UG NX二次开发源码分享: 导出parasolid 格式文件
: D% s$ D2 C! Y) O/ ~4 x
2 R# e" l0 L. q( s) G! c2 _- #include <stdio.h>
) G& @. y& b) k4 F; k, s - #include <string.h>
7 ` ^' X! d: y7 C2 d4 R - #include <uf.h>6 T/ ?: o, v/ K: l! q- |
- #include <uf_ui.h>7 N4 l$ t3 H* j! C- \; h
- #include <uf_obj.h>
4 [5 Y5 }2 R- f0 ^- N - #include <uf_object_types.h>+ k4 U. K% }7 S* D
- #include <uf_modl.h># C3 M' G! j+ W- P# K
- #include <uf_part.h>6 w7 `/ A: U( M
- #include <uf_assem.h>' V; A8 S. y! X! ~/ ~, |' o9 f
- #include <uf_ps.h>; C( A1 u7 Y+ I2 R- w9 Z" U8 z
# Q7 N1 M: a4 v - #define ECHO(X) { UF_UI_open_listing_window(); \6 i b) O- t7 |" w% s, z# m+ U: B, I1 R
- UF_UI_write_listing_window(X); \
! S. f7 u$ H+ M" P5 K - UF_print_syslog(X, FALSE); }
* z; L1 j0 P5 H4 w3 o -
# C' V! b3 l6 j1 ] - #define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
! G I0 A% \9 Z1 q - & C- \; ?. A( B& m% X. I
- static int report_error( char *file, int line, char *call, int irc)
4 U( a0 J) W6 A* K& x+ B) l: n1 t5 N - {8 ?3 }/ a H. E6 L; F" i
- if (irc)
& C Z2 S3 _2 f; _6 ] - {
% `/ B8 J- x3 z- G* ` - char err[133],$ r+ O+ Z) @% A* E
- msg[UF_UI_MAX_STRING_LEN];
$ K* J2 c# H1 R: r& C0 e - 2 y2 U: R3 [. d2 z8 q5 j! b7 u; P
- sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
, f' X# f% i2 S2 U# ?! L - irc, line, file);( X, M$ u9 h& Q( i0 I% F
- UF_get_fail_message(irc, err);7 R6 Q: @3 A3 U* Y, B4 N
- 8 }: ]% s4 e4 i! O
- ECHO(msg);8 l" {. X/ H, i% w% w) c. t0 U
- ECHO(err);
9 |! ~ l4 X4 }: j. V$ g - ECHO("\n");
$ L0 y- l7 s$ [0 J$ g/ u& I - ECHO(call); M1 O* i+ b& x6 ~5 w% y, S5 \
- ECHO(";\n");$ {( R$ O/ Y, F: i. C+ Z
8 M( Y5 _9 t$ o2 A# ~$ ]* ?4 E -
8 ` o+ e5 L) X1 A! h( `5 O3 d - return(irc);
6 m# f9 u3 ?$ p2 | - }) a$ _! u3 T4 C, G/ m1 S
- ) p* E# \3 {: x9 n( C
- static tag_t ask_next_solid_body(tag_t part, tag_t body)9 b+ L* R# _0 `. [
- {: ?4 A5 L/ Q; T
- int/ U( t$ B% |& ~+ R0 ?
- subtype,
6 K3 U, v* z7 h$ r0 }9 R - type;
5 s6 t, G) O8 P* q8 m6 h - : x8 _; h! P, X6 s h( J
- while (!UF_CALL(UF_OBJ_cycle_objs_in_part(part, UF_solid_type, &body))
; F8 H$ M( o5 }2 R. K# z" O - && (body != NULL_TAG))- F) x( U5 k" \' U3 w* W
- {% F; z# B: f |. { Y. }
- UF_CALL(UF_OBJ_ask_type_and_subtype(body, &type, &subtype));
* ?! v- I# ]0 K8 r( b' E4 P - if (subtype == UF_solid_body_subtype)
* M3 Z( i3 u% H+ B) D! \3 H1 i - {
6 v( h1 U4 Y9 ~1 W) `6 j - UF_CALL(UF_MODL_ask_body_type(body, &type));
. W$ j, E( {& E7 y! r; o - if (type == UF_MODL_SOLID_BODY) return body;
1 i2 b- o! P" l' N# X9 h6 q) l4 v - } E' f8 j4 x8 o% V) M! ~8 _$ R. Q
% n9 o7 v0 a- t! l- b( \" S - n/ p. U4 G4 F; }* r
- return NULL_TAG;; _& C2 \5 \. B; B4 U: z9 L
- }: l2 j- v6 i$ s7 y# u L' A
2 h* U% w% l& N5 L! w$ W - static int allocate_memory(unsigned int nbytes, void **where)
2 ? m- R% u, ]# p2 e( v/ R - {
7 I' ~6 R( n, r7 H - int
2 c4 U8 |$ B. f- {6 `$ `5 q: r - resp;1 H9 V/ M- F9 G# q1 [6 y
- $ k$ @) U9 F5 w$ }3 T) |9 P* U1 u; _% K
- *where = UF_allocate_memory(nbytes, &resp);0 }! J3 f6 s/ f' F
- 1 V0 A. w# H# Y7 r) ~
- return resp;
) ^) |6 ~: G& o$ d - }/ S$ `9 r/ e" ^$ X7 y% F
$ R' |% ]" [/ Y! e0 s% i. x - static int make_an_array(uf_list_p_t *object_list, tag_t **objects)
, n" f: \/ R+ ?% P - {
/ l2 W- r& T k' F8 S( _ - int' a, v, ?' f+ m$ u4 D4 ~6 {
- ii,. l* q3 Y/ a) v+ v
- n;
: Z' w4 @' X! Z& ~' C( H - uf_list_p_t7 P8 A7 O8 D, @# z0 i* Z
- temp;
5 a+ J- ^% @7 V( d -
" ?: w8 } ^3 v. h - UF_CALL(UF_MODL_ask_list_count(*object_list, &n));" J$ f) }9 X1 [( I1 A% N
) f9 p* U$ w3 ~% W; ~/ [ - UF_CALL(allocate_memory(n * sizeof(tag_t), (void **)objects));0 ~" F- M2 l8 w
7 v" W0 m; y( j( } - for (ii = 0, temp = *object_list; ii < n; temp = temp->next, ii++) Y) ^8 L& u: _+ J. g9 b) i3 u; V" `: l4 e
- (*objects)[ii] = temp->eid;2 T) w, T$ c' q4 H3 S
- 8 p7 m3 y. w4 G7 `2 @, E
- UF_CALL(UF_MODL_delete_list(object_list));
1 Z8 v& C+ T% L% D( a3 W6 n: q+ x -
* x1 T! F+ ?+ t5 o5 a - return n;2 m# `# t" Z( v+ @, D
, H7 S: C# R3 S7 J -
7 I3 v$ _" \8 Y N" |9 R5 h. |; v; _ - static int ask_all_prototype_solids(tag_t part, tag_t **solids)3 Z; l1 W3 H% {0 G$ J. _* R. [
- {- e# ~# k: | |- F& ?2 D
- tag_t
: E/ w8 r4 V6 d+ U$ e: s - solid = NULL_TAG;
) F3 h3 l, Y4 ]+ W; c - uf_list_p_t; r6 ~1 i9 _; B, q E* F% w
- solid_list;
$ h* j7 @2 c' X g - l0 f7 n3 Q8 I2 }& q. P5 g
- UF_CALL(UF_MODL_create_list(&solid_list));3 n! g. b/ Y( g7 E3 \
- % [! f% Z# C: D# _$ |
- while ((solid = ask_next_solid_body(part, solid)) != NULL_TAG)
. r+ l) c, T' g+ B9 u3 j8 j g - {
, P* s f6 i" g5 k, ?6 g - if (UF_ASSEM_is_occurrence(solid))) T2 \" l1 Y% v* a; ?
- UF_CALL(UF_MODL_put_list_item(solid_list,# k+ `; X2 D% b0 u$ J
- UF_ASSEM_ask_prototype_of_occ(solid)));) _# K3 s+ N8 A/ Q# u
- else
- r, I) i" Y' Q F# l9 W$ [! K - UF_CALL(UF_MODL_put_list_item(solid_list, solid)); ]# F4 }) p! D$ x4 ?
* j9 V* r0 X F1 P9 ]/ v. | -
; J1 E; V/ T: }# w. | - return (make_an_array(&solid_list, solids));
7 p1 D5 l0 X6 S* r3 C5 H3 t - }5 {1 C: A2 J! R, L( E+ s
- ( G- z% ~9 t) L# Q
- #define WRITE_D(X) (write_integer_to_listing_window(#X, X))
& N7 D2 _; J! N - 2 u7 d4 l$ A8 p) c
- static void write_integer_to_listing_window(char *title, int n)
- y1 L" \: U |* ] - {
0 ]/ ]" ]3 E$ B4 H" n - char
- {" t7 |+ ]; w# d' q2 d) h' X. i - msg[UF_UI_MAX_STRING_LEN+1];& ^* h4 `$ X0 k+ e' l( {6 u4 |# a
- ) v% U+ F. D% o/ R4 A2 \6 ^
- sprintf(msg, "%s = %d\n", title, n);, U' ?' K0 g' A1 U" k& T
- ECHO(msg);. v+ S# ? g! j1 m" s
1 C$ R2 E0 F+ X& `+ H# g6 p -
! t$ A) G1 P' ]; Z - #define WRITE_S(X) (write_string_to_listing_window(#X, X))8 G K5 q7 O& p9 @" M
- 3 n6 w' ?% L2 X! q1 q4 ]! v2 c9 T7 O
- void write_string_to_listing_window(char *title, char *string)
0 e4 L: a( |. Y# c* f# v - {
* P0 L6 E' x' I- A* `* B - char/ T T% o( p* ? ~+ }5 J! o& B1 E8 b
. U, H$ ?, ]" }/ Q -
( y$ {6 P8 }. }+ V5 m4 q - if (string != NULL)* M0 K' T e2 Z/ x
- sprintf(msg, "%s = "%s"\n", title, string); }0 F3 ^& @5 l9 {- {
- else
S. ]. a# a: \4 e& R - sprintf(msg, "%s = NULL\n", title);2 `5 m: J2 |: _
2 M/ |! n# S# H - ECHO(msg);* y' d7 G; [6 X+ Q% s
- }5 a1 b) o$ @9 V4 h% _! n; L. @6 M
' T2 K0 M4 N& a: e) s6 _ - static void build_unique_temp_name(char *fspec, int ftype)
8 S: u x" z' C9 L2 x5 e' B# r - {
* Q& N6 j1 d& E5 f0 z( U( b - char
6 {( u9 n$ d7 y* Y$ d7 s% V - *tmp_dir,
9 I3 h, N! J% e2 I+ m - unique[UF_CFI_MAX_FILE_NAME_SIZE];8 o3 a( ]6 N$ `3 m% _
- - z3 f: |- m _# j) h. R a
- UF_CALL(UF_translate_variable("UGII_TMP_DIR", &tmp_dir));: o- J% X# Z- M
- UF_CALL(uc4577(unique));
/ Q( [, U1 ], \ - UF_CALL(uc4575(tmp_dir, ftype, unique, fspec));# @2 X: Q' R+ Q& o
. _% \$ `* ]) \- C9 V4 W - 9 @5 l4 @' }9 ?5 x/ w
- static uf_list_p_t make_a_list(int count, tag_t *item_array)% G/ O" H- h6 m V. l7 m, ]: l" F
1 a; F3 z* }5 O: k$ [+ j - int7 K6 Q6 I/ M8 K& C+ g& t
- ii;. T; x. w) O/ w* n. C) ]% D3 S
- uf_list_p_t! L- `7 }6 S2 X3 z" c1 G1 V
- list;7 [3 ^1 z# U4 A# m" G9 ?5 N- O
- h. V; A5 @ j' A
- UF_CALL(UF_MODL_create_list(&list));
1 X) [' i; t% u! y$ Y+ m -
' [8 N5 b9 V, f' J - for (ii = 0; ii < count; ii++)
" J, H: ?: n3 |) f) I3 x - UF_CALL(UF_MODL_put_list_item(list, item_array[ii]));5 j$ x+ E) C. ^4 r, C& j1 @# N' m
- - w- \& o$ ~- I; @" g' d, u
- return (list);* c+ P+ O1 w' f9 f" ^0 b% V' s- I
- }: S2 ]4 ]( ]7 f5 ]1 q1 [5 ]7 H
w' P7 |5 P* ~. c# u - static void do_it(void)
7 F; M% k8 L9 g9 Z - {
7 r0 t) d5 J$ W" Q/ v9 g - int' Y2 ]( [; @$ J
- ii,
. d. A6 Q+ _! L5 F - n;
$ f8 r, i% i- L - tag_t) c5 ~( l9 v7 r1 [" f
- part = UF_PART_ask_display_part(),0 W/ v' e4 t& @
- *proto_solids;5 {/ D$ t8 Y2 S4 B! G, A
- char" n( Y, w* T) W' W' m! L# l
- exported_to[MAX_FSPEC_SIZE+1],
( @$ @# l/ ^4 L* Z0 k - *handle;
/ \0 ?# S* I1 l3 |# K9 I - uf_list_p_t* w; Q1 B; C- y% l( L+ G
- body_list;
) m5 o) _. k& y) x - " e# l7 p( Y$ \! ? d1 ]
- n = ask_all_prototype_solids(part, &proto_solids);
+ ]! w" k3 ~9 h0 |3 k -
7 T+ _2 P9 I: C; K- ]3 T( m1 P - for (ii = 0; ii < n; ii++); G9 w; B [. y+ a$ t$ h
3 n9 f% d& R/ A8 ~) S6 y( f# W - WRITE_D(ii);' o$ ?4 H: F6 `8 N
- WRITE_D(proto_solids[ii]);
7 ^/ p, M! Z8 ^' e - handle = UF_TAG_ask_handle_of_tag(proto_solids[ii]);
5 u* p U& L4 X" I0 W, @8 \ - WRITE_S(handle);
+ s8 h+ p( B" F2 H' B# u - UF_free(handle);; z9 `) s0 P7 e5 A5 z0 L/ I
- build_unique_temp_name(exported_to, 0);
+ K% c4 E y- S - strcat(exported_to, ".x_t");) \3 E" m' c+ A% v* g! r2 p
A+ n/ [9 F1 ? - body_list = make_a_list(1, &proto_solids[ii]);: k1 A+ O' e- n, L' u
- UF_CALL(UF_PS_export_data(body_list, exported_to));1 R3 g: w, A) m. O. Y& ^
- UF_CALL(UF_MODL_delete_list(&body_list));
( b- m y3 P" \0 A' d -
' W8 \; S( v- D6 ?) ]( I9 q - WRITE_S(exported_to);0 n4 i/ W* J1 R* u5 p; i2 W
3 C8 |% D" J% H - if (n > 0) UF_free(proto_solids);
4 r' H) o0 M9 p/ K: } - }
- i& Y; m* S, y U - * A7 g0 l( j5 h5 U4 s, P
- /*ARGSUSED*/4 P6 O! Y' Q2 E& F& a
- void ufusr(char *param, int *reTCode, int paramLen)$ ~! r' q* d1 D0 S7 g
- {4 \" j# H; y) t0 m+ V5 I
- if (UF_CALL(UF_initialize())) return;/ T ~# E0 n6 j. j' T1 j0 k/ S' h
- do_it();$ C2 I: b3 }% t+ k( U( b
- UF_terminate();
f. A3 h6 e& k2 w - }
7 o; r8 x6 ]# ?8 Y s3 ]$ A - " O& f: {( \% J
- int ufusr_ask_unload(void)/ ~% J9 I4 X( s' @7 p( v1 p6 j+ S0 C
& I5 r+ V4 p( m1 J+ ` - return (UF_UNLOAD_IMMEDIATELY);$ ?, M c9 B0 A0 I& d6 I$ Y
复制代码 & [, p/ K4 m+ j& A% }1 E
, Y& {( u' t- V4 s' o; H
