[新功能] NX9.0 CAM 加工 新功能 what‘s new ---转载官方
2013-11-7 08:02:19 4043 0
发表于 2013-11-7 08:02:19 | 显示全部楼层 |阅读模式
NX9.0 CAM 加工 新功能 what‘s new ---转载官方 NX 9 for Manufacturing1 z0 o( K1 d& K4 c; ]
Make Smarter Manufacturing Decisions
/ B) v- {5 q" N' w2 D% f9 e4 wNX 9 includes a wide range of new capabilities for manufacturing in tool design, in CMM Inspection Programming and in CAM.
. z( T7 _& O% q( t6 ?NX CAM 9
. m# i( {& |5 ^/ e) @: F4 `
登录/注册后可看大图
, F; j' z6 j* g* Q1 n
& N# J2 ^% h1 T$ GIncrease your manufacturing productivity with new industry specific capabilities in NX CAM 9. Enhanced control over cut regions for mold and die parts, faster programming of multiple-part setups and improved machining efficiency of complex parts can maximize your NC programming efficiency.
/ t0 E6 U2 K6 r( ~5 Z! G9 c
& M- K4 d! e0 y( M3 ]  J[/url] : ~6 S+ }  a$ t# e, F. U* k5 P6 b
- I2 p0 v6 \* s5 H2 h
NX CMM Inspection Programing
9 l1 y' X3 p  b2 K. |
$ S  K5 s: k! V. g, vInspect a wider range of part types, including sheet metal components, with the new functions in NX 9. Multi feature path creation can automate the process and reduce inspection programming time. The results analysis module now offers a new set of analysis options and a rich graphical environment to display measured features in NX.: k$ [4 M2 S8 a) t8 _
* R$ u* {! g+ h2 w[url=http://www.plm.automation.siemens.com/zh_cn/products/nx/9/for-manufacturing/nx-cmm.shtml] 2 C) d% Z5 G/ |5 S
  z+ ~5 g' Z$ M- ^6 [7 jMRL Connect for NX
/ d% m! S% p& g; V! F  G/ R
登录/注册后可看大图
4 @6 m, u9 d- r
) k  k! G. m" Q- D6 b9 Z
The Manufacturing Resource Library (MRL) provides an advanced tool library capability based on Teamcenter technology. With the new MRL Connect for NX you can easily connect NX CAM directly to a standalone installation of MRL while operating within the NX environment.7 \. P) K; `. i4 i6 c8 ^
2 k! Z0 u; P: h& n' f4 o& I[url=http://www.plm.automation.siemens.com/zh_cn/products/nx/9/for-manufacturing/mrl-connect.shtml][/url] 4 ?: H9 @6 g3 B$ s5 @+ J
- U/ ~8 K: h6 D( ?1 |1 {
Tooling Design
( i! N0 R& j0 D
登录/注册后可看大图
+ {* M( q& J2 P
) P1 J) c# Z  EAccelerate the preparation of tooling models for downstream machining with new modeling and analysis capabilities in NX 9. You can now more easily access libraries of standard mold and die base parts. Streamlined workflows for stamping and progressive die design in NX 9 eliminate manual processes to reduce design time.
+ ?6 a6 V& {, L
  m3 |' V  y, ^+ e  a/ p, k, y9 I8 g) a8 s4 p0 s
