[原创视频] Knowleage fusion中的使用的所有NX UI列表
2016-3-31 20:45:00 4088 0
发表于 2016-3-31 20:45:00 | 显示全部楼层 |阅读模式
Knowleage fusion中的使用的所有NX UI列表6 Q' C) C0 T% T* E6 Q+ J  d
%ui_comp
. q8 a- t) d, T6 I%ui_comp_angular_dim, f+ z: B( y0 W' Z; s& a6 N) w  c
%ui_comp_axis
6 n; |, h  G' ^4 @%ui_comp_button
" Y0 d: p& W7 E; q%ui_comp_cae_plot
0 \: ^7 U" C$ v1 @, k' l%ui_comp_csys( j, h$ W+ x8 O# S& D9 S8 y
%ui_comp_double# W' x0 B( }- l% W' U
%ui_comp_enum
' m0 F) c" N+ ?, Q0 M- z9 L%ui_comp_expression
3 L1 x7 q; o; G%ui_comp_family
# n% ?# c  J" _& I; S8 s$ U( `%ui_comp_group
3 k5 |. C; E6 R%ui_comp_integer% `, |, ]5 K: f% s3 t4 r
%ui_comp_label( z$ E. o; [/ X7 W2 d, B+ J! c. X- B
%ui_comp_layer_settings$ g% {: }! k  J5 ~; E7 l/ I
%ui_comp_linear_dim
  v7 O2 u8 e+ U%ui_comp_list_box  U( B2 y& v0 P/ ]5 X+ Q
%ui_comp_motion_graph" U' a. v; G. k8 P
%ui_comp_motion_play$ ?' y& y8 h; j! [2 L! k' V
%ui_comp_move_component) O5 r3 O' b# u; U; [' |
%ui_comp_point, Q3 m5 T: G+ o
%ui_comp_relink
& d8 m! D$ h2 w: V* ?. g4 B! L%ui_comp_routing_position
, V1 R  h- i1 i' K%ui_comp_selection; A$ ?4 N5 Y/ V2 B' [" O( w
%ui_comp_select_feature; S/ P2 X& ~3 {8 h
%ui_comp_select_file$ R+ Y* y0 y5 F/ I" V
%ui_comp_select_folder
3 b( V9 w2 h- [- \5 ?%ui_comp_separator6 F/ x' l- V2 W4 L5 w( g
%ui_comp_skeTCh
* G" h" A* ]+ c( m%ui_comp_tabs
1 \3 x* n5 e6 d! S: w: q  ^%ui_comp_toggle
5 O5 G# e& d! r% D, c%ui_comp_transform) N2 K) e% `2 J, B0 R
%ui_comp_types
, h, S$ |4 G$ Z: Y% z4 J+ e/ M7 l%ui_comp_value
  h; }& X! s# @4 R7 `0 [%ui_comp_vector; g2 A: B4 z: H' ?  X; K4 O
%ui_comp_widget
! v3 J8 h5 Y! s
