[资料] NX二次开发源码分享: 打开一个指定的文件
2018-1-10 17:43:35 2593 0
发表于 2018-1-10 17:43:35 | 显示全部楼层 |阅读模式
3 N. U" Z7 x- U
( ^  R1 W8 F7 T1 r+ [& e4 f' k5 s6 Y% i" R4 z( J+ y9 h9 Z  s
0 J, ^3 N/ L3 x* w; D[mw_shl_code=c,true]static void report_load_status(UF_PART_load_status_p_t status)0 Y" D3 G' ?- |$ `- \# S/ f
9 T. p& p& ]- y6 [0 |    int
7 M# D0 G# P" Q; L        ii;8 ^: ]3 v0 `# A+ J
    char$ m; k8 j% \9 R% X
        msg[133];
0 k, ~2 c6 Q8 h; ^7 |
( [! C, t4 u' v) S    if (status->n_parts > 0)" G* D- O6 }; g/ a. C
* f/ X  l$ ?3 N& G& Y        ECHO("Load notes:\n");
" Z, L# Q" K" G* ~$ g* {        for (ii = 0; ii < status->n_parts; ii++)8 O+ R7 j# n7 s' Z
        {  t; D- o! C! J
            UF_get_fail_message(status->statuses[ii], msg);9 }; p5 t# I( T
            ECHO("  %s - %s\n", status->file_names[ii], msg);
- p4 Q; x  L6 Q% i        }
8 F. @3 J$ N$ J1 A7 n, U' x        ECHO("\n");
3 V; o3 e& K+ B+ V! N! i6 r+ X( r  i0 u+ W  T- M- x
        UF_CALL(UF_PART_free_load_status(status));
. X- D7 |4 g  k5 {    }
, |) o- q; U# a) t4 ^}, Y# E, W, A! K5 s# f1 H
8 c% S; S+ j- i* mstatic void do_it(void)
$ t$ y; ?, t* l: H% ?{1 b$ n4 o  Y/ w: P3 _% R
    int: \/ w2 E4 q; K( W. v- B
        resp;: _4 ^0 y: I$ Y
    logical
9 F0 j$ ^: R! n" |  Y' @+ V        disp = FALSE;- r' O* q1 O$ O- P0 ]6 j
    tag_t
% R, `& @$ R  ]# g: d" `$ N        part;
; w9 i* E4 t" ?) Z+ ?1 w' f1 e    char
7 r$ z( X7 Y  o1 @0 r9 {        file_name[MAX_FSPEC_SIZE + 1] = { "" };
+ l7 R- x, ?- L( l    UF_PART_load_status_t
+ ^% v2 \; m+ J        status;. N6 w, ^. w) G2 ~# I3 G
% E9 I& _( F" R; u. i9 \7 T# G' [    if (!(UF_CALL(UF_UI_ask_open_part_filename(file_name, &disp, &resp))) &&6 J2 F; ^* Y6 l$ v
         (resp == UF_UI_OK) &&
( O* f- E/ h# L+ X7 w+ {  B& O         (UF_CALL(UF_PART_open(file_name, &part, &status)))
8 [- {# i# P5 Z6 f/ P$ }+ G         || status.n_parts > 0)7 D) w( ~% I. f* _7 y  _: V# B
        report_load_status(&status);
6 ^+ e' \/ U# w# y  r7 R}[/mw_shl_code]7 A+ b9 C' F. q8 S& {- |% K3 T
