[TC问题解决方案] 135. How to change java directory for FSC and Server Manager
2017-4-1 09:05:34 3215 0
发表于 2017-4-1 09:05:34 | 显示全部楼层 |阅读模式
135. How to change java directory for FSC and Server Manager* p' E% i" n; h8 _6 z, z
For some reason, you may change java directory to another, and delete old one, then9 X$ z5 P/ u  g) ]3 _) e0 X
FSC and Server Manager service are unable to be started.
5 o& W$ i( [/ W+ N! B' o& ?! e) H0 i7 j7 {5 N
) }5 x: l8 k& x9 e
How to fix it?! c9 Z# m4 ~5 }) m4 ]1 B9 i
You need to migrate Teamcenter to use another JRE using Environment manager.
# r8 L, Q  U* N% g& w
' U! y, p$ i2 H  ]If you face with unable to find java error when launching TEM, please first modify
3 o+ Z- o: L5 J/ }' _TC_ROOT/Install/tem.init.bat file, and give it correct jre
