[资料] 第四代设计(4GD)管理系统的优势
2013-12-5 15:54:18 4637 0
发表于 2013-12-5 15:54:18 | 显示全部楼层 |阅读模式
4GD has several advantages over previous generations of data management systems:
) c" `/ ~5 L" s( l• Flexible organization of design data. R+ w6 n# B0 M* h9 T  C. p5 Z
The collaborative design content can change dynamically as the design evolves.1 z: |! ]7 ^3 Z: N  H/ d+ P
Designers are not limited to viewing the product in predefined subassemblies.
5 ?0 a* Z! x6 p3 p( ]$ A• Independent lifecycles! {4 ^' {7 w" {( r
Each design element has its own lifecycle. You are not limited by the lifecycle
5 Z8 b$ K9 s6 e7 sof traditional assemblies. Each design element has its revision and status.9 ^9 T! p3 Z& i* ]6 ?! m: R0 y
Likewise, the CAD design owns its position and geometry.
% [4 @* {( H* L- e6 B• Multiple hierarchical views
4 g7 D  ^2 K: W9 O: _In a traditional product structure, each component is placed in an assembly. To
  S8 y7 j0 G( M* tview a component, you must load its parent assembly. Using 4GD, a design1 U, ~& |3 F3 P- ~5 V0 N1 `
element can appear in multiple partitions and subsets of the product. When7 U/ ~& r! P) q/ h' t
a designer views partitions that may contain the same design element, 4GD
, W7 T' z0 E/ I3 |- A1 ~displays only the unique design elements.
7 j+ R0 S4 f" _9 @' z5 q• Very large data sets
  V2 j) y( f3 K/ [4 R, W; d0 bBecause there is no concept of a structure, very large data sets can be managed
& s  ~! a# w1 Y1 u% K% M$ Wefficiently . Teamcenter loads collaborative designs much more quickly than! a7 b+ _* n$ ^' B+ k6 ]! O
traditional assemblies.- l0 X; {/ ]. C! \8 }. k
• Minimal data locking8 m* d# r- I- ?) J9 S5 {
Designers check out only the design elements they need. To reposition a design6 x) i  ~. n; L' K% i8 m$ Z4 O: R
element, there is no parent assembly to check out and lock.! Q9 d- j  y, H' U' r. Z# S; J
• Efficient working sets
: K" W! b6 \5 J  k5 DDesigners can work with adjacent design elements, without having to check out& ]+ c  S6 A) J, g" n5 {
the next highest parent assembly that contains all the design elements.5 y/ x9 L8 U7 S' I1 t
• Concurrent work capabilities
+ K+ S+ r$ ^' V0 oBecause designers access the design elements in their workset using a dynamic
9 F9 S+ ~' s7 b  u! X5 K" krecipe instead of a rigid subassembly, the context of the workset can be updated1 x: A3 d( Q1 }" g
to include new design elements created by other designers. For example, if the' @! m0 |% H  _$ _+ ~
recipe searches for all design elements within a spatial volume, reapplying the( `( F, {* a- W' |& e, h; J
recipe opens any new design elements within that volume.
