[二次开发源码] NX二次开发源码分享:用ufun函数选择一个装配组件
2017-2-6 12:59:23 2932 0
发表于 2017-2-6 12:59:23 | 显示全部楼层 |阅读模式
0 F+ \4 B: n) c2 k) ]2 zNX二次开发源码分享:用ufun函数选择一个装配组件
2 }8 S" D# I+ B' \2 q. l" J; P! V8 f! x9 U4 r& S  X) K
static int mask_for_components(UF_UI_selection_p_t select, void *type)
% p+ K- F3 q# q( I6 ?{( W) ]) I' a' \. {( M
    UF_UI_mask_t
; W, J) J" b' }        mask = { UF_component_type, 0, 0 };* T6 G5 V4 j& p9 e  D7 }
) J6 _% {: r1 u8 w* T- ?) W! l    if (!UF_CALL(UF_UI_set_sel_mask(select,& j9 a8 \+ A$ C9 ]( |; S; D
            UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC, 1, &mask)))
* j' w+ j- L/ {        return (UF_UI_SEL_SUCCESS);9 j7 `- d7 J) M7 m9 T2 j
    else
: y; C2 y  p- z/ ^' x        return (UF_UI_SEL_FAILURE);
# {! K( E& N  g4 {) ^}' |: e0 S- K9 g4 u6 ?+ s3 ]
3 _" z, n; D$ w+ X
static tag_t select_a_component(char *prompt)% A9 {9 e# W% x+ h" t3 U" G
/ C: O$ Y! q8 P; X    int/ l6 o# J' H; T9 m  h- V
        resp;
) j5 I$ L6 ~. z! f* q1 r: W    double
4 P/ Z' {6 N* E6 D        cp[3];) `% _8 B1 I# L) v. d4 P
    tag_t6 x$ G; L7 p) K7 }( Y
        object,! B' E8 s5 k" J2 T  ~
        view;- g- U  S7 @9 \! A% N! J
1 E" t' i! A+ \9 i
    UF_CALL(UF_UI_select_with_single_dialog("Select a component", prompt,
$ P* f- a) C4 x/ H        UF_UI_SEL_SCOPE_WORK_PART, mask_for_components, NULL, &resp,) i0 V) ]2 S- |# |2 b* E6 H7 j$ M  Q
        &object, cp, &view));
% ~  V1 |% W4 G1 M% Q- |1 W& N9 o" a& h, F7 ]
    if (resp == UF_UI_OBJECT_SELECTED || resp == UF_UI_OBJECT_SELECTED_BY_NAME)
3 S' O9 M' r5 a$ }# s9 R; W    {9 \' ?. p$ f* T& h
        UF_CALL(UF_DISP_set_highlight(object, 0));6 j& {+ C7 z" ~  N& d6 x
        return object;/ K* f& ?* j# V2 D
! _5 v5 D9 j/ G: u! C    else return NULL_TAG;' F  y9 |2 T: M/ }
" b4 M. a: K1 p9 l' R! J3 {4 V
" E! e8 k* Q+ k9 g6 h$ c' N5 K5 h+ w9 O! d$ ?
