[二次开发源码] NX二次开发源码:查找当前工作部件所有的圆柱表面代码
2015-7-26 08:31:27 3712 1
发表于 2013-12-20 15:09:07 | 显示全部楼层 |阅读模式
3 Z4 X! t3 a7 c, n/ s8 O; c, O4 f; k0 F2 f" p# E, f
  1. static void do_UGopen_api()
    ) W# D: ]1 |& c
  2. {  d6 ]1 @4 ?7 M4 C
  3. Session *theSession = Session::GetSession();
    # P/ F; G9 B! }4 N
  4. Part *workPart = theSession->Parts()->Work();$ i' ^7 w& U' v# Q' G/ T: l
  5. BodyCollection *bc = workPart->Bodies();' B4 H' [2 m) c8 q7 N. A- H
  6. ListingWindow *lw = theSession->ListingWindow();
      V$ }; l& f5 C' B6 l
  7. int count = 0 ;; }) Y" _5 K7 E  ?
  8. // get the body then to get the faces& \. N/ H! Z! T- U/ Q6 a7 b
  9. for(BodyCollection::iterator it = bc->begin();it!=bc->end();it++)1 ^+ R: d4 U; Y' I5 Z  G" A3 a: ?# Z
  10. {
    ; N/ J9 t" ^( W8 p
  11.    Body *body = (*it);
    7 k  {( j# Y8 P
  12.    // get faces7 C% x, b! H6 k8 K2 o* a3 F: r5 A' P
  13.    std::vector<Face*> faces = body->GetFaces();% p6 D9 ]9 U0 B8 w
  14.    for(int j =0 ; j <faces.size();j++)
    " t9 p. e( K1 O* V3 W) A
  15.    {
    $ x5 t1 h( X) [2 f5 B* D
  16.      Face *face = faces[j];
    4 c: [7 s7 M4 x& P  M* j) }
  17.   if ( face->SolidFaceType()==Face::FaceTypeCylindrical)
    4 l  S* [9 g" Y& ~: }" k2 C
  18.   {0 V$ Y7 G) {& Q! {& V
  19.    face->Highlight();$ M" A/ F3 a* B; z/ y& S
  20.    count++;
    . V* O$ U& e4 Z$ z; M
  21.   }
    $ [) G. i+ i; s( N$ F
  22.    }
    5 k& p  g! f0 d
  23. }7 s! \" V* i# D/ n; \) O
  24.   lw->Open();) D! t% Y$ H; R1 X- Q9 j5 M# K- v
  25.   char msg[133];
    2 z; ^; D/ l6 Z
  26.   sprintf(msg,"The Cylinder faces count is :%d\n",count);
    # Y/ }. C+ d. g2 e; W# V! d
  27.   lw->WriteLine(msg);% }$ H+ Q( g# Y, ?9 A# w$ M
  28.   ; R- k, _2 p. _! [* H; W* d& U
  29. }# P0 t" j; G' }1 v; L
  30. <p> </p>
3 i/ i4 a2 A9 T1 b+ r* p
发表于 2015-7-26 08:31:27 | 显示全部楼层
牛啊,就是复制乱码
