[二次开发源码] UG NX二次开发源码分享:VB创建自定义加工车间文档
2014-11-7 15:59:06 6031 0
发表于 2014-11-7 15:59:06 | 显示全部楼层 |阅读模式
' \. `, p1 W) d. R6 m" C7 t1 W
+ o  |* i( k2 b+ h
4 M0 w1 B) t% H. w" n4 J
  1. Option Strict Off
    & n+ Z- n: m& h3 _5 v
  2. Imports System' p% J# j  D$ H( L1 @0 J
  3. Imports System.IO
    + i" s. n$ h. f% F* G0 L
  4. Imports NXOpen
    / y. r$ x' [' s8 q/ F
  5. Imports NXOpen.CAM
    : N: u5 a  V6 c/ ^6 b/ o' S1 k, U: i0 b
  6. Imports NXOpen.UF
    5 E1 j6 y; t5 f& W: ?
  7. Imports NXOpen.Utilities
    ! W% u+ S! [4 C/ H
  8. Imports System.Drawing5 W; u# `7 W0 d% U; m% N5 D
  9. Imports System.Windows.Forms$ b+ {7 m1 @# w+ B4 G
  10. / M3 N5 R0 S* ]3 o3 E  m
  11. Module Module1
    % X- c( e! p) y* R! ]
  12.     Dim theSession As Session = Session.GetSession()
    ( |+ M' c( L  v6 c! x
  13.     Dim myUI As UI = UI.GetUI()
    6 l/ \! R+ D; S7 q
  14.     Dim theUFSession As UFSession = UFSession.GetUFSession()0 l# i" x, S1 t0 q; K
  15.     Dim theWorkPart As Part = theSession.Parts.Work
    / H% I1 \$ u" W
  16. ) T$ T5 V$ ?/ u# y0 k# }# L
  17.     Dim mytag() As NXOpen.Tag '选择的加工操作标记数组2 T) J) }8 S4 H$ ?5 ~9 m% @8 d
  18.     Dim mcount As Integer '选择的加工操作数量
    " g! Q# x; t9 i. c" m1 l
  19. & O0 G% D  ]3 g5 U. {( G6 c7 b
  20.     Sub Main()     0 U$ A/ O2 m. D8 F, A
  21. ) I/ A  i7 _  ^& k6 J
  22.         Shell(Environment.GetEnvironmentVariable("UGII_USER_DIR") + "\UDO\Post\SnapPic.exe", AppWinStyle.NormalFocus, True)1 E0 A9 B! Y& m: _/ s
  23. ( P( {0 d* j; d
  24.         Try: u5 O/ Q- [* `( D
  25.             '获取选择的操作数
    8 F7 [' L8 {% r3 d+ T) R
  26.             theUFSession.UiOnt.AskSelectedNodes(mcount, mytag)
    7 N0 Z4 O$ |% X! q8 `
  27.             If mcount = 0 Then
    : `: C/ B+ o  q- r5 R
  28.                 MsgBox("没有选择加工操作!", MsgBoxStyle.OkOnly, "提示信息")% O- w0 a  Z3 K2 ^
  29.                 Exit Sub
    % C) c$ N. e5 \) e/ d; x: j
  30.             End If) i: S: s" Y! T( _; S- e+ t
  31. ' `9 [! o- Q8 `4 t+ S+ v! p! [& N
  32.             '设置车间文档EXCEL模板路径; N, z2 `  q. k, T( Y" o* e: b
  33.             Dim fp As String = Environment.GetEnvironmentVariable("UGII_USER_DIR") + "\UDO\Post\WorkShop.xls"
    0 }9 I) u" Y( @
  34.             '打开与写出车间文档
    , }) }3 P$ q: v+ o  u- _7 a
  35.             If String.IsNullOrEmpty(fp) = False Then; z: e8 G& P9 @
  36.                 Dim myExcel As New MY_EXCEL
    9 h% `( x. @. Q9 Z& @
  37.                 myExcel.Create()
    # u5 O* |' ^9 y/ w
  38.                 myExcel.Open(fp)
    ' z. u" v' p2 N2 O. D- M
  39.                 myExcel.Write("M4", AskDisplatyPartName())$ @% o( ~# k) E. E$ k" d! @
  40.                 myExcel.Write("S4", Format(Now, "yyyy/MM/dd"))3 `! ~% v: o( c* t& P" g
  41.                 myExcel.InsertPicture("b4", Environment.GetEnvironmentVariable("UGII_USER_DIR") + "\UDO\Post\jietu.jpg")7 p2 }7 f& v" `" Z& B8 Y. l
  42.                 For i = 0 To mcount - 1) y* l) I& A" m, t8 m
  43.                     '输出结果1 }9 q) \3 Q+ ]
  44.                     myExcel.Write("B" + (i + 17).ToString, (i + 1).ToString)
    - Q6 g( P8 w: m6 c
  45.                     myExcel.Write("D" + (i + 17).ToString, GetGemoGroup_Name(mytag(i)))+ b6 d1 C0 s% P+ J0 T) X
  46.                     myExcel.Write("E" + (i + 17).ToString, GetToolPathName(mytag(i)))4 I5 s% o& O# |, c8 `# t2 D
  47.                     myExcel.Write("F" + (i + 17).ToString, GetToolName(mytag(i)))
    2 `9 J2 U2 Z: |* Q) s7 e
  48.                     myExcel.Write("G" + (i + 17).ToString, GetToolNumber(mytag(i)).ToString)
    / v! _9 q5 u- B7 Z7 W. R. H& d
  49.                     myExcel.Write("H" + (i + 17).ToString, GetToolDiameter(mytag(i)).ToString)4 J, N  ^/ y6 n& G2 b0 ]
  50.                     myExcel.Write("I" + (i + 17).ToString, GetToolCornerRadius(mytag(i)).ToString)
    + c, n- G, g+ @8 ^! O
  51.                     myExcel.Write("J" + (i + 17).ToString, GetToolHeight(mytag(i)).ToString)) O* [, Q$ b* |" {) u- h$ N
  52.                     myExcel.Write("K" + (i + 17).ToString, GetToolFluteLength(mytag(i)).ToString)0 k2 f4 ^  ?* B  ^
  53.                     myExcel.Write("L" + (i + 17).ToString, GetStockPart(mytag(i)).ToString)3 E% C- h5 D$ V! o- z! y$ d4 q
  54.                     myExcel.Write("M" + (i + 17).ToString, GetStockFloor(mytag(i)).ToString)
    3 H  R7 D+ U* H3 j* w5 e1 Y, A
  55.                     myExcel.Write("N" + (i + 17).ToString, GetSpeedValue(mytag(i)).ToString)6 s+ x9 X( c* M# P0 _$ B; t+ W6 ^# V
  56.                     myExcel.Write("O" + (i + 17).ToString, GetFeedValue(mytag(i)).ToString)
    : F# d, P) m* d7 b  n4 t; v
  57.                     myExcel.Write("Q" + (i + 17).ToString, CInt(GeTCutTime(mytag(i))).ToString)
    : ?7 L3 z8 p4 L  T
  58. & Z. u8 |% z- A# F2 D3 N* c! ]$ v
  59.                 Next$ F7 E% ?- I8 I# i
  60.                 myExcel.SaveAs()
    * B0 `/ L( z. m7 r, Z% f
  61.                 'myExcel.Quit()( L1 d  k5 C2 c+ X
  62.             End If# e+ n4 _/ }0 H. B1 L/ c
  63.             '出错处理:& Z5 C  f% Z2 {4 s' _. |* F
  64.         Catch ex As Exception
    2 o0 O+ Q+ w, Z+ K" \" Y
  65.             MsgBox(ex)- F/ o& l7 \7 `* J0 }% H) B8 J$ C( r
  66.         End Try* w# c: ^% `6 z* t! q& O/ j
  67. " u2 k$ x1 x' z& ]
  68.     End Sub& t5 t8 }" I7 }: M0 @
  69.     '当前文档文件名' U; K  I3 Y% z7 v$ \' z$ w
  70.     Function AskDisplatyPartName() As String( C$ {0 B8 j& n. i8 e5 j
  71.         Dim UFS As UFSession = UFSession.GetUFSession(); G) s& [, [6 h; e
  72.         Dim part_name As String = ""7 f8 a+ O! [! D5 h! S
  73.         Dim part_tag As NXOpen.Tag = UFS.Part.AskDisplayPart
    2 q  F3 G' q& v7 [# ^
  74.         UFS.Part.AskPartName(part_tag, part_name)+ R6 a( i3 L6 }; Q# e: U& |
  75.         Dim aa() As String2 m6 }' t  P* _& a* ^, \
  76.         Dim bb() As String
    $ m7 i- w7 I( o
  77.         aa = Split(part_name, ".prt")
    / Z- |7 b: a" O/ d0 A+ _
  78.         part_name = aa(0)( t! }$ [5 R3 F
  79.         bb = Split(part_name, "")
    ! [6 f/ L" r2 n. |% Z) D
  80.         part_name = bb(bb.Length - 1)
    & s/ z! x: T( u0 {, _6 m
  81.         Return part_name/ U7 t. R: i; r
  82.     End Function  Z) E3 `' h& C4 P
  83.     '取加工几何试图程序组
      u2 G  J9 U7 Z* Z2 m
  84.     Function GetGemoGroup_Name(ByVal camObjectTag As NXOpen.Tag) As String6 P( Q0 t/ R" N! J4 H
  85.         Dim theGemoGroup_Tag As NXOpen.Tag" [) l$ _  `8 L" g- J6 R
  86.         Dim GemoGroupName As String = ""  I5 _. f( O5 V# i# H  q# Y/ X
  87.         theUFSession.Oper.AskGeomGroup(camObjectTag, theGemoGroup_Tag)/ t2 ~1 {( u2 z9 o* Q
  88.         theUFSession.Obj.AskName(theGemoGroup_Tag, GemoGroupName)
    6 H: Q  V2 J% e
  89.         Return GemoGroupName
    ' [7 A* U) g- [1 B8 W' P. a! N
  90.     End Function6 N' l( V8 Z8 t/ m+ X
  91. 3 W, r; H. Y, P! {) d6 ?0 ?
  92.     '取操作名称  C. F( C: h) z; {1 c
  93.     Function GetToolPathName(ByVal camObjectTag As NXOpen.Tag) As String$ E; K) S* S9 r! X9 J) b, d
  94.         Dim ToolPathName As String = ""
    & [, e/ c1 ~1 u; @7 \/ n& O% w8 V1 S# n
  95.         theUFSession.Oper.AskNameFromTag(camObjectTag, ToolPathName)
    9 E* ~7 u! c; \6 a( r5 t
  96.         Return ToolPathName
    + c/ Z  k$ d9 m2 Q  t4 [+ d1 w
  97.     End Function
    2 E: C5 i* M9 ~4 ^5 N9 _' f' g
  98.     '获取刀具名称! s6 P. D! L+ [9 Q- D
  99.     Function GetToolName(ByVal camObjectTag As NXOpen.Tag) As String9 F: M8 ^4 N& u( H
  100.         Dim ToolName As String = ""
    . @: ~5 I8 n: m0 j2 x
  101.         Dim ToolTag As NXOpen.Tag
    " r3 }; l. g- Q/ D5 H
  102.         theUFSession.Oper.AskCutterGroup(camObjectTag, ToolTag)" W: |2 q& _7 H/ j& z9 O
  103.         theUFSession.Obj.AskName(ToolTag, ToolName)6 I5 t4 U- W% ^( b
  104.         Return ToolName) l! i7 H& C( V( `6 p
  105.     End Function
    * S: W: ]+ M4 B# t/ n& ~& f0 Z: E- |
  106.     '获取刀具号码0 O7 [# Z! F6 {# q# F% j2 O( a$ B1 X& `
  107.     Function GetToolNumber(ByVal camObjectTag As NXOpen.Tag) As Integer
    ; Z) [, E" J" e# y8 L# }/ r3 Q8 G
  108.         Dim ToolTag As NXOpen.Tag% g4 N4 H& A! Q, X
  109.         Dim ToolNumber As Integer+ e" o+ R7 i1 o, M* I
  110.         theUFSession.Oper.AskCutterGroup(camObjectTag, ToolTag), h; y& Q! ^; @8 m6 Q. F/ J" A
  111.         theUFSession.Param.AskIntValue(ToolTag, UFConstants.UF_PARAM_TL_NUMBER, ToolNumber)7 ]8 h) F- V) [( G. M8 [
  112.         Return ToolNumber
    * Y! l7 H, y8 R! s5 |7 g
  113.     End Function* _8 }$ G& v& S6 v6 a7 u% a. }
  114.     '获取刀具长度
    1 k) x) c: S, c9 y
  115.     Function GetToolHeight(ByVal camObjectTag As NXOpen.Tag) As Double
    2 Q( _5 u4 z6 t: p
  116.         Dim ToolTag As NXOpen.Tag  i3 i; O/ [5 h( W
  117.         Dim ToolHeight As Double6 m7 p* ]: F# C3 \5 t  f8 C8 W' ^
  118.         theUFSession.Oper.AskCutterGroup(camObjectTag, ToolTag)
      y! n) [) Y+ W3 r0 b( R
  119.         theUFSession.Param.AskDoubleValue(ToolTag, UFConstants.UF_PARAM_TL_HEIGHT, ToolHeight)
    & V0 ?+ Y, x, @9 y3 w6 ^3 ?- b' G) v
  120.         Return ToolHeight/ x. P- C$ B# L3 L2 g5 n
  121.     End Function7 @7 M7 X9 M6 [) ~3 c* i
  122.     '获取刀具直径
    * L% U0 a5 P4 t. m
  123.     Function GetToolDiameter(ByVal camObjectTag As NXOpen.Tag) As Double! V; L0 C9 x7 M. i* K
  124.         Dim ToolTag As NXOpen.Tag8 S0 u; u- X% [  i
  125.         Dim ToolDiameter As Double8 Y7 _0 A7 k! g8 e
  126.         theUFSession.Oper.AskCutterGroup(camObjectTag, ToolTag)
    5 @# q, K! q2 Y5 y% P
  127.         theUFSession.Param.AskDoubleValue(ToolTag, UFConstants.UF_PARAM_TL_DIAMETER, ToolDiameter)7 _8 I' N1 O" J, O' ]; T& |
  128.         Return ToolDiameter
    + j" y" U* M  l; y: u0 y4 s
  129.     End Function
    # }3 ?8 |: _; U) ?
  130.     '获取刀具刃长
    / Y2 V7 _0 n; C' t' m9 [0 K; N
  131.     Function GetToolFluteLength(ByVal camObjectTag As NXOpen.Tag) As Double% F; _( U1 r, T& Q* q
  132.         Dim ToolTag As NXOpen.Tag
    * D9 w5 n. u+ o3 h
  133.         Dim ToolFluteLength As Double+ N$ t& {/ E7 X- Y! m/ o. O
  134.         theUFSession.Oper.AskCutterGroup(camObjectTag, ToolTag)
    % Z/ T) t6 X$ S. m7 n  z
  135.         theUFSession.Param.AskDoubleValue(ToolTag, UFConstants.UF_PARAM_TL_FLUTE_LN, ToolFluteLength)6 |1 h1 ]8 l- F1 ~  v: G
  136.         Return ToolFluteLength( Q5 r% z8 Y+ R6 M3 F
  137.     End Function
    2 V: Z5 s5 b+ v5 ?
  138.     '获取刀具R角9 y8 q# z6 `. j5 E- L$ V7 {; h
  139.     Function GetToolCornerRadius(ByVal camObjectTag As NXOpen.Tag) As Double. |3 s0 J" o* [
  140.         Dim ToolTag As NXOpen.Tag
    ( W" M2 L% S+ m/ C$ O) Q, U3 v  Q
  141.         Dim ToolCornerRadius As Double
    : B$ ^5 |+ L9 L) v! i, b" ^
  142.         theUFSession.Oper.AskCutterGroup(camObjectTag, ToolTag)
    " }9 I) B) B* {
  143.         theUFSession.Param.AskDoubleValue(ToolTag, UFConstants.UF_PARAM_TL_COR1_RAD, ToolCornerRadius)
    , Y3 @9 K% @$ K3 X% @4 s4 o$ j
  144.         Return ToolCornerRadius
    # Q" k6 e$ z7 g8 X. g8 J4 ]
  145.     End Function
    ) i  e! {  b; n5 f
  146.     '取部件侧部余量
    8 Q- g' L; Y8 v7 O! u
  147.     Function GetStockPart(ByVal camObjectTag As NXOpen.Tag) As Double
    0 C; @" P( @3 }+ [. I, q: |/ i
  148.         Dim StockPart As Double$ {6 F% u+ u% ?* v: o& g( y' o' @
  149.         theUFSession.Param.AskDoubleValue(camObjectTag, UFConstants.UF_PARAM_STOCK_PART, StockPart)
    6 Y" Z# Y% ^: w" y
  150.         Return StockPart7 H$ e# e9 i: r" D+ S0 ~
  151.     End Function# k! A7 s5 n' c; j. V# p
  152.     '取部件底部余量
    ( F1 e8 X  K- y) Y& a/ }
  153.     Function GetStockFloor(ByVal camObjectTag As NXOpen.Tag) As Double4 ?: c2 d! y5 V  j% P7 H
  154.         Dim Stockfloor As Double; H( Q( ~, a/ V/ j& P: e- n
  155.         theUFSession.Param.AskDoubleValue(camObjectTag, UFConstants.UF_PARAM_STOCK_FLOOR, Stockfloor)8 z! q9 m1 L1 ^- H" \
  156.         Return Stockfloor  m1 I: T' k6 F! G
  157.     End Function
    % W: L) n3 E8 i/ t  |5 h: n6 ]
  158. 7 n3 F, B( h+ _: T. X
  159.     '取主轴转速
    , Q5 v: R0 S% P6 I# P8 [
  160.     Function GetSpeedValue(ByVal camObjectTag As NXOpen.Tag) As Double
    1 ^& _6 P" }7 v! I5 t) t8 W
  161.         Dim SpeedVale As Double
    3 x. m: ~2 a+ i/ z) J  ^
  162.         theUFSession.Param.AskDoubleValue(camObjectTag, UFConstants.UF_PARAM_SPINDLE_RPM, SpeedVale)
    % \! l( d( ~* e6 h# U' I0 {
  163.         Return SpeedVale
    , b) u2 v: C4 i
  164.     End Function
    / E4 F* a8 `: o4 ]0 ^5 q
  165.     '取进给速度
    2 K5 Q( u; {! g
  166.     Function GetFeedValue(ByVal camObjectTag As NXOpen.Tag) As Double
    * U0 I7 y+ ?& @6 b, ?
  167.         Dim FeedValue As Double$ K( c3 j! N( F' w  \4 Q
  168.         Dim _camObject As NXObject = NXObjectManager.Get(camObjectTag)) |' l: B3 J# e& |& Z( L# ?
  169.         Dim params(0) As CAM.Operation
    3 `% S( S8 V# ^0 M1 {
  170.         params(0) = CType(_camObject, Operation)' s- b7 c9 e! T+ }
  171.         Dim FeedsBuilder1 As ObjectsFeedsBuilder = theSession.Parts.Work.CAMSetup.CreateFeedsBuilder(params)
    - F7 O/ B$ T6 H% I0 g; z8 R2 @. ^
  172.         FeedValue = FeedsBuilder1.FeedsBuilder.FeedCutBuilder.Value* Q$ ]/ j$ w5 F2 x: p9 m
  173.         FeedsBuilder1.Destroy()( E0 H9 {+ A6 Q, Q$ \, F1 B& `' {
  174.         Return FeedValue
    1 M" a$ W4 `) ^2 M' ~- Y0 d
  175.     End Function
    & w6 E$ z3 r- h' M' y
  176.     '取切削时间
    , Z; @& N5 g! z$ C
  177.     Function GetCutTime(ByVal camObjectTag As NXOpen.Tag) As Double9 c: f0 \6 N# {) c8 Z
  178.         Dim CutTime As Double
    " B2 I% e0 R3 F( D: W
  179.         theUFSession.Param.AskDoubleValue(camObjectTag, 142, CutTime)
    ! X) b7 |4 D, P' O0 }# [( Z
  180.         Return CutTime
    # R! S+ ^3 m+ F
  181.     End Function# E% {& P1 c! ]6 D( N
  182. 2 j3 P1 E+ ^6 o
  183.     Public Function GetUnloadOption(ByVal dummy As String) As Integer
    0 s% U, D& N1 W: _
  184. 6 I" O8 ^+ |$ B
  185.         'Unloads the image immediately after execution within NX
    ! W# r0 W( Y* h) Z1 j+ \
  186.         GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    : Q1 Y0 z: j/ u0 p" m& H
  187. ' \, H. z  P# v8 l2 p9 t  o, ~
  188.         '----Other unload options-------
    8 g$ v- S0 S7 n, E/ M
  189.         'Unloads the image when the NX session terminates
    7 k! h- O4 u% p" w( H
  190.         'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination0 i0 S8 g! F2 T
  191. ; r1 r$ w# g  {# g: f% T
  192.         'Unloads the image explicitly, via an unload dialog
    ) K+ O6 ]& u: z2 Z
  193.         'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
    ( j- ?& m0 N5 y$ i6 Y; y# j
  194.         '-------------------------------* R( ~- L9 ]' |0 a1 n* [0 ?3 ~
  195. : F7 \- L( W& r1 @" H
  196.     End Function
    9 r4 L% p! r! Y7 P$ k4 H
  197. ( V! r! x# b1 T  ]) k; S
  198. . {% C/ j6 E/ a
  199. End Module2 j5 k& e- [9 {7 Y+ U9 }. W
  200. 4 P! R* C- v4 \7 K  H5 M& V
  201. Public Class MY_EXCEL
    + j0 _) u, l9 w) L1 F
  202.     Private app As Object
    5 E$ Z" j4 G1 r
  203.     Private book As Object& s( o" M" }  {! R0 X
  204.     Private sheet As Object. f" |9 J( R3 x6 i! \( e+ B7 Y
  205.     '表格名称- S1 Y2 U2 A. O3 t0 d
  206.     Public Property xlSheetName() As String& v/ `1 @  S; m4 x# u% m9 I) {
  207.         Get- y! Y, U3 }4 X3 n% w1 u5 v" X
  208.             Return sheet.Name* F6 L6 o& J# D. c9 p
  209.         End Get
    ' h9 s. E' O0 W# e8 o; [! P
  210.         Set(ByVal value As String)9 d( C2 v' j5 w) N( u9 O8 a
  211.             sheet.Name = value- e6 c: p# u; m3 c" E. g3 h9 ]) t
  212.         End Set6 E4 \- K" e/ f: G' G. f
  213.     End Property% ]/ c% g  ^6 v$ C$ Z0 H6 c
  214.     '新建程序
    ; l5 |! x1 k; O4 N3 o* i
  215.     Public Function Create() As Boolean( x$ E( C& Z- G2 U
  216.         app = CreateObject("Excel.Application")% s6 B& a; Y3 L2 X4 t9 u9 D
  217.         If app Is Nothing Then* h2 P# r9 ?; {1 f( ~4 X. _
  218.             Return False
    3 w3 l/ {5 Q- y5 y$ ^, B% B
  219.         Else' U8 |0 V" y" t5 V- j' `: H- k
  220.             app.Visible = True
    ' a5 b) Y7 i0 x( |# l4 P' S4 K
  221.             Return True" I2 g" {( h7 I& ]0 t+ H
  222.         End If  D2 z" R( }9 Z
  223.     End Function
    + \- W8 r. ]  X& ?. I% V
  224.     '打开文件
    - S, V# m6 U! |2 L
  225.     Public Sub Open(ByVal xlFileName As String), f4 B; `% N1 V/ R
  226.         book = app.Workbooks.Open(xlFileName)
    2 i* e- J  \3 t6 S
  227.         sheet = book.ActiveSheet
    " c. @* w5 h# Y5 {6 `4 m
  228.     End Sub$ Q! M8 R- ^+ I8 R/ ~, m+ M4 T
  229.     '写单元格. o7 y) L3 V5 ~, A
  230.     Public Sub Write(ByVal _Range As String, ByVal value As Object)- a4 `, q  @! z& y1 X* ?
  231.         If _Range <> "" Then% M8 `( ~1 I+ e! T! I2 f! m$ j$ D& r9 j
  232.             sheet.Range(_Range).Value = value
    7 a+ D* F" Y  z$ |) R
  233.         End If5 O* K% S; @) \; H2 c8 ]
  234.     End Sub
    - e5 e  J8 S- _- V. _1 f
  235.     '插入图片
    3 q; _. G3 _$ l; w9 q
  236.     Public Sub InsertPicture(ByVal _Range As String, ByVal imageFile As String)+ H! e% |. H+ `) [" E: H# X5 k
  237.         If _Range <> "" Then
      e' ^; B7 F3 u  J
  238.             Dim ExcelRange As Object = sheet.Range(_Range)) |4 m5 }" V9 Z% E2 g! ^
  239.             Dim Ins_image As Image* e: P: n- p' M, M" i
  240.             Ins_image = Image.FromFile(imageFile)- ~; C: e) s) _# g% n% m4 F4 C: c9 G
  241.             Dim HeightScale As Double = Math.Round((ExcelRange.Height * 12 - 6) / Ins_image.Height, 2)1 c7 X  o9 I  h8 b/ V
  242.             Dim WidthScale As Double = Math.Round((ExcelRange.Width * 15 - 6) / Ins_image.Width, 2)8 z0 j9 I+ o  ?8 j
  243.             Dim ScaleHW As Double = Math.Min(HeightScale, WidthScale)6 I  K! L: V2 V7 K3 `, L% d
  244.             sheet.Shapes.AddPicture(imageFile, 0, 1, ExcelRange.Left + 2, ExcelRange.Top + 2, Ins_image.Width * ScaleHW, Ins_image.Height * ScaleHW)
    # O, r' l0 [+ l# [8 }5 R
  245.             Ins_image.Dispose()
    8 f( g3 u  y: o1 f7 X$ Q
  246.         End If
    & m+ S6 F7 ]5 T8 i7 Z
  247.     End Sub
    ) U8 g4 i7 {6 y5 ^) m
  248.     '取指定单元格值/ O8 y: Y7 x7 Z- T2 R. Y& x
  249.     Public Function GetValue(ByVal _table As Integer, ByVal _Range As String) As String
    6 P  H8 r- u* e! A$ z
  250.         Dim sheet As Object = book.Sheets.Item(_table)
    " |0 f# C$ m( B
  251.         Return sheet.Range(_Range).value$ G' }, F6 n+ x) W
  252.     End Function
    - A' U/ V5 w9 ?1 b/ i: o/ [) `
  253.     Public Function Save() As Boolean
    + ~  f. E8 e( Y1 r+ t
  254.         book.Save()
    3 N( Z1 n% O3 ]" ^% M6 t
  255.     End Function
    5 `% ]7 c) [: R9 g# e: Q( d- ], o
  256.     Public Function SaveAs() As Boolean' B( R2 u: O& P# ]+ ^1 d
  257.         Dim Sdlg As SaveFileDialog = New SaveFileDialog '定义一个保存对话框* V* p* w& q6 `/ k" W5 n& C
  258.         Sdlg.FileName = AskDisplatyPartName() + "加工工序单.xls" '保存对话框的默认文件名# R) c% ?& G$ C4 G" _6 B: e
  259.         Sdlg.Filter = "EXCEL档案(*.xls)|*.xls" '过滤器设置* J. o: S9 ^( I
  260.         If Sdlg.ShowDialog = Windows.Forms.DialogResult.OK Then '如果保存对话框的确认按钮被按下
    + O  g: o$ ?; m2 k# I" L6 M
  261.             book.SaveAs(Sdlg.FileName) '保存文件
    * V1 D3 j/ V0 [* a2 o3 o
  262.         End If
    " J# x, g$ Y* k1 Y4 t
  263.     End Function  P+ e$ m; R+ ?% u% ?1 C
  264.     '结束EXCEL对象4 m/ j5 c/ I* ~1 Q" Q: w( T2 h
  265.     Public Function Quit() As Boolean
    # u( F8 ^' q* z- L- v: R
  266.         book.close()
    % |1 A9 V  t& Q9 V/ l7 j3 B
  267.         app.Quit()- \6 t; T% H, O1 g% f
  268.         app = Nothing# w! B' }. R$ `9 }* ^3 F
  269.         GC.Collect()  _' B+ w7 W- e8 j# [0 C
  270.     End Function
    % c: g7 m+ ?8 S# k) B
  271. 8 f* D, F/ N- V3 [7 ^0 X
  272.     '取数组
    # f/ i* f0 {/ ~  k% G* ^+ W
  273.     Public Function GetArryValue(ByRef _table As Integer, ByVal _Row As String, ByVal _Cell As String, ByRef ArryString() As String) As Integer/ N! {( C2 p0 C! [4 [; _. ]
  274.         Dim sheet As Object = book.Sheets.Item(_table)9 O2 o. |1 u( U% A$ D: ]& V' g' A  ~" W) N
  275.         Dim rowvalue As String = sheet.Range(_Row).value
    ! V- Y" d4 T. V
  276.         Dim cellvalue As String = sheet.Range(_Cell).value
    / o- x: T1 H" y5 Q  }5 d5 u
  277.         Dim k As Integer = 05 L' {# }' d! F/ W+ y9 r  H
  278.         If rowvalue <> "" And cellvalue <> "" Then) C7 ]9 R3 g- y/ L3 s/ l+ W
  279.             Dim rowstr() As String = Split(rowvalue, "/")- W  d- K) W5 c: k% m
  280.             Dim cellstring() As String = Split(cellvalue, "/")2 U2 d& q- s" Q* w) R
  281.             Dim a, b, c, d As Integer
    , M$ a: n; w  M+ N# K5 S
  282.             If rowstr.Length > 1 And cellstring.Length > 0 Then
    8 L# }  r' N: _- @* _' `; _9 O
  283.                 a = Convert.ToInt32(rowstr(0))
    1 |& [* T* Z& F5 Y+ v, T# R3 y
  284.                 b = Convert.ToInt32(rowstr(1))5 M' e; j/ P. T& [
  285.                 If a > 0 And b > a Then; n8 C5 p5 S2 K7 C! H9 p; N4 W
  286.                     ReDim Preserve ArryString(b - a)- b: I" d6 f5 Q, A) L8 {( A
  287.                     For i As Integer = 0 To b - a
    ' m0 w% B" F( o; z
  288.                         ArryString(i) = cellstring(0) & Convert.ToString(a + i)
    + I; V7 ^1 i: Q  d! q) ?/ c+ z7 j
  289.                         k += 1
    % r1 u6 U8 Q9 C; J' `4 R
  290.                     Next9 q. l) [5 d* e2 D' i+ D; ~
  291.                     If rowstr.Length > 3 And cellstring.Length > 1 Then6 j& P, ~& ~' ]/ r% Y$ {- F+ D
  292.                         c = Convert.ToInt32(rowstr(2))
    6 [  I6 n( u1 [4 V; g
  293.                         d = Convert.ToInt32(rowstr(3))/ K1 y; A" c6 S$ a! u4 K9 f3 Z' Y
  294.                         If c > 0 And d > c Then
    * @" }: l: `" K2 E/ L( q6 S! P
  295.                             ReDim Preserve ArryString(b - a + d - c + 1): G  O3 ^1 X" ^( e+ L  m
  296.                             For j As Integer = 0 To d - c' n8 V# F* b% }  ]5 D" c
  297.                                 ArryString(b - a + j + 1) = cellstring(1) & Convert.ToString(c + j)
    3 |) h* c9 N9 f" g
  298.                                 k += 1% f1 m2 r+ r$ ~* ~& F
  299.                             Next5 b; V6 O8 G0 t% S0 p
  300.                         End If
    7 e' A" X$ W) x% i' p. j
  301.                     End If
    ' P1 N4 p9 t! F3 @
  302.                 End If
    1 {( x# p! N: \4 I0 I
  303.             End If
    / I! `4 q; Q. O& ]
  304.         End If
      V( n" r# [! c( C2 g
  305.         Return k3 T! d! S( |% u% x
  306.     End Function
    7 [) W0 F# `! L' ^$ b0 B) U9 g4 _
  307. End Class
' e& ^7 l. B7 Z& M. T; \- O
7 U& Y0 ~6 l: _! a' c
$ }$ O/ [" s4 B3 z* |1 O3 K) g
