grayed out in some routing mech.  sub-applications- n0 U% B) c8 |% ^' U/ K
1941448& X* n, u$ B, x# o  d# i$ Q9 Z6 P
Provide faster access to reference dim option
- G* A9 P2 U- z. B, o3 ~4 [1 t1942299
5 M- o3 e+ k8 e. qSpecial signs in UDE-options  causes error when MKE  configuration is read
( X8 f7 ~! R% `+ K* p  d) `1945025
2 t5 }+ {9 b* L: eBolt Circle Centerline doesn't work correctly with  Extruded holes
( R; \& k5 O: n: S$ n# a, y! S6 ~) ^19459263 i& X! h  i& p
A deleted or invalid class id was used when attempting  to Remove a Spline  Point  @3 s! u+ K# I
19463148 @( q) n2 ?3 w4 `
The performance of dragging Spline  Paths is slower in NX  9 v NX 8.56 L1 T" {% p$ S
1947203
1 @! L# ^$ i0 Z/ _% H/ ECylindrical dimension with baseline attached to a  2d centerline
" F8 T: r: Z5 U19476602 }; C8 ^5 l$ `4 d7 f& Z
BSH  Check-Mate - order of features in error stack$ ~* \; A1 B2 G) G1 L
1948276& k/ y4 {0 _3 J# ?* e
Molded Part Validation shows radial crossover faces  as vertical( n9 Y1 F, L& z& `: \9 J
19491170 |+ Z0 [2 Q3 t3 U7 h* \7 q0 G
Assembly components disappear in the graphics window   NX after step  import
) G* w4 r3 l5 q" r: t# b" q1949266! u2 `! K; U4 w) ~* R
NX  7.5 tool path fails in NX  8.5 when stock is negative
  H2 H2 S1 |5 Z6 c1949429
# V- v' B  `: m3 H: ?  ZZ  Level, Tool path shifted unexpectedly5 b# `& {! F1 Y# `( D
1952503
; e3 ]: W  D3 U/ D; [5 ]! n9 m& h# IGet "The following circular update was detected:"  but no more during update& V7 A+ g" T) b  z7 ?9 N- E/ G  V
19537430 p+ P  H  ]9 W' V7 N6 Q7 O
Pattern did not show all details; d* k0 r5 r/ E( T5 ]3 s
19545888 i6 j2 w& E7 G2 R6 G
Editing spline  paths of a harness created in NX  9 is very slow( M8 U2 U8 ?5 W# d+ I: u
19546018 e2 v: _6 }4 H5 M0 {3 s
Spline  Path editing of some segments in an NX  8.5 harness is slow/ R9 N6 s3 n1 D; G" s- b* j& G
1954615+ u. y* w; E* `3 @/ T/ A
Attributes on Datum CSYS; c& ^2 Z# ?/ @9 x! n
1956064" L+ |4 _, }! s9 ?. o  x) [3 s
Simplified thread display in Drafting is incorrect  when partially hidden
( t8 r% S' L. [19563479 n0 ^8 t! |, y$ q8 Y5 F" [# T" V1 l4 ^
Wrong dimension value when associating the dim to  the boundary of a detail view
9 g% s* g0 X, m0 I+ V1 s; l+ `19563658 M9 Z% e; ]0 H: |
Export flat pattern should allow to export curve to  a chosen layer- e4 v, S$ {8 f' E+ F$ `
1956523! d/ k0 M6 e9 Y$ n
Incorrect angle measurement after geometry modification
& u1 m: h$ k% j6 w! G  L1957897+ Y5 V$ I7 c# M
Open and Update JT  facets by NXOpen  without existing PRT  needs excessive time
. A4 J1 Q1 N- u; V9 o# Z8 u1958439; i1 s1 K& \6 C
Update performance is slow, also get errors in log  file during update1 s4 o6 w9 ?8 N
1958492. {& f0 z" g) @/ l! t5 e3 O
Stock is not displayed correctly after applying Miter  Corner
' r9 P* C7 i( o, r- E1958981
7 I% F# X7 U7 Q" [6 d6 _$ v; FMultiple Blocks with the same Name exists after using  "Canned Cycles" in Postbuild. D+ G- T: n8 |7 W5 Z. s" t$ y
1960208
8 g' d/ Y2 W. P, x: SCrosshatch of exported DXF  is on the wrong position9 z. V& N/ K- W& M  G
1961748. g" X, i2 P: \/ V. H$ d7 U% {8 @6 x
Missing surface data when importing Catia  V4 .model file
+ S* R4 u5 K. N4 h: w1962995$ Q" j2 j) V4 E% R
Smart lightweight views with dashed hidden line are  creating huge cgm  files
. G! }. y+ O8 P4 R* y8 j& D1963865, l& v5 Y) O2 c
Surface finish symbols do not migrate correctly- w2 ]  `! E1 i9 o+ I
1964099: v  P, Q6 S9 ^' {& t
Gouge Check - unreasonable increase in processing  time
- r( D% ?+ Y% s$ x19641771 \) c4 ]; K: V9 d) c8 {
Wrong dimension orientation by creation with method  -Hole Callout
" h  y0 |( A  J19644988 N# m8 b/ U; P8 c' e/ C# [
Weld point command with option overlap calculates  the reference sheet not always
( G& R3 L- X* M19647914 _& ^% j3 H6 {( C$ Z
Hang appears to occur when creating PMI  Dim in a particular view) S# F1 J# d# o8 L4 \
1964816' ?1 f5 c& d" Y4 X0 b: F
Regression: System hangs when specifying hole dimension  in sketch
: i/ `; a  \+ w1965019
( t1 p5 \) E7 W- m- J3 pContext sensitive help cannot be displayed for Sussman  Bathe or Shape Memory
+ ]0 F( l# M) k9 I+ A! ~1965092/ S/ g7 ^% X, c& ~1 G
Out of Date Status after Component Replace in ANT
" x3 c; {  ]/ B5 `1965800
1 J, h. H" M% eNX  crash - creating a Hole feature
9 ~  F8 n; Z4 p* m  k) v& k1965870% o. Y7 l# T  `2 P. n
Active Feature Group gets lost
1 z2 H0 G- h. B* Z  D19658767 r# ]" d+ s$ p: `3 y, C; F: i
NX  Session hangs while creating PMI  -- Radial Dimension with static wireframe9 |0 T- c1 |2 A0 q
19658943 z; _' f# p4 S/ d9 D/ V4 i( l
Delete of the "New..." row in the Product  Interface! A8 H% m5 y, l) g1 H* c8 Y
1965948) O9 q1 l! d. R9 D: _  ^
Extension Line of linear dimension points wrong when  face is selected2 }, X/ y% W: \1 ?3 Y3 w) c: `, n
1966017+ Q& L1 g' s! `, G9 a% x
PNT  tree do not open if a JointMark  feature is selected
! R3 e/ Y- ?3 X  j: J! B  Q1967696
) d. k2 D0 B7 Q" r1 z3 M7 SElectrical Routing: Missing Tangency created After  Wrong Point Deletion
, \% C$ y/ ~- y1967736
$ \' K& L6 u/ a3 V/ u2 tNXOpen.Display.DecalBuilder  needs multiple Commit()  call for correct orientation7 o6 q: m! S; z( N$ ^4 s
1969527
3 W  \' k% N- v% D# |: rCustom Symbol color not displayed correctly
: ]1 C( ~# x4 l. D% g* |: _19698153 `* {2 q( M$ X1 G" ^
Zeros are displayed in the Surface Finish Symbol's  after migrating with cmm
0 x! U. J: j5 j' b  w) V. K* n1 s/ W1971193' Q% j" c! H6 T( o+ ]4 v' `
This CP will fix issue to load custom item type property  values in ANT
% F; S, L; K4 g4 U19712505 X7 J2 ?8 ?+ T
Associatively of datum lost after suppress_unsuppress  feature
8 H! C1 d6 ?8 {3 w7 Q1971862
% d7 {  h/ Z6 }# M( Q$ M# D2 ^$ }Copying a sheet brings up Errors
: l3 E# }( W8 A/ ~, h/ a1975114
! e- W, y" J! ~. O4 q8 r. HAdded support to translate the smart lightweight views  using 2D Exchange translator8 G! {" x& T9 t% V4 L
1975133( S: I, T8 Q: l6 K  C3 }
MTD  simulation with PP created in NX  9* j8 U% o. m' n6 q9 ~! G' F
19753855 M1 ?! R& V2 S6 D" B% l
Cannot copy an existing operation - internal error
% Q( i  D( ^; P$ a5 t* s1977380) y- ]' q* l9 d1 H: @
Intersection curve consists of spline  segments, only+ ^9 [6 _- [' @/ V7 z: J1 G4 P
19777624 F* ^- j- [- `6 f
NX  Motion Export: Wrong VRML  Animation in result file; g+ S" P! `+ w
1978845& x' L% `( h/ e
Wrong holder collision detected in operation calculation  and ISV-Simulation# [/ k$ Y. i. L
1979409
% e9 E+ d/ f7 y2 T: _0 \Part Module: Change Feature without make Part Module  active
0 Z* _! F% g5 y% L; L! d0 a19795071 C) J6 x9 L% P! ]4 O5 n* t) l
ug_udfs  incorrectly transforms sketch and ignores parameters in rotated frame
( j! W/ d. D: n0 [1979836! p. m9 n$ [6 R3 ?  N- ^
# O3 D6 y  O4 e; _8 l- X& s1980390
6 Y2 o; h, h: [& N2 {: ZAngle dimension failed* a- T" x. a) j% D0 ~1 m
19804199 ~& O: a8 V3 @5 D- P
Part CleanUp  delete Geometry
! J% I; p1 U/ q* M. F1981720
- b' T: [% B5 h6 L3 |( PZeros are displayed in the Surface Finish Symbol's  after migrating with cmm& D- h6 s) H* r+ `  K4 `! e7 q2 I: S
1982792- k  n# w- g% h8 f6 A- {: ?
Operations from the first setup get an update if Override  Position is selected" M+ A1 ?) @+ X( C- {- C( W# Z
1983329
$ S: P2 B( \. D! Z8 q7 |6 [KF  %ui_comp_selection  doesn't keep objects reliably using OnInitialize  callback" G& f% X% P, r- e0 q
1983845$ i2 R+ r) b0 W/ {2 P) \) G
Tiny Linear Moves in ZLevel  Profile/ N0 g: L' N* k1 X3 o! K4 a
1983846, o3 u8 l/ `0 y
Tiny linear move in Planar mill- F) p" i3 Y$ a, }5 l
19838472 I! k; Z' p  }+ k$ V/ P
Tiny Linear moves in Cavity Mill4 U( M# Z0 L9 e) Z: g9 ]; K
1984397% }! {* p6 Q& r6 h8 `/ L
PartFamily  COM error% \7 k" f9 z4 j1 n6 N7 A5 c
1984811
* Y2 y" w/ H  _: \" a/ I; @NXOpen:ie:rawBeadBuilder::StartPoint::SetPlane  needs ug_die_design  license
; c- R7 O  ^/ d9 R6 ?' E% H5 z$ Z1985511# O3 Y! J7 a% O6 y
Deformable Parts are not working in NX_CAM  but are able to select) f8 q/ f' R# C2 n/ {7 }. X* ]5 v  n  h; |$ A
1986114
+ x; V6 _+ J7 }3 B( fSingle Sided Dimension not maintaining its "side": U+ z9 C/ O, d% r/ b
1986434
$ z$ v; e- _4 r$ W. aPMI  Cylindrical Dimensions have additional leader lines when a face is selected% ~* }% U: k* m0 U1 W
1986483
6 X$ k1 H3 {: [5 O$ n: i  Z, TToo many RCPs  after deleting a segment of a path
& u+ I3 c: Q$ I( y, W4 u# a19865656 z5 n) N) w0 k9 W8 w
Depended features of linked updates* n* v6 I. F  j/ ?( ?$ h
1986593# ~2 a; M: y: l: r6 n& ~, g0 R
Part Module: Unable to Pick Datum outside PartModule  for internal Sketch0 ~: M9 I6 J$ s: I
1986814
- P& |3 L. m1 F1 S, g0 S* {When I set the Generic Post placement I get memory  errors when placing part% `% Q6 o+ Y: L8 d; S2 A0 l
1986929% l& T& g- d: A
PMI  Cylindrical Dimensions have incorrect leader lines with user defined plane
) `2 F. z3 `/ O" ?9 G1988104
2 l# g6 n0 B  p& T7 ]( J7 _Unable to keep saved and unlocked toolpaths
- g4 {! @; Q1 m1988387
! I) Y! ]) V7 h7 nCannot select face with specify plane after adding  new set( }2 r; y+ `& ^* V- j
19885056 Q7 W& W! {. p
Simplified thread display in Drafting is incorrect  when partially hidden& F0 j/ `9 {  L3 o6 s% M* [
1989295
0 O3 k4 c# P# R! WDisplay in Views only if a new Model View will selected1 r$ i9 z8 K5 [) e
1989491) l/ G* v' g( I' n1 U
Pattern Feature (Circular) does not work as expected  in NX 8.5.3.3MP4* m9 c7 t4 L$ D/ K, |+ P6 g+ g: M
1989862! S  A$ N6 w5 `" a/ N& \* |
Extracting edge from surface is incorrect; n* Q" O1 V9 }5 t+ v
1990587
- C) O: `4 |7 T+ L  O0 K) ]Marking lines: x! \' D1 J; h: k# U& S' r
1990658
" _1 L+ O1 e; V! vPlacing profile cutout takes too long time6 B8 {. U6 W& e1 K
1990749* C2 e4 G! O- ~
Changing parameter consumed a lot of time4 N6 I; ~7 C' T- Y
1990992
$ N! R9 t# P/ ^! dugnx_caemigrate_tc  fails to convert old CAE  model objects to new CAE  model) |( K, B6 K7 ^6 ?
1992087
6 p$ q# q) J! b- T' iA registered save part callback can no longer be used  to save another part
5 ]: g) [% ^- C: b1992090. G1 N7 E6 L+ m. p/ \8 M: J# M- e
Save of transient context ASM  required, even for some non-associative & Position6 g. B4 u" b) S
1992418" V: t/ e. h, S# M2 G  z- _+ m# {
Electrical Application: MoveRCP_MemoryAccessViolation' V; i# x8 J$ k0 i
1992422
* S" V. `' ?/ ARouting Electrical: TooManyRCPs_NewScenario; J  _. F  M3 R! A! e) C4 l# n
1992923
; y, B4 A8 F% M2 T2D exchange creates unwanted hidden lines in views1 M- B& _7 W# \
1993237  ?8 \  m6 a) O7 a3 j; C5 v
Combine results command issue when performing products  or divisions operations( B3 M% ^% J: F
1993352
5 g  c5 e' [5 N8 b, NNX  Partfile does  not open
6 R& s* m' ^. f5 E* d4 |' h# f2 @1993412
+ r: Q) z8 q$ W, A9 YSecond refresh view in drafting cause wrong hatching  for thread connection6 ?4 I. r4 u4 r3 j. r3 j
19934464 v: W& z3 w: f! ^' V3 N
Doppelte Verrundungen  im Flat-Pattern
* \% J! [* ~# G& A1993534
5 W  x# `) T1 pUndo-function has no result on retain PMI, k/ O5 m. q0 a
1994309
  z$ q3 @& ^9 Q9 k0 \$ kColoring of leaders with type Datum at PMI$ r2 L; `) L2 k, d9 V/ D$ o
1994460/ L% n7 ]5 N8 e4 s
Toolpath  has Circles inside by using Motion Output "Line" when Contact  Data is O
/ N" T: Q3 v5 N; {- ~6 K1994657
& P! z$ ~+ J; v9 fMultiple break out sections cause display problems  with Exact view
- d; e" J( e  x2 b" |3 H3 r1994661+ M0 W1 d( j* Q6 u3 c! D
Hidden geometry is visible in an Exact Section View& n2 I- N- s/ j9 u6 R
1994690
( d* {8 N4 B6 ]% F& F* g, pMissing geometry after DXF  import
4 d6 c# H8 {. Z0 d9 Y: N4 I1994852) C* s" K+ d1 N
NX  takes long time for an edge selection.: _- j! T. x$ b  b; H$ @9 M" K
1994867
4 v; {! ~9 Q& X! l2 ?Bend radius not changed after changing Sheet Metal  Preference  F2 _, A. Y& Y, @1 y  ~  {( ~- @
1994925
3 Y2 _1 t9 G9 f" j) k7 T/ d- q' xBroken Interface Links/ @- q5 v8 s4 M3 t$ d
19950280 P( w& @$ F9 ^, {# H
Extrude of a 2 circle profile to a conic pipe (as  a flagpole) give incorrect res
; E* B! n5 c1 L5 B. S3 {3 y1995318
* ]' P+ S5 L: Q, n+ Y5 R* XPart Cleanup run create timestamp  problem$ ?* F+ Z) M0 [1 b
19953817 G/ K6 _0 E# ]  U
Broken Product Interface Links7 X2 M3 |8 q: K  k
1995412' P) w" |7 l0 l9 H
Check Mate Connected Part Check fails' [/ d) [' S- Y+ u8 }" }. c
1995455
4 |; u& j2 I7 {$ {& l! R1 V, _, M8 ~Transform did not work as in previous versions of   NX.! s; {1 a$ z$ S" n+ L
1995456
% Y* `8 q/ x7 m8 gIncorrect positioning of a Datum Feature Symbol leader  on a circular centerline
2 r8 t% |# i& d) U1995474
" J& }7 m9 p$ c) U' O4 SThis issue was when two concentric circle or arcs  were used as input to create the 2D centerline, we created an approximate  arc in between, and hence the dimension values were slightly off
* L& S" L6 u! `' k' J5 }1995535
! |" r: ^* @' V1 X9 N( |Feature Playback failed in NX  9.0.1 in NX  8.5.2 it works (2)8 ]* W, A( c6 _0 L. W) R
1995544$ L, V; J, Y1 t. T+ S
ChangeAngle.prt  Feature Playback fails in NX  9.0.1 in NX  8.5.2 it works" H& ~- E4 q* S, ~1 f& J% {
1995774
% L  H5 A( m9 ?( o' C0 J9 LNew part family configuration could not be created  results in com  error
8 G* I* G; j/ K+ Q  e# e19958231 |/ y# e0 h. H( R
Lightweight move collision detection not working for  certain JTs: w  J+ X# r9 ?* s- N! x; I
1996112
  h/ `, D# X( S$ xReplace Font with character font utility - cause move  of a text
" {- C7 Z6 V  s7 Y4 X4 j7 |3 V2 C1996187
; N+ V$ _: S. ^  o( y2 DImport Part imports an old version of the component  loaded in session
5 \( x" t1 G, o4 Q; A6 }# i( V1996473" }: W' P7 C! a" `7 K+ r. u) z! |4 ^
Law Extension Self Intersection$ i) S2 c# p" g* d) i4 S
1996714, v$ G. B9 p9 Q  I0 o
Unable to edit and reattach a constraint
5 }' }* v+ ]; i5 t2 |8 x3 P1996781
1 C- G6 S! d! s; I+ {" O+ pReordering of Features results in wrong timestamp( j( m7 e/ C, o" u7 c$ d4 \
1996783, R% z$ A, e: t: T5 u% J* V' Q6 L# w# Y
Missing split view for linked objects
, ~. n  U. i1 C1 R" n+ i" X1997428
. B$ r: v* J- C" |% WPart import with reposition leads to exception error
# q7 Q2 V3 X. {: D1997453. A/ d" J6 i5 h
Wiring slow performance to edit splines  of 85 harness in NX  90255 |; Y7 s+ i! R% s# }8 }/ v6 s
1997488
; ~7 w, L5 |+ u( W/ HNX  displays different object direction in linked part
) c! [$ L! W2 o% u; X" Q1997625+ k* Z9 ~2 d* B. X. m
Changing settings of view raises error: "Settings  are rejected because one..."
2 O6 g3 h9 ]! {. ^1997635
) o8 T9 i3 C/ n1 p+ iInterpart  update does not catch 'out of date' links
: v' |! `$ G( Y4 ?5 X8 X1 P9 i1997648
5 g6 S2 N2 k& a5 P% ]$ }; [Links lose references after synchronize5 w6 R; m* Z, f* [8 x! T
19977039 x$ Y: i( K( z3 W
Inconsistence of body selection in link edit window
/ |+ ~) u% D/ K1997890
& K7 }, t4 O6 p: u: O& ]% iPlace Part Query% G: j# t: \5 a6 u
1998095
% |. Q) T  b# Z" Z6 h3 U+ a5 [Feature Vector Malfunction Selection
; X% l/ x. Y# B1998118
3 J+ E6 k3 P8 s& T1 f  r8 FLaw Extension with Folded Surface/ I2 b! J3 t2 r/ ]$ m" {/ U. l
1998235
: i; Z0 U3 M) ^' j6 oAssembly opens as modified, even after repeated saves  and updates
3 {9 y& o, t" p! I) C0 d% j& t1998364$ A+ b0 N/ c$ ]$ F
Move command is inconsistent with respect to Datum  plane
& k. Z/ ^, N5 q7 u3 \1998413( j% c3 }( u) I7 E6 [- e7 X% ~
Show_Hide  does not work in specific scenario$ `3 d/ X. J7 T
1998417( c9 r" A# j# W( X
JT  import delivers wrong orientation of parts) \' q8 {. R7 e( k+ }3 V
1998420. z8 }* H2 M$ k$ ~' F* {3 M
Product Interface selection is wrong from Part Navigator  and Graphics
/ u$ n8 `4 `# k# F( w/ [1998521
+ I: I5 [3 T# `, a1 xInternal error in WAVE Geometry Linker
# S& f* F  R5 {2 M  N19985492 s; A$ a" n3 a7 M! j+ `% B
Lock perpendicular Leader for text not working correctly
, V% s7 Y: T* Y1 T$ J8 B' v# X1998551
7 Z4 K2 O2 c  Z! A) X. o: T0 VNull Tag error from remove spline  point after detach a spline7 V( G6 H9 m" l9 Y1 q: @
1998596
8 C% x" V% d( z  V1 Q! O( }Orientation of parallel dimensions changes after view  update+ ?. c. i. {: q! f  p$ U. Q
19986891 `7 I* V* m% {9 @
Fine Finish Offset in Turing produced wrong Toolpath
, Q; R" s0 P+ i8 m/ k9 r19987410 n. j8 c. x! c0 Z! \
Export to dxf  missing values and dimensions
5 N3 r( P, |! Z' k  t; n1998774
7 ~! w7 e8 ~! Z( Q( JUnable to get Reverse Direction option on Baselines  to appear! {1 P# p7 _/ K# `# `. C& w5 t
1998805
& _* v  {% Q+ ~1 K* K! K5 _Change in the parent part is not shown as Out of Date  in linked child part (PNT)6 P% O& d$ _  a: @% P3 e8 G
1998878
; P1 A& O3 d6 bNeed API'S to access Alert messages that are provided  during weld edits" R1 [! n# g( u+ S+ R
1998890
  v$ p5 C4 ~  u! DParent of broken expression listed as not loaded and  has wrong status" P2 S. @( H& C- a# _
19989018 M9 ]* Q2 h# M& y/ a
Pattern Curve in Drafting does not update when count  value is from expression: l/ m& r+ Q- Y* p- _
19989277 t2 P' \+ E4 ^  k/ Y
Change the selection priority of product interface  bodies
' _* X7 o! a+ a1999032+ A4 T* q( m, J) U) x+ \7 L
Replace Feature makes link 'Out of date' and Synchronize  Links shows 'No Change'
' e% S# _  q$ B& N( ^$ D; ~4 T1999035
' b+ {0 @3 z: d; W; Y& e- rClone "edit existing assembly" internal  error5 E: I6 d: j2 g* l4 F  p' O4 ]7 L' E
1999092- _" r* C7 f. Q% S) w- @  H+ W
Horizontal dimension are incorrect
2 y, `1 J4 M1 F5 H) |19991000 S  y9 |2 a7 E7 [1 w
No complete hiding of initial feature after extract  body
, V( |  |' g' \2 u5 l  w0 i1999129
, s% _# g, Y. D. c/ n. tBody measurement does not update automatically when  material is changed
( z/ c" h- [3 d5 z$ R$ U1 {# k1999130; b& `# J5 ~1 K" ]/ h
Incorrect out of date ANT column value after replace  component2 G+ p4 L( T  z: i$ J2 H
19991549 Q! [/ @  P2 ^
Nastran  import including Materialdata  NX 9 vs. NX  10
8 A) u9 j; Q: ~* H+ Q1999165
9 P0 l/ ?5 A8 dWrong results for profile endcuts3 H) d+ X* K' N
1999211
: n- L* X. i* U3D Tetrahedral meshing of the part is not possible& d! Q, [( E+ z8 t& Y
19992157 v# E! `& F. ^' q
Wrong update status with wrong synchronize reason7 ~+ k- W5 \/ n% W; M
1999224- x$ z! X. `, r
PdmSearch  Simple causes the TC  Nav to error  on a simple search6 p: T- G( e. X% O# y
1999226
5 F6 Q* L+ }: D1 ~1 Z6 P; P& }NXObject.HasUserAttribute()  returns unexpected results for attribute arrays: z% p+ K  D( Z: z- X2 _# j& @
1999233
0 T. `' J- c# x6 T" M! a9 o; e5 TCannot save part after creating render set by NXOpen  without drawing view# c" g  [3 h3 X, @8 \5 a
1999277" O9 \) J1 m) x+ l1 G2 A
Updating legacy weld elements individual( z5 J# B0 Z  }
1999279
# h+ W0 p: t4 ~$ rOpen by Proximity not working for certain JT  files
: I3 P0 g0 r  Z6 P8 d$ ?1999286/ Z# v) [! O, q4 `& V" E# q% }. p
WAVE Update very time consuming9 f0 Q) {% ^& N! T! u; t8 o4 J
19992952 K/ v7 j% K* b2 s
Update to End takes longer than in NX  9.0.29 g1 z9 G) U: D9 m8 B
1999301
3 q6 o# x' K& m- q$ [2 f5 i: X: SMake Current Feature is slower than NX  9.0.2.54 y" [; J8 b  l- h- M( g1 B) H4 ]
1999319* b3 ]0 e0 l. {
Open C  API UF_DRAW_ask_render_set_parms  and Wrapper fail with NULL_TAG  input( P. s8 b! ?% H% ^- ~( f
1999503
) m; {& V7 [( b, q$ A3 _Regression on exporting NX  to DWG
2 R' h( E+ p1 O' j; o$ y19995288 D& D& J; s$ `* h3 _
Fit Method Curve Quintic  creates wrong open curves when extracting edges
' Z8 I/ O* ?6 G, D9 U4 V2 u7 k19995377 u  }6 B; j) L$ q5 G$ ^& i0 J$ u
KF  %ui_comp_selection  OnInitialize  fails on NoHostPointer  with fix of 1983329
0 C; o/ ?6 o& w9 Q/ T! b5 X1999673
8 C8 {; e$ g8 E; _# L& B8 n- B1 z9 P2 J3 HLaw Extension Gap4 s. B4 ^7 S- G" W
2137349
2 `+ ]% E  x4 K8 Z, bCSW  : Retained 2D centerline mark is displayed at the absolute origin/ @' B5 Z4 _, n; K3 L
2137927
" K' K$ ?9 j2 P. oCPJ:  The result of 2Dexchange is not correct when drawing have UserDefinedSymbol
, Y' f5 p. P% L+ @2 [2148879
2 j* x; }% t: k+ n: HNX7513MT-Part_Open_Error, Cannot open NX  5 part in NX  7.5
% M% _2 L; t& ?+ j$ E" P2150055
, c5 D; X  S. b" g# Q6 x# i; O[Routing  Mechanical] Inconsistent results observed using Place Part
' Q. `$ ~8 A5 n6 ~1 G; V2 T6 E21551474 C& x% v' c+ t: U! N
CPJ:  Internal Error occurs reporting stock information
) I) o% {! D1 o6 X* C# o+ @! C2163939" q( c6 A# g4 [$ ?6 e  Z
HNS-TWS2 Redefine "Stock offset Point" vector  direction causes Internal error7 D$ R) h2 q7 f, ?: s
2164397( B# {- k: a5 G2 a4 F( m- z0 ?) M
HNS-TWS2: Replace 2 occurrence of a component raises  an Internal Error. N. d, ~9 \) v, e) ^
2165932; C0 H1 ]7 N0 d1 j
Routing: "Overstock" deleted when I "Detach"  and "Move" path point% C9 T+ X0 Z9 W
21670151 M" I5 n9 S4 O4 K& g$ n
i-Test : Radius Dimension is not placed correctly/ g$ N" V1 P) \0 m% @; c
2167956* M6 I  T% e% q0 ~8 p3 R
An internal error occurs when the user moves the custom  symbol  T; `5 ~, w$ n" T( N3 I0 g7 |0 z
2173887( l. o. P* O8 n, s# [
Routing: Cannot determine type of stock for specify  item. Dialog will not launch
! t; x' @/ C, p0 G" v. V/ z2182328
4 ]0 M+ C# U: O8 k6 X- ICPJ:comments  in "uf_object_types.h"  are insufficient+ _0 ^7 S' |  _) S
2184729
" X0 `: d0 p& O( E. @- X" e5 v5 f3 IInconsistent view display when executing "Invert  Shown Hidden"command, n6 h3 n9 _* N  T
2195219
- t$ _$ C) E4 d( f& B3 ?% I: M; K2d centerline only half display in NX 8 with GCtools  environment  b  m" v. f+ X1 A6 a% [4 J
2197682$ Q4 m: S1 r. f0 X
After play macro the color block dialog is gray
& [; s( W& H( f! V* x, J2198372
- I0 l; X. C5 A! mLine Arrow config  is not used dimensioning to centermarks
* S0 K& U( E6 W5 a2201567
( w5 [4 T7 W( F$ ?4 \Posting output shows mom_contact_point  error in NX  7.5" ^0 f  Z( b# W
2204645
! L5 W+ Z  \- i7 d2 eCan't perform additional bend to the existing Run  in sub-assembly of routing app
  H; A% L2 x) q: v2205140
* A4 R" A4 `# yuf5947 consumes memory and does not release it
) g5 s$ B6 e7 }1 b) M9 c) L2206496
$ C' Z; }' r" ~; a1 u( PCPJ:Cannot  remove a placement position when edit master
* X: k& \2 }+ S7 I/ K2206865
  b) k, V* \  g! o' d9 ITransform path disconnects the segment from path
( g) G4 P$ S( B4 O" t2211849: i6 I" I" T8 [/ b/ u7 |/ j) \
Minutes to Delay option does not work and "Batch  Processing" runs immediately* t7 B% _- c+ o; {6 O
2215177. |6 H) q1 E( j, M6 j
Spline  path cannot be moved by Transform path/ o6 c! u! T+ `  v4 ]9 w7 g
2216781: e! m% @( z( l2 b* D
Surface Finish Symbol of .asc  file imported into NX  8.5 is different with NX  I6.3
5 T% ^6 S- |5 r! N4 s9 `8 k% u' X2218055
) P, w% P9 ~+ M- v. N5 ZInternal error occur when I detach the path point6 [& K+ _; k. F) g
22182825 ]8 E6 j2 G3 a% A, a. q  z( x8 p1 E4 h
C9 Need "Show as Reference Dimension" option  in "Textâ200235 hotspot  menu
" L. A$ Y( Z5 m) p5 H2218340+ d! r8 h$ p0 k1 Z0 Y' k2 k: A
Tolerance setting list in popup  menu does not have "Reference"" K8 k3 A5 o, t! Q# {6 j: r
2219922
# l2 U$ U6 l2 a& W( HNX  8 has stopped working: e" c! H4 P* ^/ L
2220089
& q8 c0 ]- |' kTransform path moves routing objects partially if  other command is used in b_w
' a. O3 Y1 Z" l9 ^8 `/ Z% i2 n* ~2221345
  k9 k: r* C$ C5 N/ ~The control character of Note appears by "2D  Exchange"8 K2 u/ ]% I: b) c2 D0 L$ q( A' y! z
2222403
* P9 |3 D8 \; Z7 [( O# u* uDimensions move by "2D Exchange"0 `8 A3 O( b0 a5 }
2222405  E% a+ J2 @8 I! A$ |
Target: Select Body is missing a selected object is  consumed by another feature
! E( h; ~$ {* B* n0 e22225148 W' H' i- L- H: _; T) N9 g" m, Y
Unable to transform path by selecting the RCP  at bend; T! W2 v9 P; F
22234465 X: Q) Q2 m! ]
Spline  path point get created in incorrect position
+ ]8 H! n3 ~3 c/ X/ n' S" p* Y22237193 l- l3 `. }% [5 [5 P7 ]/ Q5 e
Customer would like to edit Jog by using shift key  when editing the Ordinate dim; Z1 _7 Z5 G1 r' m1 M; j( I  l
2224311
5 d7 [$ z+ G% V+ g$ G$ h* ^Added support to translate the smart lightweight views  using 2D Exchange translator3 j- E5 \& I+ N4 d# ^6 s
2226256
/ q- ?: j+ {3 q1 j- p, aCAM: Teach the meaning of the message outputted by  Create Feature Process$ [5 q8 H0 n: }, a$ D
2226295
+ F8 ^0 \/ K) c  g" v( c+ J' t+ nDisplay Springback  and "Output Springback  Facet Body" give unexpected results% l2 Z- W0 L* c8 J! Z
2227008
" H. }3 {: K3 {7 r9 jCPJ:  Internal error occurs when a point from spline  path is removed
* B( I7 O  y& a6 n2227411: a8 s( P4 J. t  I1 c5 ?$ M) D( y
NX  900-EAP2:Rapid dimension command falls
0 a, f/ {6 K4 C2 E% n+ I: |2227996; Q; {  |4 @% X8 Y; d3 F
LawExtension  outputs wrong result on NX  8.5.1mp33 x2 |) m) m5 K/ d! H. G
2228587: n) a* G/ {& S9 w$ ~* ?$ N
Save response is unusually slow, {6 y2 P6 ^* i1 o$ {# Y$ M: W# |
2228589
8 O3 q& ?: i: Z2 p& L; sBend Relief is not created by Convert to Sheet Metal  command
; a6 Q) S! O/ J) X7 i2229228
- w1 H3 q' q8 r( A2 ~Drawing  Update causes Datum Feature Arrowhead shifted$ W3 M. r) f/ e4 H$ ]+ L) d
22293312 d& ^5 `/ D: k/ f$ y# O
Leader is changed, when tryed  to change the style of datum feature symbol3 H) S4 N' A' z
2229335* E( Z$ s- t) z0 n, Q! e  @
NX  freezes when creating sketch dimension with selecting point of datum CSYS
$ q/ w# F5 m6 ~/ P) E' M2229408* h: f$ `) I5 s
Creating Branch Path is caused Internal Error/ k7 V" p) W3 i1 ]0 C: k
2229417% l" @5 R. Y3 D, D
Spline  Path options failed, G. {- s4 u8 k& l
2229425
: H" X/ U0 d; p2 v' I( [- T9 Z$ l- XAbout move of "Custom Symbol"
' Y7 T. d1 N' a. {; s. Z8 D2229795' X) p" q  H# C
Remove point of Spline  Path with Built-in Path component
' }3 B: t, z3 U) v$ \2 }  @2231384# \5 ?# [. [4 `, @6 J# G; Y
The Drafting Standard is not applied to the new component  part
8 \+ V; \3 C' X' D4 x! e3 y2231549
0 ?8 h7 B! t5 _5 W7 C& f3 k5 yMolded Part Validation results differ in different  versions of NX
% Q0 T  A9 n  E+ j* p7 V2231678) w- ?' I5 n1 V+ B
Assign Corner->Bend->Inner Radius gives incorrect  result for certain anchors
2 X, A# y+ G$ ^0 h3 q  I& G2231761( {" D* }1 b  n* x
Routing: Null pointer supplied to Routing error occurs  while editing an S-Bend
6 K" ^: r% }- o) d6 L8 \2231762
3 A$ g5 Q  k2 ^8 T" W. P8 O' j" FNX  crashes while trying to create S-bend
0 _: M& x9 I6 @5 f- b/ l2232056
; @4 `( ^7 j( v9 \Getting message "Could not get input entity's  class" while using ugtopv! E) |& m# ~" D& C
2232774
; a' C  x2 ^1 p7 P; n3 r- vThe arrangement position of Datum Feature Symbol is  changed+ T+ n" K# [/ H! x4 L9 l% B
2232967& x7 W& [- R* m7 ~: I( m
SM  Attribute already existing on this entity message while translating JT
  r( H. {/ H3 [' L; j5 @: j22329708 ?. D2 p" n' P, E
View dependent edit do not work correctly for "delete  selected erasures"
: E7 L: v& t9 R- s2 x* k2232989( A) h0 @5 g& _% v
[CAD]The broken Bend RCP  is missing in NX 8.5.3MP1HF
8 k" e; _: o1 A* r/ y/ m6 z8 E22333153 w  R1 `7 E3 w
[Problem]COM  error 80010100 occurs in NX 9.0.0
5 ]3 ^3 x, u) h( d; b7 \* z2233554' z; {# G) Z' s! b* P( A/ j+ @
The display of the facet body changes when the scale  is increased or decreased
2 x7 ~' d' r7 M. ^: _1 h' t2233784$ V' s/ f+ Z5 [
Phantom font of section line is displayed like solid  font7 o% ~* S7 v0 Z0 M6 ~8 z
22343021 t+ o' K7 B( S, _  m$ j: R
CPJ:  "COM error  code 80010100" error is displayed in Part Families
- _& i1 N. P! F' f9 m22345467 \6 j0 S8 w6 H$ c8 A) q4 a, Q& G
When you import as the Real Dimension "Folded  Radius", position shifts
" m. K4 T. H9 e  K2235058
+ x6 d! S5 e# E* `: JBatch Process does not work in NX  9.0.1 and TC10.1.0.1
" u) Z0 A# {! p3 ]7 @22352061 l, I/ @+ [4 Y6 x8 i# X3 q) I
NX crashes while changing the stock diameter equal  to adjacent diameter
( h6 m4 L4 s' X% n2235411
% R: {+ ?) x! y/ `+ YLeader line does not switch the position, when slide  a Text to left side
' p. s* T% t, K) v3 ~2235665' t4 @. K  [" x+ W, i
Can not exported to JT
! z1 _  U* j: p3 }8 X, |22357953 ~1 _" f0 p' X
User defined sorting order is removed
4 O" M; z* W* d6 i% |2236263, @- P4 F: @3 m1 v; h  e: s
NX900_SZK_OD Selected point of dimension is shifting  while open drawing in NX 9& \; g- X- i7 p
22363054 @5 c! \  e3 @+ W$ s. a
Spline shape is not reflected when changing Shape  Type from Slack to None  u5 t2 A0 M1 S3 j& a, F$ s" U
2236564
; V' d, W8 w$ @& m! x/ D8 u: |URG:Connectors  rotate while fixing path length& b; l& e$ _% i3 v1 u
2236612
8 y. ?, o% @0 Y5 @+ UThe editing contents of the "Custom Symbol"  are not reflected
% V# n/ a- j. B4 r2236655
# B( l. J, [! @( ^' ^" U* [2 GA view label letter cannot be changed into an unused  letter
, H9 j# B- F* F8 d* [9 O, Y% u" S  X2236665" V4 i+ @8 L0 K8 d. k/ [
Internal error occurs when a spline path created with  slack is edited
6 M! M5 r8 {$ \8 b2236957
0 Q* ~+ b( X. H4 u! ?iTest: Adding a path point causes an update erro
( [1 g+ [/ R& w( B2237709( g0 `5 K$ Z+ ]8 G( Y$ m* E7 t
Autoroute fails in Electrical Routing NX 8.0.3: "Stock  not found"* x  m  x2 E( {) C; M
2237830
, I/ [/ Z* g2 B4 }& TA part cannot be opened with an error "'A deleted  or invalid class id was used'
  y: f  v; H  I2237851
9 y; e' j4 q+ o# `+ U7 C6 |Batch Processing does not work in NX 8.5.3 and TC9.1.2.4
( r8 `% u6 s* w. b2 c2238399: a  W9 o: G8 |+ H8 b3 |4 L
The length of the path gets longer than length between  Ports% Z$ v% C$ |2 t7 M" O
2238690
0 e2 V* K# o, c; j; Y. w0 N0 q- lCPJ-VUP: UAF Failure(NX 9.0.2.2) Update warning for  Convert To Sheet Metal
8 _& d9 K% n2 Q+ P" ?2238751
" H+ A6 k) g' q" zWhen export the dxf format, position of view is different8 E/ T2 A$ t! @' h" M6 ^7 ^
2238803
5 w4 s5 _. c, }& D& e+ }Exactly the same checker is not identified in NX 7.5  and NX 9.0! W1 C- Y$ Y5 w
2239326
9 k7 A6 h1 O9 v- m9 @Revolved features and the Tool body are created when  generating the operation) ^$ A* N' n3 B; A. e6 L
2240126) F+ Q, ^/ O' N9 {8 T' T
Resultant shape of Convert to sheetmetal differs from  earlier versions in NX 9
3 ?- Y7 n/ O. s$ w2240189$ X+ F, B, K; C7 U0 r) v2 K% ?
[CAD]When the spline path is subdivided ,Space Reservation  is deleted' H2 D' D0 S# D% [" g% c. v
2240291( u- s9 ~/ B. J/ g. P' C( Y( j4 E5 ?
When united component is selected in PNT only target  body is highlighted
  l# z+ z/ l; b8 n; l8 g9 Y- {! F2240560/ S% u0 t: H) S( ^; J* v8 Z, |4 ~
[CAD]NX crashes while creating a connected spline  path with space reservation
* }& C0 O% f+ p! ], L  W+ U" p2240574: I& }# M2 A1 E3 y
[CAD] NX crashes while subdividing a spline path with  space reservation
9 E, [6 C# {6 u9 S& m2240989
* _& w1 G* P$ m9 I$ `The tool and the holder collisions occur by using  3D IPW
( Y( E* F) M9 r0 p; J# c2241153* s4 \1 ]# s+ S  Z- H
When existing sketch is modified and switched to Advanced  Role -Internal Error
, t0 N" F  g& h6 u2241162, N( F6 l( W% K
Unable to hide tabs in blockstyler through hide method
2 Q0 b) h3 r* |' _# F+ J3 y2241172
$ Q( `3 h' a4 P1 O5 nError recovery completed for the following error,  while to plot TIFF image- q' |. Y; X( ~  l' v3 t) o
22412469 L5 T# ~. G: o2 }
File in use by another process error occurs while  saving part file
  ~3 R9 _9 o0 z2241318
$ w) Q9 c4 g' ?. O: ]9 A# rMemory access violation When trying to change the  role to "Advance"
6 R# n3 `) ]6 ?( U2241356$ H, u$ Y( ~# {. Y2 \5 x
Density value "1e-006" or less cannot be  set in Customer Default
6 J' B! Y  p* P2241431
" Y2 w* k+ o; Y- qIncorrect Unbend output for cascaded Sec Contour Flange  on curved edge
/ i& {' V- H- q+ [5 S$ w2241487
1 C: \% `, l+ F  x* kInvalid Hem flange output
9 x, g# e) J0 Y% B5 ?2241894& o/ d: k; @, S" q+ E; M/ c
Show hidden objects in comp with Ctrl+St+K (Show Selected  Objects) not working( ~) B0 s+ j! T; x( n  d2 ]. F
2241920
' T- r: Y$ g/ I9 E1 J1 RNXOpen.CAM>CAMSetup>TiltToolPaths() gives an  exception as "NX error status: 1"
* u/ z8 ]0 I+ Y* O- B2242262
- B) A& C9 @6 f  P9 ?[CAD]Law Extension face has a large gap than tolerance  value for the input curve
: k, s3 {/ h0 R5 ]+ n- v$ i- r- Y% y( I2242291
. y: w: e* [1 C" f5 R* ICannot create single sided Cylindrical dimension with  outer dimension arrow2 s4 z  p3 n" n2 [' i& o% O  C
2242338: K9 O% [( i, o! F$ \' G' p
[CAD]Selection intent of Trim Curve disappears in  editing' O; }( Q8 d5 \& `) B
2242373
: ~; Q+ }  e: p* b) a5 j! p3 {4 W# eCannot create Jog to Linear dimension which is created  for '0'mm distance value" e, Y' O6 H8 P+ V
2242385
6 a& u3 A2 \! Y5 X. `) }[CAD]Law Extension:Change distance tolerance,after  vector is reversed
! W: i8 H' i7 M, W# G2242392
1 |/ c& s/ {; f+ B) iSome commands cannot be found in Japanese env
0 U& }' A0 y' A) n6 \- x- m2242424% l% _* L- g0 G, k) o) Y
Hem Flange does not work on specified edges with "Material  Inside_Outside"
; q3 F6 r5 ?+ _' m0 J1 f22426350 r3 o1 O$ B/ ]
If the display of an object is changed, it will be  in the status of OUT-OF-DATE% F. C# o" {0 X* w1 P9 o1 m
2242764) c9 A+ N* G$ p+ w4 q
In [Merge Disjoint Facet Body], facet's Shading display  changed
  F/ b5 }  T0 ?% \* ~2242938
9 t3 z4 a7 h8 n+ H' m  {Spline path's shape type 'Lock length' gives incorrect  result
  P7 x( }0 w/ L5 g# G8 C# u2243057/ v" }* Z% R) K
NX 9.0.2.5 Power drafting issues after import of AutoCAD  file
* w9 g8 [& c$ V; M8 }/ r& e0 k2243201; S8 |1 N/ w& q3 ?4 h8 J0 I
Match Edge gives error as 'unable to build surface'  when ref edge is a line
2 N3 U" F0 f% m6 ?2243238/ [, L" E' o/ Z/ F4 `
Shipbuilding weld seam, drafting command doesn't work1 b, |, q% W/ y; d  i; F
2243565
8 W( Y: Z1 R3 VCXPOM_wrong_class Error occurred while creating setup  in NX CAM" x9 y4 h4 [* Y/ r
2243707
6 g3 P2 F& Y/ ^" O4 ~Ordinate dimension-> Place Automatically behave  strange after drag dimension3 ^& [) I4 M  D
22438190 X* m9 J' C! Q( j% Q  n
The name of "Expressions" is not normally  reflected by "Reuselibrary"
) z8 X( ^+ |& s$ c# c% C2244840
6 S6 W& B* y$ U- h8 iUF_DRAW_set_view_display is failing to set hidden  line width as Original! V2 a9 e4 b, u- ]8 `8 N* v% g  {
2245086& M2 G9 p1 U+ N, N4 l) P
Holes are not created when we do [Subtract] with outside  work part as Tool( C. ?9 c* g* E) b
22454932 o) ^; j* z7 F/ k/ c
NX cannot change History-Free Mode by Internal error
; n( {7 j' E  ~9 d, T) ~2245777
, u8 a' y  e' l5 k% ~( QReset occurs to Transparency of solid body when using  the MPV
. m6 Y5 c; R% Q2 f0 k( Z; r22459482 U; w) t- o2 w+ q- q
&CSLANT does not control text angle for NX font  created in NX 9) H: Q& ]2 h9 h. b5 L
22461254 K" w' w8 k" _2 x) Q3 n* ?& }  D( C
The thickness inputted as formal has changed to the  constant: E; k2 F2 c6 F; T
2246501; y4 m7 a2 d/ d; `7 \# U
When Descriptive Part Name Style is changed, PartName  of PartList isn't correct1 `) e. M2 H  O. f0 k$ E
2246708
& N: Q5 W9 o/ H; a% K$ {9 IIt is very slow to opening a motion data without loading  its child dat
0 V  l; f% t4 z. W2246872( Q6 h  ]7 x' [- E! K  w  g9 w
NX 9 hole table does not recognize all holes) e, R7 p( O( ~: b3 Z& [% Z. }
2247291
4 L( \$ h  `/ B3 B2 IWhen I execute Part cleanup to drawing part, NX change  position of Note. ]& Y+ r5 u+ E
2247292
* E3 ?% p+ Q4 ~1 p[CAD]When I execute Part cleanup to the drawing part,  NX break Note
& A4 e' s) u% u% ^0 }6 _2247496" E6 v7 _, m: O% U0 B, ?3 t/ m( K! d
Update Error occurs by "Merge Module"
( Q# n3 L3 U; M2247508
& m+ l, O- J& I- INotation difference in a filename extension pull-down  at import I-deas ASC_DWG
: F/ O8 u3 K5 ]- T2247535
+ D7 b. t: s9 o6 L4 tDrafting element is selected unintentionally
4 d4 x& v1 z$ t3 n5 e3 @2247548
* G# @% i1 h6 ~/ S& AUnable to merge facet bodies by Merge Overlapping  Facet Bodies# I) T# L8 T5 R5 O% `
22475937 s: W9 i) V" l! `
NX display line of spline that is made by studio spline  on the drawing
8 l9 l! _# l9 S6 H22480720 N6 z9 B# W5 n0 s, x8 m3 j
The created trim length exceeds "Minimum Length"  value with the warning message
0 r4 l- U* m6 w3 a; e! ]0 X7 c22482910 z6 g% r( ?7 o& z
Cannot select lines after export 2D part with no associatively  to 3D part4 H% R, _9 A, Z, t
2248471
' o- B- Y/ l0 F1 M. m* K1 m* DAlert indication is not displayed in PNT though parent  body is missing6 B7 K9 h0 @  P$ H/ Y2 S2 G. C
2248732
5 N$ L' Z, g7 k/ e# @+ ~9 LThe behavior of Check Regions of MPV* G  `0 H- {) _0 ~' B6 a8 ^
2248810) U0 n& i8 s- U+ a+ ?, o9 _
Unable to convert all drawing sheets to IGES in NX  8.5
4 `( v' {( _7 G: N2248814
( Z3 k' y) B! q$ `NXOpen C# Wizard creates external (batch) program  that will not execute; S3 ~- t0 \$ v/ b0 U# {0 g+ b
2248853
2 u( V+ ]: S- X5 u! m0 ~7 K# ]3 R" XExtractFaceBuilder.CommitCreateOnTheFly throws an  error4 w  x) g& ?: R- c1 v
2248905" y  q  b3 j1 |1 t# s7 B
Wrong translation for "OPEN" in Reuse Library
2 ~* R# l! z! z% w$ Z0 X+ l: J( [4 g2248909
' V8 k& p% `- e# MCopy Template as New Design in Reuse Library is not  translated
% t  N3 e/ G% i, I: l" H22489369 r: u# t7 f+ N+ ^' o+ v
UDF body color display changes when inserted
% y4 a. i; J4 S* z( E; Y) F2248971
2 u  X  x$ I6 C) M& I* ZUGMASTER is not assign when saving as New Item with  Automatically Assign option
) ^9 L; Z0 _& X2 S2249161
! c4 Q* M: J0 \6 UAttributes using expression from Reference Text become  incorrect Value4 K2 }+ C+ O4 A
2249327$ o5 T: E3 a' l! K  |
The name of body changes by split body operation2 ?# U% _& J9 @9 W0 Y& T
22493288 ?. ~  K) y* G4 V
The element in the non-indication layer of UDF is  displayed: y/ X3 y9 b" U& H8 X
2249356
$ L0 \% U( L* r) Y0 cProcess of creating a dimension using "Rapid  dimension"is slow9 p; d" \/ e  r. E- w; b; [7 k
2249493
; _/ s% p) [  V* JCannot able to select the same dividing object datum  twice in "Divide Face"
9 e5 m! r4 }; e+ M) g8 l2249504
9 B8 }, e$ K3 n" eAngular dimension is changed when execute plot- Y3 l3 C9 D2 f' G2 ^6 K
2249529: i; k; I% F/ K9 P1 b7 Z
When exporting 2D to autocad, balloon circle disappears, _; ~9 E! X" j+ u/ q! w/ M
2249546
, a& l2 s# R# CNX output wrong result with node information- R; s& X8 ?. G/ g( ]8 U
2249857% D4 [% l4 r+ E* @7 P
Can not save the suppress information when save drawing  file6 D' Z9 D/ t, u, m
2249910( J* h- A- `3 X1 \/ z: u. r7 ]
NX crashes when double click on "Expression Check"+ G8 O- h6 u! r( Y& h8 b
2250055  l3 }( n! i+ [/ l
The Vector arrow of Ribbon builder is not displayed
( K& U; E0 j5 D2250205' s2 X8 j: I* l2 ~
Problem when inserting in [Note] the expression including  2byte characters
5 Q  m* q+ U: z: j+ F/ S2250337- c& D5 a! O1 T5 l0 f
Extra NC path generated in Flowcut
3 O, U  t. V; t. t- k9 h' b2250351
% u7 r& J/ z' t. cNC path twisted in particular area in flow cut ref  tool operation# h8 ]$ {6 D1 k- E
2250474# w9 V  N, p. G- u! [. W( p
Non Uniform NC path generated in flow cut reference  tool operation
, `7 W2 b9 `+ m7 N2250476) k9 P# ?# s+ Z8 N, F
A extruded tool path is created
4 s# K- K4 @5 x* I- r9 |2250573
9 K1 T" g5 F0 ]Dashed line changes to a solid line by NX Plot& K7 {" K: z: H8 G
2250687
: X, _# y% u- M* eIn Transform, Mirrored Lightweight Body's (JT) normal  direction is inverted0 I6 @0 ?/ @7 t7 @
2250705
. |: C6 m8 l; t# ~. X# d4 G) X[CAD]Law Extension create incorrect surface without  error" k/ I) Y8 z1 D5 E! `
2250808- t' I; ^  K1 W/ x4 ^; y& x! ]
Exceptions occur when ug_body instance uses 0 for  color in NX 98 ]+ f, ?7 \/ x- J7 Q
2250942" R8 O# V/ Y* {2 {/ `5 V* p" U
Engage of non cutting moves is cut over
+ l' {( D& g2 l0 _2 y& P% Q9 e' G6 y0 I2251030
6 l+ U9 M9 B: u! o( m" c  T. M% PAdjacent spline path's shape gets changed when double-clicking  a spline0 \. s4 `/ ^2 ^0 e8 p' X# x
2251097
) z- e* w- \" K. ]9 QInconsistent about the display of SubCategory in Material  Information: x/ @1 M! f& G1 _" x
2810191
, o9 m, }. L. i  A1 A2 BBallons  don't update during the update of a part family member3 a' `' S  |/ ]0 x
6248511) Y) g! o; [' p( g+ W6 a
Bend taper fails if applied to bend on bend
- s% E) p5 g; U  a( n8 f+ n63050809 Q3 a% u5 T2 W
Note linked to an interpart expression rounds differently* h9 r) z5 M3 t+ w2 h
6386183
1 i! {; N+ A4 L* ?# {& i$ I2 eDatum associated to stacked FCF produces gap" @# C. K3 L' z. ?
6400356+ [7 p" T  Z! r' e: C, F
Geometry Linking Failure& V' {. I3 y3 B
6424822; [! Y8 P" h: x
CenterMark referencing ThreadCircleSymbol will be  retained in update
* c2 r2 N# u! o1 I6472032
$ Q/ q# B6 M( e2 \/ d6 ZCenter marks become retained after updating view7 Y& p7 _, _. j2 b5 u  Q1 J/ ~2 t7 y) @
6487324
9 c% u+ K6 y- d! Q* {Invalid section string definition
: M5 ~: |/ z4 E: c3 {6496575; }& J, T2 b0 ]( j5 [9 m
It is copied by wrong distance
3 k0 \4 a+ M- R* Z2 \; C$ b6498114) `2 `& Z, o4 j& p' j
Unable to create angular dimension
; A* y7 G" b3 I" k& b; |+ x, k4 x, b8 f6498459% ^  I; h* J) `: v
Routing: Neither endpoint of segment near RCP
" x5 `, ?6 L8 \$ v% e4 b6499312
2 z" V2 G6 t. ]# c% oInternal error during transform path' y3 g2 p3 N/ @
6502266
& y' @: H* ^. \2 f+ ^Angular line at current segment option not applying  Fine Finish Offset correctly
) |! L; n: V: s# t* ]7 L6559724' r7 p3 b' ^' v2 E  x+ a) }0 n
Dimension missing gap on centerline
& N2 t; P  }- ]+ x6561267% E' [+ I, ]1 ^% Y0 j
UDF with Feedback expressions - Apply does not create  new expressions( R) y$ T1 H7 Z/ S; Z
6566556" {& h+ A" g* `$ g, T
Retract move not in Inverse time (FRN_G93) feedrate  mode. Engage and Cut are
/ W& a7 ^( z9 f4 L+ Z6570966- w8 b& ^+ `( C
Fourth axis limit violation fails and then outputs  incorrect A word% P7 \. }0 ^4 o+ G: o, S
66036368 _% a- _' a. J+ o. u
Planar Profile tool path is not following the pre-drill  point
. e5 n; w$ N& L  s3 k4 O6631793
# D: r" r4 ]  H* ]3 S- BLinked ports created by filter setting Face_Two Lines  are not have associatively( V) i* a( h% ], _( g6 A: u1 [
6632138
7 r* ?0 [* {+ h$ E/ ]; q* |! HAssembly Exploded View Trace Lines do not translate  into sidecar.jt8 M$ [$ @: P7 n! F# r; v. x/ |
66342326 X3 D7 Y' r! s6 L" ^
Drafting dimension extension line gaps not reliable
5 c1 @9 G6 p/ n+ @( ^% i7 O( ?6647078, ~- W/ P+ s. ~  q
P8.0.1 - Transform path on routing branch removes  corner bends in other areas
0 F1 e) ]! X% n6681423( p) c; h$ w3 O5 F4 q0 K
Routing corner angle dimensions are off by small amount# ]9 ^1 Z- N- K, y6 z2 E
6687752, j2 ]! T5 O( D9 X
After generation the main dialog has a new option  'Verify Pre-Drill Points'
# V2 V7 F( E0 J  r2 e. i# o$ G6700641* V' O3 K: E+ O3 W: i- z* u
Unable to use function "ath Length Annotation"-part  of Drafting module in NX 7.5* m# [8 o6 G5 Q! |8 E7 ]6 H3 `
6713291
1 j2 [9 b6 i( e* J! K8 NShow = False on a Tab Page hides container items rather  than the Tab itself
% C, W% Y" ~6 `5 R) E6717554
2 b- ^) s- ^4 x, J: z$ P) C! }% j6 eAfter execute Import Bend Radius Table command, it  could not find Bend table6 m. G; M5 e* Z3 ?: C3 c; ]
6718129: J* ?0 {1 P4 T2 T* I
If segment end RCP selected on Transform Path, it  was moved only RCP4 }) |+ }1 Z2 k+ {1 V# }5 G
6718165* b; b) F- c* [  A
Number attribute value rounds when added as a relationship  in the Note editor6 |7 I5 I: ?7 Q; b( t; G
6718800: i/ B2 P8 k6 ^" h8 [+ T1 B
Replace Stock is not working if overstock created  only with Routing connection* d: i+ X$ e' y7 P
6720314: B& c% X: A4 j# K
Incorrect stock display for Transform Path from one  routing path RCP to other9 B( R! I& g) ~# Y7 n) _1 D
6720951( ]0 V& c: V7 c- p4 u2 U" d  B# x" x
Transform Path is not working for distance value measured  by Measure distance
+ P7 G  H* L4 Z. L; ~) e6723898* k% ?" p: I# }$ R5 _. y! j9 `. \
Cannot use Discontinuity RCP as path start point! v; d5 C$ B7 {$ l; y$ q; F& S
6725087
3 r! z5 I2 c" W6 V9 FPost builder; not getting circular moves output for  G18 plane
9 H/ R, }; o- `1 \0 V, g3 C4 |% }6732556
0 @! S7 G! p- Q- G4 O( \0 ^When creating a formboard get the message "an  attempt was made to associate ....
9 U2 z1 x5 e5 `% A! T' L6745860" R0 c. i( x# ^
Define Run-> Member Items does not auto-select  Path
3 d: I& j+ v7 N3 \6747193
3 }- p" t! w+ w& PTabular note cell text is not updated with attribute  value after import part
, A" c9 h0 Y$ ~5 f; h: I. A6751549
% P( i" W* _4 @( S  E  e* ATransform path- incorrect results moving "TEE"  & branch along path9 H# S8 E9 a: K. @
6754338
$ c# H& R6 C6 e; u, ORadial Bend is leaving connector and removing stock  on Formboard  Z, e' z( J5 l
6776759! G6 Z9 {1 X, e& w; @- n
The same title cannot be used on two different attributes  error opening assembly
( V$ W1 {* w4 m% [. ~5 y4 g: Q6783887& Q! U& Y+ {/ C! b  u; [2 N/ E
Transform Path move or copy does not succeed on entire  harness3 O7 ~! B6 ]% s$ q
67879194 F- R- [  b* ~/ v$ y
Unable to open part file due to same attributes of  different type
0 F  \! C2 d4 S5 D- H- v$ R1 T* Y6792884
2 }9 v( E4 I. E5 WEmpty line is removed from posted output file and  when viewing in synch manager
. e4 p. Q6 |- _6 E6796983
1 l* D0 W4 ^# t: g' J2 L+ KCenterLine is not adjusted to manual boundary" \1 V2 F9 H0 d' ]' n8 u
6802602) V0 R& J9 w+ G) z/ d! d  \* L
PMI Datum Target: Symbol leader not associative to  point in assemblies
1 F4 K% j  o: b5 v5 t0 x! U8 z& L6816157% \- y! _+ g" Q. ~  @
Routing Length: "The same title cannot be used  on two different attributes"
: _8 }1 T+ W* J3 v6 w$ b6832974
2 S2 F" v0 @( R7 ~# {, n: {Rotary axis incremental and sign determine direction  causes wrong output
: ]0 L+ R% I. Y5 Q68446699 |2 n; M" r3 ]+ P) ~
Spline path end node hanging when using Control D  in Routing& `  K- @8 ?4 O5 ?& n
6851770
8 R* r+ i& ]- B& y  oPrintPDFBuilder Commit fails when used on a non-displayed  part! l6 [6 d- q) u2 e/ n+ i7 E- Z
6857961' f4 w8 s: R* }% o! g! v. ], q
Routing Run Nav Place Part not handling attributes  correctly
  [4 R' ~& E; [0 ]) {% v3 e" q6867051
, ^# N& _  W0 S, L# \% t2 ~Incorrect results from Check-mate "Report Features  without Children"
5 R6 r# W8 r& A5 N0 ~8 u5 u68732821 O& z8 T. T% t
Predrill Start Points order not followed in Planar  Mill Profile operation4 f/ L5 k: ?) [4 a7 u! w! U7 C- {
6878962- M' i' K8 _7 x+ X9 W
Ordinate dimension will not associate to centerline
5 S* a- a3 Y! F7 v2 v7 i% n& y6879827
. N# A5 Q' p% R8 d9 p( eBoundary order not following Region Sequencing ->  Follow Pre-Drill Points
) [" J, l4 l/ [. ~! d+ Q/ L6880816
, a( U  ]. r) L: A& _$ N& ]" xCheck body not being recognized. Tool is cutting through  it9 o- e8 |+ r% f  J
68867128 W0 |& v! Y# K. G
Error saving JT: Failed to import remaining data from  foreign multi-CAD file% F% C6 ]" w6 \2 {' o, Z2 d
6888187
' }" k2 P: d1 z7 H( d- J- _* KDocumentation specifying nx_pmi_attribute leader_leaders  leader_value is vague
' e6 g7 P. I6 N0 b, I& n6888421
0 w7 n0 ^3 F& n# Q/ iReference style on tolerance pull down for dimension  edit) X8 J+ F( B, M2 @
6891680; b0 y- W) ~5 q/ w$ J8 ~; m
Autoroute fails in Electrical Routing NX 8.0.2: "Stock  not found"! Z  W* v5 \( g9 i( I4 W- F
6892275! C) G+ [6 i5 p9 \* G; R
Transform path on a RCP creates unwanted edits& Q) w5 R: A3 o: K9 ]! {" q9 c
6892318
" h8 ?' h% l$ u4 z: IAdding Bend causes undesireable edits turning Transform  path& Y5 F4 J4 d3 @! _4 _9 G2 j
6893189
" o" I, \6 l/ w% p% \. S. X5 M/ R) ZConvert Legacy Spline to V9 Spline on Selection for  Edit2 Y9 }; {' ~! X' A
6898282
, F  h" I. X6 \6 ^Mechanical Routing: Transform Path not updating edited  path as expected
5 e( f2 P' d' `5 D  l6907497( C# T) t) e: Y( V8 e! P: e
Dimension line passes through appended text when dragged
" u" F0 E: V' L  q+ N6 g. u6910642
- y9 |( c' x& s9 j1 gTransform path affecting paths down the route
# d1 B. \# N+ `$ Q* ]+ Y4 c6910694
7 [2 M7 g3 I9 a7 g" ZTransform path does not dynamically update paths
8 b% O' n1 {" {3 Q. M( o+ X3 n6925479
* d/ i2 K; ^( I8 N1 v0 KCustomer Default "Teamcenter Ship Name Format"  option for Item Name vs ID
+ L+ U5 N7 E! z  s: w( t69326442 g  I' T, x9 b/ n$ n
Lock axis with right angle head fails
9 D5 Q: [3 z, }' y8 S6938319  Q, |! R: w' X2 @% S5 |8 v
, U: N7 P7 Z# P2 A" T/ p6939350; ~0 K  ]( `" K( D
2D Centerline used to dimension Flange radius sends  leader endpoint into space
- D( G9 y8 M# y2 ]* a7 h7 A6940940
' Q1 Q4 v# J& Z$ BPossible values for mom_rotation_mode incorrectly  show ANGLE instead of ATANGLE
) \6 v0 ^# ~! q0 ?1 S, l( o69421940 e) {4 ^& J8 i0 a* `; _# }
Getting incorrect results on stock bends when transforming  path_stock
, G6 K+ U9 E6 u& z0 ]/ O6955239
3 S- }1 ~+ v( o1 vLaw Extension Builds out of tolerance with no warning  or alert6 m$ z! m' |' B. ?! [
6962826
' Z( j9 S6 k8 [8 o$ u  }( F  N. XNull tag not allowed to edit ordinate dimensions
6 ?, W* i3 c6 E8 v- o# z6968811, I9 r2 c: |, P* y
NX 9.0, Edit Spline path "Detach" is not  available1 C) r  B1 o  }7 G4 x
6972365
- w& v  [. z7 Q. }/ B( j3 u  }% YPart Cleanup (Delete Unused Fonts) changes the Symbol  Font File Font# i8 Z/ ]5 U# i9 e# H. t4 ~
6976274
- L' i, y! w) a% ^- ERouting stock inverts at bend corners
/ s5 k3 B# I( x, _' z" g/ z, C8 w6980142: x0 l5 M7 |& X. \5 H
Unable to open CAM file in NX 9.0.2 and up
$ h" _3 O# {$ ]5 |4 ^6987003
; \  b5 |4 f9 Q4 URouting Assemblies are Modified when opening in the  context of a Reuse DE8 k: N5 {% G3 ^1 Q( M: N% N) G
6987730. w- Z1 h! z! F8 K7 _/ P- E
NX 9 Drafting save Work Part only. takes about 1_2  hour
, I3 {  M- H2 u9 k# m" w69885032 u+ F9 u1 z% E! u* C; {. E
Circle_Helix moves are not linear moves in NX 9.0  when 840D UDE Compressor is ON5 j' o- h% N- z3 p* _+ n
6988562
7 a0 _' ~& f1 z8 w7 x8 y3 IAdding support to translate the smart lightweight  views using 2D Exchange translator1 O0 n- C. Z1 M5 y
6991672
" O+ e! Q' |; c# t& yOpening a JT file, what defines the units _ comps  are scattered
. M% q% I" U. n' h; C0 f$ _* Y* H70011602 W- I9 J# ?8 F2 r+ ~3 ]1 E
Part clean up "delete unused fonts" switches  the symbol font
' r% Z# S6 g8 J71043926 L+ j9 Q2 K. Z- R4 ]' S6 [
No information on mom_operation_has_path variable9 _& H5 Z0 U' p) ^
7112865
. o( C* N2 N$ O1 I0 m& X; NExporting face mills to update libref  fails to update - creates new libref
& }  p7 X6 s2 \3 ~: k$ ]7 b. d7121536+ ~+ D: P# d  ]9 P+ T1 ~
If a block template name begins with a number, NX  issues a parse error" }- V( Z; }. K
71271936 ^2 J# T9 r# K
NX Thicken not removing Gashes: h7 @# P, _0 B# ^, E$ Q) q
7127252: u' B% e/ |3 s
Routing Electrical - No tangency created when creating  a branch path
! K/ ~! }& P3 W# g! d3 V2 p, s7127258
& F, n( k4 C9 Q: \( K; DRouting Electrical - Extensions at fixture ports can  cause RCP to be offset to e+ n+ N$ u" z( B" z1 s
7127261
; w' `0 ~) y0 z. g+ CRouting Electrical - Duplicate RCPs  can be created when connecting one spline pa
0 f8 Z2 A8 _1 o. t* F7127797
1 @# J; N2 Z& ^3 [SME  bridge curve UI dialog memory issue
- H' B% c2 l$ z7 c7128731: C" Q9 d' {2 f$ x, @8 h
Engage going opposite direction when comparing NX7554mp10  to NX9013
; H2 t- [% I+ x6 g, X7131552
4 v& x) y' d3 @) w7 o/ m3 @Export CGM  or Save drawing CGM  data is creating large files
; o- Y$ {0 U8 q$ W& d& c7132153
8 F1 s3 m  r$ r6 _* {Fixed contour operation cut region tool collision  avoidance gives internal error) F& j5 T2 L" A
7135193! h7 ?- K* Y+ `8 i+ ~* W" I3 M
Internal error Subdividing a path that contains Slack..* Q& s2 r/ g9 z" X, C2 O- _
7141930
4 w8 @+ v* k6 Q* kExcel automation com  error code 80010100 creating part family  D8 f0 X7 |* `" B! o+ M
71497358 h" T: j2 `2 A/ P
Update formboard will not save last update7 e% y/ g5 I0 X, o
7151420
& N. t& G# r+ `, ~& x6 H: V! EUnable to export PLXML  netlist
4 H: Z/ d) Y+ A  |6 {7151453* H0 M5 y- g0 \
SIMPLIFY PART HAS UNEXPECTED RESULTS
( H) m8 {) f3 C4 M71534681 t. o; k0 g1 K* U( ~
PDF Export of Drawing has extremely poor performance
( X7 c3 W1 x1 T/ O1 h1 N7155067* P! ?3 j1 _9 F# M
NX: Part is showing "Missing Reference"  alert after interpart update
( K/ _) B; }# n, U/ y7158156+ _3 x" C( e( w* x
Tool path lock remains locked in current version
/ c( h  `8 z8 P) a7 J7159379, g* _6 B- `2 K+ }$ P: ~8 g6 Y
Given object does not have the required csys  matrix to create angular dimension
+ W' F8 S6 N" x! {/ Y7162788' q* C% ?( ~4 x- {* A& z+ P! a
NX 8.5:suspect geometry warning with no tool motion;  nx8.0.3 has tool motion1 ^% U+ I" w6 q1 U  a. j
7162958& Z' V  i, j! t. I5 x
Raster image causes Internal Error when creating Part  Family member
/ G5 V7 D/ \% Y" P' Y7166681; U' g( Z: [% y( Y( H$ E
Reusable object created result in user defined expression  name lost* K9 ?8 S7 g1 m
7166980
, t3 n& h: P3 C6 g- I3 V- HSmart Lightweight view performance issues' J" T7 v7 d+ |0 c6 l, N
7170902
; \& W1 \: M% K5 VImport plmxml files into Electrical Connection Navigator  crashes NX., U" R6 i; v2 G
71727118 C: A! M7 t  u2 d
Properties attribute column width is not maintained  if modified
5 j% y9 B  e& }( E4 e  H7172738
9 U# j/ W9 W) H9 _Contour profile operations will not generate; operation  terminates
& T( Z- B1 o2 B" k5 f' e. @7172867) Y, |9 G; ]4 T1 u: l. V7 n) ^
JT_NX mismatch in component positions
6 v& n6 |1 \% t3 ?. W7173718
  e: r- k0 V* |$ Z  `3 TSurface Finish symbol exported to JT is rotated1 `( x# X. A9 E$ B, k  M" G
7178300& ~' O, n6 @4 O; e. ~
NX 8.5.3.3 MP1 plot generation take an excessive amount  of time' r7 }. }" r" y: R
7179210
- P8 @8 [* b) P: K8 Q" z" LEditing a datum feature symbol creates unwanted Jog
/ h3 U: g# q8 ^# G/ K71792787 \% ]2 j8 p  x0 m; {* l/ |
NXMGR: Replacing assembly part family template with  member gives error7 [. b- Y2 _" N
7179528
! k# d; Z$ a+ n# f# @9 _2 a" W4 PRelations and Interpart link browser fails to show  linked curves( j$ s+ d% v; F9 W
7179535- F3 C* \, S4 i! b" O: U" Q
NC: Unable to open file in NX 8.5:null tag not allowed  after upgrade from NX 6
3 S2 ?7 @3 L! S7181152# P# c2 u3 B; Z, K, c  s( a6 e  b
mp6 udf fails when changing udf scale from 2 to 1: W# o5 j4 C" }% o
7182280
/ E, R6 h  F$ eNX 9 Routing Spline path conversion performance# ^% R( `) S* H% Y# u0 V
7183415
4 T  ^* k1 _  {& ?; A% g6 v1 ]Creating a hole, sketch csys goes to last hole created.
  w* H/ X- ]( B! x. K7185242
, R8 A2 y. B8 S5 l/ GDWG file in NX 9 is not maintaining layers - everything  is placed on layer 256
  f' o) }( y/ n) I0 p7 ]7185561* h7 Z. S& ]+ A4 j% W7 R/ d/ i1 @
NX- Legacy material Library Issue - read error
: x  h  b  D1 a, ^4 O( a3 e7185734, y) g; g! z( e  T1 q
No link status change after PI name change; can't  update
1 K5 q! z! G2 X$ C& S, r  N7186716) Y1 s5 `! Q1 Q' }) m8 t- f
Datum CSYS reorient will not recognize arc center  point snapping  E5 I! P/ ?, T7 g. m
7186912
5 q) d3 v6 v0 C9 QHD3D pop-up for Analyze Pockets has incorrect spelling  - information
# o, U% f: N6 ^! G7187083, @% x) F% ~' i
PMI - Section curves of Lightweight Section disappear  with the solid
, c9 c* _; j1 {7187490% |+ Z$ J; _7 I8 \6 R
Optimization & Sensitivity fields snap back to  their original size! ~7 a3 m; R- b( l0 m
71878900 t4 Z4 G" I- X6 N* w8 O
Scale value disappears with customized view label
0 @- l; d0 `0 i$ ]! u3 X& z& ]7188549
. X' T3 T2 _) {3 r' \KF FrameXY issue in ug_udfs in NX 9 versus NX 8! e1 E1 t6 t+ l) [: D
7188966
7 y$ f( A/ C) B. N' i2 m. W2 x6 `After using Adopt Existing Object, error creating  new part, \/ `5 X# T1 I0 u0 ?
7189340
* |2 k8 L0 s- b2 DElec Lock Length on a spline moves the component) m) {  h8 t4 z: r0 d
71894381 i6 d& k, G0 D# ^9 E/ l! s
WELD ISSUE - Welds failed MDM Consistency check' Z) V2 @, I# Y# O
7189444+ _5 T' w% R3 u% [' M- B  a: t# `
WELD - CFF no longer lists previously Connected part  number
* j6 r0 w2 Q& h& ~: b" k7189451
0 o( C8 E8 W! ]2 H) K# YUnable to select legacy welds to Export CSV
- w  l6 G6 k/ R% R7190075
8 U% r  e' a5 L: sMirror feature - unable to recreate feature owner  deemed the feature failed
  E* F! k& N7 B8 e( Z7 L" z7190132
9 U  A5 I& `) Z( m# bCrosshatch Settings dialog is not closing (open directory)  handles
( U) r) M6 o1 e, F& w9 i) o7190615
/ ?3 u0 W0 L: ?0 F6 u  ^UF_PART_reopen() does not post confirmation dialog" i3 o2 _5 C7 I' x
7191032
) O0 z& g( F- z3 tNX-View Updates in Drafting
- n2 x; I# C  x" p- x7191225: y. ^# c; t4 a$ i* y
IPW 'out of date' status is inconsistent/ t$ ~4 `: `( `
7191819. U9 }8 }& n# H- s. x  _5 u1 @, a
NX 6 Environment Variable
4 B4 @1 ^: q; I( v; X/ V2 Y  S7 ~7192308# A+ K2 p: q6 g5 w+ B& p# v/ }
Routing assemblies cycle through updates to features  of loaded part unexpectedly1 T4 n9 E  i+ }5 Q2 O
7192332
2 s- N3 r# \1 U/ HPMI Custom Symbol leader arrowheads detached in JT  export
1 w% v5 r# |4 R( L* c+ V, Y9 j+ @) ^7192996
/ c( L2 ]! l. }Save All should only save all showing in the preview  list
, ^& P( H' J: p3 u( W7 O71942905 A$ w  ^" b0 O: K8 U7 D' ?& E
NX allows checkout of "out of date" subordinate  DE's, y( t4 X9 C. ^5 g
7194313. }5 p+ L8 Q- h& x
No Alert is issues if Weld Point is not on the top  or overlap sheet& e" l$ R4 M1 L2 r* s# X
7194316( o" k7 [! H0 |$ Y
Linked Face created on the fly are not put on the  welding construction layer
" [, F  a, `; u! O) K  m) {7194335
( A% ?. {) t9 A8 u2 t) VDrawing Revision block (Tabular Note) updates position  in TCIN but not native NX( Z3 x# w; ~: t# ~+ C/ E* A  ]
7195365
( F, ]" T4 R5 m% i) P8 iPR7489819 Linkpmi fails to finish PR7195365 Use proto  tags to find underlying geometry
+ G: p8 B6 K0 E* w3 c7195452, c% H" |3 C' P( j) u
Line Profile FCF applied to multiple curves in PMI  produces incorrect CMM tol- h) P& k; h5 B( e
7196000' w7 j. C1 j* N. `
Published Welds are removed when file is saved without  publish option checked
4 I# S5 q7 c% E! U* Y71960056 ?3 R7 o" f6 c" J
Welds re-publish to Teamcenter with new ItemID without  a change to NX weld
: c6 B, f6 `* a1 X" X) ]7196474
5 x7 o# R) p/ E9 T" T, vLog is displayed even after using UF_CLONE_set_logfile(NULL)  h1 m1 Q1 G% m5 m  Y* L8 G
7197259
6 J# ]% z& Q0 Y# U# b5 j- QLock length changes the Shape of subdivided spline  at the takeout point
$ e. S' \3 Z) E# B7199952
4 T$ d& `" n# D) L2 k5 j, o  C" ]1 BKF adoption different in NX 9 than NX 7.5
5 k3 w/ D$ B1 X* ?7200065
/ G: ^' }6 b7 z& Q2 ^' s! b8 aCannot create a single scan path XSECT pattern
8 W% ^, `' ^* L) W- T0 W7200157
' [% r+ g) u( i( N. [Edit Parameters with Multiple Feature Selection forces  all Active Features
5 `$ b  M8 u( Y* J9 s72002431 R; d3 {1 p: D$ C
batchShadeOptions crashes JVM the second time it is  used
( }; c" g  A( k7201310
% f' Z% F, C$ m1 |9 `( QGetEvaluatedText throws "Second parameter is  invalid" NXException unexpectedly0 [# r+ [+ y0 t5 m, n9 Q4 B# H6 _
7201418, m9 [: Y% Y# V
TORUS MINOR Diam shows 'Failed' in Measured Status  column but actually passes
: a. ~7 z7 {2 s) y: ?- j$ e1 Q7202422
7 m+ w# J) a6 x- @Part file opens in NX 9.0.2.5 but not NX 9.0.3.49 V+ W: K1 z% h% F! q7 s+ [
7204075( z2 C( u: m4 o0 p
Electrical Cable editing is excessively slow in NX  9 when slack is applied
# D7 P4 L/ s! H7204201
6 x* e* H  d8 h, M- {' P3 UAdding slack to a cable in NX 9 takes WAY TOO LONG  compared to NX 8.56 \) I1 N1 k2 }& N# W  I, y
7204218  H# d5 W" G3 s
Importing CGM into a Front view breaks apart the CGM  data! t0 D% [: O4 I1 m3 {: `  c1 E
72042194 X. |1 R; e/ {# ~9 E$ x8 F
Creating a spline path the performance degrades after  selecting multiple points
2 Q+ S% K9 R( \3 e9 R7204248  I% u+ N4 y' e5 K8 X6 v
Top level assy structure is wrong after UF_UI_ask_open_part_filename
& }! L8 }, z( k6 |; W; y. l7204727
/ D. h( Q9 F+ U  E, w5 Z# pSelecting Named Centerline produces inconsistent results
6 Q8 z& C- T$ r( {( N; W. q7205173* p" X2 F5 D0 C* T" s# E2 Z
Unable to delete reference object in layer created  by View Alignment7 S& B* D: @+ r- P5 a" O
7206011
* _2 S2 t2 t; y6 ~) M9 H! y" D* iAdded Wire EDM Tool - Verified the Path - Path can  not be edited...3 [# ?2 k3 Z0 R4 m+ g2 @: z( c6 B
7206025- u: g7 Z* Q* X4 R9 M" k3 K/ _+ d0 c
True shape customer defaults need honored, should  not be controlled by registry" I( a* w; g* b0 H( D" T  h: l
7206111
0 \" K% {4 R4 z; l+ y( kCustomize button on the radial toolbar and it doesn't  stay after save user role/ ~2 `" ]! j% _" Q# G: E
7206387
# @$ S6 Z  x2 o' bNX 6 to NX 9.0.3.4 MP1 Turning "Cut Region"  incorrect when regenerated
' L/ j. X2 x8 i/ I; u72064512 Q- M+ o3 ^) v- F  a8 i* q
Opening a previous version of an assembly deletes  occurrences in TC5 D9 q, ]* c3 c7 X/ `7 V0 [
7206498
# E, h& X% Q* u" oSearch in NX Manager is displaying wrong results,  attribute is boolean7 C3 Q4 ^1 O$ \& T& R# K
7206903
# u4 c- C1 u0 ^- ~" d# IExport IGES and is missing sheet 2 and later, only  sheet 1 exports
- R& W! n+ Q. c* N$ ?7207057# ?; |2 o; ?. O
Thread Milling Instances Lose Feature Geometry; S8 X+ S6 G" I( h$ ^+ j
7207275
" ]; ?4 I% N( E3 V1 SUNLOAD_WIRE & LOAD_WIRE output2 u4 t3 Q: m$ z7 `8 I' n
7207276
1 G" N; u2 f. f6 iStandard Part Management Drawing Issue, x0 K1 T6 m0 V6 [9 _
72080905 S2 T& w- C' R6 j2 ^: o
Syslog shows "Couldn't find object for"  errors for check-mate checkers& P& ^+ y. k' Q
7208817
& E- d" f" c3 R4 g* i! }Corruption: Manufacturing part file cannot be opened  Null Tag reported
' i6 H! R3 C8 }7 t+ p7208841
  `0 P$ V" a' Z4 kCreating Part Family members crashes-COM Error - 80010100
5 q8 o1 t! X! l- Z; ^5 Q72093574 |# E7 x& i% V
WAVE Out of Date column has a Sys Delayed Link Out  of Date on Layer 1 and 27  S  w. X8 h1 Q+ \! i# F
7209392
$ [' j% G# u: J3 s: wMoving from NX 4 to NX 9, wave links are broken* S+ g/ Q: `% d! u& t% W
72096672 H7 ~& H' B) z; f& P- n
Hidden sketch curves don't display when Editing a  Sketch
, d% _# j# n# l' u! _7209788" |. h# R! x& l! }
KF - different behavior in NX 9 than in NX 7.5
2 u9 ~/ a; [$ l6 N8 j) B7210519
7 y1 F2 L  S2 o' l9 p5 y0 ^Moving from NX 6 to NX 9 and output rotation in DPM  in NX 9 is wrong& U: ~" Y% x" j6 X$ d8 ^
7210780
8 {5 a/ N1 A- ~' a' H/ ZSuppressed Drafting Objects Displayed in DWG Export  in NX 9; O% l, @, `/ l& x9 Q& r) ~
7212173' C1 }7 L0 O0 E! U8 H* ~
Memory leak in NXOpen API involving annotation associatively  data
. t3 `6 h% J8 X/ y7 B7212277) m$ B( `2 E  ^9 L( U$ y
EvaluateAnyAsString throws "Internal error: memory  access violation"  b7 q! a( j# F0 F3 @+ a# b  e
7212599/ l  B# @1 O) c5 d
Tool Axis specified as 'Vector' not maintained in  an MCS when re-entering dialog
- x# A! H( a+ {' h7 ?6 h3 f7213425
- I- W' P+ g: s* X  ^6 vLinear dimension does not connect to Baseline
# P/ U* @0 x6 B* i+ Y) F: f7214318& W8 I6 F  h) w) i: s
Absolute function is ignoring the unit it has been  assigned* V" P: Q2 u0 y) B7 }8 A( K
7217444
. g+ j( b& F5 q. O7 S) pExisting Validation Results Summary (VRS) Is Not Updating9 p& h" g8 E; z2 E! T
7217464
# M# `. R4 |1 {8 wDifferences between NX 8 versus NX 9 trim vector direction  location9 B$ e9 Z: V) X! k) l' [8 H9 l
7217705- V0 Q$ q2 `5 l6 y5 W* c' S
NX Shape Search error with UGII_GENERATE_MULTI_CAD_JT=1
5 k. w9 v* X1 F: ]. R7217767
% t% V2 i" V& W2 ~1 N+ ^- Z) _0 sNX takes a long time to accept the selected feature  that was picked1 D# b4 P% j& f
7218446% m3 v9 n4 Y6 y& u) J; [
PMI light weight section not update when rotated about  a point
$ [$ j7 A7 i3 u7218517* _9 F" C3 d+ g+ K9 v' h! Y
UF_UI_ask_ribbon_vis & UF_UI_set_ribbon_vis don't  work for Groups  P4 A' D2 q9 M9 f" f. P9 _
7219284$ k& ~) f1 j' z6 Z4 O5 g* {
UGMGR_Remote_cico Customer Default is ignored/ ]# i& o8 c* V) d# s0 Z! p
7219549, p8 V1 N" L' n% i$ l
NX: Flat Solid fails and Cleanup Utility does not  resolve
& A% `4 q: T5 H. t) U+ k7219655
) x  ?) t* ?. x3 N$ ?! p4 d: P6 \Harness Un-Routes when running 'Part Cleanup' with  the "Clean Routing Objects"
+ ^' P% A$ x6 |5 `$ `7219749! ^3 Q$ q- Y5 O
Specification drawing fails to load due to 630035  null tag error2 ?6 ~) ^- z/ a- W: n
72197674 e6 U6 Y) ]4 b3 g2 X9 w( L
Electrode Design: Patterned components have suffixes  duplicate in BOM8 `, r! W1 W" \$ E% q% M0 {
7219944
9 _: m4 d. {! v" LSend UGMaster dataset from TC to NX result in modified  but no check-out state5 i, H/ p, D: b) s' V4 t
7220673
6 B( i% E: N$ [WELD - CFF unable to select face
& h, b0 x, w/ y2 Q7 P4 w+ z7221407# }, D' t2 r) r% q. n' v
Electrode Design - BOM issue% g$ |0 B4 }& U3 }! a
7222200' Y/ ~5 U5 e/ k+ e* z  ^, v$ ?, @
NX: export flat pattern does not keep layer settings  from preferences. ^0 r. c$ h& {* |! F& {2 P1 S7 p
7222326
9 f" V# ]% E: y: bTrying to  place a component in Routing Electrical, OK not available% @1 ~+ y* p+ n! E4 e" b4 z) _
72226273 o0 ^9 \0 A( m
mqc_drawing_askViewData does not return correct info  for label and scale on_off
/ G" M  ?2 Z' H; H7223654
  V$ K( c$ {! XIPW not updating, ONT column does not show IPWs as  out of date. W* n) N- M' `5 y0 y
7224120
/ [& u, q9 J2 S4 w0 X+ _& GDeformable Part not functioning properly in NX 9.0.3.4  MP1
7 V/ z1 o6 L% O7 Q* B! u7225295" G" o; L! e' A% g) R  ]& E5 C
Progressive die wizard Collision check problem
* |  R$ V. i% |8 M: K7226331
" o# v8 N" x1 @3 [AFEM update resulting in Internal Memory Access Error: ^* l6 {) _0 t5 a; b$ [+ x. `
7226332
3 F& f- \* L" X3 YUnable to delete certain features
" k  ^$ j2 ?5 H' r7227078- {4 q! v3 H% U) a4 u
Macro playback fails when menu has a nonselectable  separator line
+ N1 M% {6 h" z7227259
# X$ ]  ^1 X$ M' RNotes linked to IPE are not updating when parent files  in Excluded state in NX 8
5 ]; }% y& B, r9 j7227981/ b+ Z4 F* A" \- O
Reposition Component (legacy) - wrong results when  using fractional input' ^+ q6 [  d" e: E
7227986
0 d3 H/ w* {' e  W. P9 {File fails to open
# l7 |7 ]- X4 q7 B" c7228118
4 f1 j3 W. g% G# C% Y& I7 rParallel generating hangs NX+ b( D, G7 f% ^9 Z1 v2 `
7228212! ?& u. A9 y* V3 F
Manufacturing Assembly will not open in NX 9.0.3 but  does in NX 7.5.5
: c7 l( l. ~7 N) j" K6 P: z' h7228330
+ {. q  B/ d5 g8 H  tPMI Custom Symbol translates to jt incorrectly) t1 E! x7 z6 ?5 ^- u/ i: N& q
7228885
4 e7 [( {! o1 J6 Q3 bExport of a SE drawing using DXF_DWG into NX is poor    Line two  times in Runner,appear Internal Error
: j7 e( A% R: p5 @+ |0 {* n2 c7230663
5 x! R% T% P8 R' gOffset Face feature doesn't display ! in PNT when  needs attention  U  t: [# J9 d  F
7231190! i7 s9 v5 t0 _$ M
Importing a JT file stacks all imported solids on  top of each other" x' ~, }, X) k0 j+ R1 e
72316062 ^3 u* M+ A% `/ c) ?) t" t
Internal memory error when creating face on mesh
. ~: s' F5 w; t/ ^: D! @72320841 w# E/ B: x, \- M& N
THREAD MILLING - operations getting flagged as edited  when retrieved into NX 9.0
# x2 Q5 c7 ?% J5 `0 J: _/ x6 u7232482" J0 Z' x1 P7 b
Not able to create XML output on a single part6 E3 k9 ]! p/ q% d- N
7232506' M0 _3 T' S$ [5 q5 V9 K1 u
Excess Material is not taken over into XML Output  for straightbrake parts# z( C* _1 X. v+ {) Z, V& @
7232686/ Z' C1 w6 D3 e  S6 A) y( l
Error adding exploded view to drawing
8 H: g+ @: q  ]7233945
* }" j2 h: P% s( K  O3 jWhat is "Nose Angle" on Customer Defaults  controlling3 {# d& t; x) o& E
7234393
3 f0 R; i% m, x) dDialog popping up Performance of almost all Manufacturing  features are very slow
. F) Q+ f2 \/ ?7234476, ]# S! v, q, Y  F
KF mqc functions for reporting template of family  instance report wrong value
& [6 N# Z, o) W2 x) ^- M2 h6 T% c. n8 b" @. [7234532) V" i1 Y( |" {" L- K( ]: {; d" o6 ]
Plate preparation on Planar parts need to be at the  end of the feature tree
# n  j0 S- f$ ^72345734 v; D$ _; c9 S
Smart flag isn't updated correctly
- `# n5 c$ j8 O# |8 o2 G7234638+ J* E# i4 @7 f# N/ N
Plate preparation is not working on some Straightbrake  parts(Not making it flat)
8 j  d. j+ l6 N* q# ~1 g! q1 r7234648
8 `& `5 T/ J* e7 aTextblock Position in XML output is sometime not correct8 Q( S4 L* M) J
7234953
! X% Q' ]% O" Q% c) {. sCAM tool axis vector in MCS object not retaining after  edit+ L, s7 K) ^- S! u
72350149 f& g( [4 K  A
When the revision rules are changed variant rule is  deleted_cleared! j: M6 ~0 i9 T; S  @" {
7235599
  _9 P9 E+ I2 J/ l9 W( g+ u7 yShiptools placing profile_plate returns Unable to  approximate guide string" m; q8 H7 R- `5 O2 c. |
7235637- [9 ^, s7 p! c3 E( w0 e
3919 Extension does not save the effectivity set on  DCE: W# h. k! _& r# S8 n
7235745
& v( J1 P, F) t4 g0 ?Spline paths change significantly when they are converted  to the New NX 9.0 spl" A: t! x: s5 N/ E
7238319
1 l% a# L5 C1 M. l/ QCheck-Mate results are not getting updated after upgrade  from NX 7.5 to NX 9.0
% L) r" }/ x5 k- Z  q+ z7238823# q4 j3 y8 J4 T# t) o9 Y1 L
NX Edit Boundary NX 9 replacement is not compatible  to the NX 8
6 x3 K) P+ V- C7239696
+ R5 e9 x) ^' OAccidentally selecting Inspection module locks user  out of CAM$ P& r8 ^: }5 `
72397054 S  h% d  |; Q' W% I3 @
Cannot disable menu items in NX 9 using UF_MB_set_button_sensitivity( o2 Y2 k* {# G+ x" p) r2 f
7240036; }& R! ~" z" o* t
Mold Wizard - tooling motion simulation run the second  time fails0 g7 K: H8 }: O6 d2 p  g  K0 o
7240515  s5 j+ S7 X5 V& C- U
Startposition for Cutcom is not usable when NO Engage_Retract  is set
9 L* D; @9 n, c; k$ I7 V7 h5 C* `1 L7240578
  w7 Z4 P5 Q0 x  u. L4 H9 bAuto Route in NX8.5 Electrical module fails to display  the assigned wire stock) E- ?( C% k3 o' T% S4 Z7 M7 G
7240702
  P; f! O4 A) j4 aCreation of detail view causes "unsuitable OM  object" error
* ^( V" [- ?( I2 U7244999
! O9 |" Z' I* U$ ?[medium] Teamcenter Naming Rule not used for PTS Parts
$ e4 J) P' |: a' c8 _3 ~, P9 y7245409( `7 N: K& y# I8 q+ g7 P
Symbol Font File is not loaded from Customer Defaults
# S: t& g$ C, J3 j, X$ z72454758 P* o7 Z: a2 w4 j  m! @6 W0 J
Cylindrical dimension using baseline does not work. R$ T6 G1 `# v- W
7245488
$ ~/ A$ ]8 v0 D& M7 qNot able to open part file in NX 9.0.3 -Plate preparation  - directions are coplanar$ M# }6 D4 A# A$ ~& W
7245509
( T' M% T5 c( TPlate Preparation is not taken over the solid specified  by METAFORM_LAYER
1 i  _) u( d7 J) ^7245561: ~' l; x0 E. `, X8 h) G
Null tag error when manufacturing XML output is created
2 M- O  H7 w' U* r* L  p! q+ z5 R7245578
5 M, I( A3 c: v' k! \Excess Material not correctly placed on the planar  metaform solid" M0 j( L0 h! \# Y  @3 Q/ {6 J
7246100& H: o" l5 t" a; p
UF_ASSEM_deform_part() fails with error code 580025
! w5 o1 j8 d$ r9 r1 G% A5 ~7246221( u8 ~6 ]3 |! D; _
Question about Continuity# s& k, d6 q, h7 S2 j0 ]* Y
7246931
6 Z- {' Y- F8 z% B( d( gG2 Continuity is not updated correctly in 'Match Edge'  dialog
3 j5 z4 F) L+ V7 B* n7247038
- u. `3 b/ ?9 j! l4 B, YPR2221699 was not fixed in NX 9.0.3
. Z' J7 A$ A5 \1 ]8 j7247370
2 @! X* o/ A: fThe vector of "Fixed Tool Axis" is not stored  in MCS dialog
. m$ w3 h3 }' O7 ~7247430
, }! @7 W1 y, P$ u' qAbout the spline editing by X-Form
, \! a6 R; _: r. ]& a2 a7 }7248034( n! O  l8 a6 d& d0 L; S
JT part not visible in drawing after insert base view  (view from part)
0 R" r$ J% }( E" C7248110
5 u7 u, E# h4 qThread Milling hangs when selecting each hole
2 H: c+ f2 G- f6 [# a3 `  e7248301
2 ?8 A* ^1 ~& p$ [/ N% o7 OExcess Material is not working on knuckled plates# o: I, X7 C+ B1 G3 t: x
7248477
2 e. X# @. C1 t1 ^# bMove Object doesn't move associative text to specified  location8 q4 r8 x1 Y3 C8 G
7248545' p5 \( z8 U# f& Z* ]+ E; c4 V4 x$ e
Cannot de-select run members to remove from run when  workset is displayed part9 [  I- j5 w" K* a
7248586
1 O9 e# z$ w2 C$ {2 K9 q3 dIdentify command VKI Error Number 1 Function : vis_GroupSetEntFlag
1 n' w4 }5 Q! j3 v$ l1 j& j6 t7248854
% W% J) d  T. W$ K, `Optimization setup gives a memory error
' `& b- H4 w' C: t. x+ b6 ]  K& M- [7248945
+ Z4 M* d, R/ ^6 W0 c+ iElectrode Drawing will not update to show the correct  attribute information( r/ U; o) y4 K7 y: Z& r- r
7249382
7 P' |+ h% {# n( w/ f: \1 UNX: Performance Issue with sketcher or drafting dimensioning
2 J4 p- e* Z  p) z) r) [3 t* g0 ~% |7250527+ m6 e6 A+ I/ v/ Q! u7 z+ L# e; w( G# k
NX 9 does not write Relative Transformation Matrix  to TC10
, Q! F9 L; W" l$ _7 G9 X' T7250615
1 U5 w$ R) g% {; s- w, F  a) d& U# y: {REG: Simple Pattern Feature of Groove fails to update  in NX 10$ I( l1 J8 m: {+ h
72506491 `4 _4 Q( t9 k0 j5 W5 \
Query conic edge blend parameters- }6 S% v) x* ]" a
7250725- q0 ^% e! I: Q! j# g8 _1 o
Editing a Surface Wrap recipe checks out two "nx_adv_fluid_mod"  licenses8 ^: \! c/ r% Q' }, F3 H
7250904$ y$ _8 o7 s( }% m, s3 [
UF_CLONE_perform_clone returns error code 7201005 j& F" c9 d% x% u! j! h) ]
72509142 z: `' g! o* V/ v  s$ K  y
Error happens while output shop doc during the tool  path verification
; ?: ~2 ~# R9 L0 [$ L/ n7251156& m7 z  Y. n  p/ f+ W
Create interpart link option is not remembered by  Routing Spline Path# N# B8 @) ?/ q* v
72511756 O5 j' A. Z4 B: U" H- j
Modeler error opening a parasolid file
$ \$ b  R5 F9 T4 F  g" L- o/ F72512030 p4 T" U6 n# z! b
CMM Inspection results do not match the results reports  from eM-Measure
6 T9 Y2 p- y; Y7251305
! K5 ~/ t7 x: H: R4 eNX 9 shows only 6 Error Estimates but NX 8 shows 7  Error Estimates( V- V3 y9 ~% }0 ~1 E
7251934
$ ^' B( _* }. i# e8 e- N% IFeed Slowdown in Corners value is not output into  CL list in NX903MP2.
# ]) {$ \0 ~$ O: I7252286
: w1 y6 K% n9 s! j# B# Y$ A. `% CMoldwizard cut pockets change color when component  is moved
! `) d$ W; K* l4 y7 a* ^7252306
2 B4 D% c1 h0 TLocalStorage not supported in NX9 internal browser
# h& @/ s1 ~. a9 }) F% c9 s3 i# c7252381
* f' R$ _( c: W: o& z$ k7 DCan't delete leader line
% u" j' X, \7 f4 q9 u72529159 J) a0 N' W; M, V# d1 `: f
To specify the boundary for CAM operation NX 9.0.3mp2  takes more time7 s7 n. {' l6 V6 Z5 O
72530057 n4 O$ G$ H! d) _! s0 [
Tabularnote with "Evaluate Cell as Formula"  -> no calculated value in DWG export
* |8 {$ F. E, P( m) c7253230
5 m: L& X% x9 a/ j( C' G- D' qImported mesh does not conform to CAD geometry after  morphing
. P9 I4 t5 O1 K9 r7253881
! g: X9 c, a( iMeshName property does not set mesh name2 R! `2 W) d( j- s
7254351; w8 }# s5 Y) i. k; e
Bead Weld ignores Construction Layer Preference6 k- R* _9 R& r  Z2 B; i9 h
7254452
% V9 p) p+ c" ^: \7 k' CFlowcut-User defined cut order shows cut regions on  part before it was mirrored7 c& N; q) F" x
7254620
% {8 u9 K( i$ A) FUnable to add Base View in Drawing -> Error: There  are no curves in the boundary
6 A. n8 s1 D3 h, a0 M7254631
# z; t, r3 k4 F' E' T! `9 @7 sEmpty Predefined View list if MW Assembly Drawing  template doesn't contain note( W6 f+ n4 J0 `, @: w1 |1 V
7254771) c, e( D8 n9 B3 M& {( {% J1 D! h
NX Part Family Assemblies fail in TcVis
7 t) c) Z+ t: G% @4 w7254795# w" r2 ~2 w2 f% z5 V, v
Wrong View Orientation using Electrode Drawing Template5 _8 T' K" Y1 @! M& n8 c6 U# I
7254883# s3 w& O  O) N! U
USER WARNING MESSAGE 2070 (MTRXIN)
2 r% A* m0 U8 u( t  L+ n. P( [! Y7255393
/ F' ?2 W+ I( L& [Force load applied as a spatial distribution is incorrect...
4 n# F) F4 @2 i5 @7256378
/ I; N+ @3 S, w( m7 R1 H' f$ PFile in use by another process error occurs while  saving JT data2 \- r* b7 B7 a9 i+ l* q( r9 J5 c
7256749% M4 H+ S" D$ Y8 l* f" I% k
Rules Based Structure Welding Callback Requires Weld  Assistant License4 O5 V9 G" ?1 I% J7 D9 P2 U
7256758
  W8 z# _: Y% ePatternFeature with boolean operation gives memory  error when asking for bodies
6 _6 v3 F' V' J7 J1 z1 N7259032
+ ^- g/ R! w5 g0 g" H; J3 a( P. @Internal error when trying to open a drawing/ i' e4 ~, Y: \3 @5 d
7259085
  M2 X7 I& c, R, O' L) hTool holder and IPW Collision in Cavity mill operation
% a3 ~" Q4 `8 p1 I0 o( z7259542
8 s3 t! V4 N' y, [* i+ z1 oNX returns an Internal Error when opening a drawing  if the ugmaster is open- ?# |1 L! i4 ^& L; ]- i
7259639; a2 w7 C, ?% [9 o
Element Modify Order does not work fine for the mesh  made in the body with MMC" Z9 F" g; V3 _, d
7259764
7 L0 M) P( [# n, c! B/ qWrong thickness of Belts2 b2 {! d. S. Y% h0 E; Y' P3 c
7259871
0 T, `& l# H  D' L, h" T0 B# N; ~# \Save As dialog does not function when Item_id and  item_revision_id are mapped5 l: K/ ~( d  I
7260083
( R' H4 q- _+ `" G" mFlow cut operation does not generate Toolpath with  the stepover value specified
) m7 }( G- x1 F9 W% u72602631 C5 h, L7 ?/ B) R9 u
ug_extract_curve needs info on UpdateAtTimestamp parameter1 {4 T% W/ N" d0 g* y
7260419
; A- }) a% V0 V9 s; D: dOffset in Face cannot create correct output
* Y$ c& D) s7 ?5 G7260939
# w6 j" U4 q9 T5 a9 |Customer Default "Teamcenter Ship Name Format"  not working with Naming Rule+ |) i% P1 n; |7 S; H5 n2 I/ m
72615917 h6 }* i. b- X. F7 ^
Order of commands of View Shortcut Menu is changed  when restart the NX
: T& D0 b3 h! d, u72616439 A4 j- s8 _# |7 @
Multi-CAD assemblies are opening as modified and being  modified by update
/ m9 ^, y& r. W, g7 W72619645 U' V. K( R1 Y" l. F# z$ c* K
PDW Tooling Motion Simulation Mounted does not get  reset
0 p) C$ s( H; q72635446 N& `- I" `5 |# X
Electrode Wizard Drawing template All Views have a  wrong orientation
  ~0 t; U6 _, S* t: }# I7264204# d! M# l$ }' s" {
No response from native NX Shape Search& D0 z; ?( ^8 W% g# j9 q. a+ \
7266198
  f3 g& I5 S3 ], ~% e8 }Table field - Spatial map: surface gives wrong result  with meter units! w" L( b# U+ Y5 ?& `& R. L
7267123
0 E# e- V2 B7 K( A# R% p" A& y4 Q; ^NX: Unable to open part in NX 9 - Error during Update
( U7 `7 y/ q; j3 M6 i: F7268516
9 u4 J- `0 @* M6 u& j2 S9 YComponent color change has no effect on sketch curves; ~/ q1 v- A: F
72685240 B+ C+ n: P/ \' k1 s8 c
Changeover Management doesn't change to second part  when creating drawing
# b: G  _% v( L8 I3 G4 b2 _7268811
& _9 {+ \7 R9 aNo locked tool path when opening a NX 8.5 holemill  operation in NX 9.0.3mp3
6 o  b8 I- @4 s; V) M( y/ `7269620% o* D4 L5 i8 E# T" N
Cannot directly open parasolid file in NX 10
% ^0 M+ k' b4 U7269692+ ^9 G: B1 l, `
Square cut not working using Stiffener by support
/ M; P  K# `- D& y' E4 F7271613
3 k& S- f4 O2 h+ c8 V* KEdit Spline Path results in Modeler error: coincident  control or spline points
# O* R" h! {+ N9 C- R& Z72720543 P# b/ g2 P  Q, i$ b( Z% P) [" S
MEMORY_ERROR- z3 c. Y6 w, j+ x  a
7272544
3 h. u7 m: j- PCavity Mill Corner Slowdown not working
5 f" L" F0 o! K3 ^* ]/ i/ g72735282 @6 N5 r: U; f  D( ^2 h' p
Spline Path creation in NX 9.0.3MP3 does not have  parallel constraint3 S9 k/ A# Z: L$ B, S
72738819 r4 d  L$ G; X/ m8 L1 ]
UFKf askListCount throws exception for an empty list
6 h: e/ k7 w" Y/ {7274038. s6 @* A4 j0 T2 ^4 U0 `- W
Freebody result on cross-section of rectangular tube  of solid elements is wrong
5 Y$ p( I0 v" K' G% x7274837* ]4 {4 c8 Z3 E: q0 G1 \  F9 U2 [* }
Interpart expression not being picked up causing component  incorrect orientation  |7 U. v/ B! E1 S9 N8 U3 P$ L& l4 ]
7275351: h0 f. E& j# }7 Q0 P$ g* F
Can not change the width of the column of "XY  Function Editor"
' U) y# N/ m" ~) J+ y7275902; ?6 W( I2 T/ a& k+ A# Z
Enable Multiple Revisions and Load Interpart Data(all  levels) cause failure
3 i% w0 Y5 {' K+ ]% N0 R6 z72762411 r9 e0 B& L+ F/ I) q2 m
'Extend at edges' in Flow cut reference tool generates  unexpected path
- ]9 Z' y# @: L4 y) n1 B8 C9 M7276455$ ?5 u& t) r. n5 P. S/ `2 O# {
Questions about setup NX 10 Doc server, p! P( y6 o6 M! a; ~
7276469
6 Z2 H, K6 Z( e3 q, V  ~. h/ yCan't edit appended text in text fields on Gwif for  PMI dimensions$ h3 P! j, @$ K* G. a
7277144$ R2 U: y8 n, v+ u, N  C# o6 v
Legacy splines converted to NX 9 and perform transform  path results in broken spl
( G8 h- z# q& W$ c7277922
# I4 d& q$ d- q" m- C1 @; lUF_UI_select_with_single_dialog() displays garbled  Japanese characters
, D) Z# ]- z% Z. K& w1 C2 Z* a7278186
+ E3 O+ G. C, h% MAnalyze Formability odd Shape of Curves
' _2 O! J7 w. s5 p2 z6 V7279064
$ k. p) t" m5 U7 K3 f0 QUF_UI_select_with_class_dialog() displays garbled  Japanese characters' m* Z( I7 h6 ?, b, E
7280728" E, l" ^$ Y! G8 p1 C
Promote body with View Section command
4 C6 `5 W) w3 V. m7281152/ D( |3 h9 ?( q2 e3 e3 d" T
NX 9 cam turning tools rotating in visualize to the  proper orientation angle (OA): v9 `* W% ^' H9 }
7281186  C4 c$ Z. N, s
Corner slowdown feed rates not being retained
5 T% r1 d9 {! b- |. @, g% y7 T7283638
% s/ {2 Y, k. E$ {Angular dimension is switching to incorrect value  after performing edit; T/ Q1 p6 F3 F6 s
7283852; u/ z1 E4 y" s* Y5 o
AssertErrorCode reports asserted error code rather  than the one which was thrown( A, Z. @7 q, z" ?8 V3 v% t
7285267! L+ E- K. u7 R* r4 I
Tool path gouged the part in the combination of the  bull-nose and Floor Wall9 t- o  H9 u) l0 _( D  [
7285563
3 t) y4 I  w3 d" X( x% QTextblock text still not correct placed with XML output
/ H* P8 v/ ~6 M8 `! B; K' V7285581
& N" K% t: J! B/ k# K. U: qView Break problems with ShipBuilding Annotation
% o& r% A2 @5 F* f0 v7287051
4 W2 Y% M2 n' x$ TObject supplied is of the wrong type using partial  loading4 j7 U1 I8 f) f- G
7288299) ^! ?9 n; C! v/ |6 h
Lost customization when choosing "Save Role"% ^6 z0 d. r5 n$ F& }# E6 s
7288817
# r1 p# V. S1 h$ M/ ^& aTag Error reported after deleting Blank geometry in  a Floor Wall operation& b* N. u/ w: t+ g+ Q
7289348
( l: `/ T+ i% ]* T* a& x# LThe symbol converted into DXF is not correctly displayed( ~; [, a" U! F  r! f2 T) x* i' {) q, l
P291752
+ k, Q' p: F$ q( ZNXOpen GetBendParameters() fails on Blend with Bead  with active Unbend feature( y/ [7 j9 f; }" F$ k7 ]$ ~
7292256
" p0 E$ n) {4 o7 Z# ]: CNX 10 Hole Table has 2 Through Holes rather than 1  C'bore hole& j& ~6 H' ^: S6 J
7297361
5 V, X, }) C4 d% r( w6 YTransform linear path in NX 9 breaks the connected  splines fixed constraint
! z9 P! C( k; V% n; d4 d/ X0 r6 P, P7303696
' ]( q1 L# r" R  K: |" P3 P/ Z# R9 HError drill+ f5 D( N/ l( U- a; Z! m$ D3 W
7304633
1 [0 B! L% {5 }/ E( lReverse direction does not work in spline path
! Z% _$ Y# s& j7306094
. x) q2 v: [1 w- D9 B" x: yDefect of "Suppress Hole" during 2D mesh  Edit: \9 Z  t- `; }
73065064 O- h, k) Z4 Z' J
Lowest Save Z should be 3mm _ 0.1 inch for all hole  machining operations8 A$ P& I& z9 Y: h! s
7307005, M# a4 {. f! W; Q! }1 `. [
GRIP truncates object names at 31 characters$ s+ D' o1 k" N  R
7307943" n* z3 M, y/ ?) i
ELEC - Update_Delete has gone thru too many Iterations  Error
' ^' S/ v1 n6 E7 O6 ]7309871
9 U# n* g! s) v4 [( c1 n2 G- T( jSurface finish symbols do not migrate correctly from  Ideas to NX
( H) L6 L! w2 Q3 c2 J  p7 f7311168
4 e  N1 W$ t) L" G) @0 nExport DXF option does not export the groups with  geometric entities
* w/ H. D0 M9 N. d0 {7 p7311266; M7 a0 S( G" O: b, [  }1 a
Excel does not close after "Cancel" in NX_Part  Families dialog
" X1 I  s* T9 y1 S, C73121873 l9 T% c3 `$ h4 Q" j
Built in Path does not move with deformable routing  harnessTODO:VIS
/ ?# n6 R" @# Y6 T1 ?7314924
' w6 ^' L( R' w" HRouting Electrical Auto-Route Speed Issue
6 i& A; ?  q; n7 P  x. T* m73175620 z7 V' n2 _0 `# E. @0 i8 k  X% i
Internal memory access violation in Mold Wizard Check  Regions
7 U! F( s9 t- ^  R8 t7320011
) f$ z# I2 W5 Y[CAD] NX_JT facet cannot fill out to Column of Comment  in Part Navigator
6 O$ b; g( f$ c9 X: d7 W1 e73214437 P. y2 M5 ^- A- E% O* x$ @* [
NX routing hangs & freezes% A4 e6 v4 [# g1 l  S% d+ |
7321459
8 h; [$ Q* W" B. h, _/ kIssues with 2D Exchange
" _& Z. V+ h6 B) f  T4 Q: B73222235 P1 g% n0 J* V# l. r
When cloning the Motion object, an error occurs) O3 |$ [) F. t  L7 I1 G- T
7323208
4 V) S8 k$ y' k; kTool neck is not taken into account in Gouge Check" ~3 l+ E6 |/ a; X$ e
7323671
2 z8 v! j. K; WReplace stock command does not work for replacing  overstocks1 V5 g: p+ B' X% S3 R4 X
7323850: t: c, k" d& O2 _
Flow operation fails to find all cut areas when ref.  tool is a button cutter' S) u# g9 K8 r6 M% S$ [. s
7324151' n& S$ H" V! t$ W
Coordinate Plane Label, create Height Specification  of an Air Duct_Cable Tray$ _, M. S5 k! P" ^
7324783# d3 p# I4 Z) h. i4 r0 }! s  M
Leader location of the labels having no text changes  on view update
1 t% _% V; l* O7324967
/ {, o" ~9 S$ u! W9 EPost Builder does not store_lose canned cycles settings
1 \- b+ x4 q  L7325314; |/ Q$ A$ b7 g6 k. W
Unexpected route line appears after deleting an elbow  component, g' w7 i& \# o2 b5 r9 g( R3 d* R
7326604
( n6 T. ]3 ~) ?7 Q1 Q: @Deform Part Shows both deform and undeformed body) l/ C6 O/ j+ t  `4 n
7327280% k; o- I+ E! Q) R
PMI with custom symbol is WRONG on the jt model when  viewed with TcVis, Z+ |& g1 G0 w: t3 S
7328032
( G' g/ _" u/ H" U4 B/ i* rPatch tool inconsistent in Mold Wizard
& d) j! V$ g4 b. w73284868 A) U' ~( d, O4 @
Generated Java code has some spelling errors  X) x9 D! M& A( y; e0 O5 J
7328655# v) Y' _! L+ y; l) p
Can't see the tool path from a defined goto point  in the machine control
9 V5 R7 _8 v  ]" R0 M+ ]3 G" V7329681
$ n, l, l' |# ~* eCan't enter appended text with environment variable  set/ V# {7 C" s6 d/ @- ^( ]1 B
7330441; \" E' B$ y2 n8 _) ]5 A: m' l4 S* U
KF ug_odbc_recordsetOpen() fails subsequently after  re-opening part: }! k2 b7 h' |, q( }
7331569
  T2 ]2 ?4 Q3 FAbout zero inner diameter for BEAM sections2 r- E0 W1 Z/ J. {& q; u" A
7331743
* ?3 O$ n6 r2 J  V' FLetter of view label is changed unintentionally in  Stepped Section Line$ J, m# E: W$ m+ C; u  D* u6 R0 F
73318365 T8 P3 |- p# ]) W8 N" ^; V
Problem selecting component face with ID-Sybol _ Balloon  in section view
1 `$ e( ]2 m, C" |7 P. j0 g+ x7334954! ~" s' t; o0 L3 j! E8 e
Opening NX 7.5 CAM part file and regenerating in NX  9 produce 3 times extra output' D/ L& N6 }$ s& G
7335606
, V$ R  z1 E/ J2 P! k/ o! W8 R4 BTranslucency of the blank geometry is changed automatically" T' N" v# l+ Y) z* g2 M( D
7336750+ g/ k+ l% i' Q: n& r, Y) s
Zlevel fails to generate
( v; G% V' n, e6 v7338346! v: \5 t5 x7 H8 a# _
Commands of "Graphics Window Manager" dialog  cannot get recorded
. f9 G! n4 R, ~9 `) m' a+ Z8 n7339437! f: U+ G! R- G6 R1 u+ h- m. n
Symbols in Hole callout dimension appear bold
. t' _2 D" t* W% r5 V( p7340006! E4 _! T5 l2 s9 b" o
Dimensions and annotations go retained when out of  date NX 7.5 drawing is updated in NX 9. The problem occurs when a boolean  operation is performed. This is a regression introduced by the fix for  PR 2184195 in NX 8.5 and NX 8 MR
; B% ^+ X- N( j, _0 U- q7340087! u8 q' P, x4 B3 \& Z' \
In NX 9, disappear component model in the view0 v) g6 w2 O# a
7340136
  J) }+ }& D) r; W1 ~[View Update] flip extension line gap, r  e/ k8 w7 }; D3 j
73401730 X  S; C9 u! o1 q
Leader location of the labels having no text changes  on view update  r) q. Y" J! g+ x# o3 R, \' D
7341153: j% F  F: C! Z" S5 J; L  P
Update Part Modules icon unavailable.# t8 y% `$ W3 V/ K! \
7343227
: g5 l) }- F) d+ a; mSymbolic Threads in Promoted Bodies are visible in  PMI Lightweight Section View; J' s5 ^/ Z1 E# K, s; Q
7343657( B: Q. Z) Y5 }: Z: ?. w
Translucency - preference setting problem in Manufacturing   ; _0 D& p) P9 V) M+ F  M
7345967) A6 ?& ?8 U) v4 k- e7 S
Values on dialog are incorrect when editing MAD
# A7 p5 q; Z8 l! [: x. I6 h/ h7347546' Q6 k3 ]5 D2 a9 R% ^0 H
Missing bending information in XML output
4 {+ L: g6 }) W2 z0 i, m: m' P% y7347671* q( Q: o! K' g8 ?" [* H
Search Reuse Library can't work when place Electrical  Part with Logical Type3 ?4 {$ L3 C/ a( x  v
7347820. }# B6 x" j+ |+ n4 i
Turning tool rotates on FROM point1 r% a% ~# o! ?( H+ @" z, `
73480495 g! `! n7 U0 V; \) C) V  }3 T
SimpleUDO Example Code will not work properly- U) D6 w' ^* V
7348637
- }# B; Y: E- g- y4 a2 D6 TRefer to PR#73486376 f& S0 |' J4 [% K+ E
7350916
+ ?+ C8 d' b/ \2 LMaterial change in Modeling has no effect in Adv.  Simulation
1 C7 m, d4 C1 n/ J6 t2 l8 i3 d7350950  ^  x4 p8 s' p& N! Q, \
SH_MASTER_PART_NAME in title block disappears when  flat pattern view is placed9 F; b8 P3 C4 c
73518275 I" t& Q! \& _7 S4 L3 g0 i
Parts List needs to be updated twice to correct callout  order
8 x8 N$ F8 C, v5 S73526038 g* S: T) D8 O7 w6 I& w
Sheet Metal - UAF: SM Solid Punch: Could not thicken  the sheet tool body+ J5 v9 w6 N% k9 j5 k
73535389 M3 E8 ?9 b8 g2 T$ d
NX: UF_ROUTE_find_path not finding path when component  is not on RCP
1 e: g1 s; e8 L* |, {$ `( j( G73545859 T' B3 J$ x. J# A7 M( V" G
Selection NX Assembly Component in an NX Assembly  Model as an NX CAM Geometry
. ?: c; H+ ]+ p* M7355284
3 z& W! @+ J8 k+ D; PProfile cutout in angle to target gives wrong cutouts
# H( ]  Z3 F. ^3 w& n5 m7355564/ k3 E' S" L0 B8 V0 @8 \% O
Assembly containing deformed part always opens as  modified# l. q4 a( t& |
7355778
2 L$ V" u8 m; _3 d6 `* `) DFixed contour cut region dialog does not retain overlap  region setting
) ]" u0 e$ a% d" |5 X# I7356726; U0 K2 k) u6 v+ S; r" l
The SM01 & SM02 cannot be opened & internal  error-memory access violation) \9 X! h; I1 h! u! U: p/ d. }
73572531 C; p7 @) U7 N, f& I( d
Dimensions suppressed and should not be, when broken  view is created$ X6 N4 [& Q) {* j0 F% Y& P
73581105 O! k( J6 d5 L) A, F4 N- z0 S
Problem selecting component face with Quick Pick section  view& @; q$ _  U) J5 c. y8 }
7358297* F. P$ J# \+ [* K# D- O
NX Search fails to find items with Display Rules
: P; `9 j5 \0 S; K, `8 i% R) o7359169  {* U; y, s7 U. u' O
Curve on Surface result seems incorrect) d: J4 x& S8 G: q" t7 p
7362888
: w" D6 q0 s/ y2 z; Z4 ~NX 10: Supported DXF_DWG versions : 'version unknown'  in logfile7 G6 v- [, E3 R! }7 t- B# ]
7366386
% i* W" X, E5 A# i3 D( f% m6 g' SCycle time incorrect for drilling operations due to  non cut units = ipm
- |1 K2 T# E* e2 }) z# D" }) c7367322
( b; B( r7 E2 ]3 |2 o) `Contour Area operation failed
, ^8 J8 ^, [! S) K2 p! K; G9 z4 m7367434
% {% I& ~" U$ ~! H& i" xSurface finish symbol migrates incorrectly' F, X* a8 {& j+ @# d2 g) T7 z
73676500 [! j7 \- m  `( e+ u; q) y
NX questions3 z+ X( j& C/ h' F6 b7 X" k/ V& t
7368418. G: ?: Q0 i+ U
Obscurity with Boringtools
. X" h; n+ z3 I7 i8 e; R- @0 V0 ~7368520
0 j! Y( l& `" t" w# O! Z0 Z0 ?The problem where Adopting a dimension to KF in NX  managed mode fails is fixed
# ~& Q7 C; b9 R* K, b  V* i  Z7368810
6 G' M/ Z& m/ @& q5 K6 CExpression linked to attribute breaks on Save As to  new revision in TC env6 _' K$ d/ T+ c" i
73688713 T% L9 H" N- ?
NXMGR: Getting error saving files to new revision
* i$ v6 f' h: c7 r5 Y" \& N: [7369360
  I1 b! Y! v% |8 a! CScCollector > GetObjects takes a very long time  to return tangent faces7 _8 k! ~7 L4 |! `& C
73701829 [- e% q# B; o0 R) R% r& S
Base string specified name rule no found in part name  is not displayed in NX 10- T& M0 T2 t3 t
7370717
8 ^1 l& A8 C  [Tracking point issue with grooving 3d tool
3 c9 ^/ f8 ?% ^/ W73709606 n3 w+ b) a/ v# D
Ship design structure reporting double volume in TC  mass properties form
$ b0 a8 d9 W# S1 p# z/ F% e2 s1 |73715573 }. R, K  ~+ D
Event MOM_part_attributes missing in CSE simulation
: N+ R4 _' J/ S1 q7371833% [& ]4 |0 ]* }  @
Thread Mill post output changes in different versions
! k/ P6 J! u- y8 z. Q4 o% \7372191
5 t3 t# @6 X2 k% [. t8 n& ZPostbuilder - right click on word in block cause "Forced"  white bar to disappear
) K$ `% J9 e+ @! ^0 g; G7372509# e  M, z. D1 W+ g+ A0 k1 D$ t
Reference Text Attribute does not update after a Save  -As in NXmanager
! c: c4 `" v7 ^9 [. k7372523" C1 Y/ e7 L" Q/ J; g
Delay Geometry, Expressions, and PMI Update cannot  be resolved& S, ~7 B# J  H- o$ H7 D
73727313 c+ X4 I. |6 Z( d' L+ D4 ?
Part cannot be closed with 'An illegal file was given  to the tag system' error/ i8 G8 |* D. @; V
73765069 ^' L9 z0 b/ B! m5 P" |% y! r8 Y$ C. J
Unable to save an NX 9 post in postbuilder NX 10.0.1  mp19 l3 Q% C. u0 H
7376627
) t  U" p6 z1 UPart Attributes that are synchronized are not updated  using Edit Stock operation4 W9 N) {/ L4 C! g% ?" O) R" M3 X) [
7376769  w2 `5 n) N- [  Z" @- _
xml out not working on part with chosen textheight  for markinglines0 e$ k2 S; P; r# i4 k
73768711 F# J. L! l8 ]; W) ]+ w& v2 z
Unable to Create Surface Weld on Face$ b: C9 b: x6 q. B
7377508
" ~( J8 U, ]/ F- Q" yPre NX 9 saved namred references in Teacenter as, W* w- d+ M2 T, ], a
7377944- U' v+ }& ?: d  D* c, J- [
It fixes following issues 1. PR#7377944 Input list  for refile with Dataset CLINames is not working as -part option 2. ugmanger_refile  not honoring user specified load options 3.Native refile doesn't have  -help switch% J: P- V' U) J* @, ^3 G, @2 p; A! M
7379136, t$ H! r5 _9 X1 ]* P/ |4 q5 v
The problem where the datasetname for PDF export can  be changed if it contains a colon or slash is fixed
9 f5 A. h4 B# u. x* l& X73795096 r- p: n! @3 n
NC: Internal error when updating views9 k- B5 L$ `1 Y! V4 z. e
7380212  J+ z( e% d8 G
File -> Print to PDF, first page prints OK, second  page fails - v9.0.3 SPECIFIC1 l4 O6 F0 e+ F- q% ?7 C2 L
7380721& Y3 F) [$ A7 I2 m& O% F
CAM Toolpath "arallelGenerate" don't delete  temporary Datasets in TC
. `1 P( i; o" o# R- }, l7380792' H1 R' n2 Z7 ~0 r5 {! s
Pattern feature on UDF gives incorrect results
; G* p* T2 ?9 [: r/ T6 }" j8 U7381332
7 D9 x2 V: @& n. X$ vTexts are lost when translating to dxf (UGI_GROUP_EXPORT=BLOCK)
" |1 q3 n/ B6 x( V3 X7 k; C7381714
& x: i6 d7 f& K2 k) w/ x& mNX 10 MACH ISSUE CUTTING REST MACHINING CONTAINMENT& u# w) ?1 O9 v# {. [; ]3 K) j
7382137
3 z9 {# b9 k% N. I- aUDF with rectangular slots gives alerts after insertion
. m/ D- B$ ]' `7382199
$ I6 J1 N. h! u3 Q+ Y4 J- ~/ ]% D  WTire Envelope command creates incorrect geometry
2 S- \0 G6 C1 z( B7382213" R, T- o! ?5 z$ E! b9 n1 v
File -> Print fails every second time with Internal  error in NX 9.0.3.4 MP6
0 c, M* ]' ?% z, ]7 R7383182
' b$ `+ s% I" b4 W3 vPrinting Problems with a 2 sheet drawing0 i1 i4 l5 H7 |; P
7384035
6 K' Z* d7 a5 g4 u, a* N3 W: |. ENeed to disable View Tool Bar in NX 9.0.3.4
3 L) B% h$ y9 r5 I( g7384414
2 Y( O7 W% ~" c8 ]1 eVASC, engage_ retract swing angle not working for  Against Part_Check* r: E2 \4 O/ S9 [" i. U3 V( Z1 t
73848161 J+ r( u- R6 [/ ~
Specify point block is not honoring snap point enabled  property0 g1 ?) A+ N) R$ a; \2 D
7384847
* \0 K1 m+ R' L: W; PInternal Error, m, h. \, {/ o# ^: }' H+ F+ c
7385572
% ~6 u3 |2 r6 p0 U2 @  b& ~Expression value will not update with delay part module  update on2 h  P; q' f1 n  e9 Y- X: t
7385619: {+ e. p. k! _* @/ v0 F6 w8 a
NXMGR: Multiplying quantity of NX assembly components.
. p2 @3 i4 G0 Q- X' I9 }73856742 @) U. v! W; u9 A6 H
Memory access violation while trying to print in drafting  mode
1 u3 U7 V% p) ^* b! C: r# X2 M7 X7385894  t" w% U& X3 w
Area milling create the unnecessary toolpath between  the cut area
) J; m* `6 r- p) X' o5 {1 p# G7387531
6 z. |3 m! c$ o; a1 jInternal error trying to edit or regenerate a lathe  operation
. j4 u7 T9 d& O, O, ^7387729" I* C* `/ g) @, {" m
Deviation gauge impacts performance during edit of  geometry
" x  Z5 d3 u0 \0 G& U  e8 z73880957 q0 s9 I( B$ W9 ^
File -> Print is returning an Internal Error on  second File -> Print execution
2 T# @& z' C/ m- M7388900
8 ^- e) u* _! ^8 h, OAbout display the full list of item types in the New  dialog
+ [/ m8 O- N) T) B' h$ L7389230
5 C8 y) i9 g# s2 ~6 A5 J$ @$ MNormal vector of the plane in which the line lies  not correct for LINE feature
6 F* C. C4 d- z( n* G. |: Q8 E2 r7389532& A' @4 I& @" [5 f6 ]( s: }7 a
NX 9 part will not open gets a Modeler error: Coincident  control or spline points
* K/ _! e* u7 w; H6 x: }: A- P9 m73897781 ?2 r; B" `+ E) y* u
Moldwizard sub-assy not updating to the INTER-PART  expressions
# }5 J( |- M' f4 `7390013
! L( ^; e2 @/ e+ d# ?& N) ?" [9 LNC data is not output with Batch Process with Background  mode
! W, k/ P/ M1 y9 I' a6 C3 x7392030
+ {- V# r. D0 H8 K0 jNX 9.0.3.4 MP6 can not print more then one or two  drawings% t6 h* B& U1 Z7 S
7392113" Z& ^# J$ b0 M: m( T+ b
Dimension value changes when opened in later NX version
% c* @4 M/ `1 Z8 X% T' }2 q6 P6 F+ W7392151; X0 K! R8 H/ g$ ]# I( o
The overstock or stock function when using stock as  component creates a new component but does not honor the seed file.5 q2 u( `# ~% N4 ~4 o) W
7392623
1 O9 k- M6 Z8 l5 e$ @! fLeader location of the labels having no text changes  on view update6 E! [* j9 e: _8 ^! F2 k1 Q0 U
7393312
0 m+ }+ E$ D/ A, j; ICustom symbol leader arrow heads change orientation  in TcVis for VDG 2.7 x% r5 a7 u" d) U! {% ^* z+ K
73954057 x: u  V  h5 J6 Q, |; `
A changed Path Display Colors will not remain for  Mill User Defined operations7 f' T( O  G0 D! V; R9 Y; z. B
7395408
/ i) F. ]4 N( }' eDisplayable Name in Teamcenter Navigator in NX - Display  additional attributes, |. s3 n+ x0 z4 q( n! Z
7395622
  U7 }  t9 b7 e* r/ A) FUnable to create Hole callout dimension on a threaded  hole
) O0 u3 R; u' f. V) {2 B$ A7395844
4 @0 v1 J1 g' [7 k; h' _mqc_askDimensions() function returns two tags for  a single dimension in drafting
% u' ~2 y& Z  Y8 |/ U7396007
0 ]  ~3 s0 \! e# j  bAnnotations of deleted bodies not marked in drafting
  g4 w, l2 t! O& c6 S7396080
4 j: O+ U( C7 K1 A1 ~0 W) i' T" i. VParser (Python) error received calling OGE05 subprogram  with comments# S5 @2 B& D# P7 e$ {+ [' Z
7396264
, h3 z* A# i7 uGetting an Internal Error when selecting a Hole Making  operation in the ONT" w2 K% ~6 |' }9 N
7396748
9 ^: V, g' |3 W9 iSeparate Feature for Each Body option fails "Make  Position Independent"! X& a" m+ {' S- i) _' [* l: d
7396828
/ P$ }! T2 s! w3 `NX351172: UPDATE_DELETE has gone through too many  iterations, pattern of UDF
5 x( \, W! h9 C! V/ j7397031
; G0 p9 y9 y2 v9 S* `' n: K& RUnable to open part NX 9 MP5Modeler error: coincident  control or spline points
* }# u6 \2 h% E  k) r- {7397240, _/ A" @! v+ B; {0 V7 `
The problem where the datasetname for PDF export can  be changed if it contains a colon or slash is fixed.
' h5 r0 k8 F) E7397281' h, i" }8 Q  E- R+ y; m
Cannot use environment variable for MW_Wizard_View_Manager  XML file
% @" k3 Z( l' G# N0 T: \& |" g) O7397357
. P2 q! T  r: q. g" K5 t7 E" pNX: bad size for allocation request in storage manager   % B2 X4 T' ^5 k, ~7 ^) h! A- V2 N
7397818% i1 i( \* M& K# s1 l0 T0 e9 C
Floor Wall operation not generate profile if two front  faces on same side
5 [7 ~0 t& j% e' T73978268 D; d- x: \/ l2 K2 ^5 e
Cannot save post in PB 10.0.1 MP2; corrupts post
  i) m! g9 R: L# X' X# K" d7397960
8 T. v1 J5 ^7 G; a- YPartSymbolFolderCollection does not work as expected% q1 b- Q5 C- l" W
73981282 t1 D+ z1 |5 o. @
How to set not to copy UGPART when "Save As"  is executed in TCNX.! v: }" d; }1 @
73981591 d- E3 S( v' `8 k" B
Problema con la funzione Print (internal error_crash  when printing twice)
- A3 F; F; T; a) s0 _0 E0 K  h7398344, q9 {. w5 t7 f+ D- i2 |
Printing problem7 B: z2 q: J' q1 T' N4 m
7398600
* _' i5 c! v- g" i) j1 l9 b" R' G7 XUnable to display "Text to Line Gap" option  if set "Text above Stub"+ d" ^2 Q0 `2 [( n/ f8 C
7398751. z$ s( ]. K' i3 }; J
In PDW Measure distance tool not working after strip  layout process0 l4 Z* w5 P- n" N( N5 p
7398903. B5 ?- S; I% S2 G% J0 ?
CAM Setup has not been stored inside History (because  using gives Internal Error
$ q. Y2 h. g9 \7 u7399045
: w9 h& R6 V3 ~5 ^, [3 aWeld Assistant does not honor Feature Sets
- q0 P! }7 x; ~$ c) V$ J; t7399195
2 j& Z/ Z& p5 n# L0 w+ j& U& c4 OAn invalid tag was passed to the tag module2 ~8 L* {$ z+ a* B& C
7399631, b( |: Y5 h% e+ R5 N  ^3 P
Post Builder post reports errors when selecting G  Code tab
6 s4 ~. q6 |6 g2 g' s  l7399914) o/ D2 i: P1 b4 @6 r6 D  A
NX freezes when we execute "View Update"
+ C  \4 ^$ {8 z7399920
% k* m3 C$ ?2 l2 L) pUnable to delete view7 ^: v' m# r6 _, X
7400098% }$ e4 ?; k& o. O( m5 ^  k
The customized command icon does not appear when restart  NX
' Z5 V: ^/ A( Q6 E" `- W: {5 Q- g74001838 t. e% @% u8 |/ p$ P, w( A
Unable to create TIFF file in NX10 from nxplot.exe+ y4 O( |9 b0 A5 }+ k( [8 y* h
7400254
5 w- a8 b9 `+ h/ ]& `# X1 TTilt Angle is not applied when generating the tool  path from MB3 or BatchProcess9 _6 z$ t' f2 V. X) P
7400388
/ O+ A. l& F2 W$ c& D  tError "Invalid geometry attached to operation"  for Wire EDM operation
5 M& h( z6 \. v; d5 F2 G0 v7400505) ^; |. d* s( O
. Q, I  c1 q8 D$ l6 U' h" c/ B7400622
. ~. h0 Z2 K  x! M' z; B! S' W0 GTransfer method ignored with floor stock* |. W& _6 U( ~& s
74007421 `9 ^9 f8 ?) K3 k( d; k4 A: p. S
Comparison Expression variables not assignable using  Okuma Parser1 I+ k# _: {2 k/ {2 A8 ?
7401527
0 r8 M. u2 p+ ?/ N( LFailures with interpart expression in NX10, worked  in NX 8.5
+ |( C# u1 s- m% y, Y2 y. {: M74015491 \7 {8 q: w& ]7 i) w( o6 S9 t
Unable to export JT file, when I have added a radial  PMI to a hole-feature
5 o  g6 H9 F* a$ b+ m" A' t7401873
+ W7 W6 v2 W& y( v6 @4 j7 H! \5 e6 f+ iConvert Mating condition doesn't work: "Object  supplied is of the wrong type"3 b( z# N, n  v) w% `
7402243
& ]; g! }( {0 UNX 9 Post Builder dropping custom UDE reference  P6 Z: {9 [! R: A4 D# K
7402494
) p9 K! @# Y% @8 o4 ?( V* c& v5 HPartSymbolFolderBuilder method getPartSymbols throws  InvalidCastException% \3 f3 E5 m6 x
74030369 n" O$ v3 X2 {( C& \; S
The display result of 'View Section' is not consistent+ A3 U8 B6 G  z( S* B, @: ?$ X
7403504
. N7 ^  \. h: ]5 j0 {, X" c! a2 G3 mPoint selection order determines associatively in  Teach Mode Operation
* \3 ~, B( d' v! U6 o7403552, ^! j/ M% B3 C
Refresh Before Each Path when de-selected still refreshes  the path* d8 R4 q3 Q" E: h  ?" c
74042910 R( S. q1 Q8 ?+ U+ M
The node label can't be corrected3 Q, r1 s1 H# n" c" X1 c" h
7404604" ]2 J) |% v( w
Assembly components with occurrence type "MEConsumed"  are not displayed in NX$ x) Y9 N' V0 ^
7404634
8 z& N% @/ u7 CPTS Copy template as new design does not transfer  classification to new item
' M# }! m) y4 \+ a7405841: _. P+ t8 ?* a+ I1 a
Cannot change selected body in concept from spreadsheet5 s& S7 C* u; u/ m. m0 H* Q
7407057
) s# H  y5 n+ W- _0 h! ZNX 10.0.1 Post Configurator  post cannot be used in NX 8.5.3 as advertised/ ^6 x4 ]: F! ^1 T3 b; t: T
7407411
0 H. d4 |( `, ^$ Q5 z) jParts fail to Open using NX 8.5.3 MP9 after attempting  to run refile
9 V5 i! s/ A0 L/ S1 X7407434
0 |3 r& ]4 i0 R4 @Defpart naming is wrong after update
: e  w4 o( C  r  G& U& S7407552) i/ N$ t1 r" u2 M2 F* N
Neat trim fails to trim when angle is too large; a: @3 \. _! m$ n* Z! g* P# s
7408111' [! D# `9 h2 D/ q5 ^2 ]2 P
mill_tool_change UDE does not pass variables to Post  Builder
: t0 F, Q: D" }* r74091778 ^9 j% G( S6 W5 S8 Q$ T8 D" Q
Replace Component resulted in not loading object attributes
$ `! z. d5 a7 M$ W  Z% b5 y6 B, {& z7409329
) {! q+ N# c* K1 C6 C8 cWCS is moving to MCS when cam object is edited(MCS  or Operation)
  \- r# y. a) A8 U0 R& ?7410068& t2 G) h6 i, x! A, Q+ L4 C. `
Unreliable toolpath hole mill operation with temporary  geometry3 {: o6 |% F2 F# o$ E& D
7410142
1 y- X! {2 n7 ^1 Q3 s9 o: gError at a choice «Fanuc» or«Heidenhain» in NX postprocessor! M8 ]8 ?( U! [. C( J: M9 v' U# v
7410245
. K) m, u1 P  _3 c8 I( FDeleted (-77) shows up in "Show Out of Date Objects"! _- m5 r2 u0 b! ]8 L) n  o3 H
7411220
# R: y) g- U, w9 c3 z  jRouting: wrong engagement value in mm-inch couple  part-assembly: m0 M1 @0 I, {& H6 U: a' H" L
74113335 c0 ~% |8 m) T, ~
CUTCOM creates additional Circle which returns in  a full Circle Move Simulation
! a# L5 C+ {; ]8 H2 A0 Z5 @  a7411917" o! }0 e# j+ a
Deleted or Invalid Class ID error on sim file export% Z5 z! F7 I" b
7412011
( C4 n: E6 N( {1 q/ j3 O  M# WUnable to revise part family member in excel, if original  part already existed
. u# \" l0 w* g' t7412848
0 }, y, R0 R& Y# K8 ^; ^$ F/ B* ]Unable to Create Surface Weld on Face  E4 Z" z, ?8 h2 ?7 Y( u0 V. ?' |
7413284) ]! ?, U+ `4 i$ O! G% g5 p
Getting "Tool Holder Clearance must be greater  than or equal to zero"
) v7 ^! z# n2 S: R; R2 w74133030 C1 p' _" J1 m% r6 T# _% |( d
Performance problem when loading assemblies
* \$ s6 z% P- E+ C" X/ d7413532; R0 V1 ]+ M5 w8 d
Updating part modules updates out of date features  multiple times
# t" u% p2 ~: b5 H3 ^8 ?* f. @74136922 C7 i9 ~; ~* h9 e* {
NC assistant misses a face with Levels option
! V% O0 I6 ~3 L$ d7413716
" g3 ~+ K# v+ r3 _, ], m! [Material properties related help statements refer  to incorrect system attribute
! V. V' t; P3 a) l7413734. ?  {8 A% e4 a8 o9 t
Editing a custom electrode blank component terminates  NX 9 session
" {! R2 i% s6 j6 }5 X7414817
' E, ?, Z' g( L3 q# f. SUF_SF_locate_material() cannot get material tag from  2D mesh
: l' }, ^, [. y. |; [% q" h7414899
1 h% |2 P) I; [7 ]3 O" i' {) lNXOpen GetBendParameters() returns weird bend angle  value of 1145915 as of NX 93 m/ Q6 E/ t: R" B1 s1 H, P4 P
7415877
: m" w% O9 T' d! ?- e, @) L; YMeasure Bodies causing NULL tag error when measure  certain assembly
$ E1 j. t3 E  U/ X% y9 R7416422* }$ a4 y$ R8 h
Wrong behave of Attributes (ENG OK but GER not OK)$ u0 x6 F4 y- S$ n0 x* A. L
7417089
3 z5 Q8 R5 _/ ]5 o! }4 }Create 0D Elements -- Incorrectly changes all Mesh  Associated Data- h" r! ?0 s5 h% G! V
74174399 A- A$ |2 f6 {. p3 a- V# o* s1 d/ ?
[CAD] The twisted shape is created by the "Tire  Envelope"5 `' Y' j6 g  O* M
7417550
  }5 I' X& G3 b; i5 l1 LMirror electrode fails to clone blank part from TC  in NX managed mode
. ]0 D% r* f7 D# Y- }7417597/ P1 |- H+ E; G) q6 Y( p& o% A
NX hangs when the operation name which has 128 characters  is copied and pasted) t! \/ w' L. U5 o: I* v1 ^4 J
7417645% d, g0 A; }( w/ W' Q
Gallery name is displayed incorrectly
2 U! t. q' R3 f* b7417650
+ z3 T" N9 x6 m' f$ zSome icons are not shown when restart NX if using  a customized mtx
& d4 k& A6 l1 ~  |- Z  F7417795
2 i/ P) `) J* a) T  XIncorrect rotary axis movement for Fanuc G91
; L4 @  O5 l7 N, E7 _' U74179946 ]8 e8 B( }* J- ?  g& {
Mesh update slower in NX 9 and NX 10.0.1 compared  to NX 8' l/ v& P% c4 o
7418280+ d) ~, x% N$ J1 J
Attributes do not update in Part Family members after  modification
) q* p8 N9 \/ m. P2 W# ?+ U2 n7418501% _8 i! q  X8 m: P9 w' d7 ?% q
Viewers don't see assembly level color with NX managed  data
3 M1 v6 n5 x! E0 O6 Q74185230 W5 F" h9 z; A7 T5 I8 W: }% t
NX ShapeSearch fails for Body with UGII_GENERATE_MULTI_CAD_JT  set4 Y  y: B  `4 T/ y. `; D
7418531
. j% w: ~% ^$ e$ g# \8 D; SNX: Info.WeldInfo object LogMessage outputting inaccurate  message' w) }* y  o7 Y1 e: o
7419493' u' z: ?. }. `) U
A part which has Linked Compoiste Curve created beore  NX751, and has source parts completely unloaded, may show curves in wrong  position after Part Import, C" Z, @& ^+ q# Y. H6 ^. u# H
7419790& P8 l4 {3 @+ Q% y* b
Subops in Generic Motion templates are limited to  a certain amount
5 u$ W: n5 J* n7419848
8 R6 j! J$ g) j0 W! E& s& kZlevel profile operation violates the part geometry
5 l( l. H' b7 I5 |( x& l- |7420183- G* k3 S' ~; f6 j0 s! j) L
Unable to keep sorted result after output spreadsheet  by customized BOM template0 E( K( X9 _" l
7420240
* {' ]# R: g% D: U) m- u3 u  a% x" cInconsistent result when changing spline path length  on a new\existing part1 e! b; H( f* U; \$ H  v" J5 d9 v
7420328
+ J3 L+ z4 D: V- R% N& \Internal error occurs while opening NX drafting part% G) `5 o  b: s6 [, B
7420433
. u" o- V* K* B4 I. S+ N! yAdd additional column "last modifying user"  in open part file dialog in NX: l4 V$ U- ?9 g" O! _+ X  J" o
7420440( B: R8 Z) k6 W8 d2 {/ L
Teamcenter Navigator in NX - custom attributes are  shown with real name, X  R' M/ r+ c% B) D. D5 i# v" L. N
7420442
6 {. `. `$ h6 UMW Drawing inherits Symbol Text Font from Defaults  with own Drafting Standard* p4 q; r3 ?; \# M
7420858
- P0 Q; Y& k+ g3 dTool holder collides with part geometry in floor wall  operation5 z! h) {: V6 I3 q5 r  X& B; v
7421004
& b& p- N4 U7 m, p: X& P6 a9 ^Reduce Ordinate Dimension origin label size, changes  to default editing dimension4 E4 H; `% m+ u: [
7421361
  U( A3 \0 ^4 w( M% S/ OLinear Counts on cutter path increased from 75 to  547
2 `' B; u! t9 M$ L4 [7421708
+ q6 a* G6 R: r) m0 o5 A+ @GetTaggedObjectVector & GetSelectedObjects does  not returns selected object, |# n9 l5 N8 l8 }
7422218
4 k( B' z/ Q0 C8 U, t; a! P, ]' EPrefix_Suffix location from shipbuilding dimensions  will be switched( b: x- v- J8 g3 q
7422566
5 q+ z4 _0 c3 ?, I. o' y3 RCopying a Tool in NX causes the tool to disappear  from TC View display
7 W) `$ }- I/ Q$ T3 b# x7422712
/ f: m2 p) [2 W" p) CGetting large Initial Move from out in space at absolute  CSYS zero
9 M' k, ]/ f" f74229605 X  H  e* E0 Y4 W
Copy and paste of a feature can't be done2 Y7 o& L: ^( P' ?9 w
7423221
8 Z1 Z7 L" B1 p" j! f4 }! k+ CExisting attribute does not allow to edit the value& z: v  I7 I4 O" T: r0 V3 f
7423310: K1 F! f8 b9 a) L
Cannot select the Coincident Curve of Face blend
1 o& v- x, J+ F- H7423766
5 ^$ e: g+ r( y7 ?9 |( nBug in tcin_cam_template_setup.bat - tries tcin_cam_template_setup.bat.bat& l$ X, G. G5 O0 E& ?. |: Y& T
7423882
7 K! D& a* P3 E! jPre-NX6 group resize Grow_Shrink -> None (please  backport PR 7393956)
$ w2 o5 S( `# |. Q74252468 R; }6 q. s- }& v% t$ j
Overstock not processing Reference Characteristics- g7 E" C2 C- v8 L" \& g* P! ~
74255073 _! o1 Y* u( g, y9 o, q
GDT symbol gets tilted during edit and export to DXF/DWG.
$ N, M9 M' t0 N! i* S6 ~5 e7426049
  w+ D5 z# q& t$ t% g/ }9 N, i& \$ K; DRegression problem: File works in NX 6 but cannot  open in NX 8.5
, P4 Y( L+ [' B) R' J! v$ h7427065+ m! ~) M+ z0 n6 e
Operation does not generate because of "Internal  error"6 l0 x0 h+ ]9 z: [- |# H. S
74272257 y# w. t  @3 E
The display of assembly parts for grooving tools with  an tool tip junction at a different corner then the first was wrong
* T3 Q0 Z+ s4 [) |7427386$ K6 q6 M1 |) f
Save As New Item Type with different Rev ID as assigned  is not possible" d' \. X% ?* U6 R# Z5 s- ~# I
7427456
6 b' m9 p* S# ^Repeated use of UF_PARAM_CLRPLANE_USAGE makes NX crash. m9 M% G6 Y4 J+ f7 \
7427544
  q# ]- u1 L" r9 V( L/ @% ]: ~Node drag is not working in NX 10# r! a1 K: C- R2 h
74276416 ^: E/ q  i. w9 ?; t' ^
DXF converter is not reading options from the dxfdwg.def
$ s* C. ?" E7 N; O+ c: A7428456, @( D7 s! k! B( v( p: v2 c4 n) N
Part Family Member part is modified message after  post placement of gasket
4 Y8 T2 X; w& Z74287067 |4 [7 J4 i; Y. z
Assembly constraints not immediately displayed when  placing routing part, {$ Y7 m7 T8 p7 v
7428719
- z2 s$ I4 O& ~Routing Reuse Search dialog does not show values for  search criteria
$ ~+ G: t6 Q; S# G, c7428739
; K. b: d9 V) LRename non-master by saveAs New Item in NX is no longer  possible2 o: U, x) b& M1 s- t+ F, V$ O  Y* N( {
74294413 M% O! d8 a8 O3 R# T0 f; c
ExportAfu() cannot export correct magnitude and phase  values in external mode# k3 L) g6 _, Y- b
7429662
9 {7 u- \* H7 d! l+ n5 u: t7 VOpening part family dialog is takes more time compare  to earlier version of NX 10! K" S( Y0 O# n! _4 X
7429756- x# F. i+ h' D9 Z: A/ D
Internal error occurs when point dialog icon on "Select  Object" block is pushed9 c3 i3 k9 m" U5 |2 I
7430627; d# h3 U4 X# E, ]; a
Feed and Speed -> Failure while generating Toolpath
6 s# Q" e6 N" Q: Q2 U% Q0 o7431105
1 p5 {' {& H+ g& ~( x: f* UThe problem where NX STEP AP203 and AP214 translator  products are not exporting and importing Nested External References files  is fixed
  G& N" \; m* R. J& B9 x74313296 p& n* t- G% B' \5 f, ]# @
Delete core pin causes part model linked body in core  file to be deleted) e  B$ b: k  S0 `; n2 x1 t
7431439
. k, ]% a% n# UOld Alt Rep component replaced in SM BOM continues  to load when sent to NX
" l4 r5 A0 ^' h7431930! o- L# i2 A+ f% r8 d
The user cannot select point & snap point on point  dialog in drafting view& w8 b1 p* Z" @& ^! V( m
74320013 x: M' f+ Y; W1 [! |
[CAD] By specifying the "Lock to View" can  not control the helper line+ b; t7 o, W$ W. `& F# Q' w" K# ?
74320032 K4 ?) `5 C: C% o
Clearance handles are not shown when selecting curves  with zero clearance3 Y6 W- t0 C9 J1 u0 q
7432113
/ m6 X+ O/ X- S/ T' G8 HFile open performance is worse in NX 10.0.1_TC10.1  than NX 8.5.3_TC9.1
' P. M' I9 G) F# B7432166: e: ~- w  z4 e0 e; i1 t' t+ h$ _
Auto Weld Symbol not working in
, t: U& y8 y- n4 t  \7432774
9 s! b' w3 l$ v  H% W! b5 AReversed offset direction in mirror feature/ @5 G% b! F& H5 l, O: d9 @
7432928" j. [" \# H1 j% r2 V$ g" |% `
Search object By Name fails with internal error! T5 P) i/ A$ E
74329889 f0 b4 t  [" m
The problem where the template region overflow logic  should play role only when contents from different regions overlap each  other (this is mentioned in TDoc) and not when the content of high priority  region crosses over the boundary of low priority without crossing/overlapping  the content in low priority region is fixed.7 i0 @4 `+ p' V, C, \2 K5 \4 I) \
7433907! M, \/ r- |; O* L4 D$ y+ x+ e# P8 j
Unable to save as Specification drawing when Save  as new item/ w$ V7 A& K9 O! w0 N
74342332 G! a9 O' P+ p
Layer changes when export to dxdwg
3 Q# N; U2 c$ R) W' _" F1 Y( e2 \7434936
2 o- N3 ~' [& ~! l4 A7 h4 nNX Crash on AskEdgeFeats call on specific assembly  drawing$ Q0 j5 E4 E8 v. [' N
74352012 C" r; m9 j! v; H
The problem where the customer cannot save their Routing  assembly due to stock descriptor characteristics (i.e. DB_PART_NO) being  applied is fixed: ]: ]6 R  ~( A3 A: n1 D* r5 V$ \
7435507# t: e0 K& Q5 k. t8 `, t
While moving assembly file,it throw error "arts  in this session may be corrupt
. {  I' r( Z9 }1 q- w' d7435528
0 Z. d. t; l& b& [) |+ k9 hStart SpreadSheet of PartFamily in NX 10 takes more  time compared to earlier version, ]% Z8 ]8 Q" Z, m. u1 g4 {
74355473 @* J+ n& P7 S
Closing part family dialog takes more time compared  to earlier versions of NX 10
2 ~" X' H7 o8 C* J- L& w7435658
6 w" s2 r6 ?9 }* h4 }  |$ ~Opening part family dialog is takes more time compare  to earlier version of NX 105 q  P1 D6 P/ M3 h& S6 E
7435666/ N0 A5 _7 Z9 }
While add component and loading in NX 10 takes more  time compared to earlier version
& a1 Y( q6 K2 [: h5 A74361982 @1 m- \' x2 @! y6 {# C
Centermark does not shows correct position after changing  the hole position.$ H8 O  k: \$ s: I' l
7436385( L7 y  ^, r. w
MKE does not accept special characters in UDE Label3 X, O% M3 y5 w. ?0 i
7436438" {- \: Y4 x  w. d' o9 j
Different numbers of curve if Edit parameter or edit  with rollback is selected, X  Z- Q- [" f& r* M$ r) G
7437460
: y6 Q/ W# G& |8 Y1 A: P0 ABatch Process only calculates the last operation selected  on ONT7 l% V, s. L( u
74375764 O$ x$ g  h! ]* p1 v& `5 L6 K( x! |1 ?
UF_MODL_export_udf() is limited to 13 parameters
9 J0 o5 \6 b+ x( w% R0 ]. T7437744! C% ^( q+ U- B, R  ~
Custom cycle GROUP is always open, even though DEFVAL  is "start_closed"& \0 k- j  s6 h& x6 `
7438056
  Y' p& a) l2 j7 Z! N" l" ^7 wInvalid Filename while open parts with NX 10 because  of desc part name style
, x( U* c$ P- U$ H+ b7438229
" B" _$ B2 {1 `1 w+ k8 zHide Business Object rules in BMIDE cause item to  not display or searchable NX5 [! `( j2 C  w; X% e8 h
7438787
1 T. f% p7 @/ L& o8 X7 uCAM: Can not delete some Milling Operation' \: z* Y) `& I. b/ D) @: H
74390670 `9 c4 L/ R( k$ p# w; b- ~; ?* e
MW Standard Part cannot create geometry expression  link from different parts
% L: t& U- j4 v+ p: Z9 m% V7439169! N( t, s; g4 l$ g( H0 p
Edit arrowhead in mixed state to Closed Solid Arrow  fails/ W( h- i/ V3 r7 Y8 t/ F$ L
7439339$ ?& d3 e  T9 W3 ]2 w
Part cleanup generates retained 2D centerlines+ ?' h$ b- @9 l$ R
7439411& S) M2 ?2 Y  z7 K( Y" j  t
Cavity Mill Profile gouges Part% v8 u3 N0 [/ ~, J4 h( h* K
7439445
, x0 x) {0 H, z6 YNX: The specified expression variable does not exist2 k- ]0 w4 [+ z5 E/ w. {
7439794! x+ s7 E5 ~& v' f9 M4 ]+ R* J
Attempting to delete category 'ALL' corrupts session' z9 h4 o; k: i; F( f/ ?# r) C
7440155, f( N( W# ^' K0 N9 s
[CAD]"Make unique" command cannot control  the copy behavior of Direct Model1 g0 c* Q0 j# ~) e3 ~) B# A/ ?- N
7440262
: N; i7 k2 w" I' v" h$ TNX hangs and crashes Fatal error1 \8 u- k9 ~, I" ]9 X' ~/ ^, X* f6 n
7440282
5 a1 B2 o/ n6 b' D& FSave part family in spreadsheet takes more time in  NX 10 compared to earlier version3 w% ]) U( ]1 l
7440284
" p. D: c; E' V) f( jMW Standard Part position on plane incorrect depending  on point selection method
; I! v/ n4 n7 M8 @& h4 [74403876 Z$ ?7 D3 m" }- ?0 ^5 j5 \
Design part not replacing the seed part when creating  a MENC file using File-New. Y- y( j$ o% ]7 X/ ]" ?- y" d$ E( D' Q
7440419# M' H" M$ b7 z1 O' X3 d# X1 R
Wrong dimension values in Ordinate Dimension+ ?& S/ `9 V) m! e7 S
7440684
- w  V, |: t6 [% {% F( F6 PChannel 1 and 2 swap places when opening sync manager
# r4 S  W5 j+ C& n7440762& o; R( \2 J2 N1 ]% a# A5 v1 D
Cannot Weld Pipe to Pipe with Hot Fix$ N( x* W+ T) u7 Q7 {
74409074 n) Z( ~# h  h3 g
General Packaging - Windshield Vision Zones &  Wiper Zones not correct
) d' `/ A7 E2 w$ x+ @& }74413086 K; R9 Z5 G5 O( \
After part cleanup if you save the work par then an  error occurs (Attempt to save bad pointer, save aborted)3 v4 j; u1 n; j9 b
7441821
! Y0 k# C- U9 Y1 u" Q5 A: pEdit Attributes in NX shows two non-editable fields  for Value in German UI
# {, E5 M8 w' c$ s! X0 R7442102
' y4 S! l6 c* aCannot get values of interpart expression references  in NX 10 anymore, h& K/ h5 q5 y- @! V  c+ V! o
74421759 V1 N, w( P$ r) q! G0 C7 Y
Drawing shows out of date (!) in header unable to  update& X0 z; z6 h3 {: N1 u) \
74423754 J2 F# D: ]* }) E, t; P
Unable to save to a new rev. via part family
/ F2 D2 Z6 Q9 v74426644 p) V- s" ^3 r( V  R" e
Overlap Distance is not inherited from the template  part. in Area Milling
! z/ e4 ]. M/ H7 r5 o7442666
$ f9 P3 C; U6 k$ @Tool path at the steep area is not connected correctly  with Z level ZigZag7 a* K5 f6 a0 \) E: Q
7442928# j. d1 E4 [# ?5 t# T9 w8 |( f
The total resistance value of the solver input data  is zero
4 b3 i; p  S" z& H7443347/ T6 g, ]- q, }; t3 X2 k3 i8 R/ _
Loading a specific role when starting NX is not working
" I9 ^& }* f! |7444361
# n6 d# ^( e  s" f4 w" }8 U: }Not possible to save Assembly as Altrep  q0 r/ j+ M1 O3 ?0 g
7445049/ {( n% C$ l* S8 E5 v' Z
Edit Line Segment - Detach Active Control Point changes  pipe angle
5 p3 W# L5 w8 X$ G74461903 l8 t' y. O/ g9 c; V" H: P
Error XML out in NATIVE SHIP DESIGN APP NX 9.0& i; r* T0 ]: i* W3 |
7446738
/ p3 M" v( x; }Cannot open the FEM file! A: [9 d( N* u* Z/ Y. _4 }
74469134 @5 o# D3 `* j. c
A problem that does not open the OP2 file of MSC Nastran5 z9 d' A; J  N) R
74470526 v" K6 S8 r4 r' I, Q" Q8 |
Error XML out Ship application.6 C3 C) Q6 L3 ?3 }* I
7447661
7 D. Q, \" u! q.NET remoting  no longer works with an external server process
4 {6 L. ?7 @& y7447946  Q& Q, d; U1 y
Getting an "Internal error" when pressing  "All other Parameters" icon9 T, T/ w9 b; T) U# X" P
7448083
' Q/ R1 T/ Y3 @+ o& ^- LNX 10 with TC takes a huge time to open the dialog  of "part family"
/ b( L% |" V3 k$ H7 J7448089
$ p& k& d6 ^8 C  K* [& ]% IStart Spreadsheet of Part Family in NX10+TC takes  more time compared to earlier
, A3 T* n. s6 {74480969 v% r: }+ i# ^: T4 }( v$ ]: `
NX10+TC takes huge time to save "Spreadsheet  of Part Family" compared to earlier
& `2 V% u) Y3 ?5 U5 s* U! ^7448104
! k7 p# `$ a$ M- p0 P9 {4 x: DClosing Part Family dialog in NX 10+TC take more time  compared to earlier version) ]7 N! U# _  ]- V3 L5 j  G
74481088 N( v+ r2 }0 A! q3 ?8 e
While add component and loading in NX10+TC takes more  time compared to earlier8 F5 p2 ^" a4 d2 w. ~5 V- C/ Q
7448143& V% a6 S, {; |4 i' `0 P
Selecting elements based on polygon geometry using  related elements does not work
& u! N# F8 q1 [! j, r4 z' q* `7448145
* F1 W' `4 s) |4 M' g* ^3 e; iComponent status not returning properly: O  s; ^2 u! l1 l( O" S1 h' P
7448270& \* H2 V( E: ^+ {. N% U  ~
Machining Knowledge feature teaching and angular dims  of conical surfaces
3 E: m  N7 F" U7448382
1 W9 w5 C: Y; jPDW - Initialize Project - Internal error: memory  access violation
$ V# l  S  X2 m2 B% K7449784
5 P# f4 ^5 Z9 pNX 10 fails to load Parts having expressions* e. n+ Q- l: E7 B" z
7449991( l: N* i% }; Z$ ^  _; W% t  N+ a
MW: New project drawing does not show images in the   titleblock  in NX 90 e; b  G0 J5 ?9 e9 H
7450283+ F$ S- N5 a  V
Polygon Edge cannot select once it fails in "Stitch"
, }" J9 Z0 i( ^7450423
" o9 g1 M- Q9 \9 f! _Unable to de-select the Pole by "Shift key +  select Pole" in X-Form operation
  T: `# f: q9 m9 t1 f- F74505991 k6 v- J- X+ I. f9 }1 K, z$ M% l! i
Missing Home Button in NX10 Web Browser
" R, o- @# g  ^74509409 S/ s: Q: ]7 @6 ^+ t% T
CAM Batch Process is executing only the last operation, H& A6 {/ t8 W# p1 _
7451146" U$ v* u! }- K5 Y% v% c
File > Close: illegal file given to tag system  due to exploded view in drafting
, E; L; ?' _* U7452545/ `; i/ y' P9 g9 [/ N. m/ z
Auto Part Size, Diameters
7 p, Q; }; J/ N; z! W0 ^, e, \7452717
$ T9 {$ a0 I) j! D% O  CShortest Tool stopped working after upgrading from  MP2 to MP7! W# U$ H# Q! e+ n( v
7452858
, `; Y# Z5 f0 x9 ^Post error on cycles if tool does not fit in hole
8 S2 M) }# Q1 h7453664
" V. ]9 n! f. l0 r4 o( J6 W/ P: n; FThe problem where NX crashes after exporting jt from  external application is fixed
5 [( d, Y# b2 r- |! Z) ]6 U74541950 n3 K9 n) S8 q9 v7 m, A) i6 M  o
Assembly raises Update Event Viewer when opened in  NX 105 h: Y& S5 H) B* P1 r
7454752
7 p. s7 L8 M# h' dNX 10 cannot open files from Teamcenter when User  has log on name with Umlauts" j4 D/ |7 [  z
7454784
' R5 d; h$ E" X/ L2 F[CAD] When saving a UDF in TCNX, an error is displayed
' E5 |# W- R0 @/ K0 z( I) Y7455488: f* ^' O5 ?: K9 A) ~
General Fault Exception when trying to divide cut  regions- G# K+ A6 h# ?
7455564
$ g9 e% I6 W7 HWrong excess material in Analyze& `# k! `4 H9 C, A6 N% ?
7455796
  {( [6 d% V; G3 hGRIP EDTEXT causes "Stack Overflow" and  terminates NX 10
( K! N4 A6 ?, K7455899; v; A7 P8 b0 f* \- L2 G
Tooling Manufacturing Geometry doesn't maintain Face  Rule setting
! F, b) ~8 t8 N7456072
  V* J: Y# b6 _; R2 q0 QTooling Manufacturing Geometry UI hangs up and NX  needs to be terminated
6 _, [+ m/ P9 D' E7 Y: F7456166& ]( z) h, d/ B! b) i6 ?, b. V& D
Problem where STEP file containing locale characters  was not importing correctly is fixed
9 P- a4 s1 D+ f% Z: ]( ]4 A7457681
2 |& F6 i% w1 H% b, A8 q1 SFile size has increased 10 fold (7385237). _7 V: p3 D6 C8 o
7458015
0 G3 X7 B# Q9 [& kUnable to create hpgl file through nxplot.exe command  line in NX 10.0.2# m% e. y; P6 h& T) l3 h; B' O8 p
7458337. m1 v- h2 x0 s1 R4 I/ Y
Internal error: memory access violation (11) while  opening assembly file. E% B9 d: |( L4 w# X1 Z2 K
74587453 ]6 P+ m  g; |- O5 f+ D6 t
Tire Envelope Wizard yields a sheet body which cannot  be used in modeling operat
8 p5 Z) C. S( r1 w; b7458765
' {# J, A( W" X; O2 B0 g0 rRouting:Null pointer supplied to Routing) U0 b4 k: x9 d. v' y3 S
7459058( {) t" i, b% u# i
FitCurveBuilder - problem extending both Start and  End. i4 h/ p5 a6 c+ L" B  t
74592123 P7 q4 i: L" ]! ?6 Z* v
Follow Predrill Points are incorrect in Cavity Mill+ u0 W5 @& U- N! Q0 D+ R
74592585 J7 O' c& e' }# L
Stop At Intersection does not work correctly in provided  case+ x1 b6 a8 _, y4 ?1 H6 ?" e
74601641 F% i% S: S" K
Macro playback with long part file name fails with  IE or terminates NX
2 T3 I/ c/ h, V, d7 H* z7460165
0 J5 x1 D9 w* }# p) nFBM: Calculation of ThreadLength attribute is wrong  in NX 10.0.2.6
5 q+ T' f; E; ?2 B4 R7460678
5 }1 |8 {4 y- C* A- A/ r2 N: a3 @Can not open the assembly file! v5 D' W: U% K2 X! f2 X* J
7460903
* z( X  i7 {* m  ?Invalid part tag - Error occurred in editing a Reusable  Component8 l+ h! E+ U, y
74609149 b& {$ ^8 t9 p
Input is not a valid parameter when changing font  size in table note+ A7 v0 P2 ^* w4 B  H& j
74610112 @# P0 j9 U( F' z
DecalBuilder.SetImageFromPart causes An illegal file  was given to the tag system
# e0 i) f1 s4 M8 V" ]6 J# C3 T7461153+ S& O2 x! ^# K0 {4 B
Error "Invalid File Name" when loading Parts  with referencing InterPartExpr, t; u! \: N+ A! d  g! x
7461207
( ]1 \, T1 Y8 a1 R) i' P: a) QFBM_HOLE_MAKING: 'COUNTER SINKING' does not support  5-PAR. MILL with Tip Angle
: ?( M; _) R9 W0 u; U7461299
* d" C- i7 Y4 Z% r; e: N2 z4 T0 EFBM_HOLE_MAKING: 'HOLE_CHAMFER_MILLING' does not support  5-PAR. MILL1 z  v  n8 ^9 z' n1 ]- {
74617347 [6 o3 t2 t, F% h& q% ]2 B
Marking parts as modified" {6 v  A( [* b" `0 k6 {
7461929
% y% E5 e& X; m. l# t- @6 FPart and IPW in Intersection Strategy does not work  correctly
! M2 M0 ~" {- r: [  c4 k7 q( N2 h# b74624293 G% C" ^1 N* `& L6 A: l8 q
Overlapping columns in the HTML file created by Export  to Browser command
" X8 Q! B9 M7 o* t7463185) N% O- r, t+ k! o$ x
Start and End reversed after adding End Cut(Flared  2-Side) to BUP Stiffener
5 L- e3 v/ m3 ?' R# S) {3 R. r" V: x74632553 W' A+ g$ \8 _
Select an object to edit the leader "Internal  error" occurs: |) s3 B7 E  M* E# \
7463269
3 R; W' f; j! `8 ?. yIn special case, Operation Runner function appear  error, and can't work
. E% s; b# h( O8 U- \7463342
: L! h# k8 l" I, i" K8 n+ _Internal error when try to create Joint Mark in 4GD  mode
7 }' N+ \2 ~% |, q74635019 l: u0 c3 H/ K4 i$ j- _
Structural Welding cannot generate Weld Preparation  on ends of a Profile
; R6 f+ u5 f* @7463992
" C6 O: ~$ J% |. x- nSame issue as PR 7340087 - component disappears in  model
' c6 U' w  ]4 G2 c' `7464051
, N- t" {- _- _+ r+ ?) ?" o8 E8 PNX 10 post does not output correct UDE cutter compensation  register value: v: ^! O" x7 w: |- h
7464410
3 `9 H" O! d) q) YThe feeds&speeds and machine control are missing  in the planar milling operations- K2 Z. D% D4 N/ }# z* B6 ]( r
7464751
/ T) N9 V1 G7 V6 Y, d& qCountersinking does not work with Standard (Twist)  drilling-Tool
% _$ b, I- w% B) [  g- Z7464972
8 @# M$ |  M5 xWhen a grooving tool is remounted on a pocket on a  turet it is positioned wrong
- w; B( o% n' L6 H6 ?! q4 J2 E7465928
7 W7 \) m: h1 n6 X/ q- S3 ^PMI Cylindrical Dimensions have incorrect extension  lines+ m4 u& E$ q" U% q% M: X$ K- y
7466062
+ b4 k* B' Y1 m- j  G4 g. K% F- NInternal error when change Depth per Cut& L6 T3 z5 D9 r/ i7 w- h
74661937 Z! q. @% N  o% Y6 X2 T# v
Wrong NX 10 attribute dialog when using the German  user interface
+ f! h8 m! {; ]- g7466281( r. a0 t$ H% s# H' r0 M' B
Weld Publishing of Pipe Welds Doesn't Work with Our  Latest Hot Fixes
. o3 L3 H" I( q% }$ r& o7466597/ \. q+ V7 ]% M" Q/ r
NX: GRIP EDTEXT causes "Stack Overflow"  and terminates NX 106 n: a6 N: ^. h! }" o! V2 D. Y
74672739 R: v$ t6 S8 Y$ R0 ]* ~$ X) L
The display of assembly parts for grooving tools with  an tool tip junction at a different corner then the first was wrong" |5 @9 F' \- q9 _
7467425
9 i3 T- K: F* n" r# RNX 10 hangs when using "Body(s) Without Assigned  Material" and a promoted body: {% o# ~+ o* p
7467555, W2 a# T- |2 n: H) ^! w4 j
Neutral Factor Value in unfolded view with SB Convert  To Sheet Metal problem
3 [. V% Q0 R" ]74683910 X2 \/ b" s# [- `1 \4 H& O& j$ i
Failed mapping units in information window when you  import materials! @& D* E: x* {- K# }, K
7469125: d0 O* g  G6 Z) ]: ^
Coolant Flow defined within "DEEP_HOLE_DRILLING"  is not printed to CLS"
. X+ D& s7 h, \+ ^4 m7 Z7469153, O/ H  U( }3 [& P+ n9 X# F: t3 s1 q
There is no "Depth Increments" in Deep drilling  with chip breakage Cycle
' X; M: A" \# d! \% \7469161
: m1 {& z1 A# j  Z6 S+ uDwell at Starting Point is not outputted into CLSF  in DEEP_HOLE_DRILLING" O8 n* d& f7 t
7469163
  i9 D0 |! Z/ G" K6 gDatum feature symbol is not created correctly on FCF  having stub length zero8 K& V$ e3 J/ n) a3 T
7469284
" c+ V/ _. f6 h3 q6 G6 m9 fInternal error: memory access violation error occurs  while opening part file; T8 L1 \6 i) R6 X0 G
7469432
' Z& `9 U. v. j- ]# C6 xGRIP EDTEXT causes "Stack Overflow" and  terminates NX 10
7 _: j+ c- V( G8 L7469599
2 D  h" f  |5 T2 o, F  \3 aLight on polygon body issue in assyfem context! ^# Y/ `6 @' c  [& @2 ?& k! g
7469700
3 I5 U& r: {! D# y0 W9 M) ZObject Type wrong if ASM will be load by "partial  loading"
0 @2 d$ Q# O* n& c9 s+ ?# V# h$ y7469857. R! s9 a2 T. a) [
Error with "point to Face" 1D connect: a  tag was passed belonging to an object2 X  U2 r/ G" q+ \
74703366 d9 D7 G1 ]% R7 I6 }7 U: A& G
Old tool path not removed from graphical view when  generating from oper dialog0 G. C! `' e$ F6 C8 s
74704647 c( v* u, S9 h5 i: r- q) S1 o
Unknown region is displayed in the graphics window  when you create a FEM- Q$ O  o$ h, ]! }& X# P, {9 {! ^, N
7470623
5 y1 }; `9 M# u+ a: N  yDialog for Partattributes corrupt in German NX 10.0.2.6.  Version* ]) I( s2 p. P" A- S2 @
7470757
9 z9 a( t0 f$ D( b: ~1 b6 L* LUnable to open Drawing File with "Null tag not  allowed" error5 ^6 i0 W9 n1 D# S) i( ^4 _2 H
7471437
8 @) v* e. g. P6 p% ~( P$ rEdit Angular dimension requires re-defining it where  Settings does not
9 W8 F4 G% `. q* ?# v8 p* z7471779
! S/ z! i: m% Z$ EMemory Access Violation while open a UGMASTER partfile
& V1 }. }6 Q- z3 k/ R7471816
, ~9 g; R7 V4 p9 E$ v/ _Memory Access Violation during view update5 H$ ]0 t; C7 ~* v( J
7472467
" o5 i8 H  X# z1 ~2 w3 i2 BTool Paths are not refreshed when the operation is  regenerated+ a% g4 R9 N+ j
7472594
# N% S6 G  T+ G* e! r# {Samples machines posts sim01 thru sim09 won't open  in Postbuilder
/ L: w( \: R. q3 m/ d: n+ B7473258$ X$ b5 }7 O7 J; @; q
General Relinker description incorrect/ Z) f. b, F+ j  ?# v! k
7473423
8 m5 Y. V, o- A+ O% g2 HCycle Force display strange in post builder 10.0.2. y+ [- \" u; b
7474064
0 p# r9 M  \/ Q$ P5 z" ^) }The specific dimensions has become a cause that causes  an error when "art clean
; D& m7 X. Q' |( [$ U0 _6 ?  F! u7475859- }* A& I+ r8 ?' h
Invalid Filename error when fully loading components
3 W" C5 w" x* |/ ?5 W# P7476349
+ {* |" I/ Z' @1 eOperation not refreshing old tool path when re-generating& N: f  b/ A- d8 U
74766970 A* j+ }' q- O6 M- a
Wrong value is imported in <(kgf)(mm)(kgf-s^2_mm)>  unit system
% [( t8 ?) I& l1 k7476719/ `8 v3 C: m0 g( B- k# K
EX: GRIP EDTEXT causes "Stack Overflow"  and terminates NX 10
) l. K1 f( q8 ?; o& n8 v/ |7478090
" Q+ v  m7 b$ \Leader location of the labels having no text changes  on view update
: x/ q' t" k0 L2 ~) T7478092/ E  `6 \2 G7 A) b2 t% @/ M
Attributes dialog contains 2 unusable input fields  for value+wert in German UI* E) B6 y* v$ H( \, ]5 J; p1 p
7478292
5 _7 ~( Z2 n0 u% e& a% ]" {Edit Plate Thicken option from two sided to symmetric  doesn't work properly; P& P; Y1 ]- t, f6 F& F8 ^
74793134 {1 |$ W+ a. k/ y
Getting wrong part name- \: I% Y) m$ l6 H3 B2 R4 ^
7479634* V& b& W9 m, v& T6 P
NX freezes when defining constraints during add component
( ]; t4 E  {; b& i' N: X: f$ O; U7480074
) N6 }5 e  z# P$ DDisplay button does not refresh image files- Q8 G* K! ^+ g5 F- D  n, ~
7480118
# l5 L/ g6 t( N. E4 P2 A1 U; zA Documentation operation can be assigned a tool for  reference purposes, but does not contribute to motion in the tool path,  so the operation should be ignored when judging for a tool change.- _9 v: N# a  r, }" c2 ~
74801652 \4 Q! \7 Y/ m8 i; o, o
MOM variable mom_tool_number does not update
& q1 ~# m' [2 g2 f- t7481066! w9 Z2 R8 a7 B0 c9 ]
NX MCD crash _ unexpected behavior with objects created  by source
$ B$ f3 c) Z/ h2 p# X* p$ |' Q7481463
2 _# M4 K5 u5 JUnable to design an insert using Parent part type  as "Owning Parent"4 Z. q# Z, j" k) ?
74826412 K* d0 z; ?# r7 A3 R  Q
"roblem description:
+ ^2 C: x6 g: X! U& Y5 `% N! n1) When Item objects are classified in the  classification tree, we do not load them properly into the NX session  via the Routing re-use library
/ `# r; p( U8 ~  E2) When a classification hierarchy is defined  with intermediate nodes as type StorageClass (instead of abstract), we  do not find the start nodes properly during our search8 c" b2 @2 f/ }. }( z* ~. @# f
Problem solution:: T$ E/ d& w) y+ i
1) For Item objects, set the TEMP_PART_SPEC  correctly in the charx data for the individual member rows so that we  know that we have to look up the specific revision based on the current  revision rules when we go to load the part into NX/ N" V6 ]( ?+ U1 m
2) Traverse the classification of the hierarchy,  including StorageClass nodes, to find the starting nodes for the Routing  re-use library tree.  We  actually reversed the search order and no longer due a depth first search,  find the Classificaiton node with the specific identifier and make sure  that node lives under the passed in start node.  This  is much more efficient and does not require searching the entire classification  tree."
2 M/ ]& u2 j6 `7 l( m# C6 q, I7483079
& v/ ?0 x) Q' f0 m, i8 T7 ^Unable to open part files with "Attempt to free  already freed object" error
( x- K" P# o, m$ M2 ^! o7483306
( y1 s5 ]( k: s. M1 G7 LUF_cs2_constraint_type entity error in checkmate
* E6 j, s+ b% i7484543
; ~" [5 \2 l2 L$ @- U0 u) H( Z& HTooling Stock Size shows wrong dimensions with existing  pattern feature in part' \7 `: E& o2 \: A
7485037, t5 B; h$ m  x, t. `
NX 10 does not recognize template parts in TC112 z. L2 J* M$ Y# z( n7 H& b# c4 y
7485152
" c1 A# B5 B) z% E- f" |9 w2 eCreate a box function changed in NX 10' v, |# H" i' Q5 G6 E
74854195 F9 G2 J6 `; i6 v/ p3 i, W( ~
CLSF Export Bug When Exporting Multiple Toolpaths  in a Project Group
3 ]; B) K- r) U! \0 b7486816
- m! p5 T: a& yThe tool path API support for Helix motions was incomplete  and had a couple of issues that needed to be addressed4 S. W5 r4 e% H9 Q4 B& l) T
7488773: E1 Y! e% H7 M9 k
Internal error caused when saving part file- h8 r' d- X, ~9 }. h9 U
74906301 B! O( U' D! Q  v2 }
Flat pattern bend radii callout does not maintain  units
: P) C7 h- C- P1 K  }9 g  N: {5 H7492187
6 `+ \; ]4 P5 ?, V; V' `These issues are EB related issues and solves the  LWSV cases
0 v. U  x( b, g' J' x; j8 n$ m0 t7492862( y# C* |' R5 i3 P0 p
When moving some sliders on the legacy Standard Part  Management dialog box, the labels are being truncated
5 t5 b# ?2 ]% i3 v, n& i- b7495362
% v' H- j7 E4 d4 a  ]' n( KWhen User do MB3 on drafting sheet and perform Part  Clean up NX outputs "An operation was attempted on an invalid or  unsuitable OM object"3 n& o6 s& ]4 j
7498845
$ l% x+ Q2 _4 H% R# p4 C/ p$ BThe problem where the datasetname for PDF export can  be changed if it contains a colon or slash is fixed% ^. Y- c. A& c3 r
7499949
) \1 e* m# E- i% R+ v2 Z) \/ FThe display of assembly parts for grooving tools with  an tool tip junction at a different corner then the first was wrong
4 W3 g* c' i1 ^  w9 l/ L7 Y7 y- `75002621 Q; b0 S4 _5 ~
An error occurs when deleting an operation
5 E* o, d# f6 c  L$ q& V7500467; m( A* n, ]( G; g, V1 ]
Progressive Die Wizard Collision checking is not accurate.  When running the Collosion Check on the provided Transfer Die, the whole  upper die is highlighted as a collision when in fact it should be a few  components, u' k, E, b% t+ `$ f
7501997
  d4 ]+ D/ Z) q' y0 s! \( vNX 10 Macro recording of Base View creation fails  playback due to UG_APP_PMI) p+ Z! t2 O6 A9 g
7502032: g+ [" J8 s2 b5 w/ n9 q
1. Create Mulitple IPEs using wrong names5 T$ s: @, t" \$ P- l- _
2. Lists not being converted in inch parts. k- h8 P& O  k; D8 c( Q0 |
7502899
6 i: t  ~5 h. [- c$ iBolt circle dimension changes when scaling a view  on a drawing
' P0 `) |% `: @) T$ t7503419& X. _. V; t, }# R. J
Problem description:* o1 N4 v4 ~/ m
1 q* ]/ O" ?# Z+ D8 P9 L2) When a classification hierarchy is defined  with intermediate nodes as type StorageClass (instead of abstract), we  do not find the start nodes properly during our search2 z( s& E: `3 O: ?3 m% H
Problem solution:
- T% L9 L8 R( a" }; P6 c1) For Item objects, set the TEMP_PART_SPEC  correctly in the charx data for the individual member rows so that we  know that we have to look up the specific revision based on the current  revision rules when we go to load the part into NX% z6 j1 x; I& s4 e  @
2) Traverse the classification of the hierarchy,  including StorageClass nodes, to find the starting nodes for the Routing  re-use library tree.  We  actually reversed the search order and no londer due a depth first search,  find the Classificaiton node with the specific identifier and make sure  that node lives under the passed in start node.  This  is much more efficient and does not require searching the entire classification  tree."( \2 N/ c& W) K2 y8 l6 i9 `2 o
7503642
6 h% n( ?" i6 d9 N! m; FThe problem where the boundary geometry of Profile  moves of Teach Mode operations is on a wrong plane is fixed
6 m8 [7 ]' K$ I* [! _3 w) Y7503938) m9 a/ G1 n* i' p' d
Problem was originally fixed in NX 10.0.3 but the  change had to be backported to NX 10.0.2MP. There was a new version token  added for the MP fix. That token needs to be reused in NX 10.0.3 so that  parts created in NX 10.0.2MP don't regress in NX 10.0.3; |8 P) m% @: _3 p
7506539
; S/ X8 X, a' l7 v' B5 A# ^' M"roblem description:
. u* m: _* @& T% Y* q% }1) When Item objects are classified in the  classification tree, we do not load them properly into the NX session  via the Routing re-use library, a3 {4 c, |/ h7 h
! A" Q- A/ o0 F) w+ L6 iProblem solution:
9 d/ T" `$ ]% l/ F+ o' T' T1) For Item objects, set the TEMP_PART_SPEC  correctly in the charx data for the individual member rows so that we  know that we have to look up the specific revision based on the current  revision rules when we go to load the part into NX
/ s- E. h$ b) K+ C2) Traverse the classification of the hierarchy,  including StorageClass nodes, to find the starting nodes for the Routing  re-use library tree.  We  actually reversed the search order and no londer due a depth first search,  find the Classificaiton node with the specific identifier and make sure  that node lives under the passed in start node.  This  is much more efficient and does not require searching the entire classification  tree."
: G6 U7 j9 u7 m75075146 T6 n* K2 Z7 f' }: O
Modl ValidateAndProcessLabel() does not allow @ chars
6 O7 n6 F- U- K7509711- y: M* U% b7 `5 @
5 o2 i* M* j; z( V$ }2. Lists not being converted in inch parts- S5 k5 ^( Y7 Z' s7 `) L2 N
7511380
5 s! h" X, U3 r8 U7 Q# y3 `GM Users do not want to see the wave link warning  message when using the Create Single Feature option in the Weld Point  Wizard/ y2 m* P8 F# i
7514048
9 W, r! D) z; |# v7 ~" SThe problem where the datasetname for PDF export can  be changed if it contains a colon or slash is fixed9 j% R) Y9 h* Q& e; J
7514341
; d4 u; L4 T: Y. tWhen sending workset to NX from TC 4GD Content Explorer  the revRule is not processed correctly. This problem is fixed by this  CP
7 T3 J1 E; E; h* L: G$ M7515446" n8 ~( `; n+ X1 _+ i
The problem where the datasetname for PDF export can  be changed if it contains a colon or slash is fixed0 q/ y) Q3 E" {1 `5 G
7516969+ l" u, O& C  H# e/ f, H6 T
Re-manage ug owned tiles when un-managing NXOpen UIStyler  dialogs. In this specific case, the customer launches a UIStyler dialog  from a user exit in the File-New dialog (Teamcenter). The dialog launches  but when the user exits the dialog, the previous (modal) file-new dialog  is not remanaged.  NX is left in a modal state and must kill it.
" S. ]- z0 y$ C5 J! ^7 X. _7520120
- b6 ]' ^2 x# |4 l"This CP fixes as issue related to MergeStock  command. This problem was discovered in EB part (at the moment EB is more  concerned with totally different issue related to pipe split) as well  as NX 11 beta test.1 q- X4 G4 p) Z. }1 ^+ N
Since EB will go to NX10.0.3, the fix is being submitted  to NX 10.0.3 delta.
  N/ U% O& P: {% _- ?6 U+ X0 v7520120: Sometimes stock may have empty identifier  attribute.  Since  MergeStock command performs strict attribute check, it fails to merge  stocks if one stock has empty attribute and the other one does not have  the attribute. In reality empty string attribute is not really a valid  attribute and it should not prevent stock merge. This CP ignores empty  string characteristics during stock merge.") V+ [  o) M* D$ i
75204905 P0 Q* {0 S4 Y" J% x& ^! z
Bug on stress results on volume elements with orthotropic  material; A+ O; S. S% r2 E2 z
7521073, l* V" S6 d2 ^2 F- |5 d
"Clone of NX376402 to Routing_nx10mr_delta0 V; b, V7 G3 C8 q$ _
ATK wants the bend radius design rule to ignore suppressed  stocks.
) l: h+ U  q" @/ q, g% yI'm backporting this fix to 10.0.3 because Nathan  (ATK) told Mandar during the beta test event in Milford that ATK is thinking  about going to 10.0.3."
& D2 F- v0 W8 X$ S* K7529760/ D& V! Y" g2 o. I" Z+ l: v
"This CP fixes as issue related to MergeStock  command. This problem was discovered in EB part (at the moment EB is more  concerned with totally different issue related to pipe split) as well  as NX11 beta test.
- \# _; I. k2 U! ~! NSince EB will go to NX.10.0.3, the fix is being submitted  to NX 10.0.3 delta.& F$ \5 Q) n7 T
7520120:
5 v  m$ f- l) @- ^9 oSometimes  stock may have empty identifier attribute.  Since  MergeStock command performs strict attribute check, it fails to merge  stocks if one stock has empty attribute and the other one does not have  the attribute. In reality empty string attribute is not really a valid  attribute and it should not prevent stock merge. This CP ignores empty  string characteristics during stock merge."
, i, E( N2 O& y& w9 `9 g$ h% Y75305422 Z% h, Z, K' j+ }$ j4 h9 @
& S& t9 s5 i+ v# K& p- u) \% p7533163
) s8 p# g8 `2 x( [3 V' Z" k) vPart not initialized3 w  v" m2 m1 E4 U6 d
8250013
$ |. \: B' p" Z* @3 U" G& kTeach Mode - Cut pattern changes
4 u$ A# ?, r* _8 I8250187
  o- {8 o* F3 {9 kOpening Replica Assembly -Error " Attempted function  idsm_distributed_app @site2 @3 _2 o" ^4 `) z6 A% a5 A
8250222! B3 M. E! p6 O1 A/ F
Curve Length fails* X9 c/ j4 ]1 a& Z4 c
8250244
' h* Y0 a% c, ]8 j& F3 v8 s& aNXOpen doesn't return contained features of Pattern  and Mirror instances
4 u, _' ~' ]: B1 I4 h8250484
3 `4 ^% S# g* X$ _7 REncountered Null pointer attempt to convert MultiLevel  Flex mating conditions% W/ ]0 b' i4 q' n0 x& [
8250508$ v* ?; C6 s' R/ z
PMI LightWeight Section View doesn't move section  entities to other layer
* U: s, I( z( [4 c7 p2 ]82505137 F, E$ h$ R7 g7 H  z4 F! o' C
File > Save fails with the message: BVR is not  checked out0 f  _- u! D$ H* U/ l0 ?* a
8250570: J- ]# M4 M! W! V% x0 g0 T! T) N
Performance issue to convert Wiring cable V1 to V2  specific Locked Length Spline
& U+ c$ V9 X) a$ I  M% X; ?8250633
; E9 C) \; \# }% ?  u: ]0 `Blend Corner fails4 b: T- g5 J9 e
8250957
/ W" M/ t( b6 ], \' wReuse library symbol in drawing title block is not  translated to DXF_DWG format
* [9 t% x; h7 C9 U1 |8251000
  }3 Y' G9 K) K2 p. D+ eNX Measure Point - Show Dimension display incorrect  values; x6 }  m1 [$ a9 Q/ t3 I
8251033
3 P4 J( K3 X3 }# f5 k/ OTop Selection Priority in quick pick changed
  ?7 I) L8 C2 s6 c& P# p; z8 t82511492 s! T) }$ S. t2 a  J: w) y
Global Shaping updates to error since MP2
; f' n$ z. a1 K; K8251168
' S8 u% x1 U5 E# z+ e3 h; PAdding an NX 6 UDF does not work anymore with NX9:  cannot paste sketch
: y$ z+ U; g  d% U; `) f8251179. C8 j: ?& G% C4 T
In the old part family template if we add any new  member at last row, the last row was getting replaced with existing member  at first row
1 h$ h% s8 X) N8 f& ^2 j) H8251385
  A' t5 }7 q& X5 T: H: TStandard parts created does not get recognized by  Cutting Side) r* ^: x) o' t8 \; B! w# q
8251440
: d. E3 q; Q6 d5 o9 u9 t2D Exchange translator doesn't handle file errors  Z/ v* {. `: e# t
8251510  B& s$ `" F* [, t6 K7 p
Note -> Insert Object Attribute doesn't list any  drawing sheet attributes
/ W2 s) b% F" c8251644! J0 D4 j7 D1 B* i) x0 o6 c5 O
Law extension - merge faces results in gap5 G) h) z. v3 H8 C7 L- O
8251660
, j* k. g" c; w. O! E: YJT - Name of NX-Facet-Body is not converted
! l: `2 R5 T7 d! H: _+ p82517852 k/ H) C! I  R* r1 s- i
Unable to update views on drawing
6 L9 D; l* f1 z9 Q$ S. v$ ^- b8251844
  p8 B- v" U! e: Y% @4 yLaw Extension - merge Face if Possible - not update  Stable4 M% e% `/ |7 Q0 Y1 H3 Y; B
8251875+ t- D( V$ s4 g& P1 _
Weld symbol edit failed
* Y% t0 M7 ]" x* k# e  O+ Y0 h) E8251932  A$ D4 ~0 l. m; H. C# F) K2 B9 p
Große Dateien beim CGM-Exportieren
9 W9 l: z* X( ^$ q4 F( [( ^( u8252012  I: o- r" p4 [3 C
Vehicle Design Automation: Close Range Visibilty -  maximum length for blind vo) v. ?/ y$ U& n$ K0 V% A
8252262
  ^! R. _/ p5 l  S# CUnsuppress of last feature takes too long+ m: S4 Q1 {4 B( j9 h' v$ i  Y
8252470
  S. D: l' Z; v$ }, LCurve Smooth does not work correctly
# p: z: t- D5 y' k8252485: b6 e& f0 `6 I$ h4 }) _# a2 r
Global Shaping does not work all around and not correct
8 P' P: ^4 M8 s8 M$ i" ~8252571
' q/ s$ a* m1 s7 V' oBaugruppe NX 7.5 kann nicht in NX 9.0 geladen werden) u- G8 Y$ T4 j* W0 n/ r
8252781
( H: _8 V2 t% B3 o. Q! q4 E6 ]Interpart expressions are multiplied by 1000; g' h/ [, e9 Q1 N) A# b4 b. b
8252795, h8 M1 n# T- B: G5 U5 r6 ]! T
Diameter Baseline Dimension not work for invisible  Centerlines
8 p, ]$ l- o5 U  o8 w! D. @8252860
3 m' T& x: R# U  N9 a7 B8 `Deleting marking lines takes long time and ends with  error6 e7 R/ a% l8 L# ^2 z
82529945 P. Z& f0 y! s; V+ q8 z
Datum Coordinatesystem losses associatively when changing  from offset to dynamic
; a; r9 {) {8 P8253096! z; V" r" j; [" x$ Z' Y0 e
UF_UI_set_minimal_graphics_window() regression in  NX 9* x- ^, j7 p" O, Q( X$ b$ ^' P0 t& I
8253219: K. J; i* D, K: r' w# E" Z) s3 R
When edit a CAM Operation appears "Null tag not  allowed"
# n8 v4 [. Z$ n* W0 v, _8253332' j" S/ A1 a' w; k
CAM: Paths unlocked manually are locked when part  is reopened* q+ L( L8 t; n  B! Z& h/ u5 [" m$ h
82534100 g% V: G7 P8 j, {# Y+ g. ?; k4 C
NX 10 MP - RR Issue 3616 - Results Probe with DR point  function gives wrong result) z5 I+ M# S( f7 N: \$ n
8253785
( Z% S. @$ M6 S. N+ Z1 p4 jReg_NX 9.0.2: internal errors (Parasolid ifail 934  from ENPBEN) with NX 9.0.3/ ~& F7 I1 f3 u. i* w  K3 ~
8253791
9 f# y" C& \7 j' ^'auto. coupling' constraint - opening .sim and switching  from .fem to .sim slow- A* s1 p1 E9 \7 N
8253806" T) F4 x( \6 O7 N' N
Electrical Routing: NX crashes during renaming of  Multi Port5 H3 M9 `1 J6 `
8253826- E& U$ @1 y. `5 i) K" _; L
CAM Face_Mill_Manual Regions have Gouges - Wrong error  message8 G5 {( e1 f( k
8253865( V' _# [0 t3 S
Part Name Management, cannot change to Reference if  part contains drawing
: s* |% t$ x+ ^8253960- t0 G) }. m6 _' i
Zero thread dimension after updating the view (lost  references)
6 {! E: v7 e5 `8253977& P, }: f! A( |+ p2 C' n/ ~
Switching between solutions slow if 'automatic coupling'  constraints defined...
; ~& G/ P) q, j: y  X0 R3 A9 d82541750 I5 p/ H* \, o' J
Changing 'automatic coupling' constraint display affects  '.sim' file open time
% }) \) B% K' y" I+ Z/ z4 f  S: g8254277
5 \9 O7 F2 U) h& KRR Issue 3643 - Bug in Time Step Control - edited  values are not retained
' S% D6 u/ s8 A/ E+ P82543504 B0 x, W4 a) t, J" ^5 F# b
Check mate failure9 W$ y7 E2 a+ |& e8 Y
8254369: n& a6 m! O" C8 B3 V+ K
MultiCAD: Error when saving parts with references  to JT components (RC 580163). Y0 h- g0 }% g- ~( [
8254534- k0 z4 x7 q; \* L! G
WIR V2 Reattach Spline Removes Lock Length
9 V$ \! Q" V9 Z7 U" N) J  _8254611
+ [3 m$ M! j. t7 X. d9 |0 QIntersection Curve is Out of Tolerance after modification  of an area that has
$ `. J8 O8 x$ \' A, l$ z  }8254724( K* z6 m- N* b" b
Law Extension Deviation
( d( c: T0 E: r1 m  {0 h. v8254760
4 \5 f$ }5 V3 r& _' F2 Z9 ^Can't create a detail view
) R; F4 e, V4 l5 B) _8254798
' K) k2 v+ Q% d+ CPDW toolbar workflow reorganization
4 N( m+ _1 H' V$ T) F6 [82548614 z! @2 Y! j' K$ Q
Replace Feature of a Sew by a Trim and Extend Feature  doesn't work- \* L  p5 s& d% v/ d5 }* h3 R3 Z
8254867. m7 t6 M: G- B
Not able to open partfile or make it the displayed  part in Assembly Context
1 Y8 ?' y+ |* M0 J82548777 |. T8 X; P. x4 S7 ]$ j, n; T5 c
CAM Cavity_Mill Problem IPW and Holder Collisions  3
7 _9 q) y0 `* z  w2 _- t8254940
; g' S  d8 J" \  kTool Axis Decimal Places Output Problem
5 N) [  h: E) H: J% A# K82550228 [& Y, i3 m' ~6 O
Find in Navigator - Warning
) O1 L$ n8 ]; B, B/ a6 b8255041
& ?$ ?, V) d* B2 g8 PProduct Interfaces not visible in the target
4 \5 E7 q$ N2 H$ Z3 K& N  d8255061
, g8 w7 z" x: [- T6 FReg_NX 9.0.3_D1 - Uable to pick PMI Centerline or  Center Mark to create Linear Dims
1 M/ f3 l8 A$ Z0 ?: [& X6 z+ s" p" T8255065
& u! R' A; L. x" U3 _" X4 D7 _1 RSAE Manikin Wizard input field looses control to feature  after reordering
3 y9 d- c, D& h0 @5 V7 [$ W5 w, S8255077
/ a& y3 c$ u, PError occurred when updating hidden line display) N) }, T6 j& V2 P" b) C* Y" H
8255092
( T+ k- j9 \+ S+ O$ c) PCannot create stock offset fixture port- K# l) m/ c0 u: Q1 X$ Y
8255123: c: u9 c0 R7 V* {8 e  [
Using 'Stock offset Point' clears extension and back  extension
8 }1 r$ ~5 l) |0 G/ C8255154! p+ O' O$ O0 j% K6 p0 `+ l$ X# |
Relations Browser does not show links of fully loaded  part
! A8 E! g! X6 P8 x+ Y8255182) M  E3 {1 Z8 d3 W' [# X2 m
Inconsistent display of new curve direction
% n& \1 s  Z0 B0 ?! R& Z" Q8255193) b9 j" ]: v4 t  E1 H- _
Problem with dimensions associated to view dependent  centerlines+ X$ C- O# I3 e/ u) s+ }/ i* |
8255229* N* f/ I+ G, L
Missing alert about legacy product interfaces
; [1 h; ?  k8 K( F, W* @, m8255235
# s8 J! O) A) Y2 jInterpart Expression does not get updated after replacing  component
$ i; o2 {/ n+ {4 V& U. u8255256" b1 c8 o0 n1 d! E$ g, g
Weld Point Wizard Distance Tolerance setting2 A) V' }4 p; E4 g
82552709 V6 @% f  u4 J7 m& i& S
Offset curve oif 50mm causes NX to hang  {/ }, q' Y/ h) |: Z8 n
82552988 D4 D) A8 h- ~& X8 k: Y: b
It has to be possible to disable the "Resistance  Spot" in Customer Defaults& Q, Z9 R$ j+ X& S+ e& g5 h6 D
82553011 }& ]4 |4 ]& z: F. V3 P) Y
Not possible to change associativ translated weldpoint  to fixed see PR1959880$ O; P5 H8 C( a  k! Z
82553213 C9 M% l' E/ [! |
UDF loses color definition
/ s4 ]6 h( A/ p$ ]+ R: d9 d) R8255329
( O* s0 J# X" \4 j, ODisplay will freeze after undefined actions of big  assemblies' Z4 K; h/ L/ j
8255338
6 p; |) P! O4 F; s% x( cOpen a parasolid file leads to error
  e0 t6 _  A/ t2 n) G% j, z, e5 w8255360
# A# s. S9 ]% |Replace component breaks links
7 K  n* N+ z- c4 w5 Y# k# S8255368: E% j4 a1 G" A; i0 X& t' Q
Selecting node within group via "Nodes by Group"  fails for single node group/ {0 g& H: m" g7 T# H
8255379! ]" S. i7 \0 J9 Q
Call of a Builder in User Exit causes disorder in  Part Navigator
: ~1 ^8 F+ d' N3 K! w+ A3 ]8255385
7 N% O1 K3 m  N' t1 E% yID Symbols do not show text in NX 9.0.3, was fine  in NX 7.5) ]3 w# J( @) Y3 s' n1 f* L
82554093 r6 f- g* j$ [$ A3 I0 k; Y
Unable to replace links in part
# R/ l  ^6 @+ l# ~. i$ I, o& l, q* b8255420
- [- p& \7 @5 E0 c8 A& g- ]( JIn NX 10.0.1 ip1 we are not getting the same PMI report  that we saw in NX 9.0.3
) O. R) X  G3 @. ^3 J9 ]7 p8255422
2 ]1 R1 `5 H) u/ wAlert Internal error during update of weld points
. R5 r7 [  W/ R! T1 J82554352 n( _2 d# Y  M$ [' [% }6 b
Incorrect Change Reason Status In the Synchronize  Links  K, R- m' L, o  L
8255496( }2 _! d( ^7 [; p
Law Extension should give an alert when the desired  miter cannot be created
  K! K7 y% U+ a5 N8 g; e8255528
- m. Z9 s& s4 iLink changes unexpected to pos. independent after  synchronize in displayed part
3 A, N, R+ q! O* `* K- _8255542
) B) v' C3 s0 DSelecting comp (ANAV Dependency panel) is slow
' h$ v3 u% \8 w0 Q/ K6 }3 s8255549
, d7 A4 I! ~0 g- m! [Up to date part displayed as out of date6 p6 h2 B5 A# v, [7 F
8255588; P" |  l7 C" `  t
The Meshing of some solid body is not possible with  NX 10
2 c% P5 w# o1 y% w6 {; u7 A* L8255670
9 z( \& \# }* ^Useless points after reopening a file with a projected  point+ d0 R6 W/ r6 y( U0 N7 F
82563132 z: {% f2 E' k( F6 \
Pedestrian Protection - Wrong WAD curves
8 h. N$ y7 ?0 u& S3 s* ~8256356. t2 I& p* [# p, A1 n3 h' n
RR Issue 3885 - Solver time heat transfer plugin -  function builder ignores cert
$ I; j& D8 C5 B- ]5 W3 X8256625, d  f9 P. t2 X; T& a7 x4 Z- F
Unable to open partfile -> internal error
& s9 J' i" x) b  J1 S; b8256692+ y: g- N7 Z: Z) Q7 t! U9 }
Regression: Method "Import" of the interface  "UFPatt" creates the min-Max-Box& z* F5 t2 c6 }- q2 [
8256925
! ~5 L9 \3 J- I6 V3 X" }ANAV: Error 11 while calling callback with reason  553+ A7 t' V* A- s
82578092 ~# V. N4 a) Q( }. Z5 S" z# p
G17_19 issue& o9 W! j, X7 X: {
82579289 F# X$ [) y$ k# J3 Q2 D
Memory access violation in NX 10.0 using KF ODBC
& o" _9 c9 n# p  ~8258457
8 i1 a0 O1 J$ A3 \% c; bTrim angle check is not associativ
( C1 u: ^$ {, r1 t8258603
0 ]; H3 M+ t9 c& M8 B: z- r0 ^Spline Length Constraints cause poor performances  when editing a RSpline
6 V! o! l7 \+ D& H; U: j6 V8259018/ ?5 L1 j/ c6 D2 h
Sketch lose Midpoint Constrain
- P+ C+ B5 c6 _1 J, e6 x3 \/ w! R8259895# R/ |- y9 [: L
Exporting a Drawing with 2DExchange some dimensions  lose the referenced objects
) G3 d+ s; n3 B, f2 h8260340
, V6 K8 w1 b5 fAssign button for dataset name is missing  ^9 f+ P% ?1 u
8262206
0 q3 S! W2 K1 N( M6 V8 ], FWhen using Mill Boundary by Points, the first point  gets lost, T& ~/ i2 W* {2 s; ]7 Z
8263130' D1 }+ [9 S" k- K0 d$ i
Bad Performance in NX 9 Spline Path with 15+ points
& [5 Z% L% s8 m8 H# y8263681- f  {9 ]5 N/ Z8 ?* y& y$ H0 p  `# q
NX Sheet Metal - bead over cutout
0 }, U. f& P( B/ T: _1 a82636881 J+ N& B8 S$ n
NX Sheet Metal - bead ending in cut out5 J# h  J; V* W% h- Z, S1 `/ O/ |* A! J
8264427% e4 D% [: u% s6 E0 Z# @
The original code set the base color to whole binder  body. Which is not consistent with fiat's requirement3 a' g! H  r" N5 W
8266572- U' f" `- f& k$ \1 `
NX: Report Shortest Path gives a wrong result causing  the collision path9 H* A' U( _" i4 a- M: z' c
8268022' S# ~0 a% c; v; w- l% W% K) M
Wave Link causes lost of Material Information% e% o" g+ y) \8 x, @+ Z6 T; D. f
8268277! a# f- k! G! g/ V! k
Replace of Thicken not possible
/ Q6 Y( b& Y, }( Y1 @  w4 K8268280
/ a0 `( U7 L) u# f+ \3 GPS27.01.209 - Feature Playback failed6 E0 J9 B5 [0 `3 g( E
8268321  w. ^3 _2 K3 L$ L+ a8 X7 b
Performance problem of Divide Face
0 p6 z! R0 M0 q8 i2 }8268602- G5 Q4 a3 _3 Y
Feature Playback Error T0929
4 t5 e: P7 Q) P8268732
! n9 s2 D" a9 zUpdate starts during load even if delay update is  active2 w9 c; s6 [5 m0 I. _- v
8268751) u: r+ z6 h8 ]" ?$ W
Selection during Animation0 S& Q" C6 t  x) |( X
8268851  P' K7 o: \; @2 }
Failure returning outline of body at cut level& L8 ^8 a- a; d* k
8269065
# J  z# Y0 y, L* D5 AWhen the interpart update is delayed, Motion doesn't  show obvious reflaction  of the "out of update" status: z" f5 z$ _" ^" _' C' Y2 m, r
8269080+ P1 D' h( F% ~, ?: d3 i2 h& S
File-Print crashes NX on second print
$ |  S& o! y( k( p, E* |8269298
3 Z3 I" J" Q- C* q% B  dIn the Upper Roof Selection Wizard of the function  Head Impact the correct req* g% z: ]7 y# t, e
8269311
! h4 r5 g0 y. R& X6 W) UMotion Envelop with Option Process in Backround  doesn't honor the start part
# G* j7 b6 i4 C. \82695318 x6 K  }7 y" P
PMI is not visible in View of converted JT
3 I4 \- O  r0 C1 S3 |( |8269813
4 l# n$ Q+ Y5 R, cDXF Radial Dimensions scaled on NX Import8 b( Z# h- j! S( F9 R* c7 E
8270011
4 G0 Z  l0 u, M8 v+ I( {2 eRouting Spline Path edit performance investigation  of user error on constraints* ]5 K3 G& g+ B2 P! }
8270015
, ?; M) E; F) a! |8 T5 FError-code 904 reported during ugmanager_refile8 h. o8 z1 G8 p
8270093' N9 l) _. J+ d- W5 Y, G& X
Company logo (custom symbol), is not translated to  DWG when part of title block
8 ^% ?: s, w* L  \; M- X82704189 v. ?5 f- @/ m. m1 t" i
PS27.1.211 - Feature Playback Error Blend Corner
9 U, U& p: p* K' c9 \& J8270452
, P0 e3 u+ z' L2 Z6 XElectrode Design: Rename Components not possible any  more in NX 10
9 Z5 J" c, p7 ?+ d# e" ^1 m8270728
9 g0 ?1 ^4 b; {0 H) E% EDIE Wave Link Datum Planes are not updated
5 ^4 I' f: J' e+ s& {9 A& f9 x8 w8270858, F5 C; g1 U. K: u- L* _1 e' v. {
Unable to generate tool path -> Operation used  suspect geometry
, _8 h& z1 `7 m- s5 Z5 m8270898
8 {& T. A( T) m9 z/ a% f/ O- }2 sThis problem was discovered in NX10.0.3 although it  can be reproduced in NX10.0 onwards. The Law Extension features created  in previous releases produced different geometry leading to downstream  feature failures.
& Y2 l9 h8 |7 J; t8270909$ H5 |+ q6 }8 X2 C! z- Y" _! c4 }
* j& L4 ?: B# A, i+ E. k5 Q8271164
( \  q' `) ?6 [0 gAttributes dialog contains 2 unusable input fields  for value+wert in German UI
2 Y8 l" l) g( \# m8271203
  k5 ^) d, i+ D/ t( G0 V# n: I7 d( e& XTC_NX_TCNavigator_Column_Config does not display property  values in TC Navig
' Q5 c5 {# @: _/ n% s- s8271296
4 }0 I6 D7 K4 O+ A" kThe loading-plane should be created and displayed  not on layer 11 but on layer 1
- O7 r! r5 ^8 ~) x0 [# I+ |8271652
& B: W! x3 k* {1 OBeam Section property calculation time too long -  IDEAS UNV solver environment; [2 e" h' T, P$ l) j
8271884! j9 w% B: l' U4 ]; w+ q' o
In the selection wizard for the function Head Impact  only one component of a p
0 R  \9 ^# e( T& c) _8272338$ Q+ E8 t0 ~' m* d' _, Y
Moving a stacked PMI fires a error message
% [+ X9 }$ J$ x! Q( f7 H, t. S8272398
/ ]# p3 i4 c+ F9 ?Slow perf. NX_PRODUCT_INTERFACE_FIXUP_OPTIONS=repair,  'Load interpart data'8 ]3 O8 P- S: ~  b2 ^0 P% G
8272436
6 h2 x7 @- |" t6 b* ~The point "Corner of bumper" is created  at the wrong place in NX 10" }' f: A& Y+ @" f: O9 H
8272568! J; ?0 t, P+ @" [% v
Unexpected update on OK in General Relinker# D& b2 [1 ?$ C$ I7 n# W; ^
82726270 P' p! K1 I" a9 j$ g2 \$ J( M: {
System response time not acceptable when cursor is  moved across geometry5 u, X( t. a: g1 R+ d6 s
8272746+ x; ]& H- W3 p& p
Assign button for dataset name is missing( i5 X4 E/ U+ j% [% i* \2 J) y% |
82727553 @2 g2 G1 ~& ~$ `
Journal generates an error when tracing a point in  articulation solution
! k2 m3 U- m2 f+ |0 j# q5 `8272907
9 p* J; [/ @, s) L% x( jUp to date expression changes to out of date after  source file load
9 _, B! s6 \9 \# _$ f0 e( h8272915( U/ j+ B. u0 w' d2 ^# q+ Y& r
Assigning interpart expression to object causes out  of date geometry* F6 F4 F0 g/ x, H
8272933
, C  @5 g5 k1 f, fFonts to use setting shows part as scope, but is session; R. w- u$ @' e
8272942
" g9 k- \/ [/ P% x5 U3 h3 Z, ?7 e& {Naming convention broken on replace of interface expression  with same name
! o9 i( F' W+ I6 E9 p8273131
" k. ~2 P/ L" i% E; A+ D( E0 g4 eCurrent Production NX 9 Harness Won't Open in NX 101 f* \1 \9 [/ }7 v
8273183
7 U2 R, S2 O- S; KNo Preview of Section Curve for a JT_Facet body in  View Section command0 R0 r* @6 s% N6 _1 \+ D
8273256
0 z- B+ f8 Q! d6 U& \NX 10 Weldpoint-Labels are not displayed in 3D-Viewer
9 `  B8 {/ \- ]% @8273328
5 Q$ J0 o8 ]/ E: cFTL - Current Production Smaragd NX 9 Harness Wont  Open IN NX 10; F: L' V+ h# g9 p7 Q3 b
8273376& s; Y$ O1 x4 `% G; m8 e: ]( x
NX 9 Parts cannot be opened (invalid foreign Expression)8 M7 x+ Q+ Q  U. p( j9 Y: \
8273403' g7 d/ v7 N' f3 H$ _' w
Cannot create sim, afem component from .fem (empty  result)
0 c* B: b4 G7 C9 f: S! `7 U! I8273515
- T8 G" a  ^( w( g. B/ L* c8 oGeometry not shown, only Bounding Boxes (Background  Loading apparently )! H4 ^: Q% ~& `% f9 l8 h  {. p
8273568
3 w' I+ n7 v0 j$ YDefinition of Draft Angle does not remain expression  setting
3 g, X7 ~9 H- b' L3 h8273624
- W0 F, U# F5 T; t0 o& gInternal Error when changing Reference Set (Pseudo-POPL  apparantly involved)0 q* B1 y7 F2 w$ C; `/ f$ m- {' ]
8273920
  D. Y- d4 r' ~& aEdge Patch Fail to patch up all loops depending on  patch order4 H6 P2 w8 }" |  L$ w: d. i- F$ w, r
8273964  O7 r1 k1 n' c* {5 ~, y
Export of multiple FRF in csv format using Save Graph  from a PLOT) P5 b5 m  d8 w- O
8274030: A$ j( G- Z% [( _
The 50mm in Y direction offset-line of the Bonnet  Side Reference Line with the
/ R  e8 w/ f  y6 {/ Y82740399 f* x% f' @. s& D3 f! r
The geometry of the bonnet rear edge reference line  is not correct to be create
) q1 X" t  N& c% u3 Z8274040- |$ f' g! t4 v  [
NX memory blowup when loading JT exact
) A5 {! V& G; n  o8274351
9 \5 v+ U8 a  y0 }2 W+ d: uDrawing not loadable6 l- I+ p- p" [/ t, `- W. V5 L! l
8274360! g/ P! V% i9 d
Failure to open Linked Mirrored Part when source is  loaded+ O8 J' `; M/ t4 {8 @  Y
8274413
, F/ E0 F+ }0 S# IReusable pocket the thread is not copied in the linked  body8 V- {5 W4 m0 y, c9 t
8274445
" a, x  w. ^4 e, |6 A' MShow exact on JT file causes memory overflow  |( x2 M1 V, E' ?, ?1 V
82745388 N  @% m7 v/ e" u/ c1 R
NX Welding: Weld orientation vector is not updated  after geometry modification+ T- v( C) J' |; `( A) X
8274555
& p( J  M! K2 ^0 G' ^Weld orientation vector is not updated after point  position modification$ Q, s; O" I0 f. k7 F6 g
8274609+ e9 g: M6 V4 \7 D4 }6 m  H
The 82.5mm behind in x direction offset-line for the  bonnet leading edge refer
" j) k1 q) Z* H) U. s' L. F8274657
9 k! S! p  d3 }5 LPart Cannot be opened in NX 10& W6 J! t$ `' z3 j
8274695
) Y8 Y6 E& g2 L7 a0 J, l7 v2 uUGPART fails to open: Invalid file name
% w8 L$ O% u4 y4 j8274697
' M: i- Y# K6 ]9 u1 GRear Crash barriere RCAR(2004) is placed at wrong  height9 C# s/ u; _, G5 Y2 z
8274725
+ m7 v# [  s+ p2 F( B* hPARAMs are duplicated when using a GROUP in a custom  cycle
  i5 c$ _& D4 k3 X& G* p- K5 x8274892/ B9 H. `; ~; n" q5 u9 T
The created Bonnet rear reference line with areal  data (SEW) under the Assess  @" _* n! I! G6 t+ B  X0 ^
8274937: i# \9 n( g, q* L9 `% |7 x
Misbehaviour: Interpart Expressions in NX 10
) y- F. q( M! s8274966  H+ {. {7 B0 J9 W8 d9 l* i
Object associativity  type is invalid with part cleanup and angular dimension, M! U+ A3 v# ~1 o, F
8275056
5 E$ n$ F4 L! L- l) `8 b9 WMoldwizard - Create Geometric Expression Link fails  with legacy UI9 `) t& ^  |( ~) ?2 [
82750958 ]8 Q2 C/ f$ x3 g) Q# r. {2 ?
NX 10 ExpressionCollection AskInterpartLhsName_AskInterpartRhsName  create objects, s) j7 p: q% U0 a$ y
8275246
! T' S1 v1 m. P/ _! P+ u, }/ GThe Wrap around distance 2100(WAD2100) is not symmetric  with the class-A data4 n  `; t3 @$ C* `* H) y$ r: O
8275252
1 s0 p7 Q& p% o6 TThe 82.5mm offset-line of the Bonnet Rear Reference  Line with class-A data fro% \8 ^! E- v4 C; `
8275282: O, F0 M- @7 P
Issue with graphics in FEM Model
3 w: T2 w1 P+ Y8 M. T7 {& D. p! P8275307. ?2 f: }2 B5 \! Z: ?
Internal Error after defining and changing workbenches  ^. X* n  k- C' b' V
8275328
9 z1 ~) b' R) U/ m1 y# oUpdate view rotates Label Arrow heads
) m& e: l8 C- O2 M3 J8275335
" O+ P6 Q; R; Q  aUpdate view moves GDT symbol leader# [/ y- o; |7 o+ A6 m  g
82753964 J6 L8 ^$ c. R* `9 t
The created upper bumper reference line is positioned  not correctly for the leg) R: x! K  X% z0 R1 b
8275519  U9 S1 T: k: W
NX9 Drawing can't open in NX 10
; B, X) D+ M7 Y$ ]8275613) n; y' z' K9 T1 N/ H! h
Failure to remove a component in NX 10.0.1.48 X3 P' R  A/ w" c* M0 Q. f
8275693. {! B; N7 V- W
Failure to save an exact mirror part in NX 10.0.1.4$ \& j. O* z1 _7 K0 W
8275729. p( [$ }  ?( Q7 A
The created Bonnet Side Reference Line under the Assessment  Program "Global"1 P( M8 t! n+ G5 d
82757352 z8 G" h5 _# R2 z+ N/ X, D
Make Current Feature und  active Feature Group are not linked in Part Modules
3 l, _7 U9 H0 S8276001
" H' q8 I  v  N) lEditing a law extension takes very long
4 D8 Z* I( V% N; n. s8276150* e# J- W: e" O0 V0 c/ Y1 L/ F( E' z
Drawing: lots of data in memory after moving a view  with crosshatches (Boundary
, x. J* x& b- h; \# j8276151
( d9 k: D8 a) g1 z" U8 a* HDrawing: Bad performance moving a view with crosshatches  (boundary curves)* N! s2 v/ r+ V! Z
82764719 |; i9 b5 T, R
Broken Expression Product Interfaces after open in  NX 106 a* R7 H. i$ h0 d; Q2 k7 \
82764746 Y# Q  J2 M. L! t  X6 h
Show_Hide of udfs not correct
0 d2 g) M% `- K1 ?) x/ E8276557
! V+ |" w) p$ ?* mNXOpen.Display.DecalBuilder.GetImagesInPart throws  "Object no longer exists"# F* [9 |* d; q7 ~* Z
8276596
- V! K& @: m3 z+ B) GMirror Feature does not work on UDF- _6 h- B7 a% f7 N! }. H$ f
8276637( V6 t, Q: U, _" B$ @
NXOpen.Display.DecalBuilder needs multiple Commit()  call for correct scaling. L2 @% f, P5 ]! G
8276658
# n% C8 b2 `% p1 S% J1 s# P8 Q  xAttribute Mapping with Tc LOV causing troubles0 z0 T9 I% m4 D
8276856! {# u4 p( M- D
NX JT translator error 1250
* O3 W. ]; K( t+ y% i& i8276928
2 d: l/ d8 D2 lAttributes of CSYS of a hole are not updated in the  mirror part
5 q* q. s* V% }8276980' _+ {8 Q8 D$ ?% U* I
DecalBuilder.SetImageFilename() does not replace image  from disk in NX 10! Y, R3 r- i  J; L/ u
8277020; q4 o8 h( M4 V! O* O8 b: {' n
Sig11 when changing applications, PMI & Partial  Loading involved
5 W: s( N0 i- R' n: ~6 R8 X4 y82772169 U* A5 `* o4 d5 W4 \1 F4 f+ @% ?7 O# O
Error loading fem after replacing component
9 o$ D: k9 [, [9 ^0 Y8277290
9 y0 z$ d4 L; [& G8 {6 \; C2 p! tCAM: Sequential Drilling with Depth User Defined -  Full length only6 @/ O  w+ \2 s& K1 \6 j3 j
8277447" V( V  K' p! R- C5 w3 V
Reg_NX100024 Wrong representation of smooth end gaps  in view; T1 u. F$ ~0 z: x+ }) D! ?
8277456
5 G0 Y$ N4 L' T) z6 KThe parametric tool (tangential drilling tool) is  not shown as solid
  P5 q- @! @, a6 E& G8277572
/ A: a& w2 T/ ]7 M$ zFor Weld Point Wizard, if using the "reuse feature"  option, do not allow a type that is different then the one specified on  the dialog9 D+ B1 Z6 k' R2 Y* |/ u' A
8277573+ X$ N5 V! S: N- h  o* g
Add new toggle "Create Single Features"  so user has option if "Single Features"
2 x2 T* E1 ^+ ~8277573' ^1 \" K4 ~! w& t* W$ L4 U
Daimler was promised an Enhancement to the Welding  Legacy Convert Utility (Converts NX 9.0 Resistance Spot welds to new NX  10.0 feature type) Add new toggle "Create Single Features" so  user has option if "Single Features" should be created by the  utility, or if features should be grouped by a master feature. PRs submitted  by QA team 7511633,7511911,7513067 and resolved in CP.' W$ D- [; y% i; a" X, Z9 Y" U. D. J
8277626
- w2 }! g  b7 y# e( B# }1) when creating reuse features in a different feature  group, the reused weld points are left in the original feature group6 b5 O% O$ ?" l+ q
2)  a change was made to the signature of 2 NXopen functions in NX 10 that  may affect the stability of existing customer NXOpen functions
1 B6 c: q2 g9 D8277662
" I; z+ I# N; c4 y" g" n) OThis is to fix customer relinker failure in managed  mode and one IE with view feature failure in case of part being closed
% f- w4 U: `1 I( @8277766
4 [3 Z( f, ^1 Q; pSelection of Measure causes NX to crash
  H$ a6 S1 u+ Q: g) H) n8277850+ x& Q" C0 ^* ?- q
Adaptively analysis 'steady stress (absolute) error'  with sol 401  can be wrong3 f% d2 |! @3 \/ M1 ~0 p
8277857
  X& ^. E! }6 a( [/ ~Spline have a Tangent parent. The dialog say there  is no parent
! {1 u; x, G8 t3 t: j8277860, V* F" E; B3 {
Not able to open partfile in NX 10) X0 K/ ~8 N- |; X+ Z' l! {
8277861/ }7 ]+ l7 s5 d$ v
PMI causes update error
; K& \0 N( E) E1 x# I1 z( r8278015
1 d$ F/ e6 N( ]6 oThe drag node command has the Cohesive Ratio option,  but is only for volume elements. Thus this option has been removed3 B5 W& y4 S5 k/ k, ~1 ?, O
8278070) [$ T! }# J0 y- A9 X" w- u
TC_CAM: Parametric Tools are automatically deleted  by opening a CAM-Part' G! F: @5 r, D" A
8278106
5 a; R1 |% {/ l0 S4 R  [) WThe quality checks on 3D elements is not available  in the samcef environment
* m- J9 w9 m) `( }" T82781672 f; ^4 L, L3 N& D7 N! u
When user create a hole feature in a part having assembly-component  structure then to infer target body it takes time. User make component  part as work part and then pick a hole point. Depending upon the hole  origin selection, hole will infer its target body. This inferring takes  long time when component part is make as work part however if component  part is make as displayed part then inferring target body operation is  completed in 10 to 12 seconds.# x- ~% V" \8 W5 \  ]: `4 w
8278472) m6 s( V" y, M+ m0 z
Adaptive meshing analysis is failing due to poor quality  elements...
0 n6 h- f( ~; r1 E& K9 W8278491' ]0 O$ g9 p3 K" r3 k
Adaptive meshing analysis is failing due to incomplete  mesh...5 N- i2 ]6 |7 e# i0 l; q& S! _$ r
8278649" t9 B/ j) h* ~0 T* h3 }, _
A delete expression regression& c; Q. ]9 _1 k. Q! ^
PR8278774, [+ [* q# v0 Y9 ^3 f
NX freezes when doing SCAO on the edge/face case
: e# E! b) o5 V' v$ X3 T1 q8279273
' Y( g) Z: ?, C* ~- M  S( kCreating field of postview of worst principal was  giving memory violation. This was not allowing user to provide with the  workflow
5 I% e9 x8 b  T' o  p! a82794948 B4 [& a9 g1 }# M, k" R3 p- ~. p
0 B7 u' Z2 I3 j% ?8279526
, U% a! S! c0 Q" ?: H# C' W' [* gAttribute units are invalid (not known in this part)  when using template
2 E' [+ g( E, h" f* L8279655$ i; w- s( f5 _' S! n
Certain Simulation Models may go through a BC validation  during a Replace FEM operation. This happens before the new FEM has been  assigned to the Simulation, causing the validation to crash when a NULLPTR  is de-referenced.8 Z9 R; A( S4 D  c/ G
8280603# t4 X) f9 i& I) C  ^: S5 \
When listing attributes to the listing window NX could  crash if one of the attribute values had a very long length2 [/ i+ M) F3 h/ n. k
8280868. P! I5 S5 W" \
When creating non-associative weld points, if a point  is selected from part navigator, the resulting weld point will be associative  instead of non-associative# \3 w) r& E9 ~& G
8281160
7 j, q" T  |" V  D6 U1) output weld points are not being projected if projection  option is on. the projection option will be hidden if associative option  is toggled on
2 ~# q0 a& W7 F9 ]9 B7 c8281215
: [$ b' M! _; u0 }Incorrect import of load scaling if vendor is MSC  Nastran in NX 10 and NX 11+ T$ y( y# U, b; L# Z
8281361' O! P( _/ O! \# d) Q& G
Regression due to IPE/MFK conversion' W! o9 T& f% x! y* K
8282134
* R4 G! J* Y9 l4 h1 AThe PDF converter is executed via command line. If  the converter software is not installed in the default location, the command  execution fails, but the user has no indication this is the reason why  no PDF file was produced; i+ s7 F1 N' D
8282425
) @% U8 k6 S4 Y5 E7 c6 C0 ]  r' eAnnotations with extensions are hidden when view break  is applied
* W3 E4 E0 B9 a" b0 w7 I1 h8500148
! ~( p/ K7 t( @; B: ?Failed to create transition in NX 9, NX 7.5 works  fine
( w5 h7 `- k7 v3 \- e3 Q4 U8500180
# i7 k& x4 U4 ]. _PR2242392 is not fixed on NX 10ip23 though CRR says  it is fixed on ip21
% T: t/ a! y+ Y! a0 B) L  |8500480
9 ]9 {: j0 Y' \Unable to open a part with Internal error:memory access  violation
8 m0 E5 p2 ?) E/ g' d' r% D2 {85008617 r' T3 b: x: `- ?( Z! O1 N
Note leader stub position and alignment differ some  cases
' ^5 @% p/ T7 p9 x! h: r8501094
9 _4 G0 R, E% Y0 ~5 A% QNX crash while adding CSE variable "VC1'4 ^7 l$ _  I$ Q* a  [1 `0 A
8501620  t5 q% I1 j* s, r& u
Failed to create profile cutout in NX
5 f, o; ^: o% l4 @# a; R8501665
3 {0 g1 T* R" N0 I, u/ h; i8 vUF_ATTR_set_user_attribute() returns error code 580014  in NX 10( |; S( I1 x- l' T
8502510
4 B( F# P, P4 ~NC path missing intermittently in flow cut reference  tool operation2 i) M: x+ [6 q" ~1 c8 }/ p9 {5 s
8503090
) ~. Y; `1 ?/ o" h* M; S( Z) USpline method is changed when editing a spline path  created by "By poles" method
& Q: N; l7 z( ]+ Y# [6 O8504021
! x6 Z+ n/ B3 c+ j: F/ TExtra NC path generated on the areas not selected  as Cut Area$ l0 E2 G4 l& |
8504512
8 U3 X- N' I+ ]* T, B4 NCGM file cannot be imported in NX 10* c- p- }6 Q' A+ C( b1 n( G
8505783
" A2 ~' s, c; o; t0 e# RCAM Face_Mill_Manual Regions have Gouges - Wrong error  message, M( v+ K" y4 k  Y
85059432 l& M2 Z1 c8 K0 G3 B1 C& K
The object changes to translucent after select it  in ONT
! @3 u4 q5 @- L3 F7 s3 h! m& z8506062
( W- i3 J- \0 ^1 S7 e6 zExtreme Point Measurement feature is not localized  in PNT+ c! W. P7 U0 H% J# R
8506772
5 {0 P6 i+ P8 H9 V% I: W7 r4 g& [Internal error occurs when running Create Region List  and Delete All three times# H% v, |, T% w1 {- w
8506844
1 g* {2 U9 t/ K  ~8 H7 b7 O; |While add component and loading in NX 10 takes more  time compared to earlier version: J0 |( j$ ^$ b, [0 n) V
8507020* N2 D* W9 g/ a2 \
GetParameterData() & Aspect() does not return  values- M! p, X$ J2 q, t- W7 a  Z& S& J
8507142
# o+ x8 W! U( KWhen moving split body, the associative curves are  not updated well
( ]8 i' x) l. J* S85081836 D. \' E# k5 u: d5 z: y+ ?' y- `
Grip primary message was not honoring 40 character  limit
$ S* n7 Q7 Z* ~" l8508685
& E' [+ d( c& @) KExport to CSV, and the attribute of measurement in  Chinese is wrong
. {- H  A+ z! G/ Q" v8508768
- O7 C8 O* Q1 ?9 U$ Sksc_5601 Teamcenter encoding was not mapped, a" P9 i. B( ~7 ~9 [/ b
8509983
- @: o4 D  y. Q- n; ~: _- N  \"work order" does not works in NX 10, NX  9 works fine
3 ^3 ~) H: f( A. N/ a- C85102460 G; k! H, P" S. m1 `, B
TABNOT_cell can_update_with_unloaded_refs(..) was  overridden in NX 10 to return TRUE so that attributes on unloaded objects  and referenced by cells are evaluated. Parts List cells are evaluated  on master model close which triggers parts list update. During auto balloon  processing of Exact views, while determining whether reference balloon  is present on a component, call to Drawing
1 e9 A9 J; c- }' R' F# r8702416( e9 Z* O7 C! Y8 r7 @! k
Unable to export a tabular note to DWG
2 _0 u6 R0 f8 Z3 U. m; Q& a
5 C# N. d, u  i4 j. e# E' M
发表于 2016-4-24 21:28:31 | 显示全部楼层
升级后,自定义设置在进入任务草图后会消失,请问有解决办法吗
