[二次开发源码] NX二次开发源码分享: 导出 step格式
2018-1-7 23:25:47 4164 1
发表于 2017-1-16 15:31:09 | 显示全部楼层 |阅读模式
1 B9 R: L9 f+ F: U% S' N, p
# h" W; _! v' k7 T$ H" o
1 o  |, \& b! l: ]; ?6 ]NX二次开发源码分享: 导出 step格式
( v, ]! D$ b2 k7 t2 Y8 a1 f+ ?6 |6 B6 b2 T
参考一下,很简单哦!!! S" W1 g) f* U/ y/ I1 o/ v, L+ j
6 m8 \# w2 E; a6 a% w6 u, Avoid StepExport::do_it()1 @9 ^& f! D1 R: w6 u! @# W# D
& H- J2 B6 \9 J: B0 o    std::vector<TaggedObject*> objectArray;
# c  T/ H$ k2 u9 z5 M6 B
# J- O0 B( X. B7 X3 g1 |5 Q' y$ Q. |    if (select_bodies(objectArray)): `, }, L- q8 c" i
+ V& Y! V1 x7 r        NXOpen::Session::UndoMarkId markId1;
+ A, M% ]+ x/ }. J/ r  A        markId1 = theSession->SetUndoMark(NXOpen::Session::MarkVisibilityVisible, "Start");0 P4 q# o7 }+ i9 b1 y1 C* l1 r+ x3 z
, P, V( _- u7 @5 p4 T, t
        NXString sBaseDir = theSession->GetEnvironmentVariableValue("UGII_BASE_DIR");
7 @8 O2 l; i" G- s- L        NXString sCfgFile = sBaseDir + "\\step214ug\\ugstep214.def";
! a# o- f4 q  b% f  q        NXString sPartSpec = displayPart->FullPath();
3 y- X- X6 D0 j2 t        std::string sFolder = sPartSpec.GetText();3 Z4 ]# E' J# L. Z- ^
        std::size_t found = sFolder.find_last_of(".");& Q& ?6 g/ n4 m' }* ?; q  F, q
        NXString sStepSpec = sFolder.substr(0, found) + ".stp";
2 ^7 s1 k5 s- m0 G8 G
) ]/ e, e3 G  d) [, t        NXOpen::StepCreator *stepCreator1;7 |$ U9 V" L8 |! m0 D+ n
        stepCreator1 = theSession->DexManager()->CreateStepCreator();& o& g% {$ @& f' x
        stepCreator1->SetExportAs(NXOpen::StepCreator::ExportAsOptionAp214);; K3 V' m% z4 |# q- O" M
        stepCreator1->ExportSelectionBlock()->SetSelectionScope(NXOpen::ObjectSelector::ScopeSelectedObjects);/ ^1 M8 q7 ^! h+ b# A, u0 Z
        stepCreator1->ObjectTypes()->SetSolids(true);1 i- `! I, b% a! ]; q- Z
        stepCreator1->SetSettingsFile(sCfgFile);& a. C0 S8 |0 @! q0 I
        stepCreator1->SetInputFile(sPartSpec);
7 o' v  J( ]0 z8 j        stepCreator1->SetOutputFile(sStepSpec);
# E* _+ V- X9 N, Q$ h        stepCreator1->SetFileSaveFlag(false);
/ r" u+ F7 H! ^4 Q: x9 {        stepCreator1->SetLayerMask("1-256");2 p9 t' D6 p' I5 o( U; T2 ?2 o
3 D2 f  l. N: D$ i* c! e7 }! p8 i  }" ~        std::stringstream sBodyList("");
# w  @1 E2 g/ \2 s. [
5 y8 {1 Q5 ]8 p. X/ i        std::vector<TaggedObject*>::iterator iter;. J/ h; J7 o  I0 V( Y
        bool added1;5 d3 p, r- Q  W9 f: e* s
        for (iter = objectArray.begin(); iter != objectArray.end(); ++iter)
3 _3 V2 d8 Q8 E& F% Q  s0 K        {
/ T+ m$ ~! p! U: z3 e1 A+ H* g            Body* theBody = dynamic_cast<NXOpen::Body*>(*iter);4 G+ j+ A5 j5 x; g) Y
            if (theBody)  R  b3 B1 w. x5 l! l# v: P& O1 C+ Q
0 S( H$ E" E) T1 U9 U% E& I. @                added1 = stepCreator1->ExportSelectionBlock()->SelectionComp()->Add(theBody);
+ Q/ ^: d) F0 n  E$ W                sBodyList << "Adding Body " << (theBody)->Tag() << std::endl;$ j8 n# K1 I& N. V& Z
; r7 P9 [. s. X& B, f9 y9 A. f5 B) v        }  p  {; M% t/ ^8 M1 u2 j
7 x, t; U% |# P/ M  f+ G        // Debug output7 F! |* G+ i: n
        print("UGII_BASE_DIR = " + sBaseDir);2 Y6 C5 Z2 l% `% E+ [
        print("Settings File = " + sCfgFile);
! G" q; ~1 ^$ j& s" ?4 {! [        print("Input File = " + sPartSpec);
2 a9 l3 v+ a- L- n' S        print("Output File = " + sStepSpec);0 c* g/ j/ `3 ]
        print(sBodyList.str());! Y# U$ t  o) J* Z2 q
) ?  o' j' j" j- `; v; O: ^0 J        NXOpen::NXObject *nXObject1 = stepCreator1->Commit();1 G3 R7 A2 b: K
        stepCreator1->Destroy();6 Q  B/ \% y0 q' [
    }$ \8 u, s8 A/ ^3 I% k: @3 y. n
: l# b, Z5 O+ A! j
}6 B4 T; n4 X8 H- e" }% Q
/ \; x8 _2 G. P: H6 ?) u
发表于 2018-1-7 23:25:47 | 显示全部楼层
请问导入dxf/dwg用哪个函数?
