[资料] UG二次开发模板(2)函数模板
2013-9-23 22:26:28 3974 0
发表于 2013-9-23 22:26:28 | 显示全部楼层 |阅读模式
函数模板
1, uc1600   //获取字符串
头文件:#include <uf_ui.h>
int res = 0;
       int len = 0;
       char string[100]="";
       res = uc1600( "",string , &len );//string:Input / Output
       if ( res == 5 || ( res== 3 && len > 0 ) )
       else
2, uc1603   //
用法1:
        char title [100] ="菜单";
       char items [3] [ 38 ] = { "选项1","选项2","选项3"};
       choice = uc1603(title, 0, items, 3);
       if (choice == 1 || choice == 2)
           UF_terminate();
       else
           if (choice == )
用法2:
       response = uc1603( "菜单", 0, items, 3 );
       swiTCh ( response )
       case 1:
       case 2:
           break;
       case 4:
       case 5:
3,选择对话框头文件
头文件1: init_proc_face
static intinit_proc_face( UF_UI_selection_p_t select, void* user_data )
       int nums = 1;
       UF_UI_mask_t masks[] = {
          UF_solid_type, 0,UF_UI_SEL_FEATURE_ANY_FACE};
          if((UF_UI_set_sel_mask(select,
              UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC,
              nums, masks)) ==0)
              return(UF_UI_SEL_SUCCESS);
          else
              return(UF_UI_SEL_FAILURE);
头文件2:init_proc_body
: z4 `! P% T& B% \& R) Xstatic int init_proc_body(UF_UI_selection_p_t select, void* user_data)
    int num_triples = 1;
    UF_UI_mask_t mask_triples[] = {UF_solid_type, 0, UF_UI_SEL_FEATURE_BODY};
    /* enableonly lines and edges */
    if((UF_CALL(UF_UI_set_sel_mask(select,
       num_triples, mask_triples))) == 0)
        return (UF_UI_SEL_SUCCESS);
    else
        return (UF_UI_SEL_FAILURE);
4UF_UI_select_with_single_dialog
        char     title[]="";
       char     cue[] ="";
       int      response=0;
       double   cursor [3];
       tag_t    face = NULL;
       tag_t    view = NULL;
       if(!UF_CALL(UF_UI_select_with_single_dialog(cue, title, UF_UI_SEL_SCOPE_NO_CHANGE,    init_proc_face,NULL,
           &response,&face,cursor ,&view)))
           if (response == UF_UI_OBJECT_SELECTED ||
              response == UF_UI_OBJECT_SELECTED_BY_NAME)
              printf("object tag = %d\n", face);
           UF_DISP_set_highlight(face, 0);//关高亮
5UF_UI_select_with_class_dialog
void class_sel_dlg(int*count,tag_p_t *objects)
    char cue[] = "";
       char title[] = "";
       int response, sel_count, i;
       tag_p_t sel_objects;
       if((UF_CALL(UF_UI_select_with_class_dialog(
           init_proc_face, NULL, &response, &sel_count,&sel_objects))) == 0)
           printf("object count = %d\n",sel_count);
           if (response == UF_UI_OK && sel_count > 0)
              *objects=sel_objects;
              *count=sel_count;
              for (i=0; i<sel_count; i++)
                  printf("object tag = %d\n",sel_objects);
                  UF_DISP_set_highlight(sel_objects, 0);
              UF_free(objects);
6,UF_MODL_delete_object_parms//消参
头文件:
#include< uf_modl.h>
#include< uf_modl_utilities.h >
uf_list_p_t obj_list;
       UF_CALL(UF_MODL_create_list(&obj_list));
       UF_CALL(UF_MODL_put_list_item(obj_list, ));
       UF_MODL_delete_object_parms(obj_list);
       UF_MODL_delete_list(&obj_list);
7 J. J9 m7 W5 a8 u
       UF_OBJ_delete_object();
7,UF_CURVE_create_arc//通过圆心,半径画圆
头文件:
#include< uf_csys.h>
#include< uf_curve.h>
    tag_t  arc, wcs_tag;
    UF_CSYS_ask_wcs(&wcs_tag);
    UF_CURVE_arc_t arc_coords;
    UF_CSYS_ask_matrix_of_object(wcs_tag,&wcs_tag);
    arc_coords.matrix_tag=wcs_tag;
    arc_coords.start_angle = 0.0;
    arc_coords.end_angle =360.0 * DEGRA;
    arc_coords.arc_center[0] = center[0];//
    arc_coords.arc_center[1] = center[1];//
    arc_coords.arc_center[2] = center[2];//
    arc_coords.radius = 500;
  UF_CURVE_create_arc(&arc_coords,&arc_id);
8,UF_OBJ_set_name(tag,name); //设置名字
头文件#include <uf_obj.h>
9,name开关
       intname_status ;
       UF_DISP_ask_name_display_status(&name_status);
       if (name_status==UF_DISP_NAME_DISPLAY_OFF )
           name_status=UF_DISP_NAME_DISPLAY_ON;
       else
           name_status=UF_DISP_NAME_DISPLAY_OFF;
       UF_DISP_set_name_display_status(name_status);
, t9 j: f% m5 u' u- f$ m  C
,UF_OBJ_set_color(tag,color); //设置颜色
11,UF_OBJ_set_layer(tag,layer); //设置层
12,UF_CALL
头文件#include <uf.h>
int UF_CALL ( interrorCode )
    if ( errorCode )
       char message [133] = "";
       UF_get_fail_message( errorCode, message );
       uc1601 ( message, 1);
    return (errorCode);
13, UF_PART_ask_display_part
头文件#include <uf_part.h>
tag_t part = UF_PART_ask_display_part( );
       if ( NULL == part )
           uc1601( "", 1 );
           return;
14,UF_OPER_create
头文件#include <uf_oper.h>
tag_t Oper_id = NULL;
UF_OPER_create ( "mill_contour","ZLEVEL_PROFILE_YBC", &GZM_Oper_id );
15,UF_MODL_ask_face_data//查询面的信息
5 W6 J; Y# ^  H" U7 {头文件#include <uf_modl.h>
tag_t face;//面的ID
    int  type; //面的类型
    double box[6];//x,y,z向最大,最小值
    double radius;
    double rad_data;
    int  norm_dir ;//法向
    UF_MODL_ask_face_data(face,&type,center,
       dir,box,&radius,&rad_data,&norm_dir);
16,UF_MODL_ask_minimum_dist_2//查询两物体间距离
doubledis,accuracy;// accuracy:准确度
double point1[3 ]={0};
double point2[3 ]={0};
UF_CALL(UF_MODL_ask_minimum_dist_2 ( obj1, obj2, 0, NULL, 0,NULL,
              & dis, point1, point1,&accuracy ));
) R. T; q# p, y7 {% ^
