[二次开发源码] NX二次开发源码分享: 如何获取系统相关信息
2014-1-24 22:56:47 3564 1
发表于 2014-1-23 09:28:55 | 显示全部楼层 |阅读模式
使用ufun的 UF_ask_system_info,通过结构体可以获取诸多信息,以下代码的输出结果如下:
$ o" Z; Y; d6 F$ J6 }0 p3 D. Z6 f' a
Date : 2014/01/22 17:28:04
8 P) b! {" \6 ?8 L$ |: A. vmachine_type : GenuineIntel Family 6 Model 10 Stepping 9, Intel(R) Core(TM) i7-3667U CPU @ 2.00GHz5 h3 `- x% F* R& s5 ^( H
node_name : Teamcenter10' p2 E' S7 }: u) B4 f  K1 A
os_name : Windows NT (x64)
. B, A- g5 T0 x  nos_version : 6.1 (Server) (Build 7601: Service Pack 1)  Terminal( L. O1 n& X+ u3 ~' o
program_name : NX 9.0.0.19' _/ A  N, e* I+ n1 d4 w
user_name : Administrator
2 Q. ~6 n" H$ w: y
! O' Q6 n" ^, U$ ?$ [; V
  1. static void do_api()
    . q9 K: A0 [3 N4 Q
  2. {; [) {0 D7 h' V
  3. ! x) a3 s& R6 {6 p; q8 _
  4. UF_system_info_t sysinfo;9 j( R" s5 T* {+ O4 x
  5. UF_ask_system_info(&sysinfo);
    * X8 J: e! s  m5 G+ j
  6. vector<string> info;
    # R4 P' y. L* F
  7. char msg[256+1] = " ";
    1 g; [3 z0 _8 X% |* r% U
  8. sprintf(msg,"Date : %s\n",sysinfo.date_buf);8 a2 S( p* h5 ?5 K9 ]
  9. info.push_back(msg);8 Z/ Y+ u8 ^$ S# A+ s$ Z
  10. sprintf(msg,"machine_type : %s\n",sysinfo.machine_type);
    + Z; l8 J- r9 g
  11. info.push_back(msg);
    9 p! j* O- X, Q: v
  12. sprintf(msg,"node_name : %s\n",sysinfo.node_name);3 W' v) \, F, A' G
  13. info.push_back(msg);
    " ?" A' {# [3 v# A& ^
  14. sprintf(msg,"os_name : %s\n",sysinfo.os_name);
    & H" L4 Y5 n/ W  m$ t/ P
  15. info.push_back(msg);
    . M0 {4 W) P6 e
  16. sprintf(msg,"os_version : %s\n",sysinfo.os_version);
    7 S* d! |4 H, X/ f/ P# n9 t8 N
  17. info.push_back(msg);6 ]: b2 u8 y; O1 G6 ^
  18. sprintf(msg,"program_name : %s\n",sysinfo.program_name);
    $ f% C8 m# R7 L5 t4 X* ~: |
  19. info.push_back(msg);$ n8 [. Z, p. V) e
  20. sprintf(msg,"user_name : %s\n",sysinfo.user_name);$ \( f* h8 ~8 v" O% p! B) ?6 p
  21. info.push_back(msg);) s# N7 Q5 ]+ h, ~0 B
  22. UF_free_system_info(&sysinfo);7 A0 u5 U: i: E7 z. n$ p
  23. // write the information to listing window) d. }3 k" f) u0 c/ A1 ]
  24. UF_UI_exit_listing_window();
    " ]: P5 p& E+ ^' g, ~5 m
  25.     UF_UI_open_listing_window();
    + i7 M: l* \) w1 S' z# U4 U
  26.     int size = info.size();! J; w# R6 D* {! Z  \$ |( c
  27.     for (int i=0; i<size; i++)! ]  H( _; Z! C
  28.     {0 `1 B# a. [" a; f
  29.         UF_UI_write_listing_window(info[i].c_str());# A+ w. O, c! m( T( i0 Q* W
  30.     }
    2 H$ @( k! J8 T( _# {+ {
  31. }& d& [' C/ O, g5 Z8 P4 B. p
  32. <p> </p>
5 g: W9 g' f7 t3 j5 b; O: c/ E) G3 R
发表于 2014-1-24 22:56:47 | 显示全部楼层
额,这个可以有
