To enable NX to work with Active Workspace when it is running as a web client, perform the following setup for Windows OS. Note | Ensure that Teamcenter FCC is running to enable NX to launch from the Active Workspace web client. |
Setup the registry to associate mime type with .nx TCxml file. Update the registry to associate the batch file startNXFromActiveWorkspace.bat, which starts NX when you double-click the .nxtcxml file. Create the batch file startNXFromActiveWorkspace.bat and place it in a directory to which you have write permissions. 1 e' A* C) u/ T4 H2 p
Setup the registry and associate the mime type
% H/ Z4 Z! A$ P/ S. XTo access the Windows registry and make changes, start regedit.exe. Right-click HKEY_CLASSES_ROOT and choose New→Key. Rename the new key .nxtcxml and then set the following: + s; r6 d* f* _6 Y* u
Right-click .nxtcxml, and choose New→String Value. Set the following:
, c, w$ n- D/ \3 x4 sRight-click HKEY_CLASSES_ROOT\MIME\Database\ContentType and choose New→Key. Rename the new key application/nxtcxml. Right-click the new key, choose New→String Value, and set the following: 7 }+ q" R/ ]. W$ ~) i: p
Value name=Extension Value data=.nxtcxml / Z/ s/ ?. J6 K1 V: F' I, b
/ d# N8 ?0 {( N! TUpdate the registry to set open action for the extension: E: k+ I- G, ^7 g# S9 z1 D% @2 Z1 t
Start regedit.exe if the Registry Editor is not already open. Right-click HKEY_CLASSES_ROOT\.nxtcxml and choose New→Key. Rename the new key Shell, and then right-click it and choose New→Key. Rename the new key Open, and then set the following:
6 _& e9 A2 p0 H9 S) }+ S# rValue data=&Open
# Q* S0 F+ P$ O) o) B+ l1 v
Right-click the Open key and choose New→Key. Rename the new key Command, and then set the following: 5 r# M: F4 O8 U6 V6 b- n
Close the Registry Editor.
7 V/ {+ v6 {; ~" o4 s
9 N8 V+ M( W6 U! \& t. RCreate the batch file and place it in the directory
2 |3 q& M0 _0 }0 JCopy the following script and save it as startNXFromActiveWorkspace.bat in the location specified by the Command key in step 6 above. @echo off@rem startNXfromActiveWorkspace@rem Copyright (c) 2014 Siemens Product Lifecycle Management Software Inc.@rem This script launches NX in managed mode when invoked from Active Workspace client.@rem In order to use this script FCC must be installed in the machine.@rem JAVA_HOME must be set in user environment or set here@rem set JAVA_HOME=C:\apps\Java\jre7x64@rem FMS_HOME must be set in user environment or set here@rem set FMS_HOME=Y:\tc91\root\tccs@if not exist "%FMS_HOME%" goto :no_fcc@if exist "%UGII_BASE_DIR%" goto :process_command@rem UGII_BASE_DIR must be set in user environment or set here@rem set UGII_BASE_DIR=D:\workdir\NX9mr_ip\nx902.1\wntx64\kits:process_command@setlocal@set PATH=%UGII_BASE_DIR%\UGII;%PATH%@set UGII_ROOT_DIR=%UGII_BASE_DIR%\UGII@"%UGII_ROOT_DIR%\ugs_router.exe" -ugm -use_file_dir %1 -version=V27.0 -passthrough -application_id=AW -user_action_flags=0x0 -opts -http_url_file="%1"@endlocal@goto :end:no_fcc@echo "The environment variable FMS_HOME is not set"@echo "FCC must be installed in the machine to run NX in managed mode. "@echo "Exiting..."@pause@goto :end:end2 j* }& Z0 S3 c% s' c1 s. U
1 C$ l L0 o$ n8 ?2 ?! W |
