[UG NX高级技巧] 189. 如何导出JT 只有B-rep
2017-5-23 10:12:48 3337 0
发表于 2017-5-23 10:12:48 | 显示全部楼层 |阅读模式
9 B/ x) G2 K6 T2 H' n189. 如何导出JT 只有B-rep
  S5 c9 v0 q/ y% e, f/ d; V/ Z. j# ?3 i( t4 ^+ e
Yes, there are 2 ways to accomplish this.* l0 b. F+ P2 Q3 |) B. I* {
, b! B! [. q  T1. Go to <install_path>Siemens\NX 11.0\PVTRANS and edit tessUG.config in a ( s1 k0 O4 \2 f4 L! q' ~: ~
test editor. Then in the top section called EAITranslator add this setting at
) z) [9 F9 o5 y. ythe end:* ]" I9 z! c: v& {8 ?  `
1 t8 h3 B7 g! i! e' `7 e# Z9 RincludeGeom = false) p. L- E. h- B2 [+ B( `% q
) r# z5 O, n& ?- K  u3 c2 VThis will create jt files with no tessellation and B-Rep only.
. z% F, r) V) l' c& c! q4 [: X) H& Y2 A
2. The other option is to load the jt data into standalone TCVis > Tools >
- s1 b5 O* p* G3 ^& M5 y! Z9 q& EPart Edit. Then go to Part Edit > Control tab > RMB on the LODs > Delete. Then
. c2 b) g, Z) f7 f4 `2 ?; Xgo to File > Export > and now you can export a .jt file with B-Rep only8 `, J3 V8 p% L  Y
