[资料] NX11.02 对二次开发界面Block Styler的一些增强
2017-10-24 16:17:59 2135 0
发表于 2017-10-24 16:17:59 | 显示全部楼层 |阅读模式
, k9 j9 i, V' @, g7 s+ X1 ~: G3 M
5 y5 T" V& n- {! dTreelist 增加宽度控制,这个比较好,以前都是通过增加标签来扩大/ _* ~0 R5 m* R8 ?
- K1 X) t5 Z. b, b+ R2 O7 J+ m
Property name
Description
Width
Specifies the number of pixels for the width of the block.
NX stores the width of the block in dialog memory when you set Dialog Sizing property to Allow Resize.
CanStreTChWidth
Specifies whether the width of the block changes dynamically when you resize the dialog box.
MinimumWidth
Applicable only when you set the CanStretchWidth property to True.
Sets the minimum width of the block when you resize the dialog box.
MaximumWidth
Specifies the maximum width of the block when you resize the dialog box.
+ M8 T  S' ], N- r" R7 v# c' l8 R1 x4 r+ |% r
6 k# }# d4 B1 k! s这里主要是字符串输入是否为强制输入,如果选中每输入,当然ok,apply就是灰色的啦,还有就是选择零件组件。3 p6 ^( u2 z. L- O. F8 o/ R0 N
其他的选择功能,增加了对3D打印这种零件类型的支持 ! 姑且叫做  汇聚体 吧
  }) q, w  D! {: Y# q3 J2 z! \# Z8 Y2 ]3 S
6 m" B+ H6 z3 L1 I, V; P# h
. C. O3 N, J. B3 k
Block
Property name
Description
String block
RequiredInput
Specifies if the string input is required.
Select Parts from List block
SearchButtonVisibility
Provides a search tool for the Loaded Parts list.
AvailableViewStyles
Specifies which View Style options should be available.
ViewStyle
Controls the display of the Loaded Parts list.
ColumnVisibility
Determines the initial column visibility state of columns in the Loaded Parts list.
LoadedListHeight
Sets the height of the Loaded Parts list.
LoadedListWidth
Sets the width of the Loaded Parts list.
Select Object block
Section Builder block
Super Section block
Curve Collector block
Face Collector block
Body Collector block
Super Point block
AllowConvergentObject
Specifies whether you can sele
4 |! m7 \4 c6 R8 ~) {2 @  }2 [3 c; H/ i; d' L) F& T% g2 d! `
+ A5 g2 H$ t1 V9 W! F' `. f
: ?8 j) Z% Y1 }; T
