1 o2 q1 ?7 I& f; W
NX二次开发-关于body,feature,face,edge 之间的访问源码分享
/ u' K* }$ M/ ^) v( N ' z9 U0 |% f( {* \2 W
也有创建孔,创建阵列的测试哦!
% u; n$ P7 _( f5 L |
: ^ }1 p" s0 \0 N5 [
' i- a( k5 z7 e: c: d- <p>static void do_UGopenApi(void)9 d/ F1 m. u! w' j
+ f4 E. C8 ^* u/ |) P3 h$ o - //create a block
" S6 p f- Z% D$ q& n - double coner[3]={0,0,0};
; r3 G" I V# n - char *edge[3] = {"100","60","40"};5 i4 \' ~8 s8 u& ^ d8 }
- tag_t blk_tag;
$ B9 n8 z2 u( r3 O2 P6 Y* k6 ` - UF_MODL_create_block1(UF_NULLSIGN,coner,edge,&blk_tag);! T' F) t+ Y3 B$ I. T' r6 N" ^
- //create a blend start
: @1 A$ \, c6 g$ l7 Q* _ - char *radius = "20";
6 j/ h5 E; [1 v! @3 q4 D - uf_list_p_t blend_list,face_list,edge_list;8 i ~# Z8 n, m& ]) r* E
- tag_t body_tag,tem_face,tem_edge,faces[6],edges[12],blend_feature;
9 w: `5 j0 ~! o; K& A - int face_count,edge_count;0 J: p: E2 b) W: C$ {' o
- // get faces0 X1 ~$ ?$ I( D& g3 i
- UF_MODL_create_list(&face_list);( ]% P$ S0 H5 G! e" J
- UF_MODL_ask_feat_body(blk_tag,&body_tag);
) u2 s; S. l6 L& k2 B( l- K - UF_MODL_ask_body_faces(body_tag,&face_list);
9 H8 R8 P5 p; i1 C `% Y& ? - UF_MODL_ask_list_count(face_list,&face_count);
0 g8 T0 x! Q. m' l7 S# s$ ? - for(int i =0 ;i <face_count;i++)" Q( |* X; D' K" Q+ v& O* c
: t8 I* ^) q8 d4 E7 S - UF_MODL_ask_list_item(face_list,i,&tem_face);
$ ]; a- i% o( I; L" S! f) a2 Q - faces[i]=tem_face;
" n& _9 `$ E- H7 y; l$ R% x - }! p: M+ _9 z- f/ u' t
- UF_MODL_delete_list(&face_list);
/ ?1 ^5 u( ]: C6 z/ z7 a' g - //get edges' z, [& h4 H$ I7 x: \- q0 G g( h; p
- UF_MODL_create_list(&edge_list);
! [& p' V7 {8 \' n3 G; b; X; j5 T - UF_MODL_ask_body_edges(body_tag,&edge_list);, {; P, ^( P& M4 w* s+ f
- UF_MODL_ask_list_count(edge_list,&edge_count);
7 ]( ^0 |2 E# [; X2 d - for(int j = 0 ; j < edge_count;j++)
/ d2 J/ S& z+ d( e) C - {: W) O3 p2 z8 s4 E, R# x
- UF_MODL_ask_list_item(edge_list,j,&tem_edge);
+ G) m/ ?$ t2 G& n' z' h - edges[j]=tem_edge;" _' b: E2 D4 K3 L0 }/ _$ G$ i
- } [6 p \' i5 C7 F# m/ {
- UF_MODL_delete_list(&edge_list);
' P3 v$ W2 v0 K2 L; } - // create the blend$ Y7 W4 b2 d' C1 b# d0 R
- UF_MODL_create_list(&blend_list);
3 I n$ j4 z" G! k+ U - UF_MODL_put_list_item(blend_list,edges[6]);! n( n9 F: v! u9 `
- UF_MODL_create_blend(radius,blend_list,0,0,0,0.5,&blend_feature);$ v, f0 D0 u" t5 t
- UF_MODL_delete_list(&blend_list);</p><p> // create hole! M* K) U; C( z& |/ f/ r) I: Y
- double location[3]={80,40,40};
" N! c! Q x; E& i- s/ Z( g - double direction[3]={0,0,-1};- {9 }) k4 y: v
- const char * diame="15";
E7 |0 z9 h/ M/ e0 @ - const char * depth="5";
; V$ J0 X' r9 @5 d( \4 N( w; U2 _ - const char * angle="0";
$ M0 N: P: H' Y2 l* e' J( l - tag_t hole_id;
+ k9 B( @" {" v; e6 ~ w1 X - UF_MODL_create_simple_hole(location,direction,diame,depth,angle,faces[0],faces[1],&hole_id);</p><p> // create instance
$ F9 b1 b' [: {* u - double origin[3]={10,10,0};
0 S3 [5 g# ?( \ - double dir[3]={0,0,1};
; G- x. Y& q: b( z) z. N7 h - tag_t cyl_tag;; T& q! I# S/ t# R0 q
- UF_MODL_create_cyl1(UF_NEGATIVE,origin,"20","10",dir,&cyl_tag); ! R* k6 B/ u* m0 w, r
- char * number_in_x="2";
5 a0 I3 C" `% S1 U - char * distance_x ="30";/ q4 a! R+ X3 Y% ~. I+ r' _
- char * number_in_y="2";# s" J/ `& Q' b1 A f
- char * distance_y ="30";& {, A' ?2 V: ^% l! ?, e* U0 _
- tag_t feature_obj_id;
' A) X% b& M0 c% S2 x) K( h - uf_list_p_t feature_list;, K& G8 W, E" ]1 f% U. x
- UF_MODL_create_list(&feature_list);
- U+ e$ x! y8 t; I* p3 y; @ - UF_MODL_put_list_item(feature_list,cyl_tag); e- S5 j8 s% V' G
- UF_MODL_create_linear_iset(0,number_in_x,distance_x,number_in_y,distance_y,feature_list,&feature_obj_id);& V! F. O, U; K& E. J# R
- UF_MODL_delete_list(&feature_list);( @0 }/ c4 n4 d9 \
- }</p>
复制代码 |
